path: root/fs/hostfs
2009-01-18fs: symlink write_begin allocation context fixNick Piggin
commit 54566b2c1594c2326a645a3551f9d989f7ba3c5e upstream. With the write_begin/write_end aops, page_symlink was broken because it could no longer pass a GFP_NOFS type mask into the point where the allocations happened. They are done in write_begin, which would always assume that the filesystem can be entered from reclaim. This bug could cause filesystem deadlocks. The funny thing with having a gfp_t mask there is that it doesn't really allow the caller to arbitrarily tinker with the context in which it can be called. It couldn't ever be GFP_ATOMIC, for example, because it needs to take the page lock. The only thing any callers care about is __GFP_FS anyway, so turn that into a single flag. Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on this flag in their write_begin function. Change __grab_cache_page to accept a nofs argument as well, to honour that flag (while we're there, change the name to grab_cache_page_write_begin which is more instructive and does away with random leading underscores). This is really a more flexible way to go in the end anyway -- if a filesystem happens to want any extra allocations aside from the pagecache ones in ints write_begin function, it may now use GFP_KERNEL (rather than GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a random example). [kosaki.motohiro@jp.fujitsu.com: fix ubifs] [kosaki.motohiro@jp.fujitsu.com: fix fuse] Signed-off-by: Nick Piggin <npiggin@suse.de> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Cleaned up the calling convention: just pass in the AOP flags untouched to the grab_cache_page_write_begin() function. That just simplifies everybody, and may even allow future expansion of the logic. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-09UML: fix hostfs buildJiri Kosina
/home/bunk/linux/kernel-2.6/git/linux-2.6/fs/hostfs/hostfs_kern.c: In function 'hostfs_show_options': /home/bunk/linux/kernel-2.6/git/linux-2.6/fs/hostfs/hostfs_kern.c:328: error: dereferencing pointer to incomplete type We need to include mount.h to get vfsmount. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Reported-by: Adrian Bunk <bunk@stusta.de> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix hostfsMiklos Szeredi
Add the "host path" option to /proc/mounts for UML hostfs filesystems. The mount source (mnt_devname) should really be used for this, but not easy to change now in a backward compatible way. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop HOSTFS from using iget() and read_inode()David Howells
Stop the HOSTFS filesystem from using iget() and read_inode(). Provide hostfs_iget(), and call that instead of iget(). hostfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. hostfs_fill_sb_common() returns any error incurred when getting the root inode instead of EINVAL. Note that the contents of hostfs_kern.c need to be examined: (*) hostfs_iget() should perhaps subsume init_inode() and hostfs_read_inode(). (*) It would appear that all hostfs inodes are the same inode because iget() was being called with inode number 0 - which forms the lookup key. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: fix hostfs tv_usec calculationsDominique Quatravaux
To convert from tv_nsec to tv_usec, one needs to divide by 1000, not multiply. Signed-off-by: Dominique Quatravaux <dominique@quatravaux.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: fix hostfs styleJeff Dike
Style fixes in hostfs. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16uml: remove unneeded if from hostfsJeff Dike
Get rid of an empty if statement which might look like a bug to a casual reader. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16UML: remove unnecessary hostfs_getattr()Miklos Szeredi
Currently hostfs_getattr() just defines the default behavior. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16hostfs: convert to new aopsNick Piggin
This also gets rid of a lot of useless read_file stuff. And also optimises the full page write case by marking a !uptodate page uptodate. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-08uml: hostfs style fixesJeff Dike
hostfs needed some style goodness. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08uml: make hostfs_setattr() support operations on unlinked open filesAlberto Bertogli
This patch allows hostfs_setattr() to work on unlinked open files by calling set_attr() (the userspace part) with the inode's fd. Without this, applications that depend on doing attribute changes to unlinked open files will fail. It works by using the fd versions instead of the path ones (for example fchmod() instead of chmod(), fchown() instead of chown()) when an fd is available. Signed-off-by: Alberto Bertogli <albertito@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-29[PATCH] uml: hostfs variable renamingPaolo 'Blaisorblade' Giarrusso
* rename name to host_root_path * rename data to req_root. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-29[PATCH] uml: fix compilation problemsJeff Dike
Fix a few miscellaneous compilation problems - an assignment with mismatched types in ldt.c a missing include in mconsole.h which needs a definition of uml_pt_regs I missed removing an include of user_util.h in hostfs Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] uml: hostfs: make hostfs= option work as a jail, as intended.Paolo 'Blaisorblade' Giarrusso
When a given host directory is specified to be mounted both in hostfs=path1 and with mount option -o path2, we should give access to path1/path2, but this does not happen. Fix that in the simpler way. Also, root_ino can be the empty string, since we use %s/%s as format. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-08[PATCH] uml: hostfs: fix double freePaolo 'Blaisorblade' Giarrusso
Fix double free in the error path - when name is assigned into root_inode we do not own it any more and we must not kfree() it - see patch for details. Thanks to William Stearns for the initial report. CC: William Stearns <wstearns@pobox.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2007-01-30[PATCH] uml: fix mknodJohannes Stezenbach
Fix UML hostfs mknod(): userspace has differernt dev_t size and encoding than kernel, so extract major/minor and reencode using glibc makedev() macro. Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Acked-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert hostfsJosef Sipek
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix hostfs stack corruptionJeff Dike
Noted by Oleg Drokin: We initialized an extra slot of struct kstatfs.spare, sometimes causing stack corruption. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Oleg Drokin <green@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-29[PATCH] uml: hostfs - fix possible PAGE_CACHE_SHIFT overflowsPaolo 'Blaisorblade' Giarrusso
Prevent page->index << PAGE_CACHE_SHIFT from overflowing. There is a casting there, but was added without care, so it's at the wrong place. Note the extra parens around the shift - "+" is higher precedence than "<<", leading to a GCC warning which saved all us. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-29[PATCH] Hostfs: remove unused varPaolo 'Blaisorblade' Giarrusso
Trivial removal of unused variable from this file - doesn't even change the generated assembly code, in fact (gcc should trigger a warning for unused value here). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-30[PATCH] uml: remove empty hostfs_truncate methodPaolo 'Blaisorblade' Giarrusso
Calling truncate() on hostfs spits a kernel warning "Something isn't implemented here", but it still works fine. Indeed, hostfs i_op->truncate doesn't do anything. But hostfs_setattr() -> set_attr() correctly detects ATTR_SIZE and calls truncate() on the host. So we should be safe (using ftruncate() may be better, in case the file is unlinked on the host, but we aren't sure to have the file open for writing, and reopening it would cause the same races; plus nobody should expect UML to be so careful). So, the warning is wrong, because the current implementation is working. Al, am I correct, and can the warning be therefore dropped? CC: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove iattr.ia_attr_flagsMiklos Szeredi
Remove unused ia_attr_flags from struct iattr, and related defines. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] uml: implement hostfs syncingPaolo 'Blaisorblade' Giarrusso
Actually implement the hostfs "sync" method. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14[PATCH] uml: hostfs: unuse ROOT_DEVPaolo 'Blaisorblade' Giarrusso
Minimal patch removing uses of ROOT_DEV; next patch unexports it. I've opposed this, but I've planned to reintroduce the functionality without using ROOT_DEV. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-28[PATCH] uml: remove 2_5compat.hJeff Dike
Remove old useless header that was used in Ye Olde Times during 2.4->2.5 porting to abstract differences. It's definitions are no more used anyway, so let's finally kill it. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] uml: hostfs failed mount handlingJeff Dike
This cleans up the error handling and fixes a crash if a hostfs mount fails. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] uml - hostfs: avoid buffersPaolo 'Blaisorblade' Giarrusso
Use this: .set_page_dirty = __set_page_dirty_nobuffers, We already dropped the inclusion of <linux/buffer_head.h>, and we don't have a backing block device for this FS. "Without having looked at it, I'm sure that hostfs does not use buffer_heads. So setting your ->set_page_dirty a_op to point at __set_page_dirty_nobuffers() is a reasonable thing to do - it'll provide a slight speedup." This speedup is one less spinlock held and one less conditional branch, which isn't bad. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
