path: root/fs/hfs
2011-05-28hfs: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
hfs does not have problems with references to unlinked directories. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-03hfs: fix rename() over non-empty directoryAl Viro
merge hfs_unlink() and hfs_rmdir(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12switch hfsAl Viro
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25switch hfs to hlist_add_fake()Al Viro
2010-10-25hfs: use sync_dirty_bufferChristoph Hellwig
Use sync_dirty_buffer instead of the incorrect opencoding it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-12hfs: Convert tree_lock to mutexThomas Gleixner
tree_lock is used as mutex so make it a mutex. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> LKML-Reference: <20100907125056.416332114@linutronix.de>
2010-10-04BKL: Remove BKL from HFSJan Blunck
The BKL is only used in put_super and fill_super that are both protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09get rid of file_fsync()Al Viro
Copy and simplify in the only two users remaining. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09sort out blockdev_direct_IO variantsChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in prepearation of the new truncate calling sequence. This was only done for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant was not needed anyway. Get rid of blockdev_direct_IO_no_locking and its _newtrunc variant while at it as just opencoding the two additional paramters is shorted than the name suffix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-15hfs: fix a potential buffer overflowAmerigo Wang
A specially-crafted Hierarchical File System (HFS) filesystem could cause a buffer overflow to occur in a process's kernel stack during a memcpy() call within the hfs_bnode_read() function (at fs/hfs/bnode.c:24). The attacker can provide the source buffer and length, and the destination buffer is a local variable of a fixed length. This local variable (passed as "&entry" from fs/hfs/dir.c:112 and allocated on line 60) is stored in the stack frame of hfs_bnode_read()'s caller, which is hfs_readdir(). Because the hfs_readdir() function executes upon any attempt to read a directory on the filesystem, it gets called whenever a user attempts to inspect any filesystem contents. [amwang@redhat.com: modify this patch and fix coding style problems] Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Eugene Teo <eteo@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Dave Anderson <anderson@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29hfs: fix oops on mount with corrupted btree extent recordsJeff Mahoney
A particular fsfuzzer run caused an hfs file system to crash on mount. This is due to a corrupted MDB extent record causing a miscalculation of HFS_I(inode)->first_blocks for the extent tree. If the extent records are zereod out, it won't trigger the first_blocks special case. Instead it falls through to the extent code which we're still in the middle of initializing. This patch catches the 0 size extent records, reports the corruption, and fails the mount. Reported-by: Ramon de Carvalho Valle <rcvalle@linux.vnet.ibm.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24fs: Make unload_nls() NULL pointer safeThomas Gleixner
Most call sites of unload_nls() do: if (nls) unload_nls(nls); Check the pointer inside unload_nls() like we do in kfree() and simplify the call sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steve French <sfrench@us.ibm.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11hfs: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11->write_super lock_super pushdownChristoph Hellwig
Push down lock_super into ->write_super instances and remove it from the caller. Following filesystem don't need ->s_lock in ->write_super and are skipped: * bfs, nilfs2 - no other uses of s_lock and have internal locks in ->write_super * ext2 - uses BKL in ext2_write_super and has internal calls without s_lock * reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in ->write_super * xfs - no other uses of s_lock and uses internal lock (buffer lock on superblock buffer) to serialize ->write_super. Also xfs_fs_write_super is superflous and will go away in the next merge window Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-13hfs: fix memory leak when unmountingDave Anderson
When an HFS filesystem is unmounted, it leaks a 2-page bitmap. Also, under extreme memory pressure, it's possible that hfs_releasepage() may use a tree pointer that has not been initialized, and if so, the release request should just be rejected. [akpm@linux-foundation.org: free_pages(0) is legal, remove obvious comment] Signed-off-by: Dave Anderson <anderson@redhat.com> Tested-by: Eugene Teo <eugeneteo@kernel.sg> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02fs/hfs: return f_fsid for statfs(2)Coly Li
Make hfs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-01-22fs/Kconfig: move hfs, hfsplus outAlexey Dobriyan
2008-11-14CRED: Wrap task credential accesses in the HFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] move executable checking into ->permission()Miklos Szeredi
For execute permission on a regular files we need to check if file has any execute bits at all, regardless of capabilites. This check is normally performed by generic_permission() but was also added to the case when the filesystem defines its own ->permission() method. In the latter case the filesystem should be responsible for performing this check. Move the check from inode_permission() inside filesystems which are not calling generic_permission(). Create a helper function execute_ok() that returns true if the inode is a directory or if any execute bits are present in i_mode. Also fix up the following code: - coda control file is never executable - sysctl files are never executable - hfs_permission seems broken on MAY_EXEC, remove - hfsplus_permission is eqivalent to generic_permission(), remove Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-10-16hfs: fix namelength memory corruptionEric Sesterhenn
Fix a stack corruption caused by a corrupted hfs filesystem. If the catalog name length is corrupted the memcpy overwrites the catalog btree structure. Since the field is limited to HFS_NAMELEN bytes in the structure and the file format, we throw an error if it is too long. Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] f_count may wrap aroundAl Viro
make it atomic_long_t; while we are at it, get rid of useless checks in affs, hfs and hpfs - ->open() always has it equal to 1, ->release() - to 0. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25hfs: convert extents_lock in a mutexMatthias Kaehlcke
Apple Macintosh file system: The semaphore extens_lock is used as a mutex. Convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25hfs: convert bitmap_lock in a mutexMatthias Kaehlcke
Apple Macintosh file system: The semaphore bitmap_lock is used as a mutex. Convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30hfs: fix warning with 64k PAGE_SIZEAndrew Morton
fs/hfs/btree.c: In function 'hfs_bmap_alloc': fs/hfs/btree.c:263: warning: comparison is always false due to limited range of data type The patch makes the warning go away, but the code might actually be buggy? Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30hfs/hfsplus: be*_add_cpu conversionMarcin Slusarz
replace all: big_endian_variable = cpu_to_beX(beX_to_cpu(big_endian_variable) + expression_in_cpu_byteorder); with: beX_add_cpu(&big_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29hfs: handle match_strdup failureJim Meyering
fs/hfs/super.c (parse_options): Handle match_strdup failure, twice. Signed-off-by: Jim Meyering <meyering@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
