path: root/fs/hppfs/hppfs_kern.c
2008-05-13uml: move hppfs_kern.c to hppfs.cJeff Dike
There's no reason for the _kern in hppfs_kern.c, so move it to hppfs.c. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13uml: hppfs fixesJeff Dike
hppfs tidying and fixes noticed during hch's get_inode work - style fixes a copy_to_user got its return value checked hppfs_write no longer fiddles file->f_pos because it gets and returns pos in its arguments hppfs_delete_inode dputs the underlyng procfs dentry stored in its private data and mntputs the vfsmnt stashed in s_fs_info hppfs_put_super no longer needs to mntput the s_fs_info, so it no longer needs to exist hppfs_readlink and hppfs_follow_link were doing a bunch of stuff with a struct file which they didn't use there is now a ->permission which calls generic_permission get_inode was always returning 0 for some reason - it now returns an inode if nothing bad happened Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19[PATCH] sanitize hppfsAl Viro
* hppfs_iget() and its users are racy; there's no need to pollute icache anyway, new_inode() works fine and is safe, unlike the current kludges (these relied on overwriting ->i_ino before another iget_locked() gets to that one - and did it after unlocking). * merge hppfs_iget()/init_inode()/hppfs_read_inode(), while we are at it. * to pass proper vfsmount to dentry_open() store the reference in hppfs superblock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> --
2008-03-19hppfs pass vfsmount to dentry_open()Dave Hansen
Here's patch for hppfs that uses vfs_kern_mount to make sure it always has a procfs instance and passed the vfsmount on through the inode private data. Also fixes a procfs file_system_type leak for every attempted hppfs mount. [ jdike - gave this file a style workover, plus deleted hppfs_dentry_ops ] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-07iget: stop HPPFS from using iget() and read_inode()David Howells
Stop the HPPFS filesystem from using iget() and read_inode(). Provide an hppfs_iget(), and call that instead of iget(). hppfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. hppfs_fill_sb_common() returns any error incurred when getting the root inode instead of EINVAL. Note that the contents of hppfs_kern.c need to be examined: (*) The HPPFS inode retains a pointer to the proc dentry it is shadowing, but whilst it does appear to retain a reference to it, it doesn't appear to destroy the reference if the inode goes away. (*) hppfs_iget() should perhaps subsume init_inode() and hppfs_read_inode(). (*) It would appear that all hppfs inodes are the same inode because iget() was being called with inode number 0, which forms the lookup key. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] struct path: convert hppfsJosef Sipek
2006-10-09[PATCH] hppfs: readdir callback missed in prototype changeAl Viro
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] uml: __user annotationsAl Viro
__user annotations (hppfs) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-08-26[PATCH] hppfs: fix symlink error pathPaolo 'Blaisorblade' Giarrusso
While touching this code I noticed the error handling is bogus, so I fixed it up. I've removed the IS_ERR(proc_dentry) check, which will never trigger and is clearly a typo: we must check proc_file instead. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-26[PATCH] Fixup symlink function pointers for hppfs [for 2.6.13]Paolo 'Blaisorblade' Giarrusso
Update hppfs for the symlink functions prototype change. Yes, I know the code I leave there is still _bogus_, see next patch for this. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-14[PATCH] uml: fix hppfs error pathPaolo 'Blaisorblade' Giarrusso
Fix the error message to refer to the error code, i.e. err, not count, plus add some cosmetical fixes. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] uml: restore hppfs supportPaolo 'Blaisorblade' Giarrusso
Some time ago a trivial patch broke HPPFS (one var became a pointer, not all uses were updated). It wasn't fixed at that time because not very used, now it's been requested so I've fixed this, and it has been tested positively (at least partially). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
