commit 794446c6946513c684d448205fbd76fa35f38b72 upstream.
The following race is possible:
[kjournald2] other_task
jbd2_journal_commit_transaction()
j_state = T_FINISHED;
spin_unlock(&journal->j_list_lock);
->jbd2_journal_remove_checkpoint()
->jbd2_journal_free_transaction();
->kmem_cache_free(transaction)
->j_commit_callback(journal, transaction);
-> USE_AFTER_FREE
WARNING: at lib/list_debug.c:62 __list_del_entry+0x1c0/0x250()
Hardware name:
list_del corruption. prev->next should be ffff88019a4ec198, but was 6b6b6b6b6b6b6b6b
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
Pid: 16400, comm: jbd2/dm-1-8 Tainted: G W 3.8.0-rc3+ #107
Call Trace:
[<ffffffff8106fb0d>] warn_slowpath_common+0xad/0xf0
[<ffffffff8106fc06>] warn_slowpath_fmt+0x46/0x50
[<ffffffff813637e9>] ? ext4_journal_commit_callback+0x99/0xc0
[<ffffffff8148cae0>] __list_del_entry+0x1c0/0x250
[<ffffffff813637bf>] ext4_journal_commit_callback+0x6f/0xc0
[<ffffffff813ca336>] jbd2_journal_commit_transaction+0x23a6/0x2570
[<ffffffff8108aa42>] ? try_to_del_timer_sync+0x82/0xa0
[<ffffffff8108b491>] ? del_timer_sync+0x91/0x1e0
[<ffffffff813d3ecf>] kjournald2+0x19f/0x6a0
[<ffffffff810ad630>] ? wake_up_bit+0x40/0x40
[<ffffffff813d3d30>] ? bit_spin_lock+0x80/0x80
[<ffffffff810ac6be>] kthread+0x10e/0x120
[<ffffffff810ac5b0>] ? __init_kthread_worker+0x70/0x70
[<ffffffff818ff6ac>] ret_from_fork+0x7c/0xb0
In order to demonstrace this issue one should mount ext4 with mount -o
discard option on SSD disk. This makes callback longer and race
window becomes wider.
In order to fix this we should mark transaction as finished only after
callbacks have completed
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
flush request is issued in transaction commit code path, so looks using
GFP_KERNEL to allocate memory for flush request bio falls into the classic
deadlock issue. I saw btrfs and dm get it right, but ext4, xfs and md are
using GFP.
Signed-off-by: Shaohua Li <shli@fusionio.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates for 3.4 from Ted Ts'o:
"Ext4 commits for 3.3 merge window; mostly cleanups and bug fixes
The changes to export dirty_writeback_interval are from Artem's s_dirt
cleanup patch series. The same is true of the change to remove the
s_dirt helper functions which never got used by anyone in-tree. I've
run these changes by Al Viro, and am carrying them so that Artem can
more easily fix up the rest of the file systems during the next merge
window. (Originally we had hopped to remove the use of s_dirt from
ext4 during this merge window, but his patches had some bugs, so I
ultimately ended dropping them from the ext4 tree.)"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (66 commits)
vfs: remove unused superblock helpers
mm: export dirty_writeback_interval
ext4: remove useless s_dirt assignment
ext4: write superblock only once on unmount
ext4: do not mark superblock as dirty unnecessarily
ext4: correct ext4_punch_hole return codes
ext4: remove restrictive checks for EOFBLOCKS_FL
ext4: always set then trimmed blocks count into len
ext4: fix trimmed block count accunting
ext4: fix start and len arguments handling in ext4_trim_fs()
ext4: update s_free_{inodes,blocks}_count during online resize
ext4: change some printk() calls to use ext4_msg() instead
ext4: avoid output message interleaving in ext4_error_<foo>()
ext4: remove trailing newlines from ext4_msg() and ext4_error() messages
ext4: add no_printk argument validation, fix fallout
ext4: remove redundant "EXT4-fs: " from uses of ext4_msg
ext4: give more helpful error message in ext4_ext_rm_leaf()
ext4: remove unused code from ext4_ext_map_blocks()
ext4: rewrite punch hole to use ext4_ext_remove_space()
jbd2: cleanup journal tail after transaction commit
Signed-off-by: Cong Wang <amwang@redhat.com>
Normally, we have to issue a cache flush before we can update journal tail in
journal superblock, effectively wiping out old transactions from the journal.
So use the fact that during transaction commit we issue cache flush anyway and
opportunistically push journal tail as far as we can. Since update of journal
superblock is still costly (we have to use WRITE_FUA), we update log tail only
if we can free significant amount of space.
When we reach jbd2_cleanup_journal_tail(), there is no guarantee that
checkpointed buffers are on a stable storage - especially if buffers were
written out by jbd2_log_do_checkpoint(), they are likely to be only in disk's
caches. Thus when we update journal superblock effectively removing old
transaction from journal, this write of superblock can get to stable storage
before those checkpointed buffers which can result in filesystem corruption
after a crash. Thus we must unconditionally issue a cache flush before we
update journal superblock in these cases.
A similar problem can also occur if journal superblock is written only in
disk's caches, other transaction starts reusing space of the transaction
cleaned from the log and power failure happens. Subsequent journal replay would
still try to replay the old transaction but some of it's blocks may be already
overwritten by the new transaction. For this reason we must use WRITE_FUA when
updating log tail and we must first write new log tail to disk and update
in-memory information only after that.
There are some log tail updates that are not protected by j_checkpoint_mutex.
Some of these are harmless because they happen during startup or shutdown but
updates in jbd2_journal_commit_transaction() and jbd2_journal_flush() can
really race with other log tail updates (e.g. someone doing
jbd2_journal_flush() with someone running jbd2_cleanup_journal_tail()). So
protect all log tail updates with j_checkpoint_mutex.
There are three case of updating journal superblock. In the first case, we want
to mark journal as empty (setting s_sequence to 0), in the second case we want
to update log tail, in the third case we want to update s_errno. Split these
cases into separate functions. It makes the code slightly more straightforward
and later patches will make the distinction even more important.
There is normally only a handful of these active at any one time, but
putting them in a separate slab cache makes debugging memory
corruption problems easier. Manish Katiyar also wanted this make it
easier to test memory failure scenarios in the jbd2 layer.
Cc: Manish Katiyar <mkatiyar@gmail.com>
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Currently, we clear revoked flag only when a block is reused. However,
this can tigger a false journal error. Consider a situation when a block
is used as a meta block and is deleted(revoked) in ordered mode, then the
block is allocated as a data block to a file. At this moment, user changes
the file's journal mode from ordered to journaled and truncates the file.
The block will be considered re-revoked by journal because it has revoked
flag still pending from the last transaction and an assertion triggers.
We fix the problem by keeping the revoked status more uptodate - we clear
revoked flag when switching revoke tables to reflect there is no revoked
buffers in current transaction any more.
Some jbd2 code prints out kernel messages with "JBD2: " prefix, at the
same time other jbd2 code prints with "JBD: " prefix. Unify the prefix
to "JBD2: ".
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
jbd2_journal_remove_journal_head() can oops when trying to access
journal_head returned by bh2jh(). This is caused for example by the
following race:
TASK1 TASK2
processing t_forget list
__jbd2_journal_refile_buffer(jh);
if (!jh->b_transaction) {
jbd_unlock_bh_state(bh);
jbd2_journal_try_to_free_buffers()
jbd2_journal_grab_journal_head(bh)
jbd_lock_bh_state(bh)
__journal_try_to_free_buffer()
jbd2_journal_put_journal_head(jh)
jbd2_journal_remove_journal_head(bh);
jbd2_journal_put_journal_head() in TASK2 sees that b_jcount == 0 and
buffer is not part of any transaction and thus frees journal_head
before TASK1 gets to doing so. Note that even buffer_head can be
released by try_to_free_buffers() after
jbd2_journal_put_journal_head() which adds even larger opportunity for
oops (but I didn't see this happen in reality).
Fix the problem by making transactions hold their own journal_head
reference (in b_jcount). That way we don't have to remove journal_head
explicitely via jbd2_journal_remove_journal_head() and instead just
remove journal_head when b_jcount drops to zero. The result of this is
that [__]jbd2_journal_refile_buffer(),
[__]jbd2_journal_unfile_buffer(), and
__jdb2_journal_remove_checkpoint() can free journal_head which needs
modification of a few callers. Also we have to be careful because once
journal_head is removed, buffer_head might be freed as well. So we
have to get our own buffer_head reference where it matters.
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (61 commits)
jbd2: Add MAINTAINERS entry
jbd2: fix a potential leak of a journal_head on an error path
ext4: teach ext4_ext_split to calculate extents efficiently
ext4: Convert ext4 to new truncate calling convention
ext4: do not normalize block requests from fallocate()
ext4: enable "punch hole" functionality
ext4: add "punch hole" flag to ext4_map_blocks()
ext4: punch out extents
ext4: add new function ext4_block_zero_page_range()
ext4: add flag to ext4_has_free_blocks
ext4: reserve inodes and feature code for 'quota' feature
ext4: add support for multiple mount protection
ext4: ensure f_bfree returned by ext4_statfs() is non-negative
ext4: protect bb_first_free in ext4_trim_all_free() with group lock
ext4: only load buddy bitmap in ext4_trim_fs() when it is needed
jbd2: Fix comment to match the code in jbd2__journal_start()
ext4: fix waiting and sending of a barrier in ext4_sync_file()
jbd2: Add function jbd2_trans_will_send_data_barrier()
jbd2: fix sending of data flush on journal commit
ext4: fix ext4_ext_fiemap_cb() to handle blocks before request range correctly
Provide a function which returns whether a transaction with given tid
will send a flush to the filesystem device. The function will be used
by ext4 to detect whether fsync needs to send a separate flush or not.
In data=ordered mode, it's theoretically possible (however rare) that
an inode is filed to transaction's t_inode_list and a flusher thread
writes all the data and inode is reclaimed before the transaction
starts to commit. In such a case, we could erroneously omit sending a
flush to file system device when it is different from the journal
device (because data can still be in disk cache only).
Fix the problem by setting a flag in a transaction when some inode is added
to it and then send disk flush in the commit code when the flag is set.
summarise_journal_usage seems to be obsolete for a long time,
so remove it.
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
In do_get_write_access() we wait on BH_Unshadow bit for buffer to get
from shadow state. The waking code in journal_commit_transaction() has
a bug because it does not issue a memory barrier after the buffer is
moved from the shadow state and before wake_up_bit() is called. Thus a
waitqueue check can happen before the buffer is actually moved from
the shadow state and waiting process may never be woken. Fix the
problem by issuing proper barrier.
Reported-by: Tao Ma <boyu.mt@taobao.com>
ext4: fix data corruption regression by reverting commit 6de9843dab3f
ext4: Allow indirect-block file to grow the file size to max file size
ext4: allow an active handle to be started when freezing
ext4: sync the directory inode in ext4_sync_parent()
ext4: init timer earlier to avoid a kernel panic in __save_error_info
jbd2: fix potential memory leak on transaction commit
ext4: fix a double free in ext4_register_li_request
ext4: fix credits computing for indirect mapped files
ext4: remove unnecessary [cm]time update of quota file
jbd2: move bdget out of critical section
There is potential memory leak of journal head in function
jbd2_journal_commit_transaction. The problem is that JBD2 will not
reclaim the journal head of commit record if error occurs or journal
is abotred.
I use the following script to reproduce this issue, on a RHEL6
system. I found it very easy to reproduce with async commit enabled.
mount /dev/sdb /mnt -o journal_checksum,journal_async_commit
touch /mnt/xxx
echo offline > /sys/block/sdb/device/state
sync
umount /mnt
rmmod ext4
rmmod jbd2
Removal of the jbd2 module will make slab complaining that
"cache `jbd2_journal_head': can't free all objects".
Signed-off-by: Zhang Huan <zhhuan@gmail.com>
'write_op' was still used, even though it was always WRITE_SYNC now.
Add plugging around the cases where it submits IO, and flush them
before we end up waiting for that IO.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
With the plugging now being explicitly controlled by the
submitter, callers need not pass down unplugging hints
to the block layer. If they want to unplug, it's because they
manually plugged on their own - in which case, they should just
unplug at will.
fs/ext4/inode.c
fs/ext4/mballoc.c
include/trace/events/ext4.h
This fixes a hang seen in jbd2_journal_release_jbd_inode
on a lot of Power 6 systems running with ext4. When we get
in the hung state, all I/O to the disk in question gets blocked
where we stay indefinitely. Looking at the task list, I can see
we are stuck in jbd2_journal_release_jbd_inode waiting on a
wake up. I added some debug code to detect this scenario and
dump additional data if we were stuck in jbd2_journal_release_jbd_inode
for longer than 30 minutes. When it hit, I was able to see that
i_flags was 0, suggesting we missed the wake up.
This patch changes i_flags to be an unsigned long, uses bit operators
to access it, and adds barriers around the accesses. Prior to applying
this patch, we were regularly hitting this hang on numerous systems
in our test environment. After applying the patch, the hangs no longer
occur.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits)
xen-blkfront: disable barrier/flush write support
Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c
block: remove BLKDEV_IFL_WAIT
aic7xxx_old: removed unused 'req' variable
block: remove the BH_Eopnotsupp flag
block: remove the BLKDEV_IFL_BARRIER flag
block: remove the WRITE_BARRIER flag
swap: do not send discards as barriers
fat: do not send discards as barriers
ext4: do not send discards as barriers
jbd2: replace barriers with explicit flush / FUA usage
jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier
jbd: replace barriers with explicit flush / FUA usage
nilfs2: replace barriers with explicit flush / FUA usage
reiserfs: replace barriers with explicit flush / FUA usage
gfs2: replace barriers with explicit flush / FUA usage
btrfs: replace barriers with explicit flush / FUA usage
xfs: replace barriers with explicit flush / FUA usage
block: pass gfp_mask and flags to sb_issue_discard
dm: convey that all flushes are processed as empty
Fsync performance for small files achieved by cfq on high-end disks is
lower than what deadline can achieve, due to idling introduced between
the sync write happening in process context and the journal commit.
Moreover, when competing with a sequential reader, a process writing
small files and fsync-ing them is starved.
This patch fixes the two problems by:
- marking journal commits as WRITE_SYNC, so that they get the REQ_NOIDLE
flag set,
- force all queues that have REQ_NOIDLE requests to be put in the noidle
tree.
Having the queue associated to the fsync-ing process and the one associated
to journal commits in the noidle tree allows:
- switching between them without idling,
- fairness vs. competing idling queues, since they will be serviced only
after the noidle tree expires its slice.
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Tested-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Corrado Zoccolo <czoccolo@gmail.com>
All the blkdev_issue_* helpers can only sanely be used for synchronous
caller. To issue cache flushes or barriers asynchronously the caller needs
to set up a bio by itself with a completion callback to move the asynchronous
state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always
specified when calling blkdev_issue_* and also remove the now unused flags
argument to blkdev_issue_flush and blkdev_issue_zeroout. For
blkdev_issue_discard we need to keep it for the secure discard flag, which
gains a more descriptive name and loses the bitops vs flag confusion.
Switch to the WRITE_FLUSH_FUA flag for journal commits and remove the
EOPNOTSUPP detection for barriers.
Acked-by: Jan Kara <jack@suse.cz>
Currently JBD2 relies blkdev_issue_flush() draining the queue when ASYNC_COMMIT
feature is set. This property is going away so make JBD2 wait for buffers it
needs on its own before submitting the cache flush.
Instead of abusing a buffer_head flag just add a variant of
sync_dirty_buffer which allows passing the exact type of write
flag required.
This should remove the last exclusive lock from start_this_handle(),
so that we should now be able to start multiple transactions at the
same time on large SMP systems.
Lockstat reports have shown that j_state_lock is a major source of
lock contention, especially on systems with more than 4 CPU cores. So
change it to be a read/write spinlock.
By using an atomic_t for t_updates and t_outstanding credits, this
should allow us to not need to take transaction t_handle_lock in
jbd2_journal_stop().
Saying things like "sync failed" when a device does
not support barriers makes users slightly more worried than
they need to be; rather than talking about sync failures,
let's just state the barrier-based facts.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
The patch just convert all blkdev_issue_xxx function to common
set of flags. Wait/allocation semantics preserved.
commit_transaction has the same value as journal->j_running_transaction,
so we can simplify the assert statement.
Signed-off-by: dingdinghua <dingdinghua@nrchpc.ac.cn>
Delay discarding buffers in journal_unmap_buffer until
we know that "add to orphan" operation has definitely been
committed, otherwise the log space of committing transation
may be freed and reused before truncate get committed, updates
may get lost if crash happens.
This is a bit complicated because we are trying to optimize when we
send barriers to the fs data disk. We could just throw in an extra
barrier to the data disk whenever we send a barrier to the journal
disk, but that's not always strictly necessary.
We only need to send a barrier during a commit when there are data
blocks which are must be written out due to an inode written in
ordered mode, or if fsync() depends on the commit to force data blocks
to disk. Finally, before we drop transactions from the beginning of
the journal during a checkpoint operation, we need to guarantee that
any blocks that were flushed out to the data disk are firmly on the
rust platter before we drop the transaction from the journal.
Thanks to Oleg Drokin for pointing out this flaw in ext3/ext4.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (21 commits)
ext3: PTR_ERR return of wrong pointer in setup_new_group_blocks()
ext3: Fix data / filesystem corruption when write fails to copy data
ext4: Support for 64-bit quota format
ext3: Support for vfsv1 quota format
quota: Implement quota format with 64-bit space and inode limits
quota: Move definition of QFMT_OCFS2 to linux/quota.h
ext2: fix comment in ext2_find_entry about return values
ext3: Unify log messages in ext3
ext2: clear uptodate flag on super block I/O error
ext2: Unify log messages in ext2
ext3: make "norecovery" an alias for "noload"
ext3: Don't update the superblock in ext3_statfs()
ext3: journal all modifications in ext3_xattr_set_handle
ext2: Explicitly assign values to on-disk enum of filetypes
quota: Fix WARN_ON in lookup_one_len
const: struct quota_format_ops
ubifs: remove manual O_SYNC handling
afs: remove manual O_SYNC handling
kill wait_on_page_writeback_range
vfs: Implement proper O_SYNC semantics
All callers really want the more logical filemap_fdatawait_range interface,
so convert them to use it and merge wait_on_page_writeback_range into
filemap_fdatawait_range.
OOM happens.
The /proc/fs/jbd2/<dev>/history was maintained manually; by using
tracepoints, we can get all of the existing functionality of the /proc
file plus extra capabilities thanks to the ftrace infrastructure. We
save memory as a bonus.
Previously the journal_async_commit mount option was equivalent to
using barrier=0 (and just as unsafe). This patch fixes it so that we
eliminate the barrier before the commit block (by not using ordered
mode), and explicitly issuing an empty barrier bio after writing the
commit block. Because of the journal checksum, it is safe to do this;
if the journal blocks are not all written before a power failure, the
checksum in the commit block will prevent the last transaction from
being replayed.
Using the fs_mark benchmark, using journal_async_commit shows a 50%
improvement:
FSUse% Count Size Files/sec App Overhead
8 1000 10240 30.5 28242
vs.
8 1000 10240 45.8 28620
It's only set, it's never checked. Kill it.
The revoke records must be written using the same way as the rest of
the blocks during the commit process; that is, either marked as
synchronous writes or as asynchornous writes.
When you are going to be submitting several sync writes, we want to
give the IO scheduler a chance to merge some of them. Instead of
using the implicitly unplugging WRITE_SYNC variant, use WRITE_SYNC_PLUG
and rely on sync_buffer() doing the unplug when someone does a
wait_on_buffer()/lock_buffer().
If a commit is triggered by fsync(), set a flag indicating the journal
blocks associated with the transaction should be flushed out using
WRITE_SYNC.
