path: root/fs/hfs/string.c
2013-06-29Don't pass inode to ->d_hash() and ->d_compare()Linus Torvalds
Instances either don't look at it at all (the majority of cases) or only want it to find the superblock (which can be had as dentry->d_sb). A few cases that want more are actually safe with dentry->d_inode - the only precaution needed is the check that it hadn't been replaced with NULL by rmdir() or by overwriting rename(), which case should be simply treated as cache miss. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
