path: root/fs/jbd2/transaction.c
2010-07-15jbd2/ocfs2: Fix block checksumming when a buffer is used in several transactionsJan Kara
OCFS2 uses t_commit trigger to compute and store checksum of the just committed blocks. When a buffer has b_frozen_data, checksum is computed for it instead of b_data but this can result in an old checksum being written to the filesystem in the following scenario: 1) transaction1 is opened 2) handle1 is opened 3) journal_access(handle1, bh) - This sets jh->b_transaction to transaction1 4) modify(bh) 5) journal_dirty(handle1, bh) 6) handle1 is closed 7) start committing transaction1, opening transaction2 8) handle2 is opened 9) journal_access(handle2, bh) - This copies off b_frozen_data to make it safe for transaction1 to commit. jh->b_next_transaction is set to transaction2. 10) jbd2_journal_write_metadata() checksums b_frozen_data 11) the journal correctly writes b_frozen_data to the disk journal 12) handle2 is closed - There was no dirty call for the bh on handle2, so it is never queued for any more journal operation 13) Checkpointing finally happens, and it just spools the bh via normal buffer writeback. This will write b_data, which was never triggered on and thus contains a wrong (old) checksum. This patch fixes the problem by calling the trigger at the moment data is frozen for journal commit - i.e., either when b_frozen_data is created by do_get_write_access or just before we write a buffer to the log if b_frozen_data does not exist. We also rename the trigger to t_frozen as that better describes when it is called. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-16jbd2: Improve scalability by not taking j_state_lock in jbd2_journal_stop()Theodore Ts'o
One of the most contended locks in the jbd2 layer is j_state_lock when running dbench. This is especially true if using the real-time kernel with its "sleeping spinlocks" patch that replaces spinlocks with priority inheriting mutexes --- but it also shows up on large SMP benchmarks. Thanks to John Stultz for pointing this out. Reviewed by Mingming Cao and Jan Kara. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-02-15jbd2: delay discarding buffers in journal_unmap_bufferdingdinghua
Delay discarding buffers in journal_unmap_buffer until we know that "add to orphan" operation has definitely been committed, otherwise the log space of committing transation may be freed and reused before truncate get committed, updates may get lost if crash happens. Signed-off-by: dingdinghua <dingdinghua@nrchpc.ac.cn> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-17jbd2: Annotate transaction start also for jbd2_journal_restart()Jan Kara
lockdep annotation for a transaction start has been at the end of jbd2_journal_start(). But a transaction is also started from jbd2_journal_restart(). Move the lockdep annotation to start_this_handle() which covers both cases. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-10jbd2: round commit timer up to avoid uncommitted transactionAndreas Dilger
fix jiffie rounding in jbd commit timer setup code. Rounding down could cause the timer to be fired before the corresponding transaction has expired. That transaction can stay not committed forever if no new transaction is created or expicit sync/umount happens. Signed-off-by: Alex Zhuravlev (Tomas) <alex.zhuravlev@sun.com> Signed-off-by: Andreas Dilger <adilger@sun.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-13jbd2: Fix a race between checkpointing code and journal_get_write_access()Jan Kara
The following race can happen: CPU1 CPU2 checkpointing code checks the buffer, adds it to an array for writeback do_get_write_access() ... lock_buffer() unlock_buffer() flush_batch() submits the buffer for IO __jbd2_journal_file_buffer() So a buffer under writeout is returned from do_get_write_access(). Since the filesystem code relies on the fact that journaled buffers cannot be written out, it does not take the buffer lock and so it can modify buffer while it is under writeout. That can lead to a filesystem corruption if we crash at the right moment. We fix the problem by clearing the buffer dirty bit under buffer_lock even if the buffer is on BJ_None list. Actually, we clear the dirty bit regardless the list the buffer is in and warn about the fact if the buffer is already journalled. Thanks for spotting the problem goes to dingdinghua <dingdinghua85@gmail.com>. Reported-by: dingdinghua <dingdinghua85@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-06-17jbd2: clean up jbd2_journal_try_to_free_buffers()Hisashi Hifumi
This patch reverts 3f31fddf, which is no longer needed because if a race between freeing buffer and committing transaction functionality occurs and dio gets error, currently dio falls back to buffered IO due to the commit 6ccfa806. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Mingming Cao <cmm@us.ibm.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-25ext4: Use WRITE_SYNC for commits which are caused by fsync()Theodore Ts'o
If a commit is triggered by fsync(), set a flag indicating the journal blocks associated with the transaction should be flushed out using WRITE_SYNC. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-02-10jbd2: Avoid possible NULL dereference in jbd2_journal_begin_ordered_truncate()Jan Kara
If we race with commit code setting i_transaction to NULL, we could possibly dereference it. Proper locking requires the journal pointer (to access journal->j_list_lock), which we don't have. So we have to change the prototype of the function so that filesystem passes us the journal pointer. Also add a more detailed comment about why the function jbd2_journal_begin_ordered_truncate() does what it does and how it should be used. Thanks to Dan Carpenter <error27@gmail.com> for pointing to the suspitious code. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Joel Becker <joel.becker@oracle.com> CC: linux-ext4@vger.kernel.org CC: ocfs2-devel@oss.oracle.com CC: mfasheh@suse.de CC: Dan Carpenter <error27@gmail.com>
2009-01-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (57 commits) jbd2: Fix oops in jbd2_journal_init_inode() on corrupted fs ext4: Remove "extents" mount option block: Add Kconfig help which notes that ext4 needs CONFIG_LBD ext4: Make printk's consistently prefixed with "EXT4-fs: " ext4: Add sanity checks for the superblock before mounting the filesystem ext4: Add mount option to set kjournald's I/O priority jbd2: Submit writes to the journal using WRITE_SYNC jbd2: Add pid and journal device name to the "kjournald2 starting" message ext4: Add markers for better debuggability ext4: Remove code to create the journal inode ext4: provide function to release metadata pages under memory pressure ext3: provide function to release metadata pages under memory pressure add releasepage hooks to block devices which can be used by file systems ext4: Fix s_dirty_blocks_counter if block allocation failed with nodelalloc ext4: Init the complete page while building buddy cache ext4: Don't allow new groups to be added during block allocation ext4: mark the blocks/inode bitmap beyond end of group as used ext4: Use new buffer_head flag to check uninit group bitmaps initialization ext4: Fix the race between read_inode_bitmap() and ext4_new_inode() ext4: code cleanup ...
2009-01-05jbd2: Add buffer triggersJoel Becker
Filesystems often to do compute intensive operation on some metadata. If this operation is repeated many times, it can be very expensive. It would be much nicer if the operation could be performed once before a buffer goes to disk. This adds triggers to jbd2 buffer heads. Just before writing a metadata buffer to the journal, jbd2 will optionally call a commit trigger associated with the buffer. If the journal is aborted, an abort trigger will be called on any dirty buffers as they are dropped from pending transactions. ocfs2 will use this feature. Initially I tried to come up with a more generic trigger that could be used for non-buffer-related events like transaction completion. It doesn't tie nicely, because the information a buffer trigger needs (specific to a journal_head) isn't the same as what a transaction trigger needs (specific to a tranaction_t or perhaps journal_t). So I implemented a buffer set, with the understanding that journal/transaction wide triggers should be implemented separately. There is only one trigger set allowed per buffer. I can't think of any reason to attach more than one set. Contrast this with a journal or transaction in which multiple places may want to watch the entire transaction separately. The trigger sets are considered static allocation from the jbd2 perspective. ocfs2 will just have one trigger set per block type, setting the same set on every bh of the same type. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-03ext4: add fsync batch tuning knobsTheodore Ts'o
Add new mount options, min_batch_time and max_batch_time, which controls how long the jbd2 layer should wait for additional filesystem operations to get batched with a synchronous write transaction. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-11-26jbd2: improve jbd2 fsync batchingJosef Bacik
This patch removes the static sleep time in favor of a more self optimizing approach where we measure the average amount of time it takes to commit a transaction to disk and the ammount of time a transaction has been running. If somebody does a sync write or an fsync() traditionally we would sleep for 1 jiffies, which depending on the value of HZ could be a significant amount of time compared to how long it takes to commit a transaction to the underlying storage. With this patch instead of sleeping for a jiffie, we check to see if the amount of time this transaction has been running is less than the average commit time, and if it is we sleep for the delta using schedule_hrtimeout to give us a higher precision sleep time. This greatly benefits high end storage where you could end up sleeping for longer than it takes to commit the transaction and therefore sitting idle instead of allowing the transaction to be committed by keeping the sleep time to a minimum so you are sure to always be doing something. Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-16ext4: Replace hackish ext4_mb_poll_new_transaction with commit callbackTheodore Ts'o
The multiblock allocator needs to be able to release blocks (and issue a blkdev discard request) when the transaction which freed those blocks is committed. Previously this was done via a polling mechanism when blocks are allocated or freed. A much better way of doing things is to create a jbd2 callback function and attaching the list of blocks to be freed directly to the transaction structure. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-08-11lockdep: rename map_[acquire|release]() => lock_map_[acquire|release]()Ingo Molnar
the names were too generic: drivers/uio/uio.c:87: error: expected identifier or '(' before 'do' drivers/uio/uio.c:87: error: expected identifier or '(' before 'while' drivers/uio/uio.c:113: error: 'map_release' undeclared here (not in a function) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-11lockdep: map_acquirePeter Zijlstra
Most the free-standing lock_acquire() usages look remarkably similar, sweep them into a new helper. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-11jbd2: Remove data=ordered mode support using jbd buffer headsJan Kara
2008-07-11jbd2: Implement data=ordered mode handling via inodesJan Kara
This patch adds necessary framework into JBD2 to be able to track inodes with each transaction and write-out their dirty data during transaction commit time. This new ordered mode brings all sorts of advantages such as possibility to get rid of journal heads and buffer heads for data buffers in ordered mode, better ordering of writes on transaction commit, simplification of some JBD code, no more anonymous pages when truncate of data being committed happens. Also with this new ordered mode, delayed allocation on ordered mode is much simpler. Signed-off-by: Jan Kara <jack@suse.cz>
2008-07-13jbd2: fix race between jbd2_journal_try_to_free_buffers() and jbd2 commit ↵Mingming Cao
transaction journal_try_to_free_buffers() could race with jbd commit transaction when the later is holding the buffer reference while waiting for the data buffer to flush to disk. If the caller of journal_try_to_free_buffers() request tries hard to release the buffers, it will treat the failure as error and return back to the caller. We have seen the directo IO failed due to this race. Some of the caller of releasepage() also expecting the buffer to be dropped when passed with GFP_KERNEL mask to the releasepage()->journal_try_to_free_buffers(). With this patch, if the caller is passing the GFP_KERNEL to indicating this call could wait, in case of try_to_free_buffers() failed, let's waiting for journal_commit_transaction() to finish commit the current committing transaction , then try to free those buffers again with journal locked. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Reviewed-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17jdb2: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17jbd2: fix kernel-doc notationRandy Dunlap
Fix kernel-doc notation in jbd2. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17jbd2: fix possible journal overflow issuesJosef Bacik
There are several cases where the running transaction can get buffers added to its BJ_Metadata list which it never dirtied, which makes its t_nr_buffers counter end up larger than its t_outstanding_credits counter. This will cause issues when starting new transactions as while we are logging buffers we decrement t_outstanding_buffers, so when t_outstanding_buffers goes negative, we will report that we need less space in the journal than we actually need, so transactions will be started even though there may not be enough room for them. In the worst case scenario (which admittedly is almost impossible to reproduce) this will result in the journal running out of space. The fix is to only refile buffers from the committing transaction to the running transactions BJ_Modified list when b_modified is set on that journal, which is the only way to be sure if the running transaction has modified that buffer. This patch also fixes an accounting error in journal_forget, it is possible that we can call journal_forget on a buffer without having modified it, only gotten write access to it, so instead of freeing a credit, we only do so if the buffer was modified. The assert will help catch if this problem occurs. Without these two patches I could hit this assert within minutes of running postmark, with them this issue no longer arises. Cc: <linux-ext4@vger.kernel.org> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17jbd2: fix the way the b_modified flag is clearedJosef Bacik
Currently at the start of a journal commit we loop through all of the buffers on the committing transaction and clear the b_modified flag (the flag that is set when a transaction modifies the buffer) under the j_list_lock. The problem is that everywhere else this flag is modified only under the jbd2 lock buffer flag, so it will race with a running transaction who could potentially set it, and have it unset by the committing transaction. This is also a big waste, you can have several thousands of buffers that you are clearing the modified flag on when you may not need to. This patch removes this code and instead clears the b_modified flag upon entering do_get_write_access/journal_get_create_access, so if that transaction does indeed use the buffer then it will be accounted for properly, and if it does not then we know we didn't use it. That will be important for the next patch in this series. Tested thoroughly by myself using postmark/iozone/bonnie++. Cc: <linux-ext4@vger.kernel.org> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Josef Bacik <jbacik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28jbd2: sparse pointer use of zero as nullMingming Cao
Get rid of sparse related warnings from places that use integer as NULL pointer. (Ported from upstream ext3/jbd changes.) Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28jbd2: Use round-jiffies() function for the "5 second" ext4/jbd2 wakeupMingming Cao
While "every 5 seconds" doesn't sound as a problem, there can be many of these (and these timers do add up over all the kernel). The "5 second" wakeup isn't really timing sensitive; in addition even with rounding it'll still happen every 5 seconds (with the exception of the very first time, which is likely to be rounded up to somewhere closer to 6 seconds) (Ported from similar JBD patch made by Arjan van de Ven to fs/jbd/transaction.c) Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28jbd2: add lockdep supportMingming Cao
Ported from similar patch for the jbd layer. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28jbd2: jbd2 stats through procfsJohann Lombardi
The patch below updates the jbd stats patch to 2.6.20/jbd2. The initial patch was posted by Alex Tomas in December 2005 (http://marc.info/?l=linux-ext4&m=113538565128617&w=2). It provides statistics via procfs such as transaction lifetime and size. Sometimes, investigating performance problems, i find useful to have stats from jbd about transaction's lifetime, size, etc. here is a patch for review and inclusion probably. for example, stats after creation of 3M files in htree directory: [root@bob ~]# cat /proc/fs/jbd/sda/history R/C tid wait run lock flush log hndls block inlog ctime write drop close R 261 8260 2720 0 0 750 9892 8170 8187 C 259 750 0 4885 1 R 262 20 2200 10 0 770 9836 8170 8187 R 263 30 2200 10 0 3070 9812 8170 8187 R 264 0 5000 10 0 1340 0 0 0 C 261 8240 3212 4957 0 R 265 8260 1470 0 0 4640 9854 8170 8187 R 266 0 5000 10 0 1460 0 0 0 C 262 8210 2989 4868 0 R 267 8230 1490 10 0 4440 9875 8171 8188 R 268 0 5000 10 0 1260 0 0 0 C 263 7710 2937 4908 0 R 269 7730 1470 10 0 3330 9841 8170 8187 R 270 0 5000 10 0 830 0 0 0 C 265 8140 3234 4898 0 C 267 720 0 4849 1 R 271 8630 2740 20 0 740 9819 8170 8187 C 269 800 0 4214 1 R 272 40 2170 10 0 830 9716 8170 8187 R 273 40 2280 0 0 3530 9799 8170 8187 R 274 0 5000 10 0 990 0 0 0 where, R - line for transaction's life from T_RUNNING to T_FINISHED C - line for transaction's checkpointing tid - transaction's id wait - for how long we were waiting for new transaction to start (the longest period journal_start() took in this transaction) run - real transaction's lifetime (from T_RUNNING to T_LOCKED lock - how long we were waiting for all handles to close (time the transaction was in T_LOCKED) flush - how long it took to flush all data (data=ordered) log - how long it took to write the transaction to the log hndls - how many handles got to the transaction block - how many blocks got to the transaction inlog - how many blocks are written to the log (block + descriptors) ctime - how long it took to checkpoint the transaction write - how many blocks have been written during checkpointing drop - how many blocks have been dropped during checkpointing close - how many running transactions have been closed to checkpoint this one all times are in msec. [root@bob ~]# cat /proc/fs/jbd/sda/info 280 transaction, each upto 8192 blocks average: 1633ms waiting for transaction 3616ms running transaction 5ms transaction was being locked 1ms flushing data (in ordered mode) 1799ms logging transaction 11781 handles per transaction 5629 blocks per transaction 5641 logged blocks per transaction Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2007-10-17JBD2/Ext4: Convert kmalloc to kzalloc in jbd2/ext4Mingming Cao
Convert kmalloc to kzalloc() and get rid of the memset(). Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-10-17JBD2: replace jbd_kmalloc with kmalloc directly.Mingming Cao
This patch cleans up jbd_kmalloc and replace it with kmalloc directly Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-10-17JBD2: jbd2 slab allocation cleanupsMingming Cao
JBD2: Replace slab allocations with page allocations JBD2 allocate memory for committed_data and frozen_data from slab. However JBD2 should not pass slab pages down to the block layer. Use page allocator pages instead. This will also prepare JBD for the large blocksize patchset. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-07[PATCH] make fs/jbd2/transaction.c:__kbd2_journal_temp_unlink_buffer() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] jbd2: journal_dirty_data re-check for unmapped buffersEric Sandeen
When running several fsx's and other filesystem stress tests, we found cases where an unmapped buffer was still being sent to submit_bh by the ext3 dirty data journaling code. I saw this happen in two ways, both related to another thread doing a truncate which would unmap the buffer in question. Either we would get into journal_dirty_data with a bh which was already unmapped (although journal_dirty_data_fn had checked for this earlier, the state was not locked at that point), or it would get unmapped in the middle of journal_dirty_data when we dropped locks to call sync_dirty_buffer. By re-checking for mapped state after we've acquired the bh state lock, we should avoid these races. If we find a buffer which is no longer mapped, we essentially ignore it, because journal_unmap_buffer has already decided that this buffer can go away. I've also added tracepoints in these two cases, and made a couple other tracepoint changes that I found useful in debugging this. Signed-off-by: Eric Sandeen <esandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] ext3/4: fix J_ASSERT(transaction->t_updates > 0) in journal_stop()OGAWA Hirofumi
A disk generated some I/O error, after it, I hitted J_ASSERT(transaction->t_updates > 0) in journal_stop(). It seems to happened on ext3_truncate() path from stack trace. Then, maybe the following case may trigger J_ASSERT(transaction->t_updates > 0). ext3_truncate() -> ext3_free_branches() -> ext3_journal_test_restart() -> ext3_journal_restart() -> journal_restart() transaction->t_updates--; /* another process aborted journal */ -> start_this_handle() returns -EROFS without transaction->t_updates++; -> ext3_journal_stop() -> journal_stop() J_ASSERT(transaction->t_updates > 0) If journal was aborted in middle of journal_restart(), ext3_truncate() may trigger J_ASSERT(). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename jbd2 symbols to avoid duplication of jbd symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: initial copy of files from jbdDave Kleikamp
This is a simple copy of the files in fs/jbd to fs/jbd2 and /usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
