path: root/fs/isofs
2010-08-11isofs: Fix lseek() to position beyond 4 GBJan Andres
isofs supports files larger than 4 GB by using multi-extent files. However an lseek() to a position beyond 4 GB in such a file will fail with EINVAL, because s_maxbytes in the isofs superblock is initialized to 2^32-1, and generic_file_llseek() checks against that value. I therefore suggest increasing the value of s_maxbytes to have full support for large files in isofs. With multi-extent files, file size is only limited by the maximum size of the file system (8 TB), so this seems a reasonable value for s_maxbytes. Signed-off-by: Jan Andres <jandres@gmx.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs/: do not fallback to default_llseek() when readdir() uses BKLjan Blunck
Do not use the fallback default_llseek() if the readdir operation of the filesystem still uses the big kernel lock. Since llseek() modifies file->f_pos of the directory directly it may need locking to not confuse readdir which usually uses file->f_pos directly as well Since the special characteristics of the BKL (unlocked on schedule) are not necessary in this case, the inode mutex can be used for locking as provided by generic_file_llseek(). This is only possible since all filesystems, except reiserfs, either use a directory as a flat file or with disk address offsets. Reiserfs on the other hand uses a 32bit hash off the filename as the offset so generic_file_llseek() can get used as well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) - blocksize). Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Anders Larsen <al@alarsen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-16Merge branch 'for-2.6.33' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits) nfsd: remove pointless paths in file headers nfsd: move most of nfsfh.h to fs/nfsd nfsd: remove unused field rq_reffh nfsd: enable V4ROOT exports nfsd: make V4ROOT exports read-only nfsd: restrict filehandles accepted in V4ROOT case nfsd: allow exports of symlinks nfsd: filter readdir results in V4ROOT case nfsd: filter lookup results in V4ROOT case nfsd4: don't continue "under" mounts in V4ROOT case nfsd: introduce export flag for v4 pseudoroot nfsd: let "insecure" flag vary by pseudoflavor nfsd: new interface to advertise export features nfsd: Move private headers to source directory vfs: nfsctl.c un-used nfsd #includes lockd: Remove un-used nfsd headers #includes s390: remove un-used nfsd #includes sparc: remove un-used nfsd #includes parsic: remove un-used nfsd #includes compat.c: Remove dependence on nfsd private headers ...
2009-12-10zisofs: Implement reading of compressed files when PAGE_CACHE_SIZE > ↵Jan Kara
compress block size Also split and cleanup zisofs_readpage() when we are changing it anyway. Signed-off-by: Jan Kara <jack@suse.cz>
2009-10-27nfs: new subdir Documentation/filesystems/nfsJ. Bruce Fields
We're adding enough nfs documentation that it may as well have its own subdirectory. Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-09-24fs: Make unload_nls() NULL pointer safeThomas Gleixner
Most call sites of unload_nls() do: if (nls) unload_nls(nls); Check the pointer inside unload_nls() like we do in kfree() and simplify the call sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steve French <sfrench@us.ibm.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-07-10isofs: fix Joliet regressionBartlomiej Zolnierkiewicz
commit 5404ac8e4418ab3d254950ee4f9bcafc1da20b4a ("isofs: cleanup mount option processing") missed conversion of joliet option flag resulting in non-working Joliet support. CC: walt <w41ter@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18isofs: cleanup mount option processingJan Kara
Remove unused variables from isofs_sb_info (used to be some mount options), unify variables for option to use 0/1 (some options used 'y'/'n'), use bit fields for option flags in superblock. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18isofs: fix setting of uid and gid to 0Jan Kara
isofs allows setting of default uid and gid of files but value 0 was used to indicate that user did not specify any uid/gid mount option. Since this option also overrides uid/gid set in Rock Ridge extension, it makes sense to allow forcing uid/gid 0. Fix option processing to allow this. Cc: <Hans-Joachim.Baader@cjt.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18isofs: let mode and dmode mount options override rock ridge mode settingJan Kara
So far, permissions set via 'mode' and/or 'dmode' mount options were effective only if the medium had no rock ridge extensions (or was mounted without them). Add 'overriderockmode' mount option to indicate that these options should override permissions set in rock ridge extensions. Maybe this should be default but the current behavior is there since mount options were created so I think we should not change how they behave. Cc: <Hans-Joachim.Baader@cjt.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15NLS: update handling of UnicodeAlan Stern
This patch (as1239) updates the kernel's treatment of Unicode. The character-set conversion routines are well behind the current state of the Unicode specification: They don't recognize the existence of code points beyond plane 0 or of surrogate pairs in the UTF-16 encoding. The old wchar_t 16-bit type is retained because it's still used in lots of places. This shouldn't cause any new problems; if a conversion now results in an invalid 16-bit code then before it must have yielded an undefined code. Difficult-to-read names like "utf_mbstowcs" are replaced with more transparent names like "utf8s_to_utf16s" and the ordering of the parameters is rationalized (buffer lengths come immediate after the pointers they refer to, and the inputs precede the outputs). Fortunately the low-level conversion routines are used in only a few places; the interfaces to the higher-level uni2char and char2uni methods have been left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-02fs/isofs: return f_fsid for statfs(2)Coly Li
Make isofs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2009-01-22fs/Kconfig: move iso9660, udf outAlexey Dobriyan
2009-01-05isofs check for NULL ->i_op in root directory is dead codeAl Viro
for one thing it never happens, for another we check that inode is a directory right after that place anyway (and we'd already checked that reading it from disk has not failed). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25isofs: fix minor filesystem corruptionAdam Greenblatt
Some iso9660 images contain files with rockridge data that is either incorrect or incompletely parsed. Prior to commit f2966632a134e865db3c819346a1dc7d96e05309 ("[PATCH] rock: handle directory overflows") (included with kernel 2.6.13) the kernel ignored the rockridge data for these files, while still allowing the files to be accessed under their non-rockridge names. That commit inadvertently changed things so that files with invalid rockridge data could not be accessed at all. (I ran across the problem when comparing some old CDs with hard disk copies I had made long ago under kernel 2.4: a few of the files on the hard disk copies were no longer visible on the CDs.) This change reverts to the pre-2.6.13 behavior. Signed-off-by: Adam Greenblatt <adam.greenblatt@gmail.com> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30isofs: fix access to unallocated memory when reading corrupted filesystemJan Kara
When a directory on isofs is corrupted, we did not check whether length of the name in a directory entry and the length of the directory entry itself are consistent. This could lead to possible access beyond the end of buffer when the length of the name was too big. Add this sanity check to directory reading code. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29isofs: use get/put_unaligned_* helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19zisofs: fix readpage() outside i_sizeDave Young
A read request outside i_size will be handled in do_generic_file_read(). So we just return 0 to avoid getting -EIO as normal reading, let do_generic_file_read do the rest. At the same time we need unlock the page to avoid system stuck. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=10227 Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Report-by: Christian Perle <chris@linuxinfotag.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix isofsMiklos Szeredi
Add a .show_options super operation to isofs. Use generic_show_options() and save the complete option string in isofs_fill_super(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08isofs: implement dmode optionJan Kara
Implement dmode option for iso9660 filesystem to allow setting of access rights for directories on the filesystem. Signed-off-by: Jan Kara <jack@suse.cz> Cc: "Ilya N. Golubev" <gin@mo.msk.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop ISOFS from using read_inode()David Howells
Stop the ISOFS filesystem from using read_inode(). Make isofs_read_inode() return an error code, and make isofs_iget() pass it on. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jan Kara <jack@ucw.cz> Acked-by: Christoph Hellwig <hch@lst.de> Cc: "Dave Young" <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22isofs: new export opsChristoph Hellwig
Nice little cleanup by consolidating things a little and using a structure for the special file handle format. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17fs/isofs/namei.c: Remove uninitialized local vars warningBorislav Petkov
shut up those: fs/isofs/namei.c: In function 'isofs_lookup': fs/isofs/namei.c:161: warning: 'offset' may be used uninitialized in this function fs/isofs/namei.c:161: warning: 'block' may be used uninitialized in this function By the way, they get overwritten at the end of isofs_find_entry(). Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17zisofs use mutex instead of semaphoreDave Young
Use mutex instead of semaphore in fs/isofs/compress.c, and remove an unnecessary variable. Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31isofs: mounting to regular file may succeedKirill Kuvaldin
It turned out that mounting a corrupted ISO image to a regular file may succeed, e.g. if an image was prepared as follows: $ dd if=correct.iso of=bad.iso bs=4k count=8 We then can mount it to a regular file: # mount -o loop -t iso9660 bad.iso /tmp/file But mounting it to a directory fails with -ENOTDIR, simply because the root directory inode doesn't have S_IFDIR set and the condition in graft_tree() is met: if (S_ISDIR(nd->dentry->d_inode->i_mode) != S_ISDIR(mnt->mnt_root->d_inode->i_mode)) return -ENOTDIR This is because the root directory inode was read from an incorrect block. It's supposed to be read from sbi->s_firstdatazone, which is an absolute value and gets messed up in the case of an incorrect image. In order to somehow circumvent this we have to check that the root directory inode is actually a directory after all. Signed-off-by: Kirill Kuvaldin <kuvkir@epsmu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16remove useless tolower in isofsyoung dave
Remove useless tolower in isofs Signed-off-by: dave young <hidave.darkstar@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16isofs: fix up CodingStyleDave Jones
fs/isofs/* had a bunch of CodingStyle issues. * Indentation was a mix of spaces and tabs * "int * foo" instead of "int *foo" * "while ( foo )" instead of "while (foo)" * if (foo) blah; on one line instead of two * Missing printk KERN_ levels * lots of trailing whitespace * lines >80 columns changed to wrap. * Unnecessary prototype removed by shuffling code order in C file. Should be no functional changes other than slight size increase due to printk changes. Further improvement possible, but this is a start.. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] isofs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the isofs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] isofs endianness annotationsAl Viro
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-29[PATCH] I/O Error attempting to read last partial block of a file in an ↵Joel & Rebecca VanderZee
ISO9660 file system There was an I/O error that prevented reading the last partial block of large files in an ISO9660 filesystem. The error was generated when a file comprised more than one section and had a size that was not an exact multiple of the filesystem block size. This patch removes the check (and failure) for reading into the last partial block (and possibly beyond) for multiple-section files. It worked in my testing to prevent reading beyond the end of the section; my first patch just incremented the sect_size block count for a partial block and continued doing the check. But there is a commment in the source code about reading beyond the end of the file to fill a page cache. Failing to access beyond the section would prevent reading beyond the end of the file. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
