commit a28e4b2b18ccb90df402da3f21e1a83c9d4f8ec1 upstream.
Removing unnecessary static buffers is good.
Use the vsprintf %pV extension instead.
Signed-off-by: Mikulas Patocka <mikulas@twibright.com>
commit ce657611baf902f14ae559ce4e0787ead6712067 upstream.
There is a possibility of nothing being allocated to the new_opts in
case of memory pressure, therefore return ENOMEM for such case.
Signed-off-by: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
that's the bulk of filesystem drivers dealing with inodes of their own
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
Fix 2 checkpatch warnings:
WARNING: suspect code indent for conditional statements
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
This patch applies a suggestion by Mikulas Patocka asking to increase
all pr_warn without commented ones to pr_err
Normalize function display fx() using __func__
Also remove redundant level names (warning:...)
No level printk in hptfs_error converted to pr_err (others to pr_warn or
pr_info)
This patch also fixes if/then/else checkpatch warnings
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Previously, the no-op "mount -o mount /dev/xxx" operation when the
file system is already mounted read-write causes an implied,
unconditional syncfs(). This seems pretty stupid, and it's certainly
documented or guaraunteed to do this, nor is it particularly useful,
except in the case where the file system was mounted rw and is getting
remounted read-only.
However, it's possible that there might be some file systems that are
actually depending on this behavior. In most file systems, it's
probably fine to only call sync_filesystem() when transitioning from
read-write to read-only, and there are some file systems where this is
not needed at all (for example, for a pseudo-filesystem or something
like romfs).
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-fsdevel@vger.kernel.org
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Anders Larsen <al@alarsen.net>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: xfs@oss.sgi.com
Cc: linux-btrfs@vger.kernel.org
Cc: linux-cifs@vger.kernel.org
Cc: samba-technical@lists.samba.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: fuse-devel@lists.sourceforge.net
Cc: cluster-devel@redhat.com
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: linux-nfs@vger.kernel.org
Cc: linux-nilfs@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: reiserfs-devel@vger.kernel.org
HPFS needs to load 4 consecutive 512-byte sectors when accessing the
directory nodes or bitmaps. We can't switch to 2048-byte block size
because files are allocated in the units of 512-byte sectors.
Previously, the driver would allocate a 2048-byte area using kmalloc,
copy the data from four buffers to this area and eventually copy them
back if they were modified.
In the current implementation of the buffer cache, buffers are allocated
in the pagecache. That means that 4 consecutive 512-byte buffers are
stored in consecutive areas in the kernel address space. So, we don't
need to allocate extra memory and copy the content of the buffers there.
This patch optimizes the code to avoid copying the buffers. It checks
if the four buffers are stored in contiguous memory - if they are not,
it falls back to allocating a 2048-byte area and copying data there.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Previously, hpfs scanned all bitmaps each time the user asked for free
space using statfs. This patch changes it so that hpfs scans the
bitmaps only once, remembes the free space and on next invocation of
statfs it returns the value instantly.
New versions of wine are hammering on the statfs syscall very heavily,
making some games unplayable when they're stored on hpfs, with load
times in minutes.
This should be backported to the stable kernels because it fixes
user-visible problem (excessive level load times in wine).
Cc: stable@vger.kernel.org
NFSv4 uses leases to guarantee that clients can cache metadata as well
as data.
Cc: Tyler Hicks <tyhicks@canonical.com>
Cc: Dustin Kirkland <dustin.kirkland@gazzang.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
makes ->d_hash() and ->d_compare() safety in RCU mode independent
from vfsmount_lock
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
Merge hpfs patches from Mikulas Patocka.
* emailed patches from Mikulas Patocka <mpatocka@artax.karlin.mff.cuni.cz>:
hpfs: implement prefetch to improve performance
hpfs: use mpage
hpfs: better test for errors
This patch implements prefetch to improve performance. It helps mostly
when scanning the bitmaps to calculate free space.
Signed-off-by: Mikulas Patocka <mpatocka@artax.karlin.mff.cuni.cz>
Use the mpage interface to improve performance.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
The test if bitmap access is out of bound could errorneously pass if the
device size is divisible by 16384 sectors and we are asking for one bitmap
after the end.
Check for invalid size in the superblock. Invalid size could cause integer
overflows in the rest of the code.
Cc: stable@kernel.org
Instances either don't look at it at all (the majority of cases) or
only want it to find the superblock (which can be had as dentry->d_sb).
A few cases that want more are actually safe with dentry->d_inode -
the only precaution needed is the check that it hadn't been replaced with
NULL by rmdir() or by overwriting rename(), which case should be simply
treated as cache miss.
This patch fixes warnings due to missing lock on write error path.
WARNING: at fs/hpfs/hpfs_fn.h:353 hpfs_truncate+0x75/0x80 [hpfs]()
Hardware name: empty
Pid: 26563, comm: dd Tainted: P O 3.9.4 #12
Call Trace:
hpfs_write_begin+0x84/0x90 [hpfs]
_hpfs_bmap+0x10/0x10 [hpfs]
generic_file_buffered_write+0x121/0x2c0
__generic_file_aio_write+0x1c7/0x3f0
generic_file_aio_write+0x7c/0x100
do_sync_write+0x98/0xd0
hpfs_file_write+0xd/0x50 [hpfs]
vfs_write+0xa2/0x160
sys_write+0x51/0xa0
page_fault+0x22/0x30
system_call_fastpath+0x1a/0x1f
Cc: stable@kernel.org # 2.6.39+
For one thing, there's an ABBA deadlock on hpfs fs-wide lock and i_mutex
in hpfs_dir_lseek() - there's a lot of methods that grab the former with
the caller already holding the latter, so it must take i_mutex first.
For another, locking the damn thing, carefully validating the offset,
then dropping locks and assigning the offset is obviously racy.
Moreover, we _must_ do hpfs_add_pos(), or the machinery in dnode.c
won't modify the sucker on B-tree surgeries.
... so that writev(2) doesn't miss it. Get rid of hpfs_file_write().
Somehow I failed to add the MODULE_ALIAS_FS for cifs, hostfs, hpfs,
squashfs, and udf despite what I thought were my careful checks :(
Add them now.
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
drivers/devfreq/exynos4_bus.c
Sync with Linus' tree to be able to apply patches that are
against newer code (mvneta).
Correct spelling typo in printk within various drivers.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Removed lock/unlock super.
Acked-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Convert cpu_to_leXX(leXX_to_cpu(E1) + E2) to use leXX_add_cpu().
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
There's no reason to call rcu_barrier() on every
deactivate_locked_super(). We only need to make sure that all delayed rcu
free inodes are flushed before we destroy related cache.
Removing rcu_barrier() from deactivate_locked_super() affects some fast
paths. E.g. on my machine exit_group() of a last process in IPC
namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
boolean "does it have to be exclusive?" flag is passed instead;
Local filesystem should just ignore it - the object is guaranteed
not to be there yet.
Just the flags; only NFS cares even about that, but there are
legitimate uses for such argument. And getting rid of that
completely would require splitting ->lookup() into a couple
of methods (at least), so let's leave that alone for now...
Pull vfs changes from Al Viro.
"A lot of misc stuff. The obvious groups:
* Miklos' atomic_open series; kills the damn abuse of
->d_revalidate() by NFS, which was the major stumbling block for
all work in that area.
* ripping security_file_mmap() and dealing with deadlocks in the
area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in
general.
* ->encode_fh() switched to saner API; insane fake dentry in
mm/cleancache.c gone.
* assorted annotations in fs (endianness, __user)
* parts of Artem's ->s_dirty work (jff2 and reiserfs parts)
* ->update_time() work from Josef.
* other bits and pieces all over the place.
Normally it would've been in two or three pull requests, but
signal.git stuff had eaten a lot of time during this cycle ;-/"
Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the
'truncate_range' inode method was removed by the VM changes, the VFS
update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due
to sparse fix added twice, with other changes nearby).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits)
nfs: don't open in ->d_revalidate
vfs: retry last component if opening stale dentry
vfs: nameidata_to_filp(): don't throw away file on error
vfs: nameidata_to_filp(): inline __dentry_open()
vfs: do_dentry_open(): don't put filp
vfs: split __dentry_open()
vfs: do_last() common post lookup
vfs: do_last(): add audit_inode before open
vfs: do_last(): only return EISDIR for O_CREAT
vfs: do_last(): check LOOKUP_DIRECTORY
vfs: do_last(): make ENOENT exit RCU safe
vfs: make follow_link check RCU safe
vfs: do_last(): use inode variable
vfs: do_last(): inline walk_component()
vfs: do_last(): make exit RCU safe
vfs: split do_lookup()
Btrfs: move over to use ->update_time
fs: introduce inode operation ->update_time
reiserfs: get rid of resierfs_sync_super
reiserfs: mark the superblock as dirty a bit later
The PRINTK() macro isn't really used. Let's just remove it because it
is ugly and out of date.
