commit 434a964daa14b9db083ce20404a4a2add54d037a upstream.
Clement Lecigne reports a filesystem which causes a kernel oops in
hfs_find_init() trying to dereference sb->ext_tree which is NULL.
This proves to be because the filesystem has a corrupted MDB extent
record, where the extents file does not fit into the first three extents
in the file record (the first blocks).
In hfs_get_block() when looking up the blocks for the extent file
(HFS_EXT_CNID), it fails the first blocks special case, and falls
through to the extent code (which ultimately calls hfs_find_init())
which is in the process of being initialised.
Hfs avoids this scenario by always having the extents b-tree fitting
into the first blocks (the extents B-tree can't have overflow extents).
The fix is to check at mount time that the B-tree fits into first
blocks, i.e. fail if HFS_I(inode)->alloc_blocks >=
HFS_I(inode)->first_blocks
Note, the existing commit 47f365eb57573 ("hfs: fix oops on mount with
corrupted btree extent records") becomes subsumed into this as a special
case, but only for the extents B-tree (HFS_EXT_CNID), it is perfectly
acceptable for the catalog B-Tree file to grow beyond three extents,
with the remaining extent descriptors in the extents overfow.
This fixes CVE-2011-2203
Reported-by: Clement LECIGNE <clement.lecigne@netasq.com>
Signed-off-by: Phillip Lougher <plougher@redhat.com>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Moritz Mühlenhoff <jmm@inutil.org>
tree_lock is used as mutex so make it a mutex.
Acked-by: Christoph Hellwig <hch@lst.de>
LKML-Reference: <20100907125056.416332114@linutronix.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
A particular fsfuzzer run caused an hfs file system to crash on mount.
This is due to a corrupted MDB extent record causing a miscalculation of
HFS_I(inode)->first_blocks for the extent tree. If the extent records are
zereod out, it won't trigger the first_blocks special case. Instead it
falls through to the extent code which we're still in the middle of
initializing.
This patch catches the 0 size extent records, reports the corruption, and
fails the mount.
Reported-by: Ramon de Carvalho Valle <rcvalle@linux.vnet.ibm.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Apple Macintosh file system: The semaphore extens_lock is used as a mutex.
Convert it to the mutex API
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Cc: Roman Zippel <zippel@linux-m68k.org>
fs/hfs/btree.c: In function 'hfs_bmap_alloc':
fs/hfs/btree.c:263: warning: comparison is always false due to limited range of data type
The patch makes the warning go away, but the code might actually be buggy?
Address Roman's review comments for the previously sent on-disk
corruption hfs robustness patch.
- use 0 as a failure value, rather than making a new macro HFS_BAD_KEYLEN,
and use a switch statement instead of if's.
- Add new fail: target to __hfs_brec_find to skip assignments using bad
values when exiting with a failure.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Fix potential null deref introduced by commit
cf0594625083111ae522496dc1c256f7476939c2
http://bugzilla.kernel.org/show_bug.cgi?id=9748
Reported-by: Adrian Bunk <bunk@stusta.de>
hfs seems prone to bad things when it encounters on disk corruption. Many
values are read from disk, and used as lengths to memcpy, as an example.
This patch fixes up several of these problematic cases.
o sanity check the on-disk maximum key lengths on mount
(these are set to a defined value at mkfs time and shouldn't differ)
o check on-disk node keylens against the maximum key length for each tree
o fix hfs_btree_open so that going out via free_tree: doesn't wind
up in hfs_releasepage, which wants to follow the very pointer
we were trying to set up:
HFS_SB(sb)->cat_tree = hfs_btree_open()
failure gets to hfs_releasepage and tries
to follow HFS_SB(sb)->cat_tree
Tested with the fsfuzzer; it survives more than it used to.
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2
Signed-off-by: vignesh babu <vignesh.babu@wipro.com>
Conversions from kmalloc+memset to kzalloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org>
Add read_mapping_page() which is used for callers that pass
mapping->a_ops->readpage as the filler for read_cache_page. This removes
some duplication from filesystem code.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Add the log level and a "hfs: " prefix to all kernel prints.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
infrastructure for it.
Let it rip!
