path: root/fs/hfsplus/bnode.c
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-01BUG_ON() Conversion in fs/hfsplus/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-18[PATCH] hfs: cleanup HFS+ printsRoman Zippel
Add the log level and a "hfs: " prefix to all kernel prints. (HFS and HFS+ will use the same prefix, as they share some code and could be merged at some point.) Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] hfs: remove debug codeRoman Zippel
This removes some old debug code, which is no longer needed. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-01[PATCH] hfs: don't reference missing pageRoman Zippel
If there was a read error, the bnode might miss some pages, so skip them. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
