path: root/fs/hugetlbfs
2012-04-25hugetlbfs: lockdep annotate root inode properlyAneesh Kumar K.V
This fixes the below reported false lockdep warning. e096d0c7e2e4 ("lockdep: Add helper function for dir vs file i_mutex annotation") added a similar annotation for every other inode in hugetlbfs but missed the root inode because it was allocated by a separate function. For HugeTLB fs we allow taking i_mutex in mmap. HugeTLB fs doesn't support file write and its file read callback is modified in a05b0855fd ("hugetlbfs: avoid taking i_mutex from hugetlbfs_read()") to not take i_mutex. Hence for HugeTLB fs with regular files we really don't take i_mutex with mmap_sem held. ====================================================== [ INFO: possible circular locking dependency detected ] 3.4.0-rc1+ #322 Not tainted ------------------------------------------------------- bash/1572 is trying to acquire lock: (&mm->mmap_sem){++++++}, at: [<ffffffff810f1618>] might_fault+0x40/0x90 but task is already holding lock: (&sb->s_type->i_mutex_key#12){+.+.+.}, at: [<ffffffff81125f88>] vfs_readdir+0x56/0xa8 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#12){+.+.+.}: [<ffffffff810a09e5>] lock_acquire+0xd5/0xfa [<ffffffff816a2f5e>] __mutex_lock_common+0x48/0x350 [<ffffffff816a3325>] mutex_lock_nested+0x2a/0x31 [<ffffffff811fb8e1>] hugetlbfs_file_mmap+0x7d/0x104 [<ffffffff810f859a>] mmap_region+0x272/0x47d [<ffffffff810f8a39>] do_mmap_pgoff+0x294/0x2ee [<ffffffff810f8b65>] sys_mmap_pgoff+0xd2/0x10e [<ffffffff8103d19e>] sys_mmap+0x1d/0x1f [<ffffffff816a5922>] system_call_fastpath+0x16/0x1b -> #0 (&mm->mmap_sem){++++++}: [<ffffffff810a0256>] __lock_acquire+0xa81/0xd75 [<ffffffff810a09e5>] lock_acquire+0xd5/0xfa [<ffffffff810f1645>] might_fault+0x6d/0x90 [<ffffffff81125d62>] filldir+0x6a/0xc2 [<ffffffff81133a83>] dcache_readdir+0x5c/0x222 [<ffffffff81125fa8>] vfs_readdir+0x76/0xa8 [<ffffffff811260b6>] sys_getdents+0x79/0xc9 [<ffffffff816a5922>] system_call_fastpath+0x16/0x1b other info that might help us debug this: Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(&sb->s_type->i_mutex_key#12); lock(&mm->mmap_sem); lock(&sb->s_type->i_mutex_key#12); lock(&mm->mmap_sem); *** DEADLOCK *** 1 lock held by bash/1572: #0: (&sb->s_type->i_mutex_key#12){+.+.+.}, at: [<ffffffff81125f88>] vfs_readdir+0x56/0xa8 stack backtrace: Pid: 1572, comm: bash Not tainted 3.4.0-rc1+ #322 Call Trace: [<ffffffff81699a3c>] print_circular_bug+0x1f8/0x209 [<ffffffff810a0256>] __lock_acquire+0xa81/0xd75 [<ffffffff810f38aa>] ? handle_pte_fault+0x5ff/0x614 [<ffffffff8109e622>] ? mark_lock+0x2d/0x258 [<ffffffff810f1618>] ? might_fault+0x40/0x90 [<ffffffff810a09e5>] lock_acquire+0xd5/0xfa [<ffffffff810f1618>] ? might_fault+0x40/0x90 [<ffffffff816a3249>] ? __mutex_lock_common+0x333/0x350 [<ffffffff810f1645>] might_fault+0x6d/0x90 [<ffffffff810f1618>] ? might_fault+0x40/0x90 [<ffffffff81125d62>] filldir+0x6a/0xc2 [<ffffffff81133a83>] dcache_readdir+0x5c/0x222 [<ffffffff81125cf8>] ? sys_ioctl+0x74/0x74 [<ffffffff81125cf8>] ? sys_ioctl+0x74/0x74 [<ffffffff81125cf8>] ? sys_ioctl+0x74/0x74 [<ffffffff81125fa8>] vfs_readdir+0x76/0xa8 [<ffffffff811260b6>] sys_getdents+0x79/0xc9 [<ffffffff816a5922>] system_call_fastpath+0x16/0x1b Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-05hugetlbfs: remove unregister_filesystem() when initializing moduleHillf Danton
It was introduced by d1d5e05ffdc1 ("hugetlbfs: return error code when initializing module") but as Al pointed out, is a bad idea. Quoted comments from Al: "Note that unregister_filesystem() in module init is *always* wrong; it's not an issue here (it's done too early to care about and realistically the box is not going anywhere - it'll panic when attempt to exec /sbin/init fails, if not earlier), but it's a damn bad example. Consider a normal fs module. Somebody loads it and in parallel with that we get a mount attempt on that fs type. It comes between register and failure exits that causes unregister; at that point we are screwed since grabbing a reference to module as done by mount is enough to prevent exit, but not to prevent the failure of init. As the result, module will get freed when init fails, mounted fs of that type be damned." So remove it. Signed-off-by: Hillf Danton <dhillf@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-22Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge first batch of patches from Andrew Morton: "A few misc things and all the MM queue" * emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits) memcg: avoid THP split in task migration thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE memcg: clean up existing move charge code mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read() mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event() mm/memcontrol.c: s/stealed/stolen/ memcg: fix performance of mem_cgroup_begin_update_page_stat() memcg: remove PCG_FILE_MAPPED memcg: use new logic for page stat accounting memcg: remove PCG_MOVE_LOCK flag from page_cgroup memcg: simplify move_account() check memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat) memcg: kill dead prev_priority stubs memcg: remove PCG_CACHE page_cgroup flag memcg: let css_get_next() rely upon rcu_read_lock() cgroup: revert ss_id_lock to spinlock idr: make idr_get_next() good for rcu_read_lock() memcg: remove unnecessary thp check in page stat accounting memcg: remove redundant returns memcg: enum lru_list lru ...
2012-03-21hugetlbfs: return error code when initializing moduleHillf Danton
Return an errno upon failure to create inode kmem cache, and unregister the FS upon failure to mount. [akpm@linux-foundation.org: remove unneeded test of `error'] Signed-off-by: Hillf Danton <dhillf@gmail.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlbfs: fix alignment of huge page requestsSteven Truelove
When calling shmget() with SHM_HUGETLB, shmget aligns the request size to PAGE_SIZE, but this is not sufficient. Modify hugetlb_file_setup() to align requests to the huge page size, and to accept an address argument so that all alignment checks can be performed in hugetlb_file_setup(), rather than in its callers. Change newseg() and mmap_pgoff() to match the new prototype and eliminate a now redundant alignment check. [akpm@linux-foundation.org: fix build] Signed-off-by: Steven Truelove <steven.truelove@utoronto.ca> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21mm, hugetlb: add thread name and pid to SHM_HUGETLB mlock rlimit warningDavid Rientjes
Add the thread name and pid of the application that is allocating shm segments with MAP_HUGETLB without being a part of /proc/sys/vm/hugetlb_shm_group or having CAP_IPC_LOCK. This identifies the application so it may be fixed by avoiding using the deprecated exception (see Documentation/feature-removal-schedule.txt). Signed-off-by: David Rientjes <rientjes@google.com> Cc: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugepages: fix use after free bug in "quota" handlingDavid Gibson
hugetlbfs_{get,put}_quota() are badly named. They don't interact with the general quota handling code, and they don't much resemble its behaviour. Rather than being about maintaining limits on on-disk block usage by particular users, they are instead about maintaining limits on in-memory page usage (including anonymous MAP_PRIVATE copied-on-write pages) associated with a particular hugetlbfs filesystem instance. Worse, they work by having callbacks to the hugetlbfs filesystem code from the low-level page handling code, in particular from free_huge_page(). This is a layering violation of itself, but more importantly, if the kernel does a get_user_pages() on hugepages (which can happen from KVM amongst others), then the free_huge_page() can be delayed until after the associated inode has already been freed. If an unmount occurs at the wrong time, even the hugetlbfs superblock where the "quota" limits are stored may have been freed. Andrew Barry proposed a patch to fix this by having hugepages, instead of storing a pointer to their address_space and reaching the superblock from there, had the hugepages store pointers directly to the superblock, bumping the reference count as appropriate to avoid it being freed. Andrew Morton rejected that version, however, on the grounds that it made the existing layering violation worse. This is a reworked version of Andrew's patch, which removes the extra, and some of the existing, layering violation. It works by introducing the concept of a hugepage "subpool" at the lower hugepage mm layer - that is a finite logical pool of hugepages to allocate from. hugetlbfs now creates a subpool for each filesystem instance with a page limit set, and a pointer to the subpool gets added to each allocated hugepage, instead of the address_space pointer used now. The subpool has its own lifetime and is only freed once all pages in it _and_ all other references to it (i.e. superblocks) are gone. subpools are optional - a NULL subpool pointer is taken by the code to mean that no subpool limits are in effect. Previous discussion of this bug found in: "Fix refcounting in hugetlbfs quota handling.". See: https://lkml.org/lkml/2011/8/11/28 or http://marc.info/?l=linux-mm&m=126928970510627&w=1 v2: Fixed a bug spotted by Hillf Danton, and removed the extra parameter to alloc_huge_page() - since it already takes the vma, it is not necessary. Signed-off-by: Andrew Barry <abarry@cray.com> Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlb: cleanup hugetlb.hDavid Gibson
Make a couple of small cleanups to linux/include/hugetlb.h. The set_file_hugepages() function, which was not used anywhere is removed, and the hugetlbfs_config and hugetlbfs_inode_info structures with its HUGETLBFS_I helper function are moved into inode.c, the only place they were used. These structures are really linked to the hugetlbfs filesystem specifically not to hugepage mm handling in general, so they belong in the filesystem code not in a generally available header. It would be nice to move the hugetlbfs_sb_info (superblock) structure in there as well, but it's currently needed in a number of places via the hstate_vma() and hstate_inode(). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: Hugh Dickins <hughd@google.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Andrew Barry <abarry@cray.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Hillf Danton <dhillf@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlbfs: avoid taking i_mutex from hugetlbfs_read()Aneesh Kumar K.V
Taking i_mutex in hugetlbfs_read() can result in deadlock with mmap as explained below Thread A: read() on hugetlbfs hugetlbfs_read() called i_mutex grabbed hugetlbfs_read_actor() called __copy_to_user() called page fault is triggered Thread B, sharing address space with A: mmap() the same file ->mmap_sem is grabbed on task_B->mm->mmap_sem hugetlbfs_file_mmap() is called attempt to grab ->i_mutex and block waiting for A to give it up Thread A: pagefault handled blocked on attempt to grab task_A->mm->mmap_sem, which happens to be the same thing as task_B->mm->mmap_sem. Block waiting for B to give it up. AFAIU the i_mutex locking was added to hugetlbfs_read() as per http://lkml.indiana.edu/hypermail/linux/kernel/0707.2/3066.html to take care of the race between truncate and read. This patch fixes this by looking at page->mapping under lock_page() (find_lock_page()) to ensure that the inode didn't get truncated in the range during a parallel read. Ideally we can extend the patch to make sure we don't increase i_size in mmap. But that will break userspace, because applications will now have to use truncate(2) to increase i_size in hugetlbfs. Based on the original patch from Hillf Danton. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@kernel.org> [everything after 2007 :)] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-21hugetlbfs: fix hugetlb_get_unmapped_area()Xiao Guangrong
Use/update cached_hole_size and free_area_cache properly to speedup finding of a free region. Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-12mm: compaction: introduce sync-light migration for use by compactionMel Gorman
This patch adds a lightweight sync migrate operation MIGRATE_SYNC_LIGHT mode that avoids writing back pages to backing storage. Async compaction maps to MIGRATE_ASYNC while sync compaction maps to MIGRATE_SYNC_LIGHT. For other migrate_pages users such as memory hotplug, MIGRATE_SYNC is used. This avoids sync compaction stalling for an excessive length of time, particularly when copying files to a USB stick where there might be a large number of dirty pages backed by a filesystem that does not support ->writepages. [aarcange@redhat.com: This patch is heavily based on Andrea's work] [akpm@linux-foundation.org: fix fs/nfs/write.c build] [akpm@linux-foundation.org: fix fs/btrfs/disk-io.c build] Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm: compaction: determine if dirty pages can be migrated without blocking ↵Mel Gorman
within ->migratepage Asynchronous compaction is used when allocating transparent hugepages to avoid blocking for long periods of time. Due to reports of stalling, there was a debate on disabling synchronous compaction but this severely impacted allocation success rates. Part of the reason was that many dirty pages are skipped in asynchronous compaction by the following check; if (PageDirty(page) && !sync && mapping->a_ops->migratepage != migrate_page) rc = -EBUSY; This skips over all mapping aops using buffer_migrate_page() even though it is possible to migrate some of these pages without blocking. This patch updates the ->migratepage callback with a "sync" parameter. It is the responsibility of the callback to fail gracefully if migration would block. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: Andy Isaacson <adi@hexapodia.org> Cc: Nai Xia <nai.xia@gmail.com> Cc: Johannes Weiner <jweiner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-03hugetlbfs: propagate umode_tAl Viro
2012-01-03hugetlbfs: switch to inode_init_owner()Al Viro
... rather than open-coding it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-25lockdep: Add helper function for dir vs file i_mutex annotationJosh Boyer
Purely in-memory filesystems do not use the inode hash as the dcache tells us if an entry already exists. As a result, they do not call unlock_new_inode, and thus directory inodes do not get put into a different lockdep class for i_sem. We need the different lockdep classes, because the locking order for i_mutex is different for directory inodes and regular inodes. Directory inodes can do "readdir()", which takes i_mutex *before* possibly taking mm->mmap_sem (due to a page fault while copying the directory entry to user space). In contrast, regular inodes can be mmap'ed, which takes mm->mmap_sem before accessing i_mutex. The two cases can never happen for the same inode, so no real deadlock can occur, but without the different lockdep classes, lockdep cannot understand that. As a result, if CONFIG_DEBUG_LOCK_ALLOC is set, this can lead to false positives from lockdep like below: find/645 is trying to acquire lock: (&mm->mmap_sem){++++++}, at: [<ffffffff81109514>] might_fault+0x5c/0xac but task is already holding lock: (&sb->s_type->i_mutex_key#15){+.+.+.}, at: [<ffffffff81149f34>] vfs_readdir+0x5b/0xb4 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#15){+.+.+.}: [<ffffffff8108ac26>] lock_acquire+0xbf/0x103 [<ffffffff814db822>] __mutex_lock_common+0x4c/0x361 [<ffffffff814dbc46>] mutex_lock_nested+0x40/0x45 [<ffffffff811daa87>] hugetlbfs_file_mmap+0x82/0x110 [<ffffffff81111557>] mmap_region+0x258/0x432 [<ffffffff811119dd>] do_mmap_pgoff+0x2ac/0x306 [<ffffffff81111b4f>] sys_mmap_pgoff+0x118/0x16a [<ffffffff8100c858>] sys_mmap+0x22/0x24 [<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b -> #0 (&mm->mmap_sem){++++++}: [<ffffffff8108a4bc>] __lock_acquire+0xa1a/0xcf7 [<ffffffff8108ac26>] lock_acquire+0xbf/0x103 [<ffffffff81109541>] might_fault+0x89/0xac [<ffffffff81149cff>] filldir+0x6f/0xc7 [<ffffffff811586ea>] dcache_readdir+0x67/0x205 [<ffffffff81149f54>] vfs_readdir+0x7b/0xb4 [<ffffffff8114a073>] sys_getdents+0x7e/0xd1 [<ffffffff814e3ec2>] system_call_fastpath+0x16/0x1b This patch moves the directory vs file lockdep annotation into a helper function that can be called by in-memory filesystems and has hugetlbfs call it. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25fs/hugetlbfs/inode.c: fix pgoff alignment checking on 32-bitBecky Bruce
This: vma->vm_pgoff & ~(huge_page_mask(h) >> PAGE_SHIFT) is incorrect on 32-bit. It causes us to & the pgoff with something that looks like this (for a 4m hugepage): 0xfff003ff. The mask should be flipped and *then* shifted, to give you 0x0000_03fff. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24VFS : mount lock scalability for internal mountsTim Chen
For a number of file systems that don't have a mount point (e.g. sockfs and pipefs), they are not marked as long term. Therefore in mntput_no_expire, all locks in vfs_mount lock are taken instead of just local cpu's lock to aggregate reference counts when we release reference to file objects. In fact, only local lock need to have been taken to update ref counts as these file systems are in no danger of going away until we are ready to unregister them. The attached patch marks file systems using kern_mount without mount point as long term. The contentions of vfs_mount lock is now eliminated. Before un-registering such file system, kern_unmount should be called to remove the long term flag and make the mount point ready to be freed. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26mm: don't access vm_flags as 'int'KOSAKI Motohiro
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor 'unsigned int'. This patch fixes such misuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> [ Changed to use a typedef - we'll extend it to cover more cases later, since there has been discussion about making it a 64-bit type.. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: Convert i_mmap_lock to a mutexPeter Zijlstra
Straightforward conversion of i_mmap_lock to a mutex. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: hugetlbfs: change remove_from_page_cacheMinchan Kim
This patch series changes remove_from_page_cache()'s page ref counting rule. Page cache ref count is decreased in delete_from_page_cache(). So we don't need to decrease the page reference in callers. Signed-off-by: Minchan Kim <minchan.kim@gmail.com> Cc: William Irwin <wli@holomorphy.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-11-12hugetlbfs: lessen the impact of a deprecation warningDave Jones
WARN_ONCE is a bit strong for a deprecation warning, given that it spews a huge backtrace. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (22 commits) Add _addr_lsb field to ia64 siginfo Fix migration.c compilation on s390 HWPOISON: Remove retry loop for try_to_unmap HWPOISON: Turn addr_valid from bitfield into char HWPOISON: Disable DEBUG by default HWPOISON: Convert pr_debugs to pr_info HWPOISON: Improve comments in memory-failure.c x86: HWPOISON: Report correct address granuality for huge hwpoison faults Encode huge page size for VM_FAULT_HWPOISON errors Fix build error with !CONFIG_MIGRATION hugepage: move is_hugepage_on_freelist inside ifdef to avoid warning Clean up __page_set_anon_rmap HWPOISON, hugetlb: fix unpoison for hugepage HWPOISON, hugetlb: soft offlining for hugepage HWPOSION, hugetlb: recover from free hugepage error when !MF_COUNT_INCREASED hugetlb: move refcounting in hugepage allocation inside hugetlb_lock HWPOISON, hugetlb: add free check to dequeue_hwpoison_huge_page() hugetlb: hugepage migration core hugetlb: redefine hugepage copy functions hugetlb: add allocate function for hugepage migration ...
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-08hugetlb: hugepage migration coreNaoya Horiguchi
This patch extends page migration code to support hugepage migration. One of the potential users of this feature is soft offlining which is triggered by memory corrected errors (added by the next patch.) Todo: - there are other users of page migration such as memory policy, memory hotplug and memocy compaction. They are not ready for hugepage support for now. ChangeLog since v4: - define migrate_huge_pages() - remove changes on isolation/putback_lru_page() ChangeLog since v2: - refactor isolate/putback_lru_page() to handle hugepage - add comment about race on unmap_and_move_huge_page() ChangeLog since v1: - divide migration code path for hugepage - define routine checking migration swap entry for hugetlb - replace "goto" with "if/else" in remove_migration_pte() Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-08-09new helper: end_writeback()Al Viro
Essentially, the minimal variant of ->evict_inode(). It's a trimmed-down clear_inode(), sans any fs callbacks. Once it returns we know that no async writeback will be happening; every ->evict_inode() instance should do that once and do that before doing anything ->write_inode() could interfere with (e.g. freeing the on-disk inode). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09switch hugetlbfs to ->evict_inode()Al Viro
The first spoils - hugetlb can use default ->drop_inode() now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Untangling ima mess, part 1: alloc_file()Al Viro
There are 2 groups of alloc_file() callers: * ones that are followed by ima_counts_get * ones giving non-regular files So let's pull that ima_counts_get() into alloc_file(); it's a no-op in case of non-regular files. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: truncate: use new helpers truncate: new helpers fs: fix overflow in sys_mount() for in-kernel calls fs: Make unload_nls() NULL pointer safe freeze_bdev: grab active reference to frozen superblocks freeze_bdev: kill bd_mount_sem exofs: remove BKL from super operations fs/romfs: correct error-handling code vfs: seq_file: add helpers for data filling vfs: remove redundant position check in do_sendfile vfs: change sb->s_maxbytes to a loff_t vfs: explicitly cast s_maxbytes in fiemap_check_ranges libfs: return error code on failed attr set seq_file: return a negative error code when seq_path_root() fails. vfs: optimize touch_time() too vfs: optimization for touch_atime() vfs: split generic_forget_inode() so that hugetlbfs does not have to copy it fs/inode.c: add dev-id and inode number for debugging in init_special_inode() libfs: make simple_read_from_buffer conventional
2009-09-24hugetlbfs: do not call user_shm_lock() for MAP_HUGETLB fixFrom: Mel Gorman
Commit 6bfde05bf5c ("hugetlbfs: allow the creation of files suitable for MAP_PRIVATE on the vfs internal mount") altered can_do_hugetlb_shm() to check if a file is being created for shared memory or mmap(). If this returns false, we then unconditionally call user_shm_lock() triggering a warning. This block should never be entered for MAP_HUGETLB. This patch partially reverts the problem and fixes the check. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24vfs: split generic_forget_inode() so that hugetlbfs does not have to copy itJan Kara
Hugetlbfs needs to do special things instead of truncate_inode_pages(). Currently, it copied generic_forget_inode() except for truncate_inode_pages() call which is asking for trouble (the code there isn't trivial). So create a separate function generic_detach_inode() which does all the list magic done in generic_forget_inode() and call it from hugetlbfs_forget_inode(). Signed-off-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22hugetlbfs: allow the creation of files suitable for MAP_PRIVATE on the vfs ↵Eric B Munson
internal mount This patchset adds a flag to mmap that allows the user to request that an anonymous mapping be backed with huge pages. This mapping will borrow functionality from the huge page shm code to create a file on the kernel internal mount and use it to approximate an anonymous mapping. The MAP_HUGETLB flag is a modifier to MAP_ANONYMOUS and will not work without both flags being preset. A new flag is necessary because there is no other way to hook into huge pages without creating a file on a hugetlbfs mount which wouldn't be MAP_ANONYMOUS. To userspace, this mapping will behave just like an anonymous mapping because the file is not accessible outside of the kernel. This patchset is meant to simplify the programming model. Presently there is a large chunk of boiler platecode, contained in libhugetlbfs, required to create private, hugepage backed mappings. This patch set would allow use of hugepages without linking to libhugetlbfs or having hugetblfs mounted. Unification of the VM code would provide these same benefits, but it has been resisted each time that it has been suggested for several reasons: it would break PAGE_SIZE assumptions across the kernel, it makes page-table abstractions really expensive, and it does not provide any benefit on architectures that do not support huge pages, incurring fast path penalties without providing any benefit on these architectures. This patch: There are two means of creating mappings backed by huge pages: 1. mmap() a file created on hugetlbfs 2. Use shm which creates a file on an internal mount which essentially maps it MAP_SHARED The internal mount is only used for shared mappings but there is very little that stops it being used for private mappings. This patch extends hugetlbfs_file_setup() to deal with the creation of files that will be mapped MAP_PRIVATE on the internal hugetlbfs mount. This extended API is used in a subsequent patch to implement the MAP_HUGETLB mmap() flag. Signed-off-by: Eric Munson <ebmunson@us.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-24mm: fix hugetlb bug due to user_shm_unlock callHugh Dickins
2.6.30's commit 8a0bdec194c21c8fdef840989d0d7b742bb5d4bc removed user_shm_lock() calls in hugetlb_file_setup() but left the user_shm_unlock call in shm_destroy(). In detail: Assume that can_do_hugetlb_shm() returns true and hence user_shm_lock() is not called in hugetlb_file_setup(). However, user_shm_unlock() is called in any case in shm_destroy() and in the following atomic_dec_and_lock(&up->__count) in free_uid() is executed and if up->__count gets zero, also cleanup_user_struct() is scheduled. Note that sched_destroy_user() is empty if CONFIG_USER_SCHED is not set. However, the ref counter up->__count gets unexpectedly non-positive and the corresponding structs are freed even though there are live references to them, resulting in a kernel oops after a lots of shmget(SHM_HUGETLB)/shmctl(IPC_RMID) cycles and CONFIG_USER_SCHED set. Hugh changed Stefan's suggested patch: can_do_hugetlb_shm() at the time of shm_destroy() may give a different answer from at the time of hugetlb_file_setup(). And fixed newseg()'s no_id error path, which has missed user_shm_unlock() ever since it came in 2.6.9. Reported-by: Stefan Huber <shuber2@gmail.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Tested-by: Stefan Huber <shuber2@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-22Merge branch 'master' into nextJames Morris
Conflicts: fs/exec.c Removed IMA changes (the IMA checks are now performed via may_open()). Signed-off-by: James Morris <jmorris@namei.org>
2009-05-22integrity: move ima_counts_getMimi Zohar
Based on discussion on lkml (Andrew Morton and Eric Paris), move ima_counts_get down a layer into shmem/hugetlb__file_setup(). Resolves drm shmem_file_setup() usage case as well. HD comment: I still think you're doing this at the wrong level, but recognize that you probably won't be persuaded until a few more users of alloc_file() emerge, all wanting your ima_counts_get(). Resolving GEM's shmem_file_setup() is an improvement, so I'll say Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
