path: root/fs/hugetlbfs
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Untangling ima mess, part 1: alloc_file()Al Viro
There are 2 groups of alloc_file() callers: * ones that are followed by ima_counts_get * ones giving non-regular files So let's pull that ima_counts_get() into alloc_file(); it's a no-op in case of non-regular files. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: truncate: use new helpers truncate: new helpers fs: fix overflow in sys_mount() for in-kernel calls fs: Make unload_nls() NULL pointer safe freeze_bdev: grab active reference to frozen superblocks freeze_bdev: kill bd_mount_sem exofs: remove BKL from super operations fs/romfs: correct error-handling code vfs: seq_file: add helpers for data filling vfs: remove redundant position check in do_sendfile vfs: change sb->s_maxbytes to a loff_t vfs: explicitly cast s_maxbytes in fiemap_check_ranges libfs: return error code on failed attr set seq_file: return a negative error code when seq_path_root() fails. vfs: optimize touch_time() too vfs: optimization for touch_atime() vfs: split generic_forget_inode() so that hugetlbfs does not have to copy it fs/inode.c: add dev-id and inode number for debugging in init_special_inode() libfs: make simple_read_from_buffer conventional
2009-09-24hugetlbfs: do not call user_shm_lock() for MAP_HUGETLB fixFrom: Mel Gorman
Commit 6bfde05bf5c ("hugetlbfs: allow the creation of files suitable for MAP_PRIVATE on the vfs internal mount") altered can_do_hugetlb_shm() to check if a file is being created for shared memory or mmap(). If this returns false, we then unconditionally call user_shm_lock() triggering a warning. This block should never be entered for MAP_HUGETLB. This patch partially reverts the problem and fixes the check. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24vfs: split generic_forget_inode() so that hugetlbfs does not have to copy itJan Kara
Hugetlbfs needs to do special things instead of truncate_inode_pages(). Currently, it copied generic_forget_inode() except for truncate_inode_pages() call which is asking for trouble (the code there isn't trivial). So create a separate function generic_detach_inode() which does all the list magic done in generic_forget_inode() and call it from hugetlbfs_forget_inode(). Signed-off-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22hugetlbfs: allow the creation of files suitable for MAP_PRIVATE on the vfs ↵Eric B Munson
internal mount This patchset adds a flag to mmap that allows the user to request that an anonymous mapping be backed with huge pages. This mapping will borrow functionality from the huge page shm code to create a file on the kernel internal mount and use it to approximate an anonymous mapping. The MAP_HUGETLB flag is a modifier to MAP_ANONYMOUS and will not work without both flags being preset. A new flag is necessary because there is no other way to hook into huge pages without creating a file on a hugetlbfs mount which wouldn't be MAP_ANONYMOUS. To userspace, this mapping will behave just like an anonymous mapping because the file is not accessible outside of the kernel. This patchset is meant to simplify the programming model. Presently there is a large chunk of boiler platecode, contained in libhugetlbfs, required to create private, hugepage backed mappings. This patch set would allow use of hugepages without linking to libhugetlbfs or having hugetblfs mounted. Unification of the VM code would provide these same benefits, but it has been resisted each time that it has been suggested for several reasons: it would break PAGE_SIZE assumptions across the kernel, it makes page-table abstractions really expensive, and it does not provide any benefit on architectures that do not support huge pages, incurring fast path penalties without providing any benefit on these architectures. This patch: There are two means of creating mappings backed by huge pages: 1. mmap() a file created on hugetlbfs 2. Use shm which creates a file on an internal mount which essentially maps it MAP_SHARED The internal mount is only used for shared mappings but there is very little that stops it being used for private mappings. This patch extends hugetlbfs_file_setup() to deal with the creation of files that will be mapped MAP_PRIVATE on the internal hugetlbfs mount. This extended API is used in a subsequent patch to implement the MAP_HUGETLB mmap() flag. Signed-off-by: Eric Munson <ebmunson@us.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-24mm: fix hugetlb bug due to user_shm_unlock callHugh Dickins
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed user_shm_lock() calls in hugetlb_file_setup() but left the user_shm_unlock call in shm_destroy(). In detail: Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock() is not called in hugetlb_file_setup(). However, user_shm_unlock() is called in any case in shm_destroy() and in the following atomic_dec_and_lock(&up->__count) in free_uid() is executed and if up->__count gets zero, also cleanup_user_struct() is scheduled. Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set. However, the ref counter up->__count gets unexpectedly non-positive and the corresponding structs are freed even though there are live references to them, resulting in a kernel oops after a lots of shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set. Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the time of shm_destroy() may give a different answer from at the time of hugetlb_file_setup(). And fixed newseg()'s no_id error path, which has missed user_shm_unlock() ever since it came in 2.6.9. Reported-by: Stefan Huber <shuber2@gmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Tested-by: Stefan Huber <shuber2@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-22Merge branch 'master' into nextJames Morris
Conflicts: fs/exec.c Removed IMA changes (the IMA checks are now performed via may_open()). Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22integrity: move ima_counts_getMimi Zohar
Based on discussion on lkml (Andrew Morton and Eric Paris), move ima_counts_get down a layer into shmem/hugetlb__file_setup(). Resolves drm shmem_file_setup() usage case as well. HD comment: I still think you're doing this at the wrong level, but recognize that you probably won't be persuaded until a few more users of alloc_file() emerge, all wanting your ima_counts_get(). Resolving GEM's shmem_file_setup() is an improvement, so I'll say Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-13Remove implementation of readpage from the hugetlbfs_aopsMel Gorman
The core VM assumes the page size used by the address_space in inode->i_mapping is PAGE_SIZE but hugetlbfs breaks this assumption by inserting pages into the page cache at offsets the core VM considers unexpected. This would not be a problem except that hugetlbfs also provide a ->readpage implementation. As it exists, the core VM can assume the base page size is being used, allocate pages on behalf of the filesystem, insert them into the page cache and call ->readpage to populate them. These pages are the wrong size and at the wrong offset for hugetlbfs causing confusion. This patch deletes the ->readpage implementation for hugetlbfs on the grounds the core VM should not be allocating and populating pages on behalf of hugetlbfs. There should be no existing users of the ->readpage implementation so it should not cause a regression. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21hugetlbfs: return negative error code for bad mount optionAkinobu Mita
This fixes the following BUG: # mount -o size=MM -t hugetlbfs none /huge hugetlbfs: Bad value 'MM' for mount option 'size=MM' ------------[ cut here ]------------ kernel BUG at fs/super.c:996! Due to BUG_ON(!mnt->mnt_sb); in vfs_kern_mount(). Also, remove unused #include <linux/quotaops.h> Cc: William Irwin <wli@holomorphy.com> Cc: <stable@kernel.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: reintroduce and deprecate rlimit based access for SHM_HUGETLBRavikiran G Thirumalai
Allow non root users with sufficient mlock rlimits to be able to allocate hugetlb backed shm for now. Deprecate this though. This is being deprecated because the mlock based rlimit checks for SHM_HUGETLB is not consistent with mmap based huge page allocations. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: fix SHM_HUGETLB to work with users in hugetlb_shm_groupRavikiran G Thirumalai
Fix hugetlb subsystem so that non root users belonging to hugetlb_shm_group can actually allocate hugetlb backed shm. Currently non root users cannot even map one large page using SHM_HUGETLB when they belong to the gid in /proc/sys/vm/hugetlb_shm_group. This is because allocation size is verified against RLIMIT_MEMLOCK resource limit even if the user belongs to hugetlb_shm_group. This patch 1. Fixes hugetlb subsystem so that users with CAP_IPC_LOCK and users belonging to hugetlb_shm_group don't need to be restricted with RLIMIT_MEMLOCK resource limits 2. This patch also disables mlock based rlimit checking (which will be reinstated and marked deprecated in a subsequent patch). Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-10Do not account for the address space used by hugetlbfs using VM_ACCOUNTMel Gorman
When overcommit is disabled, the core VM accounts for pages used by anonymous shared, private mappings and special mappings. It keeps track of VMAs that should be accounted for with VM_ACCOUNT and VMAs that never had a reserve with VM_NORESERVE. Overcommit for hugetlbfs is much riskier than overcommit for base pages due to contiguity requirements. It avoids overcommiting on both shared and private mappings using reservation counters that are checked and updated during mmap(). This ensures (within limits) that hugepages exist in the future when faults occurs or it is too easy to applications to be SIGKILLed. As hugetlbfs makes its own reservations of a different unit to the base page size, VM_ACCOUNT should never be set. Even if the units were correct, we would double account for the usage in the core VM and hugetlbfs. VM_NORESERVE may be set because an application can request no reserves be made for hugetlbfs at the risk of getting killed later. With commit fc8744adc870a8d4366908221508bb113d8b72ee, VM_NORESERVE and VM_ACCOUNT are getting unconditionally set for hugetlbfs-backed mappings. This breaks the accounting for both the core VM and hugetlbfs, can trigger an OOM storm when hugepage pools are too small lockups and corrupted counters otherwise are used. This patch brings hugetlbfs more in line with how the core VM treats VM_NORESERVE but prevents VM_ACCOUNT being set. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06hugetlb: unsigned ret cannot be negativeRoel Kluin
unsigned long ret cannot be negative, but ret can get -EFAULT. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Ken Chen <kenchen@google.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the hugetlbfs filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: William Irwin <wli@holomorphy.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlbfs: per mount huge page sizesAndi Kleen
Add the ability to configure the hugetlb hstate used on a per mount basis. - Add a new pagesize= option to the hugetlbfs mount that allows setting the page size - This option causes the mount code to find the hstate corresponding to the specified size, and sets up a pointer to the hstate in the mount's superblock. - Change the hstate accessors to use this information rather than the global_hstate they were using (requires a slight change in mm/memory.c so we don't NULL deref in the error-unmap path -- see comments). [np: take hstate out of hugetlbfs inode and vma->vm_private_data] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: modular state for hugetlb page sizeAndi Kleen
The goal of this patchset is to support multiple hugetlb page sizes. This is achieved by introducing a new struct hstate structure, which encapsulates the important hugetlb state and constants (eg. huge page size, number of huge pages currently allocated, etc). The hstate structure is then passed around the code which requires these fields, they will do the right thing regardless of the exact hstate they are operating on. This patch adds the hstate structure, with a single global instance of it (default_hstate), and does the basic work of converting hugetlb to use the hstate. Future patches will add more hstate structures to allow for different hugetlbfs mounts to have different page sizes. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: guarantee that COW faults for a process that called ↵Mel Gorman
mmap(MAP_PRIVATE) on hugetlbfs will succeed After patch 2 in this series, a process that successfully calls mmap() for a MAP_PRIVATE mapping will be guaranteed to successfully fault until a process calls fork(). At that point, the next write fault from the parent could fail due to COW if the child still has a reference. We only reserve pages for the parent but a copy must be made to avoid leaking data from the parent to the child after fork(). Reserves could be taken for both parent and child at fork time to guarantee faults but if the mapping is large it is highly likely we will not have sufficient pages for the reservation, and it is common to fork only to exec() immediatly after. A failure here would be very undesirable. Note that the current behaviour of mainline with MAP_PRIVATE pages is pretty bad. The following situation is allowed to occur today. 1. Process calls mmap(MAP_PRIVATE) 2. Process calls mlock() to fault all pages and makes sure it succeeds 3. Process forks() 4. Process writes to MAP_PRIVATE mapping while child still exists 5. If the COW fails at this point, the process gets SIGKILLed even though it had taken care to ensure the pages existed This patch improves the situation by guaranteeing the reliability of the process that successfully calls mmap(). When the parent performs COW, it will try to satisfy the allocation without using reserves. If that fails the parent will steal the page leaving any children without a page. Faults from the child after that point will result in failure. If the child COW happens first, an attempt will be made to allocate the page without reserves and the child will get SIGKILLed on failure. To summarise the new behaviour: 1. If the original mapper performs COW on a private mapping with multiple references, it will attempt to allocate a hugepage from the pool or the buddy allocator without using the existing reserves. On fail, VMAs mapping the same area are traversed and the page being COW'd is unmapped where found. It will then steal the original page as the last mapper in the normal way. 2. The VMAs the pages were unmapped from are flagged to note that pages with data no longer exist. Future no-page faults on those VMAs will terminate the process as otherwise it would appear that data was corrupted. A warning is printed to the console that this situation occured. 2. If the child performs COW first, it will attempt to satisfy the COW from the pool if there are enough pages or via the buddy allocator if overcommit is allowed and the buddy allocator can satisfy the request. If it fails, the child will be killed. If the pool is large enough, existing applications will not notice that the reserves were a factor. Existing applications depending on the no-reserves been set are unlikely to exist as for much of the history of hugetlbfs, pages were prefaulted at mmap(), allocating the pages at that point or failing the mmap(). [npiggin@suse.de: fix CONFIG_HUGETLB=n build] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: reserve huge pages for reliable MAP_PRIVATE hugetlbfs mappings ↵Mel Gorman
until fork() This patch reserves huge pages at mmap() time for MAP_PRIVATE mappings in a similar manner to the reservations taken for MAP_SHARED mappings. The reserve count is accounted both globally and on a per-VMA basis for private mappings. This guarantees that a process that successfully calls mmap() will successfully fault all pages in the future unless fork() is called. The characteristics of private mappings of hugetlbfs files behaviour after this patch are; 1. The process calling mmap() is guaranteed to succeed all future faults until it forks(). 2. On fork(), the parent may die due to SIGKILL on writes to the private mapping if enough pages are not available for the COW. For reasonably reliable behaviour in the face of a small huge page pool, children of hugepage-aware processes should not reference the mappings; such as might occur when fork()ing to exec(). 3. On fork(), the child VMAs inherit no reserves. Reads on pages already faulted by the parent will succeed. Successful writes will depend on enough huge pages being free in the pool. 4. Quotas of the hugetlbfs mount are checked at reserve time for the mapper and at fault time otherwise. Before this patch, all reads or writes in the child potentially needs page allocations that can later lead to the death of the parent. This applies to reads and writes of uninstantiated pages as well as COW. After the patch it is only a write to an instantiated page that causes problems. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30mm: bdi: add separate writeback accounting capabilityMiklos Szeredi
Add a new BDI capability flag: BDI_CAP_NO_ACCT_WB. If this flag is set, then don't update the per-bdi writeback stats from test_set_page_writeback() and test_clear_page_writeback(). Misc cleanups: - convert bdi_cap_writeback_dirty() and friends to static inline functions - create a flag that includes all three dirty/writeback related flags, since almst all users will want to have them toghether Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: use struct mempolicy pointer in shmem_sb_infoLee Schermerhorn
This patch replaces the mempolicy mode, mode_flags, and nodemask in the shmem_sb_info struct with a struct mempolicy pointer, initialized to NULL. This removes dependency on the details of mempolicy from shmem.c and hugetlbfs inode.c and simplifies the interfaces. mpol_parse_str() in mempolicy.c is changed to return, via a pointer to a pointer arg, a struct mempolicy pointer on success. For MPOL_DEFAULT, the returned pointer is NULL. Further, mpol_parse_str() now takes a 'no_context' argument that causes the input nodemask to be stored in the w.user_nodemask of the created mempolicy for use when the mempolicy is installed in a tmpfs inode shared policy tree. At that time, any cpuset contextualization is applied to the original input nodemask. This preserves the previous behavior where the input nodemask was stored in the superblock. We can think of the returned mempolicy as "context free". Because mpol_parse_str() is now calling mpol_new(), we can remove from mpol_to_str() the semantic checks that mpol_new() already performs. Add 'no_context' parameter to mpol_to_str() to specify that it should format the nodemask in w.user_nodemask for 'bind' and 'interleave' policies. Change mpol_shared_policy_init() to take a pointer to a "context free" struct mempolicy and to create a new, "contextualized" mempolicy using the mode, mode_flags and user_nodemask from the input mempolicy. Note: we know that the mempolicy passed to mpol_to_str() or mpol_shared_policy_init() from a tmpfs superblock is "context free". This is currently the only instance thereof. However, if we found more uses for this concept, and introduced any ambiguity as to whether a mempolicy was context free or not, we could add another internal mode flag to identify context free mempolicies. Then, we could remove the 'no_context' argument from mpol_to_str(). Added shmem_get_sbmpol() to return a reference counted superblock mempolicy, if one exists, to pass to mpol_shared_policy_init(). We must add the reference under the sb stat_lock to prevent races with replacement of the mpol by remount. This reference is removed in mpol_shared_policy_init(). [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: yet another build fix] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: support optional mode flagsDavid Rientjes
With the evolution of mempolicies, it is necessary to support mempolicy mode flags that specify how the policy shall behave in certain circumstances. The most immediate need for mode flag support is to suppress remapping the nodemask of a policy at the time of rebind. Both the mempolicy mode and flags are passed by the user in the 'int policy' formal of either the set_mempolicy() or mbind() syscall. A new constant, MPOL_MODE_FLAGS, represents the union of legal optional flags that may be passed as part of this int. Mempolicies that include illegal flags as part of their policy are rejected as invalid. An additional member to struct mempolicy is added to support the mode flags: struct mempolicy { ... unsigned short policy; unsigned short flags; } The splitting of the 'int' actual passed by the user is done in sys_set_mempolicy() and sys_mbind() for their respective syscalls. This is done by intersecting the actual with MPOL_MODE_FLAGS, rejecting the syscall of there are additional flags, and storing it in the new 'flags' member of struct mempolicy. The intersection of the actual with ~MPOL_MODE_FLAGS is stored in the 'policy' member of the struct and all current users of pol->policy remain unchanged. The union of the policy mode and optional mode flags is passed back to the user in get_mempolicy(). This combination of mode and flags within the same actual does not break userspace code that relies on get_mempolicy(&policy, ...) and either switch (policy) { case MPOL_BIND: ... case MPOL_INTERLEAVE: ... }; statements or if (policy == MPOL_INTERLEAVE) { ... } statements. Such applications would need to use optional mode flags when calling set_mempolicy() or mbind() for these previously implemented statements to stop working. If an application does start using optional mode flags, it will need to mask the optional flags off the policy in switch and conditional statements that only test mode. An additional member is also added to struct shmem_sb_info to store the optional mode flags. [hugh@veritas.com: shmem mpol: fix build warning] Cc: Paul Jackson <pj@sgi.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19[PATCH] double iput() on failure exit in hugetlbAl Viro
once we'd done d_instantiate(), we should only do dput(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08mount options: fix hugetlbfsMiklos Szeredi
Add a .show_options super operation to hugetlbfs. Use generic_show_options() and save the complete option string in hugetlbfs_fill_super(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Adam Litke <agl@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Ken Chen <kenchen@google.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05hugetlb: allow sticky directory mount optionKen Chen
Allow sticky directory mount option for hugetlbfs. This allows admin to create a shared hugetlbfs mount point for multiple users, while prevent accidental file deletion that users may step on each other. It is similiar to default tmpfs mount option, or typical option used on /tmp. Signed-off-by: Ken Chen <kenchen@google.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <hermes@gibson.dropbear.id.au> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14hugetlb: allow bulk updating in hugetlb_*_quota()Adam Litke
Add a second parameter 'delta' to hugetlb_get_quota and hugetlb_put_quota to allow bulk updating of the sbinfo->free_blocks counter. This will be used by the next patch in the series. Signed-off-by: Adam Litke <agl@us.ibm.com> Cc: Ken Chen <kenchen@google.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: David Gibson <hermes@gibson.dropbear.id.au> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14hugetlb: fix quota management for private mappingsAdam Litke
The hugetlbfs quota management system was never taught to handle MAP_PRIVATE mappings when that support was added. Currently, quota is debited at page instantiation and credited at file truncation. This approach works correctly for shared pages but is incomplete for private pages. In addition to hugetlb_no_page(), private pages can be instantiated by hugetlb_cow(); but this function does not respect quotas. Private huge pages are treated very much like normal, anonymous pages. They are not "backed" by the hugetlbfs file and are not stored in the mapping's radix tree. This means that private pages are invisible to truncate_hugepages() so that function will not credit the quota. This patch (based on a prototype provided by Ken Chen) moves quota crediting for all pages into free_huge_page(). page->private is used to store a pointer to the mapping to which this page belongs. This is used to credit quota on the appropriate hugetlbfs instance. Signed-off-by: Adam Litke <agl@us.ibm.com> Cc: Ken Chen <kenchen@google.com> Cc: Ken Chen <kenchen@google.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: David Gibson <hermes@gibson.dropbear.id.au> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17r/o bind mounts: filesystem helpers for custom 'struct file'sDave Hansen
Why do we need r/o bind mounts? This feature allows a read-only view into a read-write filesystem. In the process of doing that, it also provides infrastructure for keeping track of the number of writers to any given mount. This has a number of uses. It allows chroots to have parts of filesystems writable. It will be useful for containers in the future because users may have root inside a container, but should not be allowed to write to somefilesystems. This also replaces patches that vserver has had out of the tree for several years. It allows security enhancement by making sure that parts of your filesystem read-only (such as when you don't trust your FTP server), when you don't want to have entire new filesystems mounted, or when you want atime selectively updated. I've been using the following script to test that the feature is working as desired. It takes a directory and makes a regular bind and a r/o bind mount of it. It then performs some normal filesystem operations on the three directories, including ones that are expected to fail, like creating a file on the r/o mount. This patch: Some filesystems forego the vfs and may_open() and create their own 'struct file's. This patch creates a couple of helper functions which can be used by these filesystems, and will provide a unified place which the r/o bind mount code may patch. Also, rename an existing, static-scope init_file() to a less generic name. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17introduce I_SYNCJoern Engel
I_LOCK was used for several unrelated purposes, which caused deadlock situations in certain filesystems as a side effect. One of the purposes now uses the new I_SYNC bit. Also document the various bits and change their order from historical to logical. [bunk@stusta.de: make fs/inode.c:wake_up_inode() static] Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: David Chinner <dgc@sgi.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: bdi init hooksPeter Zijlstra
provide BDI constructor/destructor hooks [akpm@linux-foundation.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16hugetlbfs read() supportBadari Pulavarty
Support for reading from hugetlbfs files. libhugetlbfs lets application text/data to be placed in large pages. When we do that, oprofile doesn't work - since libbfd tries to read from it. This code is very similar to what do_generic_mapping_read() does, but I can't use it since it has PAGE_CACHE_SIZE assumptions. [akpm@linux-foundation.org: cleanups, fix leak] [bunk@stusta.de: make hugetlbfs_read() static] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: William Irwin <bill.irwin@oracle.com> Tested-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16hugetlb: allow extending ftruncate on hugetlbfsKen Chen
For historical reason, expanding ftruncate that increases file size on hugetlbfs is not allowed due to pages were pre-faulted and lack of fault handler. Now that we have demand faulting on hugetlb since 2.6.15, there is no reason to hold back that limitation. This will make hugetlbfs behave more like a normal fs. I'm writing a user level code that uses hugetlbfs but will fall back to tmpfs if there are no hugetlb page available in the system. Having hugetlbfs specific ftruncate behavior is a bit quirky and I would like to remove that artificial limitation. Signed-off-by: <kenchen@google.com> Acked-by: Wiliam Irwin <wli@holomorphy.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16implement simple fs aopsNick Piggin
Implement new aops for some of the simpler filesystems. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-31hugepage: fix broken check for offset alignment in hugepage mappingsDavid Gibson
For hugepage mappings, the file offset, like the address and size, needs to be aligned to the size of a hugepage. In commit 68589bc353037f233fe510ad9ff432338c95db66, the check for this was moved into prepare_hugepage_range() along with the address and size checks. But since BenH's rework of the get_unmapped_area() paths leading up to commit 4b1d89290b62bb2db476c94c82cf7442aab440c8, prepare_hugepage_range() is only called for MAP_FIXED mappings, not for other mappings. This means we're no longer ever checking for an aligned offset - I've confirmed that mmap() will (apparently) succeed with a misaligned offset on both powerpc and i386 at least. This patch restores the check, removing it from prepare_hugepage_range() and putting it back into hugetlbfs_file_mmap(). I'm putting it there, rather than in the get_unmapped_area() path so it only needs to go in one place, than separately in the half-dozen or so arch-specific implementations of hugetlb_get_unmapped_area(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16hugetlbfs: handle empty options stringLee Schermerhorn
I was seeing a null pointer deref in fs/super.c:vfs_kern_mount(). Some file system get_sb() handler was returning NULL mnt_sb with a non-negative return value. I also noticed a "hugetlbfs: Bad mount option:" message in the log. Turns out that hugetlbfs_parse_options() was not checking for an empty option string after call to strsep(). On failure, hugetlbfs_parse_options() returns 1. hugetlbfs_fill_super() just passed this return code back up the call stack where vfs_kern_mount() missed the error and proceeded with a NULL mnt_sb. Apparently introduced by patch: hugetlbfs-use-lib-parser-fix-docs.patch The problem was exposed by this line in my fstab: none /huge hugetlbfs defaults 0 0 It can also be demonstrated by invoking mount of hugetlbfs directly with no options or a bogus option. This patch: 1) adds the check for empty option to hugetlbfs_parse_options(), 2) enhances the error message to bracket any unrecognized option with quotes , 3) modifies hugetlbfs_parse_options() to return -EINVAL on any unrecognized option, 4) adds a BUG_ON() to vfs_kern_mount() to catch any get_sb() handler that returns a NULL mnt->mnt_sb with a return value >= 0. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16hugetlbfs: use lib/parser, fix docsRandy Dunlap
Use lib/parser.c to parse hugetlbfs mount options. Correct docs in hugetlbpage.txt. old size of hugetlbfs_fill_super: 675 bytes new size of hugetlbfs_fill_super: 686 bytes (hugetlbfs_parse_options() is inlined) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Adam Litke <agl@us.ibm.com> Acked-by: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16shm: fix the filename of hugetlb sysv shared memoryEric W. Biederman
Some user space tools need to identify SYSV shared memory when examining /proc/<pid>/maps. To do so they look for a block device with major zero, a dentry named SYSV<sysv key>, and having the minor of the internal sysv shared memory kernel mount. To help these tools and to make it easier for people just browsing /proc/<pid>/maps this patch modifies hugetlb sysv shared memory to use the SYSV<key> dentry naming convention. User space tools will still have to be aware that hugetlb sysv shared memory lives on a different internal kernel mount and so has a different block device minor number from the rest of sysv shared memory. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serge@hallyn.com> Cc: Albert Cahalan <acahalan@gmail.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07hugetlbfs: add NULL check in hugetlb_zero_setup()Akinobu Mita
If hugetlbfs module_init() fails, hugetlbfs_vfsmount is not initialized and shmget() with SHM_HUGETLB flag will cause NULL pointer dereference. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: William Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
