path: root/fs/jbd
2010-07-21ext3: Fix set but unused variablesAndi Kleen
[tytso@mit.edu: Fix compilation with CONFIG_JBD_DEBUG enabled] Acked-by: tytso@mit.edu cc: linux-ext4@vger.kernel.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: Fix waiting on transaction during fsyncJan Kara
log_start_commit() returns 1 only when it started a transaction commit. Thus in case transaction commit is already running, we fail to wait for the commit to finish. Fix the issue by always waiting for the commit regardless of the log_start_commit return value. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21jbd: Provide function to check whether transaction will issue data barrierJan Kara
Provide a function which returns whether a transaction with given tid will send a barrier to the filesystem device. The function will be used by ext3 to detect whether fsync needs to send a separate barrier or not. Signed-off-by: Jan Kara <jack@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05jbd: Delay discarding buffers in journal_unmap_bufferJan Kara
Delay discarding buffers in journal_unmap_buffer until we know that "add to orphan" operation has definitely been committed, otherwise the log space of committing transation may be freed and reused before truncate get committed, updates may get lost if crash happens. This patch is a backport of JBD2 fix by dingdinghua <dingdinghua@nrchpc.ac.cn>. Signed-off-by: Jan Kara <jack@suse.cz>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-23jbd: jbd-debug and jbd2-debug should be writableYin Kangkai
jbd-debug and jbd2-debug is currently read-only (S_IRUGO), which is not correct. Make it writable so that we can start debuging. Signed-off-by: Yin Kangkai <kangkai.yin@intel.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-17Revert "task_struct: make journal_info conditional"Linus Torvalds
This reverts commit e4c570c4cb7a95dbfafa3d016d2739bf3fdfe319, as requested by Alexey: "I think I gave a good enough arguments to not merge it. To iterate: * patch makes impossible to start using ext3 on EXT3_FS=n kernels without reboot. * this is done only for one pointer on task_struct" None of config options which define task_struct are tristate directly or effectively." Requested-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15task_struct: make journal_info conditionalHiroshi Shimamoto
journal_info in task_struct is used in journaling file system only. So introduce CONFIG_FS_JOURNAL_INFO and make it conditional. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12fs/jbd: Export log_start_commit to fix ext3 build.Stefan Schmidt
This fixes: ERROR: "log_start_commit" [fs/ext3/ext3.ko] undefined! Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
2009-11-11JBD/JBD2: free j_wbuf if journal init fails.Tao Ma
If journal init fails, we need to free j_wbuf. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-16jbd: Annotate transaction start also for journal_restart()Jan Kara
lockdep annotation for a transaction start has been at the end of journal_start(). But a transaction is also started from journal_restart(). Move the lockdep annotation to start_this_handle() which covers both cases. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-16jbd: Journal block numbers can ever be only 32-bit use unsigned int for themJan Kara
It does not make sense to store block number for journal as unsigned long since they can be only 32-bit (because of on-disk format limitation). So change in-memory structures and variables to use unsigned int instead. Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-16JBD: round commit timer up to avoid uncommitted transactionAndreas Dilger
Fix jiffie rounding in jbd commit timer setup code. Rounding down could cause the timer to be fired before the corresponding transaction has expired. That transaction can stay not committed forever if no new transaction is created or explicit sync/umount happens. Signed-off-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-07-21jbd: fix race between write_metadata_buffer and get_write_accessdingdinghua
The function journal_write_metadata_buffer() calls jbd_unlock_bh_state(bh_in) too early; this could potentially allow another thread to call get_write_access on the buffer head, modify the data, and dirty it, and allowing the wrong data to be written into the journal. Fortunately, if we lose this race, the only time this will actually cause filesystem corruption is if there is a system crash or other unclean shutdown of the system before the next commit can take place. Signed-off-by: dingdinghua <dingdinghua85@gmail.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2009-07-15jbd: Fix a race between checkpointing code and journal_get_write_access()Jan Kara
The following race can happen: CPU1 CPU2 checkpointing code checks the buffer, adds it to an array for writeback do_get_write_access() ... lock_buffer() unlock_buffer() flush_batch() submits the buffer for IO __jbd_journal_file_buffer() So a buffer under writeout is returned from do_get_write_access(). Since the filesystem code relies on the fact that journaled buffers cannot be written out, it does not take the buffer lock and so it can modify buffer while it is under writeout. That can lead to a filesystem corruption if we crash at the right moment. The similar problem can happen with the journal_get_create_access() path. We fix the problem by clearing the buffer dirty bit under buffer_lock even if the buffer is on BJ_None list. Actually, we clear the dirty bit regardless the list the buffer is in and warn about the fact if the buffer is already journalled. Thanks for spotting the problem goes to dingdinghua <dingdinghua85@gmail.com>. Reported-by: dingdinghua <dingdinghua85@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-07-15jbd: Fail to load a journal if it is too shortJan Kara
Due to on disk corruption, it can happen that journal is too short. Fail to load it in such case so that we don't oops somewhere later. Reported-by: Nageswara R Sastry <rnsastry@linux.vnet.ibm.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-06-18jbd: clean up journal_try_to_free_buffers()Hisashi Hifumi
I delete the following patch "commit 3f31fddfa26b7594b44ff2b34f9a04ba409e0f91 Author: Mingming Cao <cmm@us.ibm.com> Date: Fri Jul 25 01:46:22 2008 -0700 jbd: fix race between free buffer and commit transaction This patch is no longer needed because if race between freeing buffer and committing transaction functionality occurs and dio gets error, currently dio falls back to buffered IO by the following patch. commit 6ccfa806a9cfbbf1cd43d5b6aa47ef2c0eb518fd Author: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Date: Tue Sep 2 14:35:40 2008 -0700 VFS: fix dio write returning EIO when try_to_release_page fails Signed-off-by: Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Cc: Theodore Tso <tytso@mit.edu> Cc: Mingming Cao <cmm@us.ibm.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09jbd: fix race in buffer processing in commit codeJan Kara
In commit code, we scan buffers attached to a transaction. During this scan, we sometimes have to drop j_list_lock and then we recheck whether the journal buffer head didn't get freed by journal_try_to_free_buffers(). But checking for buffer_jbd(bh) isn't enough because a new journal head could get attached to our buffer head. So add a check whether the journal head remained the same and whether it's still at the same transaction and list. This is a nasty bug and can cause problems like memory corruption (use after free) or trigger various assertions in JBD code (observed). Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Fix potential inode allocation soft lockup in Orlov allocator ext4: Make the extent validity check more paranoid jbd: use SWRITE_SYNC_PLUG when writing synchronous revoke records jbd2: use SWRITE_SYNC_PLUG when writing synchronous revoke records ext4: really print the find_group_flex fallback warning only once
2009-04-14jbd: use SWRITE_SYNC_PLUG when writing synchronous revoke recordsTheodore Ts'o
The revoke records must be written using the same way as the rest of the blocks during the commit process; that is, either marked as synchronous writes or as asynchornous writes. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-13jbd: update locking comentsJan Kara
Update information about locking in JBD revoke code. Reported-by: Lin Tan <tammy000@gmail.com>. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06jbd: use WRITE_SYNC_PLUG instead of WRITE_SYNCJens Axboe
When you are going to be submitting several sync writes, we want to give the IO scheduler a chance to merge some of them. Instead of using the implicitly unplugging WRITE_SYNC variant, use WRITE_SYNC_PLUG and rely on sync_buffer() doing the unplug when someone does a wait_on_buffer()/lock_buffer(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03Merge branch 'ext3-latency-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'ext3-latency-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext3: Add replace-on-rename hueristics for data=writeback mode ext3: Add replace-on-truncate hueristics for data=writeback mode ext3: Use WRITE_SYNC for commits which are caused by fsync() block_write_full_page: Use synchronous writes for WBC_SYNC_ALL writebacks
2009-04-02jbd: fix oops in jbd_journal_init_inode() on corrupted fsJan Kara
On 32-bit system with CONFIG_LBD getblk can fail because provided block number is too big. Make JBD gracefully handle that. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <dmaciejak@fortinet.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27ext3: Use WRITE_SYNC for commits which are caused by fsync()Theodore Ts'o
If a commit is triggered by fsync(), set a flag indicating the journal blocks associated with the transaction should be flushed out using WRITE_SYNC. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz>
2009-02-11jbd: fix return value of journal_start_commit()Jan Kara
journal_start_commit() returns 1 if either a transaction is committing or the function has queued a transaction commit. But it returns 0 if we raced with somebody queueing the transaction commit as well. This resulted in ext3_sync_fs() not functioning correctly (description from Arthur Jones): In the case of a data=ordered umount with pending long symlinks which are delayed due to a long list of other I/O on the backing block device, this causes the buffer associated with the long symlinks to not be moved to the inode dirty list in the second phase of fsync_super. Then, before they can be dirtied again, kjournald exits, seeing the UMOUNT flag and the dirty pages are never written to the backing block device, causing long symlink corruption and exposing new or previously freed block data to userspace. This can be reproduced with a script created by Eric Sandeen <sandeen@redhat.com>: #!/bin/bash umount /mnt/test2 mount /dev/sdb4 /mnt/test2 rm -f /mnt/test2/* dd if=/dev/zero of=/mnt/test2/bigfile bs=1M count=512 touch /mnt/test2/thisisveryveryveryveryveryveryveryveryveryveryveryveryveryveryveryverylongfilename ln -s /mnt/test2/thisisveryveryveryveryveryveryveryveryveryveryveryveryveryveryveryverylongfilename /mnt/test2/link umount /mnt/test2 mount /dev/sdb4 /mnt/test2 ls /mnt/test2/ This patch fixes journal_start_commit() to always return 1 when there's a transaction committing or queued for commit. Cc: Eric Sandeen <sandeen@redhat.com> Cc: Mike Snitzer <snitzer@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08jbd: remove excess kernel-doc notationRandy Dunlap
Remove excess kernel-doc from fs/jbd/transaction.c: Warning(linux-2.6.28-git5//fs/jbd/transaction.c:764): Excess function parameter 'credits' description in 'journal_get_write_access' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08jbd: improve fsync batchingJosef Bacik
There is a flaw with the way jbd handles fsync batching. If we fsync() a file and we were not the last person to run fsync() on this fs then we automatically sleep for 1 jiffie in order to wait for new writers to join into the transaction before forcing the commit. The problem with this is that with really fast storage (ie a Clariion) the time it takes to commit a transaction to disk is way faster than 1 jiffie in most cases, so sleeping means waiting longer with nothing to do than if we just committed the transaction and kept going. Ric Wheeler noticed this when using fs_mark with more than 1 thread, the throughput would plummet as he added more threads. This patch attempts to fix this problem by recording the average time in nanoseconds that it takes to commit a transaction to disk, and what time we started the transaction. If we run an fsync() and we have been running for less time than it takes to commit the transaction to disk, we sleep for the delta amount of time and then commit to disk. We acheive sub-jiffie sleeping using schedule_hrtimeout. This means that the wait time is auto-tuned to the speed of the underlying disk, instead of having this static timeout. I weighted the average according to somebody's comments (Andreas Dilger I think) in order to help normalize random outliers where we take way longer or way less time to commit than the average. I also have a min() check in there to make sure we don't sleep longer than a jiffie in case our storage is super slow, this was requested by Andrew. I unfortunately do not have access to a Clariion, so I had to use a ramdisk to represent a super fast array. I tested with a SATA drive with barrier=1 to make sure there was no regression with local disks, I tested with a 4 way multipathed Apple Xserve RAID array and of course the ramdisk. I ran the following command fs_mark -d /mnt/ext3-test -s 4096 -n 2000 -D 64 -t $i where $i was 2, 4, 8, 16 and 32. I mkfs'ed the fs each time. Here are my results type threads with patch without patch sata 2 24.6 26.3 sata 4 49.2 48.1 sata 8 70.1 67.0 sata 16 104.0 94.1 sata 32 153.6 142.7 xserve 2 246.4 222.0 xserve 4 480.0 440.8 xserve 8 829.5 730.8 xserve 16 1172.7 1026.9 xserve 32 1816.3 1650.5 ramdisk 2 2538.3 1745.6 ramdisk 4 2942.3 661.9 ramdisk 8 2882.5 999.8 ramdisk 16 2738.7 1801.9 ramdisk 32 2541.9 2394.0 Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ric Wheeler <rwheeler@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06jbd: don't give up looking for space so easily in __log_wait_for_spaceTheodore Ts'o
Commit be07c4ed introducd a regression because it assumed that if there were no transactions ready to be checkpointed, that no progress could be made on making space available in the journal, and so the journal should be aborted. This assumption is false; it could be the case that simply calling cleanup_journal_tail() will recover the necessary space, or, for small journals, the currently committing transaction could be responsible for chewing up the required space in the log, so we need to wait for the currently committing transaction to finish before trying to force a checkpoint operation. This patch fixes the bug reported by Meelis Roos at: http://bugzilla.kernel.org/show_bug.cgi?id=11937 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Duane Griffin <duaneg@dghda.com> Cc: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
2008-10-30fs: remove excess kernel-docRandy Dunlap
Delete excess kernel-doc notation in fs/ subdirectory: Warning(linux-2.6.27-git10//fs/jbd/transaction.c:886): Excess function parameter or struct member 'credits' description in 'journal_get_undo_access' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: abort instead of waiting for nonexistent transactionsDuane Griffin
The __log_wait_for_space function sits in a loop checkpointing transactions until there is sufficient space free in the journal. However, if there are no transactions to be processed (e.g. because the free space calculation is wrong due to a corrupted filesystem) it will never progress. Check for space being required when no transactions are outstanding and abort the journal instead of endlessly looping. This patch fixes the bug reported by Sami Liedes at: http://bugzilla.kernel.org/show_bug.cgi?id=10976 Signed-off-by: Duane Griffin <duaneg@dghda.com> Tested-by: Sami Liedes <sliedes@cc.hut.fi> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: test BH_Write_EIO to detect errors on metadata buffersHidehiro Kawai
__try_to_free_cp_buf(), __process_buffer(), and __wait_cp_io() test BH_Uptodate flag to detect write I/O errors on metadata buffers. But by commit 95450f5a7e53d5752ce1a0d0b8282e10fe745ae0 "ext3: don't read inode block if the buffer has a write error"(*), BH_Uptodate flag can be set to inode buffers with BH_Write_EIO in order to avoid reading old inode data. So now, we have to test BH_Write_EIO flag of checkpointing inode buffers instead of BH_Uptodate. This patch does it. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23jbd: fix error handling for checkpoint ioHidehiro Kawai
When a checkpointing IO fails, current JBD code doesn't check the error and continue journaling. This means latest metadata can be lost from both the journal and filesystem. This patch leaves the failed metadata blocks in the journal space and aborts journaling in the case of log_do_checkpoint(). To achieve this, we need to do: 1. don't remove the failed buffer from the checkpoint list where in the case of __try_to_free_cp_buf() because it may be released or overwritten by a later transaction 2. log_do_checkpoint() is the last chance, remove the failed buffer from the checkpoint list and abort the journal 3. when checkpointing fails, don't update the journal super block to prevent the journaled contents from being cleaned. For safety, don't update j_tail and j_tail_sequence either 4. when checkpointing fails, notify this error to the ext3 layer so that ext3 don't clear the needs_recovery flag, otherwise the journaled contents are ignored and cleaned in the recovery phase 5. if the recovery fails, keep the needs_recovery flag 6. prevent cleanup_journal_tail() from being called between __journal_drop_transaction() and journal_abort() (a race issue between journal_flush() and __log_wait_for_space() Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20fs/Kconfig: move ext2, ext3, ext4, JBD, JBD2 outAlexey Dobriyan
Use fs/*/Kconfig more, which is good because everything related to one filesystem is in one place and fs/Kconfig is quite fat. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20jbd: ordered data integrity fixHidehiro Kawai
In ordered mode, if a file data buffer being dirtied exists in the committing transaction, we write the buffer to the disk, move it from the committing transaction to the running transaction, then dirty it. But we don't have to remove the buffer from the committing transaction when the buffer couldn't be written out, otherwise it would miss the error and the committing transaction would not abort. This patch adds an error check before removing the buffer from the committing transaction. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20ext3: add an option to control error handling on file dataHidehiro Kawai
If the journal doesn't abort when it gets an IO error in file data blocks, the file data corruption will spread silently. Because most of applications and commands do buffered writes without fsync(), they don't notice the IO error. It's scary for mission critical systems. On the other hand, if the journal aborts whenever it gets an IO error in file data blocks, the system will easily become inoperable. So this patch introduces a filesystem option to determine whether it aborts the journal or just call printk() when it gets an IO error in file data. If you mount a ext3 fs with data_err=abort option, it aborts on file data write error. If you mount it with data_err=ignore, it doesn't abort, just call printk(). data_err=ignore is the default. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20jbd: don't dirty original metadata buffer on abortHidehiro Kawai
Currently, original metadata buffers are dirtied when they are unfiled whether the journal has aborted or not. Eventually these buffers will be written-back to the filesystem by pdflush. This means some metadata buffers are written to the filesystem without journaling if the journal aborts. So if both journal abort and system crash happen at the same time, the filesystem would become inconsistent state. Additionally, replaying journaled metadata can overwrite the latest metadata on the filesystem partly. Because, if the journal aborts, journaled metadata are preserved and replayed during the next mount not to lose uncheckpointed metadata. This would also break the consistency of the filesystem. This patch prevents original metadata buffers from being dirtied on abort by clearing BH_JBDDirty flag from those buffers. Thus, no metadata buffers are written to the filesystem without journaling. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20jbd: abort when failed to log metadata buffersHidehiro Kawai
If we failed to write metadata buffers to the journal space and succeeded to write the commit record, stale data can be written back to the filesystem as metadata in the recovery phase. To avoid this, when we failed to write out metadata buffers, abort the journal before writing the commit record. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12Merge branch 'core/locking' into core/urgentIngo Molnar
2008-08-11lockdep: rename map_[acquire|release]() => lock_map_[acquire|release]()Ingo Molnar
the names were too generic: drivers/uio/uio.c:87: error: expected identifier or '(' before 'do' drivers/uio/uio.c:87: error: expected identifier or '(' before 'while' drivers/uio/uio.c:113: error: 'map_release' undeclared here (not in a function) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-11lockdep: map_acquirePeter Zijlstra
Most the free-standing lock_acquire() usages look remarkably similar, sweep them into a new helper. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-04fs: rename buffer trylockNick Piggin
Like the page lock change, this also requires name change, so convert the raw test_and_set bitop to a trylock. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04mm: rename page trylockNick Piggin
Converting page lock to new locking bitops requires a change of page flag operation naming, so we might as well convert it to something nicer (!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked). This also facilitates lockdeping of page lock. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: don't abort if flushing file data failedHidehiro Kawai
In ordered mode, the current jbd aborts the journal if a file data buffer has an error. But this behavior is unintended, and we found that it has been adopted accidentally. This patch undoes it and just calls printk() instead of aborting the journal. Additionally, set AS_EIO into the address_space object of the failed buffer which is submitted by journal_do_submit_data() so that fsync() can get -EIO. Missing error checkings are also added to inform errors on file data buffers to the user. The following buffers are targeted. (a) the buffer which has already been written out by pdflush (b) the buffer which has been unlocked before scanned in the t_locked_list loop [akpm@linux-foundation.org: improve grammar in a printk] Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: positively dispose the unmapped data buffers in ↵Toshiyuki Okajima
journal_commit_transaction() After ext3-ordered files are truncated, there is a possibility that the pages which cannot be estimated still remain. Remaining pages can be released when the system has really few memory. So, it is not memory leakage. But the resource management software etc. may not work correctly. It is possible that journal_unmap_buffer() cannot release the buffers, and the pages to which they belong because they are attached to a commiting transaction and journal_unmap_buffer() cannot release them. To release such the buffers and the pages later, journal_unmap_buffer() leaves it to journal_commit_transaction(). (journal_unmap_buffer() puts the mark 'BH_Freed' to the buffers so that journal_commit_transaction() can identify whether they can be released or not.) In the journalled mode and the writeback mode, jbd does with only metadata buffers. But in the ordered mode, jbd does with metadata buffers and also data buffers. Actually, journal_commit_transaction() releases only the metadata buffers of which release is demanded by journal_unmap_buffer(), and also releases the pages to which they belong if possible. As a result, the data buffers of which release is demanded by journal_unmap_buffer() remain after a transaction commits. And also the pages to which they belong remain. Such the remained pages don't have mapping any longer. Due to this fact, there is a possibility that the pages which cannot be estimated remain. The metadata buffers marked 'BH_Freed' and the pages to which they belong can be released at 'JBD: commit phase 7'. Therefore, by applying the same code into 'JBD: commit phase 2' (where the data buffers are done with), journal_commit_transaction() can also release the data buffers marked 'BH_Freed' and the pages to which they belong. As a result, all the buffers marked 'BH_Freed' can be released, and also all the pages to which these buffers belong can be released at journal_commit_transaction(). So, the page which cannot be estimated is lost. <<Excerpt of code at 'JBD: commit phase 7'>> > spin_lock(&journal->j_list_lock); > while (commit_transaction->t_forget) { > transaction_t *cp_transaction; > struct buffer_head *bh; > > jh = commit_transaction->t_forget; >... > if (buffer_freed(bh)) { > ^^^^^^^^^^^^^^^^^^^^^^^^ > clear_buffer_freed(bh); > ^^^^^^^^^^^^^^^^^^^^^^^^ > clear_buffer_jbddirty(bh); > } > > if (buffer_jbddirty(bh)) { > JBUFFER_TRACE(jh, "add to new checkpointing trans"); > __journal_insert_checkpoint(jh, commit_transaction); > JBUFFER_TRACE(jh, "refile for checkpoint writeback"); > __journal_refile_buffer(jh); > jbd_unlock_bh_state(bh); > } else { > J_ASSERT_BH(bh, !buffer_dirty(bh)); > ... > JBUFFER_TRACE(jh, "refile or unfile freed buffer"); > __journal_refile_buffer(jh); > if (!jh->b_transaction) { > jbd_unlock_bh_state(bh); > /* needs a brelse */ > journal_remove_journal_head(bh); > release_buffer_page(bh); > ^^^^^^^^^^^^^^^^^^^^^^^^ > } else > } **************************************************************** * Apply the code of "^^^^^^" lines into 'JBD: commit phase 2' * **************************************************************** At journal_commit_transaction() code, there is one extra message in the series of jbd debug messages. ("JBD: commit phase 2") This patch fixes it, too. Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: unexport journal_update_superblockAdrian Bunk
Remove the unused EXPORT_SYMBOL(journal_update_superblock). Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: fix race between free buffer and commit transactionMingming Cao
journal_try_to_free_buffers() could race with jbd commit transaction when the later is holding the buffer reference while waiting for the data buffer to flush to disk. If the caller of journal_try_to_free_buffers() request tries hard to release the buffers, it will treat the failure as error and return back to the caller. We have seen the directo IO failed due to this race. Some of the caller of releasepage() also expecting the buffer to be dropped when passed with GFP_KERNEL mask to the releasepage()->journal_try_to_free_buffers(). With this patch, if the caller is passing the __GFP_WAIT and __GFP_FS to indicating this call could wait, in case of try_to_free_buffers() failed, let's waiting for journal_commit_transaction() to finish commit the current committing transaction, then try to free those buffers again. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mingming Cao <cmm@us.ibm.com> Reviewed-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25jbd: tidy up revoke cache initialisation and destructionDuane Griffin
Make revocation cache destruction safe to call if initialisation fails partially or entirely. This allows it to be used to cleanup in the case of initialisation failure, simplifying that code slightly. Signed-off-by: Duane Griffin <duaneg@dghda.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
