commit 4e2024624e678f0ebb916e6192bd23c1f9fdf696 upstream.
We didn't check length of rock ridge ER records before printing them.
Thus corrupted isofs image can cause us to access and print some memory
behind the buffer with obvious consequences.
Reported-and-tested-by: Carl Henrik Lunde <chlunde@ping.uio.no>
commit f54e18f1b831c92f6512d2eedb224cd63d607d3d upstream.
Rock Ridge extensions define so called Continuation Entries (CE) which
define where is further space with Rock Ridge data. Corrupted isofs
image can contain arbitrarily long chain of these, including a one
containing loop and thus causing kernel to end in an infinite loop when
traversing these entries.
Limit the traversal to 32 entries which should be more than enough space
to store all the Rock Ridge data.
Reported-by: P J P <ppandit@redhat.com>
commit 410dd3cf4c9b36f27ed4542ee18b1af5e68645a4 upstream.
We did not check relocated directory in any way when processing Rock
Ridge 'CL' tag. Thus a corrupted isofs image can possibly have a CL
entry pointing to another CL entry leading to possibly unbounded
recursion in kernel code and thus stack overflow or deadlocks (if there
is a loop created from CL entries).
Fix the problem by not allowing CL entry to point to a directory entry
with CL entry (such use makes no good sense anyway) and by checking
whether CL entry doesn't point to itself.
Reported-by: Chris Evans <cevans@google.com>
commit 17b7f7cf58926844e1dd40f5eb5348d481deca6a upstream.
Refuse RW mount of isofs filesystem. So far we just silently changed it
to RO mount but when the media is writeable, block layer won't notice
this change and thus will think device is used RW and will block eject
button of the drive. That is unexpected by users because for
non-writeable media eject button works just fine.
Userspace mount(8) command handles this just fine and retries mounting
with MS_RDONLY set so userspace shouldn't see any regression. Plus any
tool mounting isofs is likely confronted with the case of read-only
media where block layer already refuses to mount the filesystem without
MS_RDONLY set so our behavior shouldn't be anything new for it.
Reported-by: Hui Wang <hui.wang@canonical.com>
commit fe685aabf7c8c9f138e5ea900954d295bf229175 upstream.
For type 1 the parent_offset member in struct isofs_fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
commit 35c2a7f4908d404c9124c2efc6ada4640ca4d5d5 upstream.
Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(),
u64 inum = fid->raw[2];
which is unhelpfully reported as at the end of shmem_alloc_inode():
BUG: unable to handle kernel paging request at ffff880061cd3000
IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Call Trace:
[<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0
[<ffffffff812d77c3>] do_handle_open+0x163/0x2c0
[<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10
[<ffffffff83a5f3f8>] tracesys+0xe1/0xe6
Right, tmpfs is being stupid to access fid->raw[2] before validating that
fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may
fall at the end of a page, and the next page not be present.
But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being
careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and
could oops in the same way: add the missing fh_len checks to those.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Says Andrew:
"60 patches. That's good enough for -rc1 I guess. I have quite a lot
of detritus to be rechecked, work through maintainers, etc.
- most of the remains of MM
- rtc
- various misc
- cgroups
- memcg
- cpusets
- procfs
- ipc
- rapidio
- sysctl
- pps
- w1
- drivers/misc
- aio"
* akpm: (60 commits)
memcg: replace ss->id_lock with a rwlock
aio: allocate kiocbs in batches
drivers/misc/vmw_balloon.c: fix typo in code comment
drivers/misc/vmw_balloon.c: determine page allocation flag can_sleep outside loop
w1: disable irqs in critical section
drivers/w1/w1_int.c: multiple masters used same init_name
drivers/power/ds2780_battery.c: fix deadlock upon insertion and removal
drivers/power/ds2780_battery.c: add a nolock function to w1 interface
drivers/power/ds2780_battery.c: create central point for calling w1 interface
w1: ds2760 and ds2780, use ida for id and ida_simple_get() to get it
pps gpio client: add missing dependency
pps: new client driver using GPIO
pps: default echo function
include/linux/dma-mapping.h: add dma_zalloc_coherent()
sysctl: make CONFIG_SYSCTL_SYSCALL default to n
sysctl: add support for poll()
RapidIO: documentation update
drivers/net/rionet.c: fix ethernet address macros for LE platforms
RapidIO: fix potential null deref in rio_setup_device()
RapidIO: add mport driver for Tsi721 bridge
Use mpage_readpages() instead of multiple calls to isofs_readpage() to
reduce the CPU utilization and make performance higher.
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
sbi->s_mutex isn't needed for isofs at all so we can just remove it. Generally,
since isofs is always mounted read-only, filesystem structure cannot change
under us. So buffer_head contents stays constant after it's filled in. That
leaves us with possible changes of global data structures. Superblock changes
only during filesystem mount (even remount does not change it), inodes are only
filled in during reading from disk. So there are no changes of these structures
to bother about.
Arguments why sbi->s_mutex can be removed at each place:
isofs_readdir: Accesses sb, inode, filp, local variables => s_mutex not needed
isofs_lookup: Protected by directory's i_mutex. Accesses sb, inode, dentry,
rock_ridge_symlink_readpage: Protected by page lock. Accesses sb, inode,
local variables => s_mutex not needed.
... and simplify the living hell out of callers
In isofs_fill_super(), when an iso_primary_descriptor is found, it is
kept in pri_bh. The error cases don't properly release it. Fix it.
Reported-and-tested-by: 김원석 <stanley.will.kim@gmail.com>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
The exportfs encode handle function should return the minimum required
handle size. This helps user to find out the handle size by passing 0
handle size in the first step and then redoing to the call again with
the returned handle size value.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
switch to ->s_d_op; d_obtain_alias() will DTRT now
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Change d_hash so it may be called from lock-free RCU lookups. See similar
patch for d_compare for details.
For in-tree filesystems, this is just a mechanical change.
Change d_compare so it may be called from lock-free RCU lookups. This
does put significant restrictions on what may be done from the callback,
however there don't seem to have been any problems with in-tree fses.
If some strange use case pops up that _really_ cannot cope with the
rcu-walk rules, we can just add new rcu-unaware callbacks, which would
cause name lookup to drop out of rcu-walk mode.
... and switch of the obvious get_sb_bdev() users to ->mount()
If a CD has both Rock Ridge and Joliet extensions and the ISO root
directory is empty, no files are visible. Disable Rock Ridge extensions
in this case and use Joliet root directory instead.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Cc: Guenter Roeck <guenter.roeck@ericsson.com>
Currently isofs_get_blocks() was limited to handle only 4TB files on 32-bit
architectures because of unnecessary use of iblock variable which was signed
long. Just remove the variable. The error messages that were using this
variable should have rather used b_off anyway because that is the block we
are currently mapping.
As in other file systems, we can replace the big kernel lock
with a private mutex in isofs. This means we can now access
multiple file systems concurrently, but it also means that
we serialize readdir and lookup across sleeping operations
which previously released the big kernel lock. This should
not matter though, as these operations are in practice
serialized through the hardware access.
The isofs_get_blocks functions now does not take any lock
any more, it used to recursively get the BKL. After looking
at the code for hours, I convinced myself that it was never
needed here anyway, because it only reads constant fields
of the inode and writes to a buffer head array that is
at this time only visible to the caller.
The get_sb and fill_super operations do not need the locking
at all because they operate on a file system that is either
about to be created or to be destroyed but in either case
is not visible to other threads.
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Signed-off-by: Jan Blunck <jblunck@infradead.org>
Cc: Matthew Wilcox <matthew@wil.cx>
isofs supports files larger than 4 GB by using multi-extent files.
However an lseek() to a position beyond 4 GB in such a file will
fail with EINVAL, because s_maxbytes in the isofs superblock is
initialized to 2^32-1, and generic_file_llseek() checks against
that value.
I therefore suggest increasing the value of s_maxbytes to have
full support for large files in isofs. With multi-extent files, file
size is only limited by the maximum size of the file system (8 TB),
so this seems a reasonable value for s_maxbytes.
Signed-off-by: Jan Andres <jandres@gmx.net>
Do not use the fallback default_llseek() if the readdir operation of the
filesystem still uses the big kernel lock.
Since llseek() modifies
file->f_pos of the directory directly it may need locking to not confuse
readdir which usually uses file->f_pos directly as well
Since the special characteristics of the BKL (unlocked on schedule) are
not necessary in this case, the inode mutex can be used for locking as
provided by generic_file_llseek(). This is only possible since all
filesystems, except reiserfs, either use a directory as a flat file or
with disk address offsets. Reiserfs on the other hand uses a 32bit hash
off the filename as the offset so generic_file_llseek() can get used as
well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) -
blocksize).
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Anders Larsen <al@alarsen.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits)
nfsd: remove pointless paths in file headers
nfsd: move most of nfsfh.h to fs/nfsd
nfsd: remove unused field rq_reffh
nfsd: enable V4ROOT exports
nfsd: make V4ROOT exports read-only
nfsd: restrict filehandles accepted in V4ROOT case
nfsd: allow exports of symlinks
nfsd: filter readdir results in V4ROOT case
nfsd: filter lookup results in V4ROOT case
nfsd4: don't continue "under" mounts in V4ROOT case
nfsd: introduce export flag for v4 pseudoroot
nfsd: let "insecure" flag vary by pseudoflavor
nfsd: new interface to advertise export features
nfsd: Move private headers to source directory
vfs: nfsctl.c un-used nfsd #includes
lockd: Remove un-used nfsd headers #includes
s390: remove un-used nfsd #includes
sparc: remove un-used nfsd #includes
parsic: remove un-used nfsd #includes
compat.c: Remove dependence on nfsd private headers
compress block size
Also split and cleanup zisofs_readpage() when we are changing it anyway.
We're adding enough nfs documentation that it may as well have its own
subdirectory.
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Most call sites of unload_nls() do:
if (nls)
unload_nls(nls);
Check the pointer inside unload_nls() like we do in kfree() and
simplify the call sites.
Cc: Steve French <sfrench@us.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Cc: Anton Altaparmakov <aia21@cantab.net>
commit 5404ac8e4418ab3d254950ee4f9bcafc1da20b4a ("isofs: cleanup mount
option processing") missed conversion of joliet option flag resulting
in non-working Joliet support.
CC: walt <w41ter@gmail.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Remove unused variables from isofs_sb_info (used to be some mount
options), unify variables for option to use 0/1 (some options used
'y'/'n'), use bit fields for option flags in superblock.
isofs allows setting of default uid and gid of files but value 0 was used
to indicate that user did not specify any uid/gid mount option. Since
this option also overrides uid/gid set in Rock Ridge extension, it makes
sense to allow forcing uid/gid 0. Fix option processing to allow this.
Cc: <Hans-Joachim.Baader@cjt.de>
So far, permissions set via 'mode' and/or 'dmode' mount options were
effective only if the medium had no rock ridge extensions (or was mounted
without them). Add 'overriderockmode' mount option to indicate that these
options should override permissions set in rock ridge extensions. Maybe
this should be default but the current behavior is there since mount
options were created so I think we should not change how they behave.
This patch (as1239) updates the kernel's treatment of Unicode. The
character-set conversion routines are well behind the current state of
the Unicode specification: They don't recognize the existence of code
points beyond plane 0 or of surrogate pairs in the UTF-16 encoding.
The old wchar_t 16-bit type is retained because it's still used in
lots of places. This shouldn't cause any new problems; if a
conversion now results in an invalid 16-bit code then before it must
have yielded an undefined code.
Difficult-to-read names like "utf_mbstowcs" are replaced with more
transparent names like "utf8s_to_utf16s" and the ordering of the
parameters is rationalized (buffer lengths come immediate after the
pointers they refer to, and the inputs precede the outputs).
Fortunately the low-level conversion routines are used in only a few
places; the interfaces to the higher-level uni2char and char2uni
methods have been left unchanged.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
Make isofs return f_fsid info for statfs(2).
Signed-off-by: Coly Li <coly.li@suse.de>
Cc: Jan Kara <jack@ucw.cz>
for one thing it never happens, for another we check that inode
is a directory right after that place anyway (and we'd already
checked that reading it from disk has not failed).
Switch all users of d_alloc_anon to d_obtain_alias.
This is a much better version of a previous patch to make the parser
tables constant. Rather than changing the typedef, we put the "const" in
all the various places where its required, allowing the __initconst
exception for nfsroot which was the cause of the previous trouble.
This was posted for review some time ago and I believe its been in -mm
since then.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Alexander Viro <aviro@redhat.com>
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Some iso9660 images contain files with rockridge data that is either
incorrect or incompletely parsed. Prior to commit
f2966632a134e865db3c819346a1dc7d96e05309 ("[PATCH] rock: handle directory
overflows") (included with kernel 2.6.13) the kernel ignored the rockridge
data for these files, while still allowing the files to be accessed under
their non-rockridge names. That commit inadvertently changed things so
that files with invalid rockridge data could not be accessed at all. (I
ran across the problem when comparing some old CDs with hard disk copies I
had made long ago under kernel 2.4: a few of the files on the hard disk
copies were no longer visible on the CDs.)
This change reverts to the pre-2.6.13 behavior.
Signed-off-by: Adam Greenblatt <adam.greenblatt@gmail.com>
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
When a directory on isofs is corrupted, we did not check whether length of the
name in a directory entry and the length of the directory entry itself are
consistent. This could lead to possible access beyond the end of buffer when
the length of the name was too big. Add this sanity check to directory
reading code.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
A read request outside i_size will be handled in do_generic_file_read(). So
we just return 0 to avoid getting -EIO as normal reading, let
do_generic_file_read do the rest.
At the same time we need unlock the page to avoid system stuck.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=10227
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Report-by: Christian Perle <chris@linuxinfotag.de>
Add a .show_options super operation to isofs.
Use generic_show_options() and save the complete option string in
isofs_fill_super().
