path: root/fs/jbd/revoke.c
2010-08-18remove SWRITE* I/O typesChristoph Hellwig
These flags aren't real I/O types, but tell ll_rw_block to always lock the buffer instead of giving up on a failed trylock. Instead add a new write_dirty_buffer helper that implements this semantic and use it from the existing SWRITE* callers. Note that the ll_rw_block code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which this patch fixes. In the ufs code clean up the helper that used to call ll_rw_block to mirror sync_dirty_buffer, which is the function it implements for compound buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-16jbd: Journal block numbers can ever be only 32-bit use unsigned int for themJan Kara
It does not make sense to store block number for journal as unsigned long since they can be only 32-bit (because of on-disk format limitation). So change in-memory structures and variables to use unsigned int instead. Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-24Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Fix potential inode allocation soft lockup in Orlov allocator ext4: Make the extent validity check more paranoid jbd: use SWRITE_SYNC_PLUG when writing synchronous revoke records jbd2: use SWRITE_SYNC_PLUG when writing synchronous revoke records ext4: really print the find_group_flex fallback warning only once
2009-04-14jbd: use SWRITE_SYNC_PLUG when writing synchronous revoke recordsTheodore Ts'o
The revoke records must be written using the same way as the rest of the blocks during the commit process; that is, either marked as synchronous writes or as asynchornous writes. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-13jbd: update locking comentsJan Kara
Update information about locking in JBD revoke code. Reported-by: Lin Tan <tammy000@gmail.com>. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: tidy up revoke cache initialisation and destructionDuane Griffin
Make revocation cache destruction safe to call if initialisation fails partially or entirely. This allows it to be used to cleanup in the case of initialisation failure, simplifying that code slightly. Signed-off-by: Duane Griffin <duaneg@dghda.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: eliminate duplicated code in revocation table init/destroy functionsDuane Griffin
The revocation table initialisation/destruction code is repeated for each of the two revocation tables stored in the journal. Refactoring the duplicated code into functions is tidier, simplifies the logic in initialisation in particular, and slightly reduces the code size. There should not be any functional change. Signed-off-by: Duane Griffin <duaneg@dghda.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28jbd: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-30jbd/jbd2 NULL noiseAl Viro
2007-10-16Group short-lived and reclaimable kernel allocationsMel Gorman
This patch marks a number of allocations that are either short-lived such as network buffers or are reclaimable such as inode allocations. When something like updatedb is called, long-lived and unmovable kernel allocations tend to be spread throughout the address space which increases fragmentation. This patch groups these allocations together as much as possible by adding a new MIGRATE_TYPE. The MIGRATE_RECLAIMABLE type is for allocations that can be reclaimed on demand, but not moved. i.e. they can be migrated by deleting them and re-reading the information from elsewhere. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16is_power_of_2(): jbdvignesh babu
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2(). Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Change ll_rw_block() calls in JBDJan Kara
We must be sure that the current data in buffer are sent to disk. Hence we have to call ll_rw_block() with SWRITE. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fs/jbd/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - journal.c: remove the unused global function __journal_internal_check and move the check to journal_init - remove the following write-only global variable: - journal.c: current_journal - remove the following unneeded EXPORT_SYMBOL: - journal.c: journal_recover Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
