[ Upstream commit d0a186e0d3e7ac05cc77da7c157dae5aa59f95d9 ]
We invoke jbd2_journal_abort() to abort the journal and record errno
in the jbd2 superblock when committing journal transaction besides the
failure on submitting the commit record. But there is no need for the
case and we can also invoke jbd2_journal_abort() instead of
__jbd2_journal_abort_hard().
Fixes: 818d276ceb83a ("ext4: Add the journal checksum feature")
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Link: https://lore.kernel.org/r/20191204124614.45424-2-yi.zhang@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit 51f57b01e4a3c7d7bdceffd84de35144e8c538e7 ]
JBD2_REC_ERR flag used to indicate the errno has been updated when jbd2
aborted, and then __ext4_abort() and ext4_handle_error() can invoke
panic if ERRORS_PANIC is specified. But if the journal has been aborted
with zero errno, jbd2_journal_abort() didn't set this flag so we can
no longer panic. Fix this by always record the proper errno in the
journal superblock.
Fixes: 4327ba52afd03 ("ext4, jbd2: ensure entering into panic after recording an error in superblock")
Link: https://lore.kernel.org/r/20191204124614.45424-3-yi.zhang@huawei.com
when load journal
[ Upstream commit a09decff5c32060639a685581c380f51b14e1fc2 ]
If the journal is dirty when the filesystem is mounted, jbd2 will replay
the journal but the journal superblock will not be updated by
journal_reset() because JBD2_ABORT flag is still set (it was set in
journal_init_common()). This is problematic because when a new transaction
is then committed, it will be recorded in block 1 (journal->j_tail was set
to 1 in journal_reset()). If unclean shutdown happens again before the
journal superblock is updated, the new recorded transaction will not be
replayed during the next mount (because of stale sb->s_start and
sb->s_sequence values) which can lead to filesystem corruption.
Fixes: 85e0c4e89c1b ("jbd2: if the journal is aborted then don't allow update of the log tail")
Signed-off-by: Kai Li <li.kai4@h3c.com>
Link: https://lore.kernel.org/r/20200111022542.5008-1-li.kai4@h3c.com
[ Upstream commit c96dceeabf765d0b1b1f29c3bf50a5c01315b820 ]
Commit 904cdbd41d74 ("jbd2: clear dirty flag when revoking a buffer from
an older transaction") set the BH_Freed flag when forgetting a metadata
buffer which belongs to the committing transaction, it indicate the
committing process clear dirty bits when it is done with the buffer. But
it also clear the BH_Mapped flag at the same time, which may trigger
below NULL pointer oops when block_size < PAGE_SIZE.
rmdir 1 kjournald2 mkdir 2
jbd2_journal_commit_transaction
commit transaction N
jbd2_journal_forget
set_buffer_freed(bh1)
commit transaction N+1
clear_buffer_mapped(bh1)
ext4_getblk(bh2 ummapped)
grow_dev_page
init_page_buffers
bh1->b_private=NULL
bh2->b_private=NULL
jbd2_journal_put_journal_head(jh1)
__journal_remove_journal_head(hb1)
jh1 is NULL and trigger oops
*) Dir entry block bh1 and bh2 belongs to one page, and the bh2 has
already been unmapped.
For the metadata buffer we forgetting, we should always keep the mapped
flag and clear the dirty flags is enough, so this patch pick out the
these buffers and keep their BH_Mapped flag.
Link: https://lore.kernel.org/r/20200213063821.30455-3-yi.zhang@huawei.com
Fixes: 904cdbd41d74 ("jbd2: clear dirty flag when revoking a buffer from an older transaction")
Cc: stable@kernel.org
[ Upstream commit 6a66a7ded12baa6ebbb2e3e82f8cb91382814839 ]
There is no need to delay the clearing of b_modified flag to the
transaction committing time when unmapping the journalled buffer, so
just move it to the journal_unmap_buffer().
Link: https://lore.kernel.org/r/20200213063821.30455-2-yi.zhang@huawei.com
[ Upstream commit 015c6033068208d6227612c878877919f3fcf6b6 ]
jbd2 statistics counting number of blocks logged in a transaction was
wrong. It didn't count the commit block and more importantly it didn't
count revoke descriptor blocks. Make sure these get properly counted.
Reviewed-by: Theodore Ts'o <tytso@mit.edu>
Link: https://lore.kernel.org/r/20191105164437.32602-13-jack@suse.cz
commit 742b06b5628f2cd23cb51a034cb54dc33c6162c5 upstream.
We hit a BUG at fs/buffer.c:3057 if we detached the nbd device
before unmounting ext4 filesystem.
The typical chain of events leading to the BUG:
jbd2_write_superblock
submit_bh
submit_bh_wbc
BUG_ON(!buffer_mapped(bh));
The block device is removed and all the pages are invalidated. JBD2
was trying to write journal superblock to the block device which is
no longer present.
Fix this by checking the journal superblock's buffer head prior to
submitting.
Reported-by: Eric Ren <renzhen@linux.alibaba.com>
Signed-off-by: Jiufei Xue <jiufei.xue@linux.alibaba.com>
[ Upstream commit 6e876c3dd205d30b0db6850e97a03d75457df007 ]
In jbd2_journal_commit_transaction(), if we are in abort mode,
we may flush the buffer without setting descriptor block checksum
by goto start_journal_io. Then fs is mounted,
jbd2_descriptor_block_csum_verify() failed.
[ 271.379811] EXT4-fs (vdd): shut down requested (2)
[ 271.381827] Aborting journal on device vdd-8.
[ 271.597136] JBD2: Invalid checksum recovering block 22199 in log
[ 271.598023] JBD2: recovery failed
[ 271.598484] EXT4-fs (vdd): error loading journal
Fix this problem by keep setting descriptor block checksum if the
descriptor buffer is not NULL.
This checksum problem can be reproduced by xfstests generic/388.
Signed-off-by: luojiajun <luojiajun3@huawei.com>
commit 01215d3edb0f384ddeaa5e4a22c1ae5ff634149f upstream.
The jh pointer may be used uninitialized in the two cases below and the
compiler complain about it when enabling JBUFFER_TRACE macro, fix them.
In file included from fs/jbd2/transaction.c:19:0:
fs/jbd2/transaction.c: In function ‘jbd2_journal_get_undo_access’:
./include/linux/jbd2.h:1637:38: warning: ‘jh’ is used uninitialized in this function [-Wuninitialized]
#define JBUFFER_TRACE(jh, info) do { printk("%s: %d\n", __func__, jh->b_jcount);} while (0)
fs/jbd2/transaction.c:1219:23: note: ‘jh’ was declared here
struct journal_head *jh;
fs/jbd2/transaction.c: In function ‘jbd2_journal_dirty_metadata’:
./include/linux/jbd2.h:1637:38: warning: ‘jh’ may be used uninitialized in this function [-Wmaybe-uninitialized]
fs/jbd2/transaction.c:1332:23: note: ‘jh’ was declared here
Cc: stable@vger.kernel.org
commit 904cdbd41d749a476863a0ca41f6f396774f26e4 upstream.
Now, we capture a data corruption problem on ext4 while we're truncating
an extent index block. Imaging that if we are revoking a buffer which
has been journaled by the committing transaction, the buffer's jbddirty
flag will not be cleared in jbd2_journal_forget(), so the commit code
will set the buffer dirty flag again after refile the buffer.
fsx kjournald2
jbd2_journal_revoke commit phase 1~5...
jbd2_journal_forget
belongs to older transaction commit phase 6
jbddirty not clear __jbd2_journal_refile_buffer
__jbd2_journal_unfile_buffer
test_clear_buffer_jbddirty
mark_buffer_dirty
Finally, if the freed extent index block was allocated again as data
block by some other files, it may corrupt the file data after writing
cached pages later, such as during unmount time. (In general,
clean_bdev_aliases() related helpers should be invoked after
re-allocation to prevent the above corruption, but unfortunately we
missed it when zeroout the head of extra extent blocks in
ext4_ext_handle_unwritten_extents()).
This patch mark buffer as freed and set j_next_transaction to the new
transaction when it already belongs to the committing transaction in
jbd2_journal_forget(), so that commit code knows it should clear dirty
This problem can be reproduced by xfstests generic/455 easily with
seeds (3246 3247 3248 3249).
commit ccd3c4373eacb044eb3832966299d13d2631f66f upstream.
The code cleaning transaction's lists of checkpoint buffers has a bug
where it increases bh refcount only after releasing
journal->j_list_lock. Thus the following race is possible:
CPU0 CPU1
jbd2_log_do_checkpoint()
jbd2_journal_try_to_free_buffers()
__journal_try_to_free_buffer(bh)
while (transaction->t_checkpoint_io_list)
if (buffer_locked(bh)) {
<-- IO completes now, buffer gets unlocked -->
spin_unlock(&journal->j_list_lock);
spin_lock(&journal->j_list_lock);
__jbd2_journal_remove_checkpoint(jh);
try_to_free_buffers(page);
get_bh(bh) <-- accesses freed bh
Fix the problem by grabbing bh reference before unlocking
Fixes: dc6e8d669cf5 ("jbd2: don't call get_bh() before calling __jbd2_journal_remove_checkpoint()")
Fixes: be1158cc615f ("jbd2: fold __process_buffer() into jbd2_log_do_checkpoint()")
Reported-by: syzbot+7f4a27091759e2fe7453@syzkaller.appspotmail.com
CC: stable@vger.kernel.org
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit e09463f220ca9a1a1ecfda84fcda658f99a1f12a upstream.
Do not set the b_modified flag in block's journal head should not
until after we're sure that jbd2_journal_dirty_metadat() will not
abort with an error due to there not being enough space reserved in
the jbd2 handle.
Otherwise, future attempts to modify the buffer may lead a large
number of spurious errors and warnings.
This addresses CVE-2018-10883.
https://bugzilla.kernel.org/show_bug.cgi?id=200071
commit b2569260d55228b617bd82aba6d0db2faeeb4116 upstream.
If ext4 tries to start a reserved handle via
jbd2_journal_start_reserved(), and the journal has been aborted, this
can result in a NULL pointer dereference. This is because the fields
h_journal and h_transaction in the handle structure share the same
memory, via a union, so jbd2_journal_start_reserved() will clear
h_journal before calling start_this_handle(). If this function fails
due to an aborted handle, h_journal will still be NULL, and the call
to jbd2_journal_free_reserved() will pass a NULL journal to
sub_reserve_credits().
This can be reproduced by running "kvm-xfstests -c dioread_nolock
generic/475".
Cc: stable@kernel.org # 3.11
Fixes: 8f7d89f36829b ("jbd2: transaction reservation support")
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit dbfcef6b0f4012c57bc0b6e0e660d5ed12a5eaed upstream.
Below is the synchronization issue between unmount and kjournald2
contexts, which results into use after free issue in kjournald2().
Fix this issue by using journal->j_state_lock to synchronize the
wait_event() done in journal_kill_thread() and the wake_up() done
in kjournald2().
TASK 1:
umount cmd:
|--jbd2_journal_destroy() {
|--journal_kill_thread() {
write_lock(&journal->j_state_lock);
journal->j_flags |= JBD2_UNMOUNT;
write_unlock(&journal->j_state_lock);
wake_up(&journal->j_wait_commit); TASK 2 wakes up here:
kjournald2() {
checks JBD2_UNMOUNT flag and calls goto end-loop;
end_loop:
journal->j_task = NULL; --> If this thread gets
pre-empted here, then TASK 1 wait_event will
exit even before this thread is completely
done.
wait_event(journal->j_wait_done_commit, journal->j_task == NULL);
|--kfree(journal);
wake_up(&journal->j_wait_done_commit); --> this step
now results into use after free issue.
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Cc: Amit Pundir <amit.pundir@linaro.org>
commit 85e0c4e89c1b864e763c4e3bb15d0b6d501ad5d9 upstream.
This updates the jbd2 superblock unnecessarily, and on an abort we
shouldn't truncate the log.
[ Upstream commit c52c47e4b4fbe4284602fc2ccbfc4a4d8dc05b49 ]
I've hit a lockdep splat with generic/270 test complaining that:
3216.fsstress.b/3533 is trying to acquire lock:
(jbd2_handle){++++..}, at: [<ffffffff813152e0>] jbd2_log_wait_commit+0x0/0x150
but task is already holding lock:
(jbd2_handle){++++..}, at: [<ffffffff8130bd3b>] start_this_handle+0x35b/0x850
The underlying problem is that jbd2_journal_force_commit_nested()
(called from ext4_should_retry_alloc()) may get called while a
transaction handle is started. In such case it takes care to not wait
for commit of the running transaction (which would deadlock) but only
for a commit of a transaction that is already committing (which is safe
as that doesn't wait for any filesystem locks).
In fact there are also other callers of jbd2_log_wait_commit() that take
care to pass tid of a transaction that is already committing and for
those cases, the lockdep instrumentation is too restrictive and leading
to false positive reports. Fix the problem by calling
jbd2_might_wait_for_commit() from jbd2_log_wait_commit() only if the
transaction isn't already committing.
Fixes: 1eaa566d368b214d99cbb973647c1b0b8102a9ae
commit f69120ce6c024aa634a8fc25787205e42f0ccbe6 upstream.
Sphinx emits various (26) warnings when building make target 'htmldocs'.
Currently struct definitions contain duplicate documentation, some as
kernel-docs and some as standard c89 comments. We can reduce
duplication while cleaning up the kernel docs.
Move all kernel-docs to right above each struct member. Use the set of
all existing comments (kernel-doc and c89). Add documentation for
missing struct members and function arguments.
Signed-off-by: Tobin C. Harding <me@tobin.cc>
commit cd9cb405e0b948363811dc74dbb2890f56f2cb87 upstream.
In journal_init_common(), if we failed to allocate the j_wbuf array, or
if we failed to create the buffer_head for the journal superblock, we
leaked the memory allocated for the revocation tables. Fix this.
Fixes: f0c9fd5458bacf7b12a9a579a727dc740cbe047e
commit e112666b4959b25a8552d63bc564e1059be703e8 upstream.
If the journal has been aborted, we shouldn't mark the underlying
buffer head as dirty, since that will cause the metadata block to get
modified. And if the journal has been aborted, we shouldn't allow
this since it will almost certainly lead to a corrupted file system.
When 'jh->b_transaction == transaction' (asserted by below)
J_ASSERT_JH(jh, (jh->b_transaction == transaction || ...
'journal->j_list_lock' will be incorrectly unlocked, since
the the lock is aquired only at the end of if / else-if
statements (missing the else case).
Signed-off-by: Taesoo Kim <tsgatesv@gmail.com>
Fixes: 6e4862a5bb9d12be87e4ea5d9a60836ebed71d28
Cc: stable@vger.kernel.org # 3.14+
The mapping_set_error() helper sets the correct AS_ flag for the mapping
so there is no reason to open code it. Use the helper directly.
[akpm@linux-foundation.org: be honest about conversion from -ENXIO to -EIO]
Link: http://lkml.kernel.org/r/20160912111608.2588-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Thomas has reported a lockdep splat hitting in
add_transaction_credits(). The problem is that that function calls
jbd2_might_wait_for_commit() while holding j_state_lock which is wrong
(we do not really wait for transaction commit while holding that lock).
Fix the problem by moving jbd2_might_wait_for_commit() into places where
we are ready to wait for transaction commit and thus j_state_lock is
unlocked.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
There are some repetitive code in jbd2_journal_init_dev() and
jbd2_journal_init_inode(). So this patch moves the common code into
journal_init_common() helper to simplify the code. And fix the coding
style warnings reported by checkpatch.pl by the way.
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"The major change this cycle is deleting ext4's copy of the file system
encryption code and switching things over to using the copies in
fs/crypto. I've updated the MAINTAINERS file to add an entry for
fs/crypto listing Jaeguk Kim and myself as the maintainers.
There are also a number of bug fixes, most notably for some problems
found by American Fuzzy Lop (AFL) courtesy of Vegard Nossum. Also
fixed is a writeback deadlock detected by generic/130, and some
potential races in the metadata checksum code"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (21 commits)
ext4: verify extent header depth
ext4: short-cut orphan cleanup on error
ext4: fix reference counting bug on block allocation error
MAINTAINRES: fs-crypto maintainers update
ext4 crypto: migrate into vfs's crypto engine
ext2: fix filesystem deadlock while reading corrupted xattr block
ext4: fix project quota accounting without quota limits enabled
ext4: validate s_reserved_gdt_blocks on mount
ext4: remove unused page_idx
ext4: don't call ext4_should_journal_data() on the journal inode
ext4: Fix WARN_ON_ONCE in ext4_commit_super()
ext4: fix deadlock during page writeback
ext4: correct error value of function verifying dx checksum
ext4: avoid modifying checksum fields directly during checksum verification
ext4: check for extents that wrap around
jbd2: make journal y2038 safe
jbd2: track more dependencies on transaction commit
jbd2: move lockdep tracking to journal_s
jbd2: move lockdep instrumentation for jbd2 handles
ext4: respect the nobarrier mount option in nojournal mode
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
The jbd2 journal stores the commit time in 64-bit seconds and 32-bit
nanoseconds, which avoids an overflow in 2038, but it gets the numbers
from current_kernel_time(), which uses 'long' seconds on 32-bit
architectures.
This simply changes the code to call current_kernel_time64() so
we use 64-bit seconds consistently.
So far we were tracking only dependency on transaction commit due to
starting a new handle (which may require commit to start a new
transaction). Now add tracking also for other cases where we wait for
transaction commit. This way lockdep can catch deadlocks e. g. because we
call jbd2_journal_stop() for a synchronous handle with some locks held
which rank below transaction start.
Currently lockdep map is tracked in each journal handle. To be able to
expand lockdep support to cover also other cases where we depend on
transaction commit and where handle is not available, move lockdep map
into struct journal_s. Since this makes the lockdep map shared for all
handles, we have to use rwsem_acquire_read() for acquisitions now.
The transaction the handle references is free to commit once we've
decremented t_updates counter. Move the lockdep instrumentation to that
place. Currently it was a bit later which did not really matter but
subsequent improvements to lockdep instrumentation would cause false
positives with it.
jbd2_alloc is explicit about its allocation preferences wrt. the
allocation size. Sub page allocations go to the slab allocator and
larger are using either the page allocator or vmalloc. This is all good
but the logic is unnecessarily complex.
1) as per Ted, the vmalloc fallback is a left-over:
: jbd2_alloc is only passed in the bh->b_size, which can't be PAGE_SIZE, so
: the code path that calls vmalloc() should never get called. When we
: conveted jbd2_alloc() to suppor sub-page size allocations in commit
: d2eecb039368, there was an assumption that it could be called with a size
: greater than PAGE_SIZE, but that's certaily not true today.
Moreover vmalloc allocation might even lead to a deadlock because the
callers expect GFP_NOFS context while vmalloc is GFP_KERNEL.
2) __GFP_REPEAT for requests <= PAGE_ALLOC_COSTLY_ORDER is ignored
since the flag was introduced.
Let's simplify the code flow and use the slab allocator for sub-page
requests and the page allocator for others. Even though order > 0 is
not currently used as per above leave that option open.
Link: http://lkml.kernel.org/r/1464599699-30131-18-git-send-email-mhocko@kernel.org
Cc: "Theodore Ts'o" <tytso@mit.edu>
To avoid confusion between REQ_OP_FLUSH, which is handled by
request_fn drivers, and upper layers requesting the block layer
perform a flush sequence along with possibly a WRITE, this patch
renames REQ_FLUSH to REQ_PREFLUSH.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This has ll_rw_block users pass in the operation and flags separately,
so ll_rw_block can setup the bio op and bi_rw flags on the bio that
is submitted.
This has submit_bh users pass in the operation and flags separately,
so submit_bh_wbc can setup the bio op and bi_rw flags on the bio that
is submitted.
"Fix a number of bugs, most notably a potential stale data exposure
after a crash and a potential BUG_ON crash if a file has the data
journalling flag enabled while it has dirty delayed allocation blocks
that haven't been written yet. Also fix a potential crash in the new
project quota code and a maliciously corrupted file system.
In addition, fix some DAX-specific bugs, including when there is a
transient ENOSPC situation and races between writes via direct I/O and
an mmap'ed segment that could lead to lost I/O.
Finally the usual set of miscellaneous cleanups"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (23 commits)
ext4: pre-zero allocated blocks for DAX IO
ext4: refactor direct IO code
ext4: fix race in transient ENOSPC detection
ext4: handle transient ENOSPC properly for DAX
dax: call get_blocks() with create == 1 for write faults to unwritten extents
ext4: remove unmeetable inconsisteny check from ext4_find_extent()
jbd2: remove excess descriptions for handle_s
ext4: remove unnecessary bio get/put
ext4: silence UBSAN in ext4_mb_init()
ext4: address UBSAN warning in mb_find_order_for_block()
ext4: fix oops on corrupted filesystem
ext4: fix check of dqget() return value in ext4_ioctl_setproject()
ext4: clean up error handling when orphan list is corrupted
ext4: fix hang when processing corrupted orphaned inode list
ext4: remove trailing \n from ext4_warning/ext4_error calls
ext4: fix races between changing inode journal mode and ext4_writepages
ext4: handle unwritten or delalloc buffers before enabling data journaling
ext4: fix jbd2 handle extension in ext4_ext_truncate_extend_restart()
ext4: do not ask jbd2 to write data for delalloc buffers
jbd2: add support for avoiding data writes during transaction commits
Currently when filesystem needs to make sure data is on permanent
storage before committing a transaction it adds inode to transaction's
inode list. During transaction commit, jbd2 writes back all dirty
buffers that have allocated underlying blocks and waits for the IO to
finish. However when doing writeback for delayed allocated data, we
allocate blocks and immediately submit the data. Thus asking jbd2 to
write dirty pages just unnecessarily adds more work to jbd2 possibly
writing back other redirtied blocks.
Add support to jbd2 to allow filesystem to ask jbd2 to only wait for
outstanding data writes before committing a transaction and thus avoid
unnecessary writes.
Sync with Linus' tree so that patches against newer codebase can be applied.
This patch fix spelling typos found in DocBook/filesystem.xml.
It is because the file was generated from comments in code,
I have to fix the comments in codes, instead of xml file.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Journal transaction might fail prematurely because the frozen_buffer
is allocated by GFP_NOFS request:
[ 72.440013] do_get_write_access: OOM for frozen_buffer
[ 72.440014] EXT4-fs: ext4_reserve_inode_write:4729: aborting transaction: Out of memory in __ext4_journal_get_write_access
[ 72.440015] EXT4-fs error (device sda1) in ext4_reserve_inode_write:4735: Out of memory
(...snipped....)
[ 72.495559] do_get_write_access: OOM for frozen_buffer
[ 72.495560] EXT4-fs: ext4_reserve_inode_write:4729: aborting transaction: Out of memory in __ext4_journal_get_write_access
[ 72.496839] do_get_write_access: OOM for frozen_buffer
[ 72.496841] EXT4-fs: ext4_reserve_inode_write:4729: aborting transaction: Out of memory in __ext4_journal_get_write_access
[ 72.505766] Aborting journal on device sda1-8.
[ 72.505851] EXT4-fs (sda1): Remounting filesystem read-only
This wasn't a problem until "mm: page_alloc: do not lock up GFP_NOFS
allocations upon OOM" because small GPF_NOFS allocations never failed.
This allocation seems essential for the journal and GFP_NOFS is too
restrictive to the memory allocator so let's use __GFP_NOFAIL here to
emulate the previous behavior.
On umount path, jbd2_journal_destroy() writes latest transaction ID
(->j_tail_sequence) to be used at next mount.
The bug is that ->j_tail_sequence is not holding latest transaction ID
in some cases. So, at next mount, there is chance to conflict with
remaining (not overwritten yet) transactions.
mount (id=10)
write transaction (id=11)
write transaction (id=12)
umount (id=10) <= the bug doesn't write latest ID
mount (id=10)
crash
mount
[recovery process]
transaction (id=11)
transaction (id=12) <= valid transaction ID, but old commit
must not replay
Like above, this bug become the cause of recovery failure, or FS
corruption.
So why ->j_tail_sequence doesn't point latest ID?
Because if checkpoint transactions was reclaimed by memory pressure
(i.e. bdev_try_to_free_page()), then ->j_tail_sequence is not updated.
(And another case is, __jbd2_journal_clean_checkpoint_list() is called
with empty transaction.)
So in above cases, ->j_tail_sequence is not pointing latest
transaction ID at umount path. Plus, REQ_FLUSH for checkpoint is not
done too.
So, to fix this problem with minimum changes, this patch updates
->j_tail_sequence, and issue REQ_FLUSH. (With more complex changes,
some optimizations would be possible to avoid unnecessary REQ_FLUSH
for example though.)
BTW,
journal->j_tail_sequence =
++journal->j_transaction_sequence;
Increment of ->j_transaction_sequence seems to be unnecessary, but
ext3 does this.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Currently we used atomic bit operations to manipulate
__JI_COMMIT_RUNNING bit. However this is unnecessary as i_flags are
always written and read under j_list_lock. So just change the operations
to standard bit operations.
Revoke and tag descriptor blocks are just different kinds of descriptor
blocks and thus have checksum in the same place. Unify computation and
checking of checksums for these.
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Descriptor block header is initialized in several places. Factor out the
common code into jbd2_journal_get_descriptor_buffer().
jbd2_journal_write_revoke_records() takes journal pointer and write_op,
although journal can be obtained from the passed transaction and
write_op is always WRITE_SYNC. Remove these superfluous arguments.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Pull ext4 fixes from Ted Ts'o:
"Ext4 bug fixes for v4.4, including fixes for post-2038 time encodings,
some endian conversion problems with ext4 encryption, potential memory
leaks after truncate in data=journal mode, and an ocfs2 regression
caused by a jbd2 performance improvement"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd2: fix null committed data return in undo_access
ext4: add "static" to ext4_seq_##name##_fops struct
ext4: fix an endianness bug in ext4_encrypted_follow_link()
ext4: fix an endianness bug in ext4_encrypted_zeroout()
jbd2: Fix unreclaimed pages after truncate in data=journal mode
ext4: Fix handling of extended tv_sec
introduced jbd2_write_access_granted() to improve write|undo_access
speed, but missed to check the status of b_committed_data which caused
a kernel panic on ocfs2.
[ 6538.405938] ------------[ cut here ]------------
[ 6538.406686] kernel BUG at fs/ocfs2/suballoc.c:2400!
[ 6538.406686] invalid opcode: 0000 [#1] SMP
[ 6538.406686] Modules linked in: ocfs2 nfsd lockd grace nfs_acl auth_rpcgss sunrpc autofs4 ocfs2_dlmfs ocfs2_stack_o2cb ocfs2_dlm ocfs2_nodemanager ocfs2_stackglue configfs sd_mod sg ip6t_REJECT nf_reject_ipv6 nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb4i cxgb4 cxgb3i libcxgbi cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr ipv6 iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi ppdev xen_kbdfront xen_netfront xen_fbfront parport_pc parport pcspkr i2c_piix4 acpi_cpufreq ext4 jbd2 mbcache xen_blkfront floppy pata_acpi ata_generic ata_piix cirrus ttm drm_kms_helper drm fb_sys_fops sysimgblt sysfillrect i2c_core syscopyarea dm_mirror dm_region_hash dm_log dm_mod
[ 6538.406686] CPU: 1 PID: 16265 Comm: mmap_truncate Not tainted 4.3.0 #1
[ 6538.406686] Hardware name: Xen HVM domU, BIOS 4.3.1OVM 05/14/2014
[ 6538.406686] task: ffff88007c2bab00 ti: ffff880075b78000 task.ti: ffff880075b78000
[ 6538.406686] RIP: 0010:[<ffffffffa06a286b>] [<ffffffffa06a286b>] ocfs2_block_group_clear_bits+0x23b/0x250 [ocfs2]
[ 6538.406686] RSP: 0018:ffff880075b7b7f8 EFLAGS: 00010246
[ 6538.406686] RAX: ffff8800760c5b40 RBX: ffff88006c06a000 RCX: ffffffffa06e6df0
[ 6538.406686] RDX: 0000000000000000 RSI: ffff88007a6f6ea0 RDI: ffff88007a760430
[ 6538.406686] RBP: ffff880075b7b878 R08: 0000000000000002 R09: 0000000000000001
[ 6538.406686] R10: ffffffffa06769be R11: 0000000000000000 R12: 0000000000000001
[ 6538.406686] R13: ffffffffa06a1750 R14: 0000000000000001 R15: ffff88007a6f6ea0
[ 6538.406686] FS: 00007f17fde30720(0000) GS:ffff88007f040000(0000) knlGS:0000000000000000
[ 6538.406686] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 6538.406686] CR2: 0000000000601730 CR3: 000000007aea0000 CR4: 00000000000406e0
[ 6538.406686] Stack:
[ 6538.406686] ffff88007c2bb5b0 ffff880075b7b8e0 ffff88007a7604b0 ffff88006c640800
[ 6538.406686] ffff88007a7604b0 ffff880075d77390 0000000075b7b878 ffffffffa06a309d
[ 6538.406686] ffff880075d752d8 ffff880075b7b990 ffff880075b7b898 0000000000000000
[ 6538.406686] Call Trace:
[ 6538.406686] [<ffffffffa06a309d>] ? ocfs2_read_group_descriptor+0x6d/0xa0 [ocfs2]
[ 6538.406686] [<ffffffffa06a3654>] _ocfs2_free_suballoc_bits+0xe4/0x320 [ocfs2]
[ 6538.406686] [<ffffffffa06a1750>] ? ocfs2_put_slot+0xf0/0xf0 [ocfs2]
[ 6538.406686] [<ffffffffa06a397e>] _ocfs2_free_clusters+0xee/0x210 [ocfs2]
[ 6538.406686] [<ffffffffa0682d50>] ? ocfs2_extend_trans+0x50/0x1a0 [ocfs2]
[ 6538.406686] [<ffffffffa06a3ad5>] ocfs2_free_clusters+0x15/0x20 [ocfs2]
[ 6538.406686] [<ffffffffa065072c>] ocfs2_replay_truncate_records+0xfc/0x290 [ocfs2]
[ 6538.406686] [<ffffffffa06843ac>] ? ocfs2_start_trans+0xec/0x1d0 [ocfs2]
[ 6538.406686] [<ffffffffa0654600>] __ocfs2_flush_truncate_log+0x140/0x2d0 [ocfs2]
[ 6538.406686] [<ffffffffa0654394>] ? ocfs2_reserve_blocks_for_rec_trunc.clone.0+0x44/0x170 [ocfs2]
[ 6538.406686] [<ffffffffa065acd4>] ocfs2_remove_btree_range+0x374/0x630 [ocfs2]
[ 6538.406686] [<ffffffffa017486b>] ? jbd2_journal_stop+0x25b/0x470 [jbd2]
[ 6538.406686] [<ffffffffa065d5b5>] ocfs2_commit_truncate+0x305/0x670 [ocfs2]
[ 6538.406686] [<ffffffffa0683430>] ? ocfs2_journal_access_eb+0x20/0x20 [ocfs2]
[ 6538.406686] [<ffffffffa067adb7>] ocfs2_truncate_file+0x297/0x380 [ocfs2]
[ 6538.406686] [<ffffffffa01759e4>] ? jbd2_journal_begin_ordered_truncate+0x64/0xc0 [jbd2]
[ 6538.406686] [<ffffffffa067c7a2>] ocfs2_setattr+0x572/0x860 [ocfs2]
[ 6538.406686] [<ffffffff810e4a3f>] ? current_fs_time+0x3f/0x50
[ 6538.406686] [<ffffffff812124b7>] notify_change+0x1d7/0x340
[ 6538.406686] [<ffffffff8121abf9>] ? generic_getxattr+0x79/0x80
[ 6538.406686] [<ffffffff811f5876>] do_truncate+0x66/0x90
[ 6538.406686] [<ffffffff81120e30>] ? __audit_syscall_entry+0xb0/0x110
[ 6538.406686] [<ffffffff811f5bb3>] do_sys_ftruncate.clone.0+0xf3/0x120
[ 6538.406686] [<ffffffff811f5bee>] SyS_ftruncate+0xe/0x10
[ 6538.406686] [<ffffffff816aa2ae>] entry_SYSCALL_64_fastpath+0x12/0x71
[ 6538.406686] Code: 28 48 81 ee b0 04 00 00 48 8b 92 50 fb ff ff 48 8b 80 b0 03 00 00 48 39 90 88 00 00 00 0f 84 30 fe ff ff 0f 0b eb fe 0f 0b eb fe <0f> 0b 0f 1f 00 eb fb 66 66 66 66 66 2e 0f 1f 84 00 00 00 00 00
[ 6538.406686] RIP [<ffffffffa06a286b>] ocfs2_block_group_clear_bits+0x23b/0x250 [ocfs2]
[ 6538.406686] RSP <ffff880075b7b7f8>
[ 6538.691128] ---[ end trace 31cd7011d6770d7e ]---
[ 6538.694492] Kernel panic - not syncing: Fatal exception
[ 6538.695484] Kernel Offset: disabled
Fixes: de92c8caf16c("jbd2: speedup jbd2_journal_get_[write|undo]_access()")
Cc: <stable@vger.kernel.org>
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Ted and Namjae have reported that truncated pages don't get timely
reclaimed after being truncated in data=journal mode. The following test
triggers the issue easily:
for (i = 0; i < 1000; i++) {
pwrite(fd, buf, 1024*1024, 0);
fsync(fd);
fsync(fd);
ftruncate(fd, 0);
The reason is that journal_unmap_buffer() finds that truncated buffers
are not journalled (jh->b_transaction == NULL), they are part of
checkpoint list of a transaction (jh->b_cp_transaction != NULL) and have
been already written out (!buffer_dirty(bh)). We clean such buffers but
we leave them in the checkpoint list. Since checkpoint transaction holds
a reference to the journal head, these buffers cannot be released until
the checkpoint transaction is cleaned up. And at that point we don't
call release_buffer_page() anymore so pages detached from mapping are
lingering in the system waiting for reclaim to find them and free them.
Fix the problem by removing buffers from transaction checkpoint lists
when journal_unmap_buffer() finds out they don't have to be there
anymore.
Reported-and-tested-by: Namjae Jeon <namjae.jeon@samsung.com>
Fixes: de1b794130b130e77ffa975bb58cb843744f9ae5
Merge second patch-bomb from Andrew Morton:
- most of the rest of MM
- procfs
- lib/ updates
- printk updates
- bitops infrastructure tweaks
- checkpatch updates
- nilfs2 update
- signals
- various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc,
dma-debug, dma-mapping, ...
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits)
ipc,msg: drop dst nil validation in copy_msg
include/linux/zutil.h: fix usage example of zlib_adler32()
panic: release stale console lock to always get the logbuf printed out
dma-debug: check nents in dma_sync_sg*
dma-mapping: tidy up dma_parms default handling
pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode
kexec: use file name as the output message prefix
fs, seqfile: always allow oom killer
seq_file: reuse string_escape_str()
fs/seq_file: use seq_* helpers in seq_hex_dump()
coredump: change zap_threads() and zap_process() to use for_each_thread()
coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP
signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT)
signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()
signal: turn dequeue_signal_lock() into kernel_dequeue_signal()
signals: kill block_all_signals() and unblock_all_signals()
nilfs2: fix gcc uninitialized-variable warnings in powerpc build
nilfs2: fix gcc unused-but-set-variable warnings
MAINTAINERS: nilfs2: add header file for tracing
nilfs2: add tracepoints for analyzing reading and writing metadata files
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
