path: root/fs/hostfs
2011-01-12switch hostfsAl Viro
->d_delete() doesn't matter for s_root anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07hostfs: simplify lockingNick Piggin
Remove dcache_lock locking from hostfs filesystem, and move it into dcache helpers. All that is required is a coherent path name. Protection from concurrent modification of the namespace after path name generation is not provided in current code, because dcache_lock is dropped before the path is used. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-26hostfs: code cleanupsRichard Weinberger
Some code cleanups for hostfs. Signed-off-by: Richard Weinberger <richard@nod.at> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hostfs: fix UML crash: remove f_spare from hostfsRichard Weinberger
365b1818 ("add f_flags to struct statfs(64)") resized f_spare within struct statfs which caused a UML crash. There is no need to copy f_spare. Signed-off-by: Richard Weinberger <richard@nod.at> Reported-by: Toralf Förster <toralf.foerster@gmx.de> Tested-by: Toralf Förster <toralf.foerster@gmx.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Jeff Dike <jdike@addtoit.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-18hostfs ->follow_link() brainoAl Viro
we want the assignment to err done inside the if () to be visible after it, so (re)declaring err inside if () body is wrong. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-18hostfs: dumb (and usually harmless) tpyo - strncpy instead of strlcpyAl Viro
... not harmless in this case - we have a string in the end of buffer already. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09try to get rid of races in hostfs open()Al Viro
In case of mode mismatch, do *not* blindly close the descriptor another openers might be using right now. Open the underlying file with currently sufficient mode, then * if current mode has grown so that it's sufficient for us now, just close our new fd * if current mode has grown and our fd is *not* enough to cover it, close and repeat. * otherwise, install our fd if the file hadn't been opened at all or dup2() our fd over the current one (and close our fd). Critical section is protected by mutex; yes, system-wide. All we do under it is a bunch of comparison and maybe an overwriting dup2() on host. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09leak in hostfs_unlink()Al Viro
2010-08-09hostfs: fix races in dentry_name() and inode_name()Al Viro
calculating size, then doing allocation, then filling the path is a Bad Idea(tm), since the ancestors can be renamed, leading to buffer overrun. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09hostfs: sanitize symlinksAl Viro
2010-08-09hostfs: get rid of inode_dentry_name()Al Viro
it's equivalent to dentry_name() anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09hostfs: get rid of file_type(), fold init_inode()Al Viro
2010-08-09switch stat_file() to passing a single struct rather than fsckloads of pointersAl Viro
2010-08-09hostfs: pass pathname to init_inode()Al Viro
We will calculate it in all callers anyway, so there's no need to duplicate that inside. Moreover, that way we lose all failure exits in init_inode(), so it doesn't need to return anything. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of hostfs_read_inode()Al Viro
There are only two call sites; in one (hostfs_iget()) it's actually a no-op and in another (fill_super()) it's easier to expand the damn thing and use what we know about its arguments to simplify it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09hostfs: don't keep a field in each inode when we are using it only in rootAl Viro
2010-08-09stop icache pollution in hostfs, switch to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09Deal with missing exports for hostfsAl Viro
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-30hostfs: set maximum filesize in superblock for proper LFS supportWolfgang Illmeyer
Maximum file size for hostfs mounts defaults to 2GB, so bigger files cannot be read/written through hostfs. This patch initializes the maximum file size to MAX_LFS_SIZE. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13531 Signed-off-by: Wolfgang Illmeyer <wolfgang@illmeyer.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-01-04fs: symlink write_begin allocation context fixNick Piggin
With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19hostfs: fix a duplicated global function nameWANG Cong
fs/hostfs/hostfs_user.c defines do_readlink() as non-static, and so does fs/xfs/linux-2.6/xfs_ioctl.c when CONFIG_XFS_DEBUG=y. So rename do_readlink() in hostfs to hostfs_do_readlink(). I think it's better if XFS guys will also rename their do_readlink(), it's not necessary to use such a general name. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-09UML: fix hostfs buildJiri Kosina
/home/bunk/linux/kernel-2.6/git/linux-2.6/fs/hostfs/hostfs_kern.c: In function 'hostfs_show_options': /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/hostfs/hostfs_kern.c:328: error: dereferencing pointer to incomplete type We need to include mount.h to get vfsmount. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Reported-by: Adrian Bunk <bunk@stusta.de> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix hostfsMiklos Szeredi
Add the "host path" option to /proc/mounts for UML hostfs filesystems. The mount source (mnt_devname) should really be used for this, but not easy to change now in a backward compatible way. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop HOSTFS from using iget() and read_inode()David Howells
Stop the HOSTFS filesystem from using iget() and read_inode(). Provide hostfs_iget(), and call that instead of iget(). hostfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. hostfs_fill_sb_common() returns any error incurred when getting the root inode instead of EINVAL. Note that the contents of hostfs_kern.c need to be examined: (*) hostfs_iget() should perhaps subsume init_inode() and hostfs_read_inode(). (*) It would appear that all hostfs inodes are the same inode because iget() was being called with inode number 0 - which forms the lookup key. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: fix hostfs tv_usec calculationsDominique Quatravaux
To convert from tv_nsec to tv_usec, one needs to divide by 1000, not multiply. Signed-off-by: Dominique Quatravaux <dominique@quatravaux.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix hostfs styleJeff Dike
Style fixes in hostfs. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove unneeded if from hostfsJeff Dike
Get rid of an empty if statement which might look like a bug to a casual reader. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16UML: remove unnecessary hostfs_getattr()Miklos Szeredi
Currently hostfs_getattr() just defines the default behavior. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16hostfs: convert to new aopsNick Piggin
This also gets rid of a lot of useless read_file stuff. And also optimises the full page write case by marking a !uptodate page uptodate. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-08uml: hostfs style fixesJeff Dike
hostfs needed some style goodness. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08uml: make hostfs_setattr() support operations on unlinked open filesAlberto Bertogli
This patch allows hostfs_setattr() to work on unlinked open files by calling set_attr() (the userspace part) with the inode's fd. Without this, applications that depend on doing attribute changes to unlinked open files will fail. It works by using the fd versions instead of the path ones (for example fchmod() instead of chmod(), fchown() instead of chown()) when an fd is available. Signed-off-by: Alberto Bertogli <albertito@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-29[PATCH] uml: hostfs variable renamingPaolo 'Blaisorblade' Giarrusso
* rename name to host_root_path * rename data to req_root. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-29[PATCH] uml: fix compilation problemsJeff Dike
Fix a few miscellaneous compilation problems - an assignment with mismatched types in ldt.c a missing include in mconsole.h which needs a definition of uml_pt_regs I missed removing an include of user_util.h in hostfs Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] uml: hostfs: make hostfs= option work as a jail, as intended.Paolo 'Blaisorblade' Giarrusso
When a given host directory is specified to be mounted both in hostfs=path1 and with mount option -o path2, we should give access to path1/path2, but this does not happen. Fix that in the simpler way. Also, root_ino can be the empty string, since we use %s/%s as format. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] uml: hostfs: fix double freePaolo 'Blaisorblade' Giarrusso
Fix double free in the error path - when name is assigned into root_inode we do not own it any more and we must not kfree() it - see patch for details. Thanks to William Stearns for the initial report. CC: William Stearns <wstearns@pobox.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
