path: root/fs/hfsplus
2009-11-09hfsplus: refuse to mount volumes larger than 2TBBen Hutchings
commit 5c36fe3d87b3f0c85894a49193c66096a3d6b26f upstream. As found in <http://bugs.debian.org/550010>, hfsplus is using type u32 rather than sector_t for some sector number calculations. In particular, hfsplus_get_block() does: u32 ablock, dblock, mask; ... map_bh(bh_result, sb, (dblock << HFSPLUS_SB(sb).fs_shift) + HFSPLUS_SB(sb).blockoffset + (iblock & mask)); I am not confident that I can find and fix all cases where a sector number may be truncated. For now, avoid data loss by refusing to mount HFS+ volumes with more than 2^32 sectors (2TB). [akpm@linux-foundation.org: fix 32 and 64-bit issues] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Eric Sesterhenn <snakebyte@gmx.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-06hfsplus: check read_mapping_page() return valueEric Sesterhenn
While testing more corrupted images with hfsplus, i came across one which triggered the following bug: [15840.675016] BUG: unable to handle kernel paging request at fffffffb [15840.675016] IP: [<c0116a4f>] kmap+0x15/0x56 [15840.675016] *pde = 00008067 *pte = 00000000 [15840.675016] Oops: 0000 [#1] PREEMPT DEBUG_PAGEALLOC [15840.675016] Modules linked in: [15840.675016] [15840.675016] Pid: 11575, comm: ln Not tainted (2.6.27-rc4-00123-gd3ee1b4-dirty #29) [15840.675016] EIP: 0060:[<c0116a4f>] EFLAGS: 00010202 CPU: 0 [15840.675016] EIP is at kmap+0x15/0x56 [15840.675016] EAX: 00000246 EBX: fffffffb ECX: 00000000 EDX: cab919c0 [15840.675016] ESI: 000007dd EDI: cab0bcf4 EBP: cab0bc98 ESP: cab0bc94 [15840.675016] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 [15840.675016] Process ln (pid: 11575, ti=cab0b000 task=cab919c0 task.ti=cab0b000) [15840.675016] Stack: 00000000 cab0bcdc c0231cfb 00000000 cab0bce0 00000800 ca9290c0 fffffffb [15840.675016] cab145d0 cab919c0 cab15998 22222222 22222222 22222222 00000001 cab15960 [15840.675016] 000007dd cab0bcf4 cab0bd04 c022cb3a cab0bcf4 cab15a6c ca9290c0 00000000 [15840.675016] Call Trace: [15840.675016] [<c0231cfb>] ? hfsplus_block_allocate+0x6f/0x2d3 [15840.675016] [<c022cb3a>] ? hfsplus_file_extend+0xc4/0x1db [15840.675016] [<c022ce41>] ? hfsplus_get_block+0x8c/0x19d [15840.675016] [<c06adde4>] ? sub_preempt_count+0x9d/0xab [15840.675016] [<c019ece6>] ? __block_prepare_write+0x147/0x311 [15840.675016] [<c0161934>] ? __grab_cache_page+0x52/0x73 [15840.675016] [<c019ef4f>] ? block_write_begin+0x79/0xd5 [15840.675016] [<c022cdb5>] ? hfsplus_get_block+0x0/0x19d [15840.675016] [<c019f22a>] ? cont_write_begin+0x27f/0x2af [15840.675016] [<c022cdb5>] ? hfsplus_get_block+0x0/0x19d [15840.675016] [<c0139ebe>] ? tick_program_event+0x28/0x4c [15840.675016] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [15840.675016] [<c022b723>] ? hfsplus_write_begin+0x2d/0x32 [15840.675016] [<c022cdb5>] ? hfsplus_get_block+0x0/0x19d [15840.675016] [<c0161988>] ? pagecache_write_begin+0x33/0x107 [15840.675016] [<c01879e5>] ? __page_symlink+0x3c/0xae [15840.675016] [<c019ad34>] ? __mark_inode_dirty+0x12f/0x137 [15840.675016] [<c0187a70>] ? page_symlink+0x19/0x1e [15840.675016] [<c022e6eb>] ? hfsplus_symlink+0x41/0xa6 [15840.675016] [<c01886a9>] ? vfs_symlink+0x99/0x101 [15840.675016] [<c018a2f6>] ? sys_symlinkat+0x6b/0xad [15840.675016] [<c018a348>] ? sys_symlink+0x10/0x12 [15840.675016] [<c01038bd>] ? sysenter_do_call+0x12/0x31 [15840.675016] ======================= [15840.675016] Code: 00 00 75 10 83 3d 88 2f ec c0 02 75 07 89 d0 e8 12 56 05 00 5d c3 55 ba 06 00 00 00 89 e5 53 89 c3 b8 3d eb 7e c0 e8 16 74 00 00 <8b> 03 c1 e8 1e 69 c0 d8 02 00 00 05 b8 69 8e c0 2b 80 c4 02 00 [15840.675016] EIP: [<c0116a4f>] kmap+0x15/0x56 SS:ESP 0068:cab0bc94 [15840.675016] ---[ end trace 4fea40dad6b70e5f ]--- This happens because the return value of read_mapping_page() is passed on to kmap unchecked. The bug is triggered after the first read_mapping_page() in hfsplus_block_allocate(), this patch fixes all three usages in this functions but leaves the ones further down in the file unchanged. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-06hfsplus: fix Buffer overflow with a corrupted imageEric Sesterhenn
commit efc7ffcb4237f8cb9938909041c4ed38f6e1bf40 upstream When an hfsplus image gets corrupted it might happen that the catalog namelength field gets b0rked. If we mount such an image the memcpy() in hfsplus_cat_build_key_uni() writes more than the 255 that fit in the name field. Depending on the size of the overwritten data, we either only get memory corruption or also trigger an oops like this: [ 221.628020] BUG: unable to handle kernel paging request at c82b0000 [ 221.629066] IP: [<c022d4b1>] hfsplus_find_cat+0x10d/0x151 [ 221.629066] *pde = 0ea29163 *pte = 082b0160 [ 221.629066] Oops: 0002 [#1] PREEMPT DEBUG_PAGEALLOC [ 221.629066] Modules linked in: [ 221.629066] [ 221.629066] Pid: 4845, comm: mount Not tainted (2.6.27-rc4-00123-gd3ee1b4-dirty #28) [ 221.629066] EIP: 0060:[<c022d4b1>] EFLAGS: 00010206 CPU: 0 [ 221.629066] EIP is at hfsplus_find_cat+0x10d/0x151 [ 221.629066] EAX: 00000029 EBX: 00016210 ECX: 000042c2 EDX: 00000002 [ 221.629066] ESI: c82d70ca EDI: c82b0000 EBP: c82d1bcc ESP: c82d199c [ 221.629066] DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068 [ 221.629066] Process mount (pid: 4845, ti=c82d1000 task=c8224060 task.ti=c82d1000) [ 221.629066] Stack: c080b3c4 c82aa8f8 c82d19c2 00016210 c080b3be c82d1bd4 c82aa8f0 00000300 [ 221.629066] 01000000 750008b1 74006e00 74006900 65006c00 c82d6400 c013bd35 c8224060 [ 221.629066] 00000036 00000046 c82d19f0 00000082 c8224548 c8224060 00000036 c0d653cc [ 221.629066] Call Trace: [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c013bca3>] ? trace_hardirqs_off_caller+0x14/0x9b [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c013bca3>] ? trace_hardirqs_off_caller+0x14/0x9b [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c0107aa3>] ? native_sched_clock+0x82/0x96 [ 221.629066] [<c01302d2>] ? __kernel_text_address+0x1b/0x27 [ 221.629066] [<c010487a>] ? dump_trace+0xca/0xd6 [ 221.629066] [<c0109e32>] ? save_stack_address+0x0/0x2c [ 221.629066] [<c0109eaf>] ? save_stack_trace+0x1c/0x3a [ 221.629066] [<c013b571>] ? save_trace+0x37/0x8d [ 221.629066] [<c013b62e>] ? add_lock_to_list+0x67/0x8d [ 221.629066] [<c013ea1c>] ? validate_chain+0x8a4/0x9f4 [ 221.629066] [<c013553d>] ? down+0xc/0x2f [ 221.629066] [<c013f1f6>] ? __lock_acquire+0x68a/0x6e0 [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c013bca3>] ? trace_hardirqs_off_caller+0x14/0x9b [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c0107aa3>] ? native_sched_clock+0x82/0x96 [ 221.629066] [<c013da5d>] ? mark_held_locks+0x43/0x5a [ 221.629066] [<c013dc3a>] ? trace_hardirqs_on+0xb/0xd [ 221.629066] [<c013dbf4>] ? trace_hardirqs_on_caller+0xf4/0x12f [ 221.629066] [<c06abec8>] ? _spin_unlock_irqrestore+0x42/0x58 [ 221.629066] [<c013555c>] ? down+0x2b/0x2f [ 221.629066] [<c022aa68>] ? hfsplus_iget+0xa0/0x154 [ 221.629066] [<c022b0b9>] ? hfsplus_fill_super+0x280/0x447 [ 221.629066] [<c0107aa3>] ? native_sched_clock+0x82/0x96 [ 221.629066] [<c013bca3>] ? trace_hardirqs_off_caller+0x14/0x9b [ 221.629066] [<c013bca3>] ? trace_hardirqs_off_caller+0x14/0x9b [ 221.629066] [<c013f1f6>] ? __lock_acquire+0x68a/0x6e0 [ 221.629066] [<c041c9e4>] ? string+0x2b/0x74 [ 221.629066] [<c041cd16>] ? vsnprintf+0x2e9/0x512 [ 221.629066] [<c010487a>] ? dump_trace+0xca/0xd6 [ 221.629066] [<c0109eaf>] ? save_stack_trace+0x1c/0x3a [ 221.629066] [<c0109eaf>] ? save_stack_trace+0x1c/0x3a [ 221.629066] [<c013b571>] ? save_trace+0x37/0x8d [ 221.629066] [<c013b62e>] ? add_lock_to_list+0x67/0x8d [ 221.629066] [<c013ea1c>] ? validate_chain+0x8a4/0x9f4 [ 221.629066] [<c01354d3>] ? up+0xc/0x2f [ 221.629066] [<c013f1f6>] ? __lock_acquire+0x68a/0x6e0 [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c013bca3>] ? trace_hardirqs_off_caller+0x14/0x9b [ 221.629066] [<c013bd35>] ? trace_hardirqs_off+0xb/0xd [ 221.629066] [<c0107aa3>] ? native_sched_clock+0x82/0x96 [ 221.629066] [<c041cfb7>] ? snprintf+0x1b/0x1d [ 221.629066] [<c01ba466>] ? disk_name+0x25/0x67 [ 221.629066] [<c0183960>] ? get_sb_bdev+0xcd/0x10b [ 221.629066] [<c016ad92>] ? kstrdup+0x2a/0x4c [ 221.629066] [<c022a7b3>] ? hfsplus_get_sb+0x13/0x15 [ 221.629066] [<c022ae39>] ? hfsplus_fill_super+0x0/0x447 [ 221.629066] [<c0183583>] ? vfs_kern_mount+0x3b/0x76 [ 221.629066] [<c0183602>] ? do_kern_mount+0x32/0xba [ 221.629066] [<c01960d4>] ? do_new_mount+0x46/0x74 [ 221.629066] [<c0196277>] ? do_mount+0x175/0x193 [ 221.629066] [<c013dbf4>] ? trace_hardirqs_on_caller+0xf4/0x12f [ 221.629066] [<c01663b2>] ? __get_free_pages+0x1e/0x24 [ 221.629066] [<c06ac07b>] ? lock_kernel+0x19/0x8c [ 221.629066] [<c01962e6>] ? sys_mount+0x51/0x9b [ 221.629066] [<c01962f9>] ? sys_mount+0x64/0x9b [ 221.629066] [<c01038bd>] ? sysenter_do_call+0x12/0x31 [ 221.629066] ======================= [ 221.629066] Code: 89 c2 c1 e2 08 c1 e8 08 09 c2 8b 85 e8 fd ff ff 66 89 50 06 89 c7 53 83 c7 08 56 57 68 c4 b3 80 c0 e8 8c 5c ef ff 89 d9 c1 e9 02 <f3> a5 89 d9 83 e1 03 74 02 f3 a4 83 c3 06 8b 95 e8 fd ff ff 0f [ 221.629066] EIP: [<c022d4b1>] hfsplus_find_cat+0x10d/0x151 SS:ESP 0068:c82d199c [ 221.629066] ---[ end trace e417a1d67f0d0066 ]--- Since hfsplus_cat_build_key_uni() returns void and only has one callsite, the check is performed at the callsite. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26[PATCH] f_count may wrap aroundAl Viro
make it atomic_long_t; while we are at it, get rid of useless checks in affs, hfs and hpfs - ->open() always has it equal to 1, ->release() - to 0. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25hfsplus: convert the extents_lock in a mutexMatthias Kaehlcke
Apple Extended HFS file system: The semaphore extents lock is used as a mutex. Convert it to the mutex API. Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13Fix hfsplus oops on image without extentsEric Sesterhenn
Fix an oops with a corrupted hfs+ image. See http://bugzilla.kernel.org/show_bug.cgi?id=10548 for details. Problem is that we call hfs_btree_open() from hfsplus_fill_super() to set HFSPLUS_SB(sb).[ext_tree|cat_tree] Both trees are still NULL at this moment. If hfs_btree_open() fails for any reason it calls iput() on the page, which gets to hfsplus_releasepage() which tries to access HFSPLUS_SB(sb).* which is still NULL and oopses while dereferencing it. [akpm@linux-foundation.org: build fix] Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30hfsplus: fix warning with 64k PAGE_SIZEAndrew Morton
fs/hfsplus/btree.c: In function 'hfsplus_bmap_alloc': fs/hfsplus/btree.c:239: warning: comparison is always false due to limited range of data type But this might hide a real bug? Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30hfs/hfsplus: be*_add_cpu conversionMarcin Slusarz
replace all: big_endian_variable = cpu_to_beX(beX_to_cpu(big_endian_variable) + expression_in_cpu_byteorder); with: beX_add_cpu(&big_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29trivial: fix user-visible typo in hfsplusDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29hfsplus: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29hfsplus: handle match_strdup failureJim Meyering
fs/hfsplus/options.c (hfsplus_parse_options): Handle match_strdup failure. Signed-off-by: Jim Meyering <meyering@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/hfsplus/: proper externsAdrian Bunk
Add proper extern declarations for two structs in fs/hfsplus/hfsplus_fs.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[PATCH] r/o bind mounts: elevate write count for ioctls()Dave Hansen
Some ioctl()s can cause writes to the filesystem. Take these, and make them use mnt_want/drop_write() instead. [AV: updated] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-10HFS+: fix unlink of linksRoman Zippel
Some time ago while attempting to handle invalid link counts, I botched the unlink of links itself, so this patch fixes this now correctly, so that only the link count of nodes that don't point to links is ignored. Thanks to Vlado Plaga <rechner@vlado-do.de> to notify me of this problem. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08fs/hfsplus/unicode.c: fix uninitialized var warningAndrew Morton
fs/hfsplus/unicode.c: In function 'hfsplus_hash_dentry': fs/hfsplus/unicode.c:328: warning: 'dsize' may be used uninitialized in this function Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop HFSPLUS from using iget() and read_inode()David Howells
Stop the HFSPLUS filesystem from using iget() and read_inode(). Replace hfsplus_read_inode() with hfsplus_iget(), and call that instead of iget(). hfsplus_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. hfsplus_fill_super() returns any error incurred when getting the root inode. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16hfsplus: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFS+: add custom dentry hash and comparison operationsDuane Griffin
Add custom dentry hash and comparison operations for HFS+ filesystems that are case-insensitive and/or do automatic unicode decomposition. The new operations reuse the existing HFS+ ASCII to unicode conversion, unicode decomposition and case folding functionality. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFS+: refactor ASCII to unicode conversion routine for later reuseDuane Griffin
The HFS+ filesystem is case-insensitive and does automatic unicode decomposition by default, but does not provide custom dentry operations. This can lead to multiple dentries being cached for lookups on a filename with varying case and/or character (de)composition. These patches add custom dentry hash and comparison operations for case-sensitive and/or automatically decomposing HFS+ filesystems. Unicode decomposition and case-folding are performed as required to ensure equivalent filenames are hashed to the same values and compare as equal. This patch: Refactor existing HFS+ ASCII to unicode string conversion routine to split out character conversion functionality. This will be reused by the custom dentry hash and comparison routines. This approach avoids unnecessary memory allocation compared to using the string conversion routine directly in the new functions. [akpm@linux-foundation.org: avoid use-of-uninitialised] Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16HFSPlus: change kmalloc/memset to kzallocWyatt Banks
Removed kmalloc and memset in favor of kzalloc. To explain the HFSPLUS_SB() macro in the removed memset call: hfsplus_fs.h:#define HFSPLUS_SB(super) (*(struct hfsplus_sb_info *)(super)->s_fs_info) Signed-off-by: Wyatt Banks <wyatt@banksresearch.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08is_power_of_2 in fs/hfsVignesh Babu BM
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2 Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-02-11[PATCH] extend the set of "__attribute__" shortcut macrosRobert P. J. Day
Extend the set of "__attribute__" shortcut macros, and remove identical (and now superfluous) definitions from a couple of source files. based on a page at robert love's blog: http://rlove.org/log/2005102601 extend the set of shortcut macros defined in compiler-gcc.h with the following: #define __packed __attribute__((packed)) #define __weak __attribute__((weak)) #define __naked __attribute__((naked)) #define __noreturn __attribute__((noreturn)) #define __pure __attribute__((pure)) #define __aligned(x) __attribute__((aligned(x))) #define __printf(a,b) __attribute__((format(printf,a,b))) Once these are in place, it's up to subsystem maintainers to decide if they want to take advantage of them. there is already a strong precedent for using shortcuts like this in the source tree. The ones that might give people pause are "__aligned" and "__printf", but shortcuts for both of those are already in use, and in some ways very confusingly. note the two very different definitions for a macro named "ALIGNED": drivers/net/sgiseeq.c:#define ALIGNED(x) ((((unsigned long)(x)) + 0xf) & ~(0xf)) drivers/scsi/ultrastor.c:#define ALIGNED(x) __attribute__((aligned(x))) also: include/acpi/platform/acgcc.h: #define ACPI_PRINTF_LIKE(c) __attribute__ ((__format__ (__printf__, c, c+1))) Given the precedent, then, it seems logical to at least standardize on a consistent set of these macros. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert hfsplusJosef Sipek
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
