commit 8019ad13ef7f64be44d4f892af9c840179009254 upstream.
As reported by Jann, ihold() does not in fact guarantee inode
persistence. And instead of making it so, replace the usage of inode
pointers with a per boot, machine wide, unique inode identifier.
This sequence number is global, but shared (file backed) futexes are
rare enough that this should not become a performance issue.
Reported-by: Jann Horn <jannh@google.com>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit f69e749a49353d96af1a293f56b5b56de59c668a upstream.
file_remove_privs() might be called for non-regular files, e.g.
blkdev inode. There is no reason to do its job on things
like blkdev inodes, pipes, or cdevs. Hence, abort if
file does not refer to a regular inode.
AV: more to the point, for devices there might be any number of
inodes refering to given device. Which one to strip the permissions
from, even if that made any sense in the first place? All of them
will be observed with contents modified, after all.
Found by LockDoc (Alexander Lochmann, Horst Schirmeier and Olaf
Spinczyk)
Signed-off-by: Alexander Lochmann <alexander.lochmann@tu-dortmund.de>
Signed-off-by: Horst Schirmeier <horst.schirmeier@tu-dortmund.de>
Cc: Zubin Mithra <zsm@chromium.org>
commit 0fa3ecd87848c9c93c2c828ef4c3a8ca36ce46c7 upstream.
sgid directories have special semantics, making newly created files in
the directory belong to the group of the directory, and newly created
subdirectories will also become sgid. This is historically used for
group-shared directories.
But group directories writable by non-group members should not imply
that such non-group members can magically join the group, so make sure
to clear the sgid bit on non-directories for non-members (but remember
that sgid without group execute means "mandatory locking", just to
confuse things even more).
commit 799ea9e9c59949008770aab4e1da87f10e99dbe4 upstream.
When we introduced the bmap redo log items, we set MS_ACTIVE on the
mountpoint and XFS_IRECOVERY on the inode to prevent unlinked inodes
from being truncated prematurely during log recovery. This also had the
effect of putting linked inodes on the lru instead of evicting them.
Unfortunately, we neglected to find all those unreferenced lru inodes
and evict them after finishing log recovery, which means that we leak
them if anything goes wrong in the rest of xfs_mountfs, because the lru
is only cleaned out on unmount.
Therefore, evict unreferenced inodes in the lru list immediately
after clearing MS_ACTIVE.
Fixes: 17c12bcd30 ("xfs: when replaying bmap operations, don't let unlinked inodes get reaped")
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Cc: viro@ZenIV.linux.org.uk
Reviewed-by: Brian Foster <bfoster@redhat.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
The IOP_XATTR inode operations flag in inode->i_opflags indicates that
the inode has xattr support. The flag is automatically set by
new_inode() on filesystems with xattr support (where sb->s_xattr is
defined), and cleared otherwise. Filesystems can explicitly clear it
for inodes that should not have xattr support.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
current_fs_time() is used for inode timestamps.
Change the signature of the function to take inode pointer
instead of superblock as per Linus's suggestion.
Also, move the api under vfs as per the discussion on the
thread: https://lkml.org/lkml/2016/6/9/36 . As per Arnd's
suggestion on the thread, changing the function name.
current_fs_time() will be deleted after all the references
to it are replaced by current_time().
There was a bug reported by kbuild test bot with the change
as some of the calls to current_time() were made before the
super_block was initialized. Catch these accidental assignments
as timespec_trunc() does for wrong granularities. This allows
for the function to work right even in these circumstances.
But, adds a warning to make the user aware of the bug.
A coccinelle script was used to identify all the current
.alloc_inode super_block callbacks that updated inode timestamps.
proc filesystem was the only one that was modifying inode times
as part of this callback. The series includes a patch to fix that.
Note that timespec_trunc() will also be moved to fs/inode.c
in a separate patch when this will need to be revamped for
bounds checking purposes.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
On overlayfs relatime_need_update() needs inode times to be correct on
overlay inode. But i_mtime and i_ctime are updated by filesystem code on
underlying inode only, so they will be out-of-date on the overlay inode.
This patch copies the times from the underlying inode if needed. This
can't be done if called from RCU lookup (link following) but link m/ctime
are not updated by fs, so this is all right.
This patch doesn't change functionality for anything but overlayfs.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
"Assorted cleanups and fixes.
In the "trivial API change" department - ->d_compare() losing 'parent'
argument"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
cachefiles: Fix race between inactivating and culling a cache object
9p: use clone_fid()
9p: fix braino introduced in "9p: new helper - v9fs_parent_fid()"
vfs: make dentry_needs_remove_privs() internal
vfs: remove file_needs_remove_privs()
vfs: fix deadlock in file_remove_privs() on overlayfs
get rid of 'parent' argument of ->d_compare()
cifs, msdos, vfat, hfs+: don't bother with parent in ->d_compare()
affs ->d_compare(): don't bother with ->d_inode
fold _d_rehash() and __d_rehash() together
fold dentry_rcuwalk_invalidate() into its only remaining caller
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into for-linus
Only used by the vfs.
file_remove_privs() is called with inode lock on file_inode(), which
proceeds to calling notify_change() on file->f_path.dentry. Which triggers
the WARN_ON_ONCE(!inode_is_locked(inode)) in addition to deadlocking later
when ovl_setattr tries to lock the underlying inode again.
Fix this mess by not mixing the layers, but doing everything on underlying
dentry/inode.
Fixes: 07a2daab49c5 ("ovl: Copy up underlying inode's ->i_mode to overlay inode")
Cc: <stable@vger.kernel.org>
Radix trees may be used not only for storing page cache pages, so
unconditionally accounting radix tree nodes to the current memory cgroup
is bad: if a radix tree node is used for storing data shared among
different cgroups we risk pinning dead memory cgroups forever.
So let's only account radix tree nodes if it was explicitly requested by
passing __GFP_ACCOUNT to INIT_RADIX_TREE. Currently, we only want to
account page cache entries, so mark mapping->page_tree so.
Fixes: 58e698af4c63 ("radix-tree: account radix_tree_node to memory cgroup")
Link: http://lkml.kernel.org/r/1470057188-7864-1-git-send-email-vdavydov@virtuozzo.com
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: <stable@vger.kernel.org> [4.6+]
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull userns vfs updates from Eric Biederman:
"This tree contains some very long awaited work on generalizing the
user namespace support for mounting filesystems to include filesystems
with a backing store. The real world target is fuse but the goal is
to update the vfs to allow any filesystem to be supported. This
patchset is based on a lot of code review and testing to approach that
goal.
While looking at what is needed to support the fuse filesystem it
became clear that there were things like xattrs for security modules
that needed special treatment. That the resolution of those concerns
would not be fuse specific. That sorting out these general issues
made most sense at the generic level, where the right people could be
drawn into the conversation, and the issues could be solved for
everyone.
At a high level what this patchset does a couple of simple things:
- Add a user namespace owner (s_user_ns) to struct super_block.
- Teach the vfs to handle filesystem uids and gids not mapping into
to kuids and kgids and being reported as INVALID_UID and
INVALID_GID in vfs data structures.
By assigning a user namespace owner filesystems that are mounted with
only user namespace privilege can be detected. This allows security
modules and the like to know which mounts may not be trusted. This
also allows the set of uids and gids that are communicated to the
filesystem to be capped at the set of kuids and kgids that are in the
owning user namespace of the filesystem.
One of the crazier corner casees this handles is the case of inodes
whose i_uid or i_gid are not mapped into the vfs. Most of the code
simply doesn't care but it is easy to confuse the inode writeback path
so no operation that could cause an inode write-back is permitted for
such inodes (aka only reads are allowed).
This set of changes starts out by cleaning up the code paths involved
in user namespace permirted mounts. Then when things are clean enough
adds code that cleanly sets s_user_ns. Then additional restrictions
are added that are possible now that the filesystem superblock
contains owner information.
These changes should not affect anyone in practice, but there are some
parts of these restrictions that are changes in behavior.
- Andy's restriction on suid executables that does not honor the
suid bit when the path is from another mount namespace (think
/proc/[pid]/fd/) or when the filesystem was mounted by a less
privileged user.
- The replacement of the user namespace implicit setting of MNT_NODEV
with implicitly setting SB_I_NODEV on the filesystem superblock
instead.
Using SB_I_NODEV is a stronger form that happens to make this state
user invisible. The user visibility can be managed but it caused
problems when it was introduced from applications reasonably
expecting mount flags to be what they were set to.
There is a little bit of work remaining before it is safe to support
mounting filesystems with backing store in user namespaces, beyond
what is in this set of changes.
- Verifying the mounter has permission to read/write the block device
during mount.
- Teaching the integrity modules IMA and EVM to handle filesystems
mounted with only user namespace root and to reduce trust in their
security xattrs accordingly.
- Capturing the mounters credentials and using that for permission
checks in d_automount and the like. (Given that overlayfs already
does this, and we need the work in d_automount it make sense to
generalize this case).
Furthermore there are a few changes that are on the wishlist:
- Get all filesystems supporting posix acls using the generic posix
acls so that posix_acl_fix_xattr_from_user and
posix_acl_fix_xattr_to_user may be removed. [Maintainability]
- Reducing the permission checks in places such as remount to allow
the superblock owner to perform them.
- Allowing the superblock owner to chown files with unmapped uids and
gids to something that is mapped so the files may be treated
normally.
I am not considering even obvious relaxations of permission checks
until it is clear there are no more corner cases that need to be
locked down and handled generically.
Many thanks to Seth Forshee who kept this code alive, and putting up
with me rewriting substantial portions of what he did to handle more
corner cases, and for his diligent testing and reviewing of my
changes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (30 commits)
fs: Call d_automount with the filesystems creds
fs: Update i_[ug]id_(read|write) to translate relative to s_user_ns
evm: Translate user/group ids relative to s_user_ns when computing HMAC
dquot: For now explicitly don't support filesystems outside of init_user_ns
quota: Handle quota data stored in s_user_ns in quota_setxquota
quota: Ensure qids map to the filesystem
vfs: Don't create inodes with a uid or gid unknown to the vfs
vfs: Don't modify inodes with a uid or gid unknown to the vfs
cred: Reject inodes with invalid ids in set_create_file_as()
fs: Check for invalid i_uid in may_follow_link()
vfs: Verify acls are valid within superblock's s_user_ns.
userns: Handle -1 in k[ug]id_has_mapping when !CONFIG_USER_NS
fs: Refuse uid/gid changes which don't map into s_user_ns
selinux: Add support for unprivileged mounts from user namespaces
Smack: Handle labels consistently in untrusted mounts
Smack: Add support for unprivileged mounts from user namespaces
fs: Treat foreign mounts as nosuid
fs: Limit file caps to the user namespace of the super block
userns: Remove the now unnecessary FS_USERNS_DEV_MOUNT flag
userns: Remove implicit MNT_NODEV fragility.
wait_sb_inodes() currently does a walk of all inodes in the filesystem
to find dirty one to wait on during sync. This is highly inefficient
and wastes a lot of CPU when there are lots of clean cached inodes that
we don't need to wait on.
To avoid this "all inode" walk, we need to track inodes that are
currently under writeback that we need to wait for. We do this by
adding inodes to a writeback list on the sb when the mapping is first
tagged as having pages under writeback. wait_sb_inodes() can then walk
this list of "inodes under IO" and wait specifically just for the inodes
that the current sync(2) needs to wait for.
Define a couple helpers to add/remove an inode from the writeback list
and call them when the overall mapping is tagged for or cleared from
writeback. Update wait_sb_inodes() to walk only the inodes under
writeback due to the sync.
With this change, filesystem sync times are significantly reduced for
fs' with largely populated inode caches and otherwise no other work to
do. For example, on a 16xcpu 2GHz x86-64 server, 10TB XFS filesystem
with a ~10m entry inode cache, sync times are reduced from ~7.3s to less
than 0.1s when the filesystem is fully clean.
Link: http://lkml.kernel.org/r/1466594593-6757-2-git-send-email-bfoster@redhat.com
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: Brian Foster <bfoster@redhat.com>
Tested-by: Holger Hoffstätte <holger.hoffstaette@applied-asynchrony.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
When a filesystem outside of init_user_ns is mounted it could have
uids and gids stored in it that do not map to init_user_ns.
The plan is to allow those filesystems to set i_uid to INVALID_UID and
i_gid to INVALID_GID for unmapped uids and gids and then to handle
that strange case in the vfs to ensure there is consistent robust
handling of the weirdness.
Upon a careful review of the vfs and filesystems about the only case
where there is any possibility of confusion or trouble is when the
inode is written back to disk. In that case filesystems typically
read the inode->i_uid and inode->i_gid and write them to disk even
when just an inode timestamp is being updated.
Which leads to a rule that is very simple to implement and understand
inodes whose i_uid or i_gid is not valid may not be written.
In dealing with access times this means treat those inodes as if the
inode flag S_NOATIME was set. Reads of the inodes appear safe and
useful, but any write or modification is disallowed. The only inode
write that is allowed is a chown that sets the uid and gid on the
inode to valid values. After such a chown the inode is normal and may
be treated as such.
Denying all writes to inodes with uids or gids unknown to the vfs also
prevents several oddball cases where corruption would have occurred
because the vfs does not have complete information.
One problem case that is prevented is attempting to use the gid of a
directory for new inodes where the directories sgid bit is set but the
directories gid is not mapped.
Another problem case avoided is attempting to update the evm hash
after setxattr, removexattr, and setattr. As the evm hash includeds
the inode->i_uid or inode->i_gid not knowning the uid or gid prevents
a correct evm hash from being computed. evm hash verification also
fails when i_uid or i_gid is unknown but that is essentially harmless
as it does not cause filesystem corruption.
Acked-by: Seth Forshee <seth.forshee@canonical.com>
If one thread does iget_locked(), proceeds to try and set
the new inode up and fails, inode will be unhashed and dropped.
However, another thread doing ilookup/iget_locked in the middle
of that would end up finding a half-set-up inode, grabbing
a reference, waiting for it to come unlocked and getting the
resulting bad inode. It's a race (if that ilookup had been
called just after the failure of setup attempt it wouldn't
have found the sucker at all), particularly unpleasant in
cases when failure is transient/caller-dependent/etc.
While it can be dealt with in the callers, there's no reason
not to handle it in fs/inode.c primitives, especially since
the cost is trivial.
ta-da!
The main issue is the lack of down_write_killable(), so the places
like readdir.c switched to plain inode_lock(); once killable
variants of rwsem primitives appear, that'll be dealt with.
lockdep side also might need more work
We'll need to verify that there's neither a hashed nor in-lookup
dentry with desired parent/name before adding to in-lookup set.
One possible solution would be to hold the parent's ->d_lock through
both checks, but while the in-lookup set is relatively small at any
time, dcache is not. And holding the parent's ->d_lock through
something like __d_lookup_rcu() would suck too badly.
So we leave the parent's ->d_lock alone, which means that we watch
out for the following scenario:
* we verify that there's no hashed match
* existing in-lookup match gets hashed by another process
* we verify that there's no in-lookup matches and decide
that everything's fine.
Solution: per-directory kinda-sorta seqlock, bumped around the times
we hash something that used to be in-lookup or move (and hash)
something in place of in-lookup. Then the above would turn into
* read the counter
* do dcache lookup
* if no matches found, check for in-lookup matches
* if there had been none of those either, check if the
counter has changed; repeat if it has.
The "kinda-sorta" part is due to the fact that we don't have much spare
space in inode. There is a spare word (shared with i_bdev/i_cdev/i_pipe),
so the counter part is not a problem, but spinlock is a different story.
We could use the parent's ->d_lock, and it would be less painful in
terms of contention, for __d_add() it would be rather inconvenient to
grab; we could do that (using lock_parent()), but...
Fortunately, we can get serialization on the counter itself, and it
might be a good idea in general; we can use cmpxchg() in a loop to
get from even to odd and smp_store_release() from odd to even.
This commit adds the counter and updating logics; the readers will be
added in the next commit.
When get_acl() is called for an inode whose ACL is not cached yet, the
get_acl inode operation is called to fetch the ACL from the filesystem.
The inode operation is responsible for updating the cached acl with
set_cached_acl(). This is done without locking at the VFS level, so
another task can call set_cached_acl() or forget_cached_acl() before the
get_acl inode operation gets to calling set_cached_acl(), and then
get_acl's call to set_cached_acl() results in caching an outdate ACL.
Prevent this from happening by setting the cached ACL pointer to a
task-specific sentinel value before calling the get_acl inode operation.
Move the responsibility for updating the cached ACL from the get_acl
inode operations to get_acl(). There, only set the cached ACL if the
sentinel value hasn't changed.
The sentinel values are chosen to have odd values. Likewise, the value
of ACL_NOT_CACHED is odd. In contrast, ACL object pointers always have
an even value (ACLs are aligned in memory). This allows to distinguish
uncached ACLs values from ACL objects.
In addition, switch from guarding inode->i_acl and inode->i_default_acl
upates by the inode->i_lock spinlock to using xchg() and cmpxchg().
Filesystems that do not want ACLs returned from their get_acl inode
operations to be cached must call forget_cached_acl() to prevent the VFS
from doing so.
(Patch written by Al Viro and Andreas Gruenbacher.)
inode struct members that track cgroup writeback information
should be reinitialized when inode gets allocated from
kmem_cache. Otherwise, their values remain and get used by the
new inode.
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
Fixes: d10c80955265 ("writeback: implement foreign cgroup inode bdi_writeback switching")
Signed-off-by: Jens Axboe <axboe@fb.com>
Pull final vfs updates from Al Viro:
- The ->i_mutex wrappers (with small prereq in lustre)
- a fix for too early freeing of symlink bodies on shmem (they need to
be RCU-delayed) (-stable fodder)
- followup to dedupe stuff merged this cycle
vfs: abort dedupe loop if fatal signals are pending
make sure that freeing shmem fast symlinks is RCU-delayed
wrappers for ->i_mutex access
lustre: remove unused declaration
Add support for tracking dirty DAX entries in the struct address_space
radix tree. This tree is already used for dirty page writeback, and it
already supports the use of exceptional (non struct page*) entries.
In order to properly track dirty DAX pages we will insert new
exceptional entries into the radix tree that represent dirty DAX PTE or
PMD pages. These exceptional entries will also contain the writeback
addresses for the PTE or PMD faults that we can use at fsync/msync time.
There are currently two types of exceptional entries (shmem and shadow)
that can be placed into the radix tree, and this adds a third. We rely
on the fact that only one type of exceptional entry can be found in a
given radix tree based on its usage. This happens for free with DAX vs
shmem but we explicitly prevent shadow entries from being added to radix
trees for DAX mappings.
The only shadow entries that would be generated for DAX radix trees
would be to track zero page mappings that were created for holes. These
pages would receive minimal benefit from having shadow entries, and the
choice to have only one type of exceptional entry in a given radix tree
makes the logic simpler both in clear_exceptional_entry() and in the
rest of DAX.
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jan Kara <jack@suse.com>
Cc: Jeff Layton <jlayton@poochiereds.net>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Pull file locking updates from Jeff Layton:
"File locking related changes for v4.5 (pile #1)
Highlights:
- new Kconfig option to allow disabling mandatory locking (which is
racy anyway)
- new tracepoints for setlk and close codepaths
- fix for a long-standing bug in code that handles races between
setting a POSIX lock and close()"
* tag 'locks-v4.5-1' of git://git.samba.org/jlayton/linux:
locks: rename __posix_lock_file to posix_lock_inode
locks: prink more detail when there are leaked locks
locks: pass inode pointer to locks_free_lock_context
locks: sprinkle some tracepoints around the file locking code
locks: don't check for race with close when setting OFD lock
locks: fix unlock when fcntl_setlk races with a close
fs: make locks.c explicitly non-modular
locks: use list_first_entry_or_null()
locks: Don't allow mounts in user namespaces to enable mandatory locking
locks: Allow disabling mandatory locking at compile time
...so we can print information about it if there are leaked locks.
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
kmap() in page_follow_link_light() needed to go - allowing to hold
an arbitrary number of kmaps for long is a great way to deadlocking
the system.
new helper (inode_nohighmem(inode)) needs to be used for pagecache
symlinks inodes; done for all in-tree cases. page_follow_link_light()
instrumented to yell about anything missed.
Fix kernel-doc warning in fs/inode.c:
../fs/inode.c:1606: warning: No description found for parameter 'inode'
On a box with a lot of ram (148gb) I can make the box softlockup after running
an fs_mark job that creates hundreds of millions of empty files. This is
because we never generate enough memory pressure to keep the number of inodes on
our unused list low, so when we go to unmount we have to evict ~100 million
inodes. This makes one processor a very unhappy person, so add a cond_resched()
in dispose_list() and if we need a resched when processing the s_inodes list do
that and run dispose_list() on what we've currently culled. Thanks,
There's a small consistency problem between the inode and writeback
naming. Writeback calls the "for IO" inode queues b_io and
b_more_io, but the inode calls these the "writeback list" or
i_wb_list. This makes it hard to an new "under writeback" list to
the inode, or call it an "under IO" list on the bdi because either
way we'll have writeback on IO and IO on writeback and it'll just be
confusing. I'm getting confused just writing this!
So, rename the inode "for IO" list variable to i_io_list so we can
add a new "writeback list" in a subsequent patch.
Tested-by: Dave Chinner <dchinner@redhat.com>
The process of reducing contention on per-superblock inode lists
starts with moving the locking to match the per-superblock inode
list. This takes the global lock out of the picture and reduces the
contention problems to within a single filesystem. This doesn't get
rid of contention as the locks still have global CPU scope, but it
does isolate operations on different superblocks form each other.
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
currently, get_next_ino() is able to create inodes with inode number = 0.
This have a bad impact in the filesystems relying in this function to generate
inode numbers.
While there is no problem at all in having inodes with number 0, userspace tools
which handle file management tasks can have problems handling these files, like
for example, the impossiblity of users to delete these files, since glibc will
ignore them. So, I believe the best way is kernel to avoid creating them.
This problem has been raised previously, but the old thread didn't have any
other update for a year+, and I've seen too many users hitting the same issue
regarding the impossibility to delete files while using filesystems relying on
this function. So, I'm starting the thread again, with the same patch
that I believe is enough to address this problem.
Signed-off-by: Carlos Maiolino <cmaiolino@redhat.com>
Pull cgroup writeback support from Jens Axboe:
"This is the big pull request for adding cgroup writeback support.
This code has been in development for a long time, and it has been
simmering in for-next for a good chunk of this cycle too. This is one
of those problems that has been talked about for at least half a
decade, finally there's a solution and code to go with it.
Also see last weeks writeup on LWN:
http://lwn.net/Articles/648292/"
* 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits)
writeback, blkio: add documentation for cgroup writeback support
vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB
writeback: do foreign inode detection iff cgroup writeback is enabled
v9fs: fix error handling in v9fs_session_init()
bdi: fix wrong error return value in cgwb_create()
buffer: remove unusued 'ret' variable
writeback: disassociate inodes from dying bdi_writebacks
writeback: add lockdep annotation to inode_to_wb()
writeback: use unlocked_inode_to_wb transaction in inode_congested()
writeback: implement unlocked_inode_to_wb transaction and use it for stat updates
writeback: implement [locked_]inode_to_wb_and_lock_list()
writeback: implement foreign cgroup inode detection
writeback: make writeback_control track the inode being written back
writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb()
mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use
writeback: implement memcg writeback domain based throttling
writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes
writeback: implement memcg wb_domain
writeback: update wb_over_bg_thresh() to use wb_domain aware operations
Comment in include/linux/security.h says that ->inode_killpriv() should
be called when setuid bit is being removed and that similar security
labels (in fact this applies only to file capabilities) should be
removed at this time as well. However we don't call ->inode_killpriv()
when we remove suid bit on truncate.
We fix the problem by calling ->inode_need_killpriv() and subsequently
->inode_killpriv() on truncate the same way as we do it on file write.
After this patch there's only one user of should_remove_suid() - ocfs2 -
and indeed it's buggy because it doesn't call ->inode_killpriv() on
write. However fixing it is difficult because of special locking
constraints.
Provide function telling whether file_remove_privs() will do anything.
Currently we only have should_remove_suid() and that does something
slightly different.
file_remove_suid() is a misnomer since it removes also file capabilities
stored in xattrs and sets S_NOSEC flag. Also should_remove_suid() tells
something else than whether file_remove_suid() call is necessary which
leads to bugs.
file_remove_suid() could mistakenly set S_NOSEC inode bit when root was
modifying the file. As a result following writes to the file by ordinary
user would avoid clearing suid or sgid bits.
Fix the bug by checking actual mode bits before setting S_NOSEC.
CC: stable@vger.kernel.org
For the planned cgroup writeback support, on each bdi
(backing_dev_info), each memcg will be served by a separate wb
(bdi_writeback). This patch updates bdi so that a bdi can host
multiple wbs (bdi_writebacks).
On the default hierarchy, blkcg implicitly enables memcg. This allows
using memcg's page ownership for attributing writeback IOs, and every
memcg - blkcg combination can be served by its own wb by assigning a
dedicated wb to each memcg. This means that there may be multiple
wb's of a bdi mapped to the same blkcg. As congested state is per
blkcg - bdi combination, those wb's should share the same congested
state. This is achieved by tracking congested state via
bdi_writeback_congested structs which are keyed by blkcg.
bdi->wb remains unchanged and will keep serving the root cgroup.
cgwb's (cgroup wb's) for non-root cgroups are created on-demand or
looked up while dirtying an inode according to the memcg of the page
being dirtied or current task. Each cgwb is indexed on bdi->cgwb_tree
by its memcg id. Once an inode is associated with its wb, it can be
retrieved using inode_to_wb().
Currently, none of the filesystems has FS_CGROUP_WRITEBACK and all
pages will keep being associated with bdi->wb.
v3: inode_attach_wb() in account_page_dirtied() moved inside
mapping_cap_account_dirty() block where it's known to be !NULL.
Also, an unnecessary NULL check before kfree() removed. Both
detected by the kbuild bot.
v2: Updated so that wb association is per inode and wb is per memcg
rather than blkcg.
Cc: kbuild test robot <fengguang.wu@intel.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Jan Kara <jack@suse.cz>
touch_atime is not RCU-safe, and so cannot be called on an RCU walk.
However, in situations where RCU-walk makes a difference, the symlink
will likely to accessed much more often than it is useful to update
the atime.
So split out the test of "Does the atime actually need to be updated"
into atime_needs_update(), and have get_link() unlazy if it finds that
it will need to do that update.
Signed-off-by: NeilBrown <neilb@suse.de>
let "fast" symlinks store the pointer to the body into ->i_link and
use simple_follow_link for ->follow_link()
do_blockdev_direct_IO() increments and decrements the inode
->i_dio_count for each IO operation. It does this to protect against
truncate of a file. Block devices don't need this sort of protection.
For a capable multiqueue setup, this atomic int is the only shared
state between applications accessing the device for O_DIRECT, and it
presents a scaling wall for that. In my testing, as much as 30% of
system time is spent incrementing and decrementing this value. A mixed
read/write workload improved from ~2.5M IOPS to ~9.6M IOPS, with
better latencies too. Before:
clat percentiles (usec):
| 1.00th=[ 33], 5.00th=[ 34], 10.00th=[ 34], 20.00th=[ 34],
| 30.00th=[ 34], 40.00th=[ 34], 50.00th=[ 35], 60.00th=[ 35],
| 70.00th=[ 35], 80.00th=[ 35], 90.00th=[ 37], 95.00th=[ 80],
| 99.00th=[ 98], 99.50th=[ 151], 99.90th=[ 155], 99.95th=[ 155],
| 99.99th=[ 165]
After:
| 1.00th=[ 95], 5.00th=[ 108], 10.00th=[ 129], 20.00th=[ 149],
| 30.00th=[ 155], 40.00th=[ 161], 50.00th=[ 167], 60.00th=[ 171],
| 70.00th=[ 177], 80.00th=[ 185], 90.00th=[ 201], 95.00th=[ 270],
| 99.00th=[ 390], 99.50th=[ 398], 99.90th=[ 418], 99.95th=[ 422],
| 99.99th=[ 438]
In other setups, Robert Elliott reported seeing good performance
improvements:
https://lkml.org/lkml/2015/4/3/557
The more applications accessing the device, the worse it gets.
Add a new direct-io flags, DIO_SKIP_DIO_COUNT, which tells
do_blockdev_direct_IO() that it need not worry about incrementing
or decrementing the inode i_dio_count for this caller.
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Elliott, Robert (Server Storage) <elliott@hp.com>
these should be used on objects already in top layer
Pull lazytime mount option support from Al Viro:
"Lazytime stuff from tytso"
* 'lazytime' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
ext4: add optimization for the lazytime mount option
vfs: add find_inode_nowait() function
vfs: add support for a lazytime mount option
Merge third set of updates from Andrew Morton:
- the rest of MM
[ This includes getting rid of the numa hinting bits, in favor of
just generic protnone logic. Yay. - Linus ]
- core kernel
- procfs
- some of lib/ (lots of lib/ material this time)
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (104 commits)
lib/lcm.c: replace include
lib/percpu_ida.c: remove redundant includes
lib/strncpy_from_user.c: replace module.h include
lib/stmp_device.c: replace module.h include
lib/sort.c: move include inside #if 0
lib/show_mem.c: remove redundant include
lib/radix-tree.c: change to simpler include
lib/plist.c: remove redundant include
lib/nlattr.c: remove redundant include
lib/kobject_uevent.c: remove redundant include
lib/llist.c: remove redundant include
lib/md5.c: simplify include
lib/list_sort.c: rearrange includes
lib/genalloc.c: remove redundant include
lib/idr.c: remove redundant include
lib/halfmd4.c: simplify includes
lib/dynamic_queue_limits.c: simplify includes
lib/sort.c: use simpler includes
lib/interval_tree.c: simplify includes
hexdump: make it return number of bytes placed in buffer
