path: root/fs/inode.c
2010-08-10Merge branch 'for-linus' of git://git.infradead.org/users/eparis/notifyLinus Torvalds
* 'for-linus' of git://git.infradead.org/users/eparis/notify: (132 commits) fanotify: use both marks when possible fsnotify: pass both the vfsmount mark and inode mark fsnotify: walk the inode and vfsmount lists simultaneously fsnotify: rework ignored mark flushing fsnotify: remove global fsnotify groups lists fsnotify: remove group->mask fsnotify: remove the global masks fsnotify: cleanup should_send_event fanotify: use the mark in handler functions audit: use the mark in handler functions dnotify: use the mark in handler functions inotify: use the mark in handler functions fsnotify: send fsnotify_mark to groups in event handling functions fsnotify: Exchange list heads instead of moving elements fsnotify: srcu to protect read side of inode and vfsmount locks fsnotify: use an explicit flag to indicate fsnotify_destroy_mark has been called fsnotify: use _rcu functions for mark list traversal fsnotify: place marks on object in order of group memory address vfs/fsnotify: fsnotify_close can delay the final work in fput fsnotify: store struct file not struct path ... Fix up trivial delete/modify conflict in fs/notify/inotify/inotify.c.
2010-08-09All filesystems that need invalidate_inode_buffers() are doing that explicitlyAl Viro
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09Make ->drop_inode() just return whether inode needs to be droppedAl Viro
... and let iput_final() do the actual eviction or retention Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09fs/inode.c:clear_inode() is goneAl Viro
2010-08-09fs/inode.c:evict() doesn't care about delete vs. non-delete paths nowAl Viro
2010-08-09->delete_inode() is goneAl Viro
2010-08-09new helper: end_writeback()Al Viro
Essentially, the minimal variant of ->evict_inode(). It's a trimmed-down clear_inode(), sans any fs callbacks. Once it returns we know that no async writeback will be happening; every ->evict_inode() instance should do that once and do that before doing anything ->write_inode() could interfere with (e.g. freeing the on-disk inode). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09Take ->i_bdev/->i_cdev handling out of clear_inode()Al Viro
All call chains to clear_inode() pass through evict_inode() and clear_inode() should be called by evict_inode() exactly once. So we can pull i_bdev/i_cdev detaching up to evict_inode() itself. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09generic_detach_inode() can be static nowAl Viro
2010-08-09New method - evict_inode()Al Viro
Hybrid of ->clear_inode() and ->delete_inode(); if present, does all fs work to be done when in-core inode is about to be gone, for whatever reason. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09unify fs/inode.c callers of clear_inode()Al Viro
For now, just a straightforward merge Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09simplify checks for I_CLEAR/I_FREEINGAl Viro
add I_CLEAR instead of replacing I_FREEING with it. I_CLEAR is equivalent to I_FREEING for almost all code looking at either; it's there to keep track of having called clear_inode() exactly once per inode lifetime, at some point after having set I_FREEING. I_CLEAR and I_FREEING never get set at the same time with the current code, so we can switch to setting i_flags to I_FREEING | I_CLEAR instead of I_CLEAR without loss of information. As the result of such change, checks become simpler and the amount of code that needs to know about I_CLEAR shrinks a lot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-07-28fsnotify: rename fsnotify_mark_entry to just fsnotify_markEric Paris
The name is long and it serves no real purpose. So rename fsnotify_mark_entry to just fsnotify_mark. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-28inotify: remove inotify in kernel interfaceEric Paris
nothing uses inotify in the kernel, drop it! Signed-off-by: Eric Paris <eparis@redhat.com>
2010-07-19mm: add context argument to shrinker callbackDave Chinner
The current shrinker implementation requires the registered callback to have global state to work from. This makes it difficult to shrink caches that are not global (e.g. per-filesystem caches). Pass the shrinker structure to the callback so that users can embed the shrinker structure in the context the shrinker needs to operate on and get back to it in the callback via container_of(). Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-05-21vfs: Add inode uid,gid,mode init helperDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21fs: inode.c use atomic_inc_return in __igetRichard Kennedy
Using atomic_inc_return in __iget(struct inode *inode) makes the intent of this code clearer and generates less code on processors that have this operation. On x86_64 this patch reduces the text size of inode.o by 12 bytes. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> ---- patch against 2.6.34-rc7 compiled & tested on x86_64 AMD X2 I've been running with this patch applied for several weeks with no obvious problems. regards Richard Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-04-12security: remove dead hook inode_deleteEric Paris
Unused hook. Remove. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: move dquot drop responsibility into the filesystemChristoph Hellwig
Currently clear_inode calls vfs_dq_drop directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the drop inside the ->clear_inode superblock operation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-17kill I_LOCKChristoph Hellwig
After I_SYNC was split from I_LOCK the leftover is always used together with I_NEW and thus superflous. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-10-25LSM: imbed ima calls in the security hooksMimi Zohar
Based on discussions on LKML and LSM, where there are consecutive security_ and ima_ calls in the vfs layer, move the ima_ calls to the existing security_ hooks. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-24vfs: optimize touch_time() tooAndi Kleen
Do a similar optimization as earlier for touch_atime. Getting the lock in mnt_get_write is relatively costly, so try all avenues to avoid it first. This patch is careful to still only update inode fields inside the lock region. This didn't show up in benchmarks, but it's easy enough to do. [akpm@linux-foundation.org: fix typo in comment] [hugh.dickins@tiscali.co.uk: fix inverted test of mnt_want_write_file()] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Valerie Aurora <vaurora@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24vfs: optimization for touch_atime()Andi Kleen
Some benchmark testing shows touch_atime to be high up in profile logs for IO intensive workloads. Most likely that's due to the lock in mnt_want_write(). Unfortunately touch_atime first takes the lock, and then does all the other tests that could avoid atime updates (like noatime or relatime). Do it the other way round -- first try to avoid the update and only then if that didn't succeed take the lock. That works because none of the atime avoidance tests rely on locking. This also eliminates a goto. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Reviewed-by: Valerie Aurora <vaurora@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24vfs: split generic_forget_inode() so that hugetlbfs does not have to copy itJan Kara
Hugetlbfs needs to do special things instead of truncate_inode_pages(). Currently, it copied generic_forget_inode() except for truncate_inode_pages() call which is asking for trouble (the code there isn't trivial). So create a separate function generic_detach_inode() which does all the list magic done in generic_forget_inode() and call it from hugetlbfs_forget_inode(). Signed-off-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24fs/inode.c: add dev-id and inode number for debugging in init_special_inode()Manish Katiyar
Add device-id and inode number for better debugging. This was suggested by Andreas in one of the threads http://article.gmane.org/gmane.comp.file-systems.ext4/12062 . "If anyone has a chance, fixing this error message to be not-useless would be good... Including the device name and the inode number would help track down the source of the problem." Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-23fs: turn iprune_mutex into rwsemNick Piggin
We have had a report of bad memory allocation latency during DVD-RAM (UDF) writing. This is causing the user's desktop session to become unusable. Jan tracked the cause of this down to UDF inode reclaim blocking: gnome-screens D ffff810006d1d598 0 20686 1 ffff810006d1d508 0000000000000082 ffff810037db6718 0000000000000800 ffff810006d1d488 ffffffff807e4280 ffffffff807e4280 ffff810006d1a580 ffff8100bccbc140 ffff810006d1a8c0 0000000006d1d4e8 ffff810006d1a8c0 Call Trace: [<ffffffff804477f3>] io_schedule+0x63/0xa5 [<ffffffff802c2587>] sync_buffer+0x3b/0x3f [<ffffffff80447d2a>] __wait_on_bit+0x47/0x79 [<ffffffff80447dc6>] out_of_line_wait_on_bit+0x6a/0x77 [<ffffffff802c24f6>] __wait_on_buffer+0x1f/0x21 [<ffffffff802c442a>] __bread+0x70/0x86 [<ffffffff88de9ec7>] :udf:udf_tread+0x38/0x3a [<ffffffff88de0fcf>] :udf:udf_update_inode+0x4d/0x68c [<ffffffff88de26e1>] :udf:udf_write_inode+0x1d/0x2b [<ffffffff802bcf85>] __writeback_single_inode+0x1c0/0x394 [<ffffffff802bd205>] write_inode_now+0x7d/0xc4 [<ffffffff88de2e76>] :udf:udf_clear_inode+0x3d/0x53 [<ffffffff802b39ae>] clear_inode+0xc2/0x11b [<ffffffff802b3ab1>] dispose_list+0x5b/0x102 [<ffffffff802b3d35>] shrink_icache_memory+0x1dd/0x213 [<ffffffff8027ede3>] shrink_slab+0xe3/0x158 [<ffffffff8027fbab>] try_to_free_pages+0x177/0x232 [<ffffffff8027a578>] __alloc_pages+0x1fa/0x392 [<ffffffff802951fa>] alloc_page_vma+0x176/0x189 [<ffffffff802822d8>] __do_fault+0x10c/0x417 [<ffffffff80284232>] handle_mm_fault+0x466/0x940 [<ffffffff8044b922>] do_page_fault+0x676/0xabf This blocks with iprune_mutex held, which then blocks other reclaimers: X D ffff81009d47c400 0 17285 14831 ffff8100844f3728 0000000000000086 0000000000000000 ffff81000000e288 ffff81000000da00 ffffffff807e4280 ffffffff807e4280 ffff81009d47c400 ffffffff805ff890 ffff81009d47c740 00000000844f3808 ffff81009d47c740 Call Trace: [<ffffffff80447f8c>] __mutex_lock_slowpath+0x72/0xa9 [<ffffffff80447e1a>] mutex_lock+0x1e/0x22 [<ffffffff802b3ba1>] shrink_icache_memory+0x49/0x213 [<ffffffff8027ede3>] shrink_slab+0xe3/0x158 [<ffffffff8027fbab>] try_to_free_pages+0x177/0x232 [<ffffffff8027a578>] __alloc_pages+0x1fa/0x392 [<ffffffff8029507f>] alloc_pages_current+0xd1/0xd6 [<ffffffff80279ac0>] __get_free_pages+0xe/0x4d [<ffffffff802ae1b7>] __pollwait+0x5e/0xdf [<ffffffff8860f2b4>] :nvidia:nv_kern_poll+0x2e/0x73 [<ffffffff802ad949>] do_select+0x308/0x506 [<ffffffff802adced>] core_sys_select+0x1a6/0x254 [<ffffffff802ae0b7>] sys_select+0xb5/0x157 Now I think the main problem is having the filesystem block (and do IO) in inode reclaim. The problem is that this doesn't get accounted well and penalizes a random allocator with a big latency spike caused by work generated from elsewhere. I think the best idea would be to avoid this. By design if possible, or by deferring the hard work to an asynchronous context. If the latter, then the fs would probably want to throttle creation of new work with queue size of the deferred work, but let's not get into those details. Anyway, the other obvious thing we looked at is the iprune_mutex which is causing the cascading blocking. We could turn this into an rwsem to improve concurrency. It is unreasonable to totally ban all potentially slow or blocking operations in inode reclaim, so I think this is a cheap way to get a small improvement. This doesn't solve the whole problem of course. The process doing inode reclaim will still take the latency hit, and concurrent processes may end up contending on filesystem locks. So fs developers should keep these problems in mind. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jan Kara <jack@ucw.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining inode_operations as constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22fs: make sure data stored into inode is properly seen before unlocking new inodeJan Kara
In theory it could happen that on one CPU we initialize a new inode but clearing of I_NEW | I_LOCK gets reordered before some of the initialization. Thus on another CPU we return not fully uptodate inode from iget_locked(). This seems to fix a corruption issue on ext3 mounted over NFS. [akpm@linux-foundation.org: add some commentary] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@infradead.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16fs: remove bdev->bd_inode_backing_dev_infoJens Axboe
It has been unused since it was introduced in: commit 520808bf20e90fdbdb320264ba7dd5cf9d47dcac Author: Andrew Morton <akpm@osdl.org> Date: Fri May 21 00:46:17 2004 -0700 [PATCH] block device layer: separate backing_dev_info infrastructure So lets just kill it. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-08-07vfs: add __destroy_inodeChristoph Hellwig
When we want to tear down an inode that lost the add to the cache race in XFS we must not call into ->destroy_inode because that would delete the inode that won the race from the inode cache radix tree. This patch provides the __destroy_inode helper needed to fix this, the actual fix will be in th next patch. As XFS was the only reason destroy_inode was exported we shift the export to the new __destroy_inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2009-08-07vfs: fix inode_init_always calling conventionChristoph Hellwig
Currently inode_init_always calls into ->destroy_inode if the additional initialization fails. That's not only counter-intuitive because inode_init_always did not allocate the inode structure, but in case of XFS it's actively harmful as ->destroy_inode might delete the inode from a radix-tree that has never been added. This in turn might end up deleting the inode for the same inum that has been instanciated by another process and cause lots of cause subtile problems. Also in the case of re-initializing a reclaimable inode in XFS it would free an inode we still want to keep alive. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Eric Sandeen <sandeen@sandeen.net>
2009-06-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits) switch xfs to generic acl caching helpers helpers for acl caching + switch to those switch shmem to inode->i_acl switch reiserfs to inode->i_acl switch reiserfs to usual conventions for caching ACLs reiserfs: minimal fix for ACL caching switch nilfs2 to inode->i_acl switch btrfs to inode->i_acl switch jffs2 to inode->i_acl switch jfs to inode->i_acl switch ext4 to inode->i_acl switch ext3 to inode->i_acl switch ext2 to inode->i_acl add caching of ACLs in struct inode fs: Add new pre-allocation ioctls to vfs for compatibility with legacy xfs ioctls cleanup __writeback_single_inode ... and the same for vfsmount id/mount group id Make allocation of anon devices cheaper update Documentation/filesystems/Locking devpts: remove module-related code ...
2009-06-24add caching of ACLs in struct inodeAl Viro
No helpers, no conversions yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-22vfs: Set special lockdep map for dirs only if not set by fsJan Kara
Some filesystems need to set lockdep map for i_mutex differently for different directories. For example OCFS2 has system directories (for orphan inode tracking and for gathering all system files like journal or quota files into a single place) which have different locking locking rules than standard directories. For a filesystem setting lockdep map is naturaly done when the inode is read but we have to modify unlock_new_inode() not to overwrite the lockdep map the filesystem has set. Acked-by: peterz@infradead.org CC: mingo@redhat.com Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-06-12trivial: fs/inode: Fix typo in file_update_time nanodocWolfram Sang
The advertised flag for not updating the time was wrong. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11fs: introduce mnt_clone_writenpiggin@suse.de
This patch speeds up lmbench lat_mmap test by about another 2% after the first patch. Before: avg = 462.286 std = 5.46106 After: avg = 453.12 std = 9.58257 (50 runs of each, stddev gives a reasonable confidence) It does this by introducing mnt_clone_write, which avoids some heavyweight operations of mnt_want_write if called on a vfsmount which we know already has a write count; and mnt_want_write_file, which can call mnt_clone_write if the file is open for write. After these two patches, mnt_want_write and mnt_drop_write go from 7% on the profile down to 1.3% (including mnt_clone_write). [AV: mnt_want_write_file() should take file alone and derive mnt from it; not only all callers have that form, but that's the only mnt about which we know that it's already held for write if file is opened for write] Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11fsnotify: handle filesystem unmounts with fsnotify marksEric Paris
When an fs is unmounted with an fsnotify mark entry attached to one of its inodes we need to destroy that mark entry and we also (like inotify) send an unmount event. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-11fsnotify: add marks to inodes so groups can interpret how to handle those inodesEric Paris
This patch creates a way for fsnotify groups to attach marks to inodes. These marks have little meaning to the generic fsnotify infrastructure and thus their meaning should be interpreted by the group that attached them to the inode's list. dnotify and inotify will make use of these markings to indicate which inodes are of interest to their respective groups. But this implementation has the useful property that in the future other listeners could actually use the marks for the exact opposite reason, aka to indicate which inodes it had NO interest in. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2009-06-06integrity: fix IMA inode leakHugh Dickins
CONFIG_IMA=y inode activity leaks iint_cache and radix_tree_node objects until the system runs out of memory. Nowhere is calling ima_inode_free() a.k.a. ima_iint_delete(). Fix that by calling it from destroy_inode(). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-06ext3/4 with synchronous writes gets wedged by PostfixAl Viro
OK, that's probably the easiest way to do that, as much as I don't like it... Since iget() et.al. will not accept I_FREEING (will wait to go away and restart), and since we'd better have serialization between new/free on fs data structures anyway, we can afford simply skipping I_FREEING et.al. in insert_inode_locked(). We do that from new_inode, so it won't race with free_inode in any interesting ways and it won't race with iget (of any origin; nfsd or in case of fs corruption a lookup) since both still will wait for I_LOCK. Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Tested-by: David Watson <dbwatson@ukfsn.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Make checkpatch.pl shut up on fs/inode.cManish Katiyar
Code Quality According To Mingo(tm) has been vastly improved, no code has been damaged^Wchanged^Wdamaged. [commit message rewritten -- AV] Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-15splice: add helpers for locking pipe inodeMiklos Szeredi
There are lots of sequences like this, especially in splice code: if (pipe->inode) mutex_lock(&pipe->inode->i_mutex); /* do something */ if (pipe->inode) mutex_unlock(&pipe->inode->i_mutex); so introduce helpers which do the conditional locking and unlocking. Also replace the inode_double_lock() call with a pipe_double_lock() helper to avoid spreading the use of this functionality beyond the pipe code. This patch is just a cleanup, and should cause no behavioral changes. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits) fs: avoid I_NEW inodes Merge code for single and multiple-instance mounts Remove get_init_pts_sb() Move common mknod_ptmx() calls into caller Parse mount options just once and copy them to super block Unroll essentials of do_remount_sb() into devpts vfs: simple_set_mnt() should return void fs: move bdev code out of buffer.c constify dentry_operations: rest constify dentry_operations: configfs constify dentry_operations: sysfs constify dentry_operations: JFS constify dentry_operations: OCFS2 constify dentry_operations: GFS2 constify dentry_operations: FAT constify dentry_operations: FUSE constify dentry_operations: procfs constify dentry_operations: ecryptfs constify dentry_operations: CIFS constify dentry_operations: AFS ...
2009-03-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-quota-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-quota-2.6: (27 commits) ext2: Zero our b_size in ext2_quota_read() trivial: fix typos/grammar errors in fs/Kconfig quota: Coding style fixes quota: Remove superfluous inlines quota: Remove uppercase aliases for quota functions. nfsd: Use lowercase names of quota functions jfs: Use lowercase names of quota functions udf: Use lowercase names of quota functions ufs: Use lowercase names of quota functions reiserfs: Use lowercase names of quota functions ext4: Use lowercase names of quota functions ext3: Use lowercase names of quota functions ext2: Use lowercase names of quota functions ramfs: Remove quota call vfs: Use lowercase names of quota functions quota: Remove dqbuf_t and other cleanups quota: Remove NODQUOT macro quota: Make global quota locks cacheline aligned quota: Move quota files into separate directory ext4: quota reservation for delayed allocation ...
2009-03-27fs: avoid I_NEW inodesNick Piggin
To be on the safe side, it should be less fragile to exclude I_NEW inodes from inode list scans by default (unless there is an important reason to have them). Normally they will get excluded (eg. by zero refcount or writecount etc), however it is a bit fragile for list walkers to know exactly what parts of the inode state is set up and valid to test when in I_NEW. So along these lines, move I_NEW checks upward as well (sometimes taking I_FREEING etc checks with them too -- this shouldn't be a problem should it?) Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (71 commits) SELinux: inode_doinit_with_dentry drop no dentry printk SELinux: new permission between tty audit and audit socket SELinux: open perm for sock files smack: fixes for unlabeled host support keys: make procfiles per-user-namespace keys: skip keys from another user namespace keys: consider user namespace in key_permission keys: distinguish per-uid keys in different namespaces integrity: ima iint radix_tree_lookup locking fix TOMOYO: Do not call tomoyo_realpath_init unless registered. integrity: ima scatterlist bug fix smack: fix lots of kernel-doc notation TOMOYO: Don't create securityfs entries unless registered. TOMOYO: Fix exception policy read failure. SELinux: convert the avc cache hash list to an hlist SELinux: code readability with avc_cache SELinux: remove unused av.decided field SELinux: more careful use of avd in avc_has_perm_noaudit SELinux: remove the unused ae.used SELinux: check seqno when updating an avc_node ...
2009-03-26Allow relatime to update atime once a dayMatthew Garrett
Allow atime to be updated once per day even with relatime. This lets utilities like tmpreaper (which delete files based on last access time) continue working, making relatime a plausible default for distributions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Valerie Aurora Henson <vaurora@redhat.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-26vfs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: Alexander Viro <viro@zeniv.linux.org.uk>
