path: root/fs/isofs/dir.c
2008-04-30isofs: fix access to unallocated memory when reading corrupted filesystemJan Kara
When a directory on isofs is corrupted, we did not check whether length of the name in a directory entry and the length of the directory entry itself are consistent. This could lead to possible access beyond the end of buffer when the length of the name was too big. Add this sanity check to directory reading code. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16isofs: fix up CodingStyleDave Jones
fs/isofs/* had a bunch of CodingStyle issues. * Indentation was a mix of spaces and tabs * "int * foo" instead of "int *foo" * "while ( foo )" instead of "while (foo)" * if (foo) blah; on one line instead of two * Missing printk KERN_ levels * lots of trailing whitespace * lines >80 columns changed to wrap. * Unnecessary prototype removed by shuffling code order in C file. Should be no functional changes other than slight size increase due to printk changes. Further improvement possible, but this is a start.. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] isofs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the isofs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] isofs: show hidden files, add granularity for assoc/hidden files flagsJeremy White
The current isofs treatment of hidden files is flawed in two ways. First, it does not provide sufficient granularity; it hides both 'hidden' files and 'associated' files (resource fork for Mac files). Second, the default behavior to completely strip hidden files, while an admirable implementation of the spec, is a poor choice given the real world use of hidden files as a poor mans copy protection scheme for MSDOS and Windows based systems. A longer description of this is available here: http://www.uwsg.iu.edu/hypermail/linux/kernel/0205.3/0267.html This patch was originally built after a few private conversations with Alan Cox; I shamefully failed to persist in seeing it go forward, I hope to make amends now. This patch introduces granularity by allowing explicit control for both hidden and associated files. It also reverses the default so that by default, hidden files are treated as regular files on the iso9660 file system. This allow Wine to process Windows CDs, including those that are hybrid Mac/Windows CDs properly and completely, without our having to go muck up peoples fstabs as we do now. (I have tested this with such a hybrid + hidden CD and have verified that this patch works as claimed). Signed-off-by: Jeremy White <jwhite@codeweavers.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-25[PATCH] isofs includes sanitizedAl Viro
fs/isofs includes trimmed down to something resembling sanity. Kernel-only parts of linux/iso_fs.h and entire linux/iso_fs_{sb,i}.h moved to fs/isofs/isofs.h. A lot of useless #include in fs/isofs/*.c killed. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
