path: root/fs/jbd2
2008-01-28jbd2: add lockdep supportMingming Cao
Ported from similar patch for the jbd layer. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28ext4: Add the journal checksum featureGirish Shilamkar
The journal checksum feature adds two new flags i.e JBD2_FEATURE_INCOMPAT_ASYNC_COMMIT and JBD2_FEATURE_COMPAT_CHECKSUM. JBD2_FEATURE_CHECKSUM flag indicates that the commit block contains the checksum for the blocks described by the descriptor blocks. Due to checksums, writing of the commit record no longer needs to be synchronous. Now commit record can be sent to disk without waiting for descriptor blocks to be written to disk. This behavior is controlled using JBD2_FEATURE_ASYNC_COMMIT flag. Older kernels/e2fsck should not be able to recover the journal with _ASYNC_COMMIT hence it is made incompat. The commit header has been extended to hold the checksum along with the type of the checksum. For recovery in pass scan checksums are verified to ensure the sanity and completeness(in case of _ASYNC_COMMIT) of every transaction. Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Girish Shilamkar <girish@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-01-28jbd2: jbd2 stats through procfsJohann Lombardi
The patch below updates the jbd stats patch to 2.6.20/jbd2. The initial patch was posted by Alex Tomas in December 2005 (http://marc.info/?l=linux-ext4&m=113538565128617&w=2). It provides statistics via procfs such as transaction lifetime and size. Sometimes, investigating performance problems, i find useful to have stats from jbd about transaction's lifetime, size, etc. here is a patch for review and inclusion probably. for example, stats after creation of 3M files in htree directory: [root@bob ~]# cat /proc/fs/jbd/sda/history R/C tid wait run lock flush log hndls block inlog ctime write drop close R 261 8260 2720 0 0 750 9892 8170 8187 C 259 750 0 4885 1 R 262 20 2200 10 0 770 9836 8170 8187 R 263 30 2200 10 0 3070 9812 8170 8187 R 264 0 5000 10 0 1340 0 0 0 C 261 8240 3212 4957 0 R 265 8260 1470 0 0 4640 9854 8170 8187 R 266 0 5000 10 0 1460 0 0 0 C 262 8210 2989 4868 0 R 267 8230 1490 10 0 4440 9875 8171 8188 R 268 0 5000 10 0 1260 0 0 0 C 263 7710 2937 4908 0 R 269 7730 1470 10 0 3330 9841 8170 8187 R 270 0 5000 10 0 830 0 0 0 C 265 8140 3234 4898 0 C 267 720 0 4849 1 R 271 8630 2740 20 0 740 9819 8170 8187 C 269 800 0 4214 1 R 272 40 2170 10 0 830 9716 8170 8187 R 273 40 2280 0 0 3530 9799 8170 8187 R 274 0 5000 10 0 990 0 0 0 where, R - line for transaction's life from T_RUNNING to T_FINISHED C - line for transaction's checkpointing tid - transaction's id wait - for how long we were waiting for new transaction to start (the longest period journal_start() took in this transaction) run - real transaction's lifetime (from T_RUNNING to T_LOCKED lock - how long we were waiting for all handles to close (time the transaction was in T_LOCKED) flush - how long it took to flush all data (data=ordered) log - how long it took to write the transaction to the log hndls - how many handles got to the transaction block - how many blocks got to the transaction inlog - how many blocks are written to the log (block + descriptors) ctime - how long it took to checkpoint the transaction write - how many blocks have been written during checkpointing drop - how many blocks have been dropped during checkpointing close - how many running transactions have been closed to checkpoint this one all times are in msec. [root@bob ~]# cat /proc/fs/jbd/sda/info 280 transaction, each upto 8192 blocks average: 1633ms waiting for transaction 3616ms running transaction 5ms transaction was being locked 1ms flushing data (in ordered mode) 1799ms logging transaction 11781 handles per transaction 5629 blocks per transaction 5641 logged blocks per transaction Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2008-01-28jbd2: Fix assertion failure in fs/jbd2/checkpoint.cJan Kara
Before we start committing a transaction, we call __journal_clean_checkpoint_list() to cleanup transaction's written-back buffers. If this call happens to remove all of them (and there were already some buffers), __journal_remove_checkpoint() will decide to free the transaction because it isn't (yet) a committing transaction and soon we fail some assertion - the transaction really isn't ready to be freed :). We change the check in __journal_remove_checkpoint() to free only a transaction in T_FINISHED state. The locking there is subtle though (as everywhere in JBD ;(). We use j_list_lock to protect the check and a subsequent call to __journal_drop_transaction() and do the same in the end of journal_commit_transaction() which is the only place where a transaction can get to T_FINISHED state. Probably I'm too paranoid here and such locking is not really necessary - checkpoint lists are processed only from log_do_checkpoint() where a transaction must be already committed to be processed or from __journal_clean_checkpoint_list() where kjournald itself calls it and thus transaction cannot change state either. Better be safe if something changes in future... Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-17JBD2: debug code cleanup.Jose R. Santos
Mostly stolen from akpm's JBD cleanup patch. - use `#ifdef foo' instead of `#if defined(foo)' - Make journal_enable_debug __read_mostly just for the heck of it - Make jbd_debugfs_dir and jbd_debug static - debugfs_remove(NULL) is legal: remove unneeded tests - remove unnecessary empty loops Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-17jbd2: fix commit code to properly abort journalJan Kara
We should really call journal_abort() and not __journal_abort_hard() in case of errors. The latter call does not record the error in the journal superblock and thus filesystem won't be marked as with errors later (and user could happily mount it without any warning). Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-17jbd2: JBD_XXX to JBD2_XXX naming cleanupMingming Cao
change JBD_XXX macros to JBD2_XXX in JBD2/Ext4 Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-10-17JBD2/Ext4: Convert kmalloc to kzalloc in jbd2/ext4Mingming Cao
Convert kmalloc to kzalloc() and get rid of the memset(). Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-10-17JBD2: replace jbd_kmalloc with kmalloc directly.Mingming Cao
This patch cleans up jbd_kmalloc and replace it with kmalloc directly Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-10-17JBD2: jbd2 slab allocation cleanupsMingming Cao
JBD2: Replace slab allocations with page allocations JBD2 allocate memory for committed_data and frozen_data from slab. However JBD2 should not pass slab pages down to the block layer. Use page allocator pages instead. This will also prepare JBD for the large blocksize patchset. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2007-07-19fix ext4/JBD2 build warningsMingming Cao
Looking at the current linus-git tree jbd_debug() define in include/linux/jbd2.h extern u8 journal_enable_debug; #define jbd_debug(n, f, a...) \ do { \ if ((n) <= journal_enable_debug) { \ printk (KERN_DEBUG "(%s, %d): %s: ", \ __FILE__, __LINE__, __FUNCTION__); \ printk (f, ## a); \ } \ } while (0) > fs/ext4/inode.c: In function ‘ext4_write_inode’: > fs/ext4/inode.c:2906: warning: comparison is always true due to limited > range of data type > > fs/jbd2/recovery.c: In function ‘jbd2_journal_recover’: > fs/jbd2/recovery.c:254: warning: comparison is always true due to > limited range of data type > fs/jbd2/recovery.c:257: warning: comparison is always true due to > limited range of data type > > fs/jbd2/recovery.c: In function ‘jbd2_journal_skip_recovery’: > fs/jbd2/recovery.c:301: warning: comparison is always true due to > limited range of data type > Noticed all warnings are occurs when the debug level is 0. Then found the "jbd2: Move jbd2-debug file to debugfs" patch http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=0f49d5d019afa4e94253bfc92f0daca3badb990b changed the jbd2_journal_enable_debug from int type to u8, makes the jbd_debug comparision is always true when the debugging level is 0. Thus the compile warning occurs. Thought about changing the jbd2_journal_enable_debug data type back to int, but can't, because the jbd2-debug is moved to debug fs, where calling debugfs_create_u8() to create the debugfs entry needs the value to be u8 type. Even if we changed the data type back to int, the code is still buggy, kernel should not print jbd2 debug message if the jbd2_journal_enable_debug is set to 0. But this is not the case. The fix is change the level of debugging to 1. The same should fixed in ext3/JBD, but currently ext3 jbd-debug via /proc fs is broken, so we probably should fix it all together. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Theodore Tso <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18jbd2: Move jbd2-debug file to debugfsJose R. Santos
The jbd2-debug file used to be located in /proc/sys/fs/jbd2-debug, but it incorrectly used create_proc_entry() instead of the sysctl routines, and no proc entry was ever created. Instead of fixing this we might as well move the jbd2-debug file to debugfs which would be the preferred location for this kind of tunable. The new location is now /sys/kernel/debug/jbd2/jbd2-debug. Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-07-18jbd2: Fix CONFIG_JBD_DEBUG ifdef to be CONFIG_JBD2_DEBUGJose R. Santos
When the JBD code was forked to create the new JBD2 code base, the references to CONFIG_JBD_DEBUG where never changed to CONFIG_JBD2_DEBUG. This patch fixes that. Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-07-16is_power_of_2(): jbdvignesh babu
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2(). Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16jbd2 commit: fix transaction droppingJan Kara
We have to check that also the second checkpoint list is non-empty before dropping the transaction. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08jbd: check for error returned by kthread_create on creating journal threadPavel Emelianov
If the thread failed to create the subsequent wait_event will hang forever. This is likely to happen if kernel hits max_threads limit. Will be critical for virtualization systems that limit the number of tasks and kernel memory usage within the container. (akpm: JBD should be converted fully to the kthread API: kthread_should_stop() and kthread_stop()). Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] jbd2: wait for already submitted t_sync_datalist buffer to completeHisashi Hifumi
In the current jbd code, if a buffer on BJ_SyncData list is dirty and not locked, the buffer is refiled to BJ_Locked list, submitted to the IO and waited for IO completion. But the fsstress test showed the case that when a buffer was already submitted to the IO just before the buffer_dirty(bh) check, the buffer was not waited for IO completion. Following patch solves this problem. If it is assumed that a buffer is submitted to the IO before the buffer_dirty(bh) check and still being written to disk, this buffer is refiled to BJ_Locked list. Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Jan Kara <jack@ucw.cz> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] make fs/jbd2/transaction.c:__kbd2_journal_temp_unlink_buffer() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] jbd2: journal_dirty_data re-check for unmapped buffersEric Sandeen
When running several fsx's and other filesystem stress tests, we found cases where an unmapped buffer was still being sent to submit_bh by the ext3 dirty data journaling code. I saw this happen in two ways, both related to another thread doing a truncate which would unmap the buffer in question. Either we would get into journal_dirty_data with a bh which was already unmapped (although journal_dirty_data_fn had checked for this earlier, the state was not locked at that point), or it would get unmapped in the middle of journal_dirty_data when we dropped locks to call sync_dirty_buffer. By re-checking for mapped state after we've acquired the bh state lock, we should avoid these races. If we find a buffer which is no longer mapped, we essentially ignore it, because journal_unmap_buffer has already decided that this buffer can go away. I've also added tracepoints in these two cases, and made a couple other tracepoint changes that I found useful in debugging this. Signed-off-by: Eric Sandeen <esandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] ext3/4: fix J_ASSERT(transaction->t_updates > 0) in journal_stop()OGAWA Hirofumi
A disk generated some I/O error, after it, I hitted J_ASSERT(transaction->t_updates > 0) in journal_stop(). It seems to happened on ext3_truncate() path from stack trace. Then, maybe the following case may trigger J_ASSERT(transaction->t_updates > 0). ext3_truncate() -> ext3_free_branches() -> ext3_journal_test_restart() -> ext3_journal_restart() -> journal_restart() transaction->t_updates--; /* another process aborted journal */ -> start_this_handle() returns -EROFS without transaction->t_updates++; -> ext3_journal_stop() -> journal_stop() J_ASSERT(transaction->t_updates > 0) If journal was aborted in middle of journal_restart(), ext3_truncate() may trigger J_ASSERT(). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] null dereference in fs/jbd2/journal.cDave Kleikamp
This is Eric Sesterhenn's jbd patch applied to jbd2. Commit: 41716c7c21b15e7ecf14f0caf1eef3980707fb74 His words: Since commit d1807793e1e7e502e3dc047115e9dbc3b50e4534 we dereference a NULL pointer. Coverity id #1432. We set journal to NULL, and use it directly afterwards. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: switch blks_type from sector_t to ullMingming Cao
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: sector_t conversionMingming Cao
JBD layer in-kernel block varibles type fixes to support >32 bit block number and convert to sector_t type. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] 64-bit jbd2 coreZach Brown
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach Brown. This patch is useful only after adding support for 64-bit block numbers in the filesystem. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename slabJohann Lombardi
jbd and jbd2 currently use the same slab names which must be unique. The patch below just renames jbd2's slabs. Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename jbd2 symbols to avoid duplication of jbd symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: initial copy of files from jbdDave Kleikamp
This is a simple copy of the files in fs/jbd to fs/jbd2 and /usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
