path: root/fs/hfsplus/unicode.c
2008-02-08fs/hfsplus/unicode.c: fix uninitialized var warningAndrew Morton
fs/hfsplus/unicode.c: In function 'hfsplus_hash_dentry': fs/hfsplus/unicode.c:328: warning: 'dsize' may be used uninitialized in this function Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFS+: add custom dentry hash and comparison operationsDuane Griffin
Add custom dentry hash and comparison operations for HFS+ filesystems that are case-insensitive and/or do automatic unicode decomposition. The new operations reuse the existing HFS+ ASCII to unicode conversion, unicode decomposition and case folding functionality. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFS+: refactor ASCII to unicode conversion routine for later reuseDuane Griffin
The HFS+ filesystem is case-insensitive and does automatic unicode decomposition by default, but does not provide custom dentry operations. This can lead to multiple dentries being cached for lookups on a filename with varying case and/or character (de)composition. These patches add custom dentry hash and comparison operations for case-sensitive and/or automatically decomposing HFS+ filesystems. Unicode decomposition and case-folding are performed as required to ensure equivalent filenames are hashed to the same values and compare as equal. This patch: Refactor existing HFS+ ASCII to unicode string conversion routine to split out character conversion functionality. This will be reused by the custom dentry hash and comparison routines. This approach avoids unnecessary memory allocation compared to using the string conversion routine directly in the new functions. [akpm@linux-foundation.org: avoid use-of-uninitialised] Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-18[PATCH] hfs: add HFSX supportDavid Elliott
Add support for HFSX, which allows for case-sensitive filenames. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
