path: root/fs/hfs/brec.c
2008-03-17hfs_bnode_find() can fail, resulting in hfs_bnode_split() breakageAl Viro
oops and fs corruption; the latter can happen even on valid fs in case of oom. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06address hfs on-disk corruption robustness review commentsEric Sandeen
Address Roman's review comments for the previously sent on-disk corruption hfs robustness patch. - use 0 as a failure value, rather than making a new macro HFS_BAD_KEYLEN, and use a switch statement instead of if's. - Add new fail: target to __hfs_brec_find to skip assignments using bad values when exiting with a failure. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08hfs: handle more on-disk corruptions without oopsingEric Sandeen
hfs seems prone to bad things when it encounters on disk corruption. Many values are read from disk, and used as lengths to memcpy, as an example. This patch fixes up several of these problematic cases. o sanity check the on-disk maximum key lengths on mount (these are set to a defined value at mkfs time and shouldn't differ) o check on-disk node keylens against the maximum key length for each tree o fix hfs_btree_open so that going out via free_tree: doesn't wind up in hfs_releasepage, which wants to follow the very pointer we were trying to set up: HFS_SB(sb)->cat_tree = hfs_btree_open() ... failure gets to hfs_releasepage and tries to follow HFS_SB(sb)->cat_tree Tested with the fsfuzzer; it survives more than it used to. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-18[PATCH] hfs: cleanup HFS printsRoman Zippel
Add the log level and a "hfs: " prefix to all kernel prints. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
