path: root/fs/jffs2/debug.h
2010-08-08jffs2: Update copyright noticesDavid Woodhouse
2008-04-30fs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-23[JFFS2] Introduce dbg_readinode2 log level, use it to shut read_dnode() upDavid Woodhouse
We haven't seen bugs in this for a while now, since the rewrite. No need to be _quite_ so verbose... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[JFFS2] Tidy up licensing/copyright boilerplate.David Woodhouse
In particular, remove the bit in the LICENCE file about contacting Red Hat for alternative arrangements. Their errant IS department broke that arrangement a long time ago -- the policy of collecting copyright assignments from contributors came to an end when the plug was pulled on the servers hosting the project, without notice or reason. We do still dual-license it for use with eCos, with the GPL+exception licence approved by the FSF as being GPL-compatible. It's just that nobody has the right to license it differently. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-01-13[JFFS2] debug.h: include <linux/sched.h> for current->pidDavid Woodhouse
2006-05-13[JFFS2][XATTR] XATTR support on JFFS2 (version. 5)KaiGai Kohei
This attached patches provide xattr support including POSIX-ACL and SELinux support on JFFS2 (version.5). There are some significant differences from previous version posted at last December. The biggest change is addition of EBS(Erase Block Summary) support. Currently, both kernel and usermode utility (sumtool) can recognize xattr nodes which have JFFS2_NODETYPE_XATTR/_XREF nodetype. In addition, some bugs are fixed. - A potential race condition was fixed. - Unexpected fail when updating a xattr by same name/value pair was fixed. - A bug when removing xattr name/value pair was fixed. The fundamental structures (such as using two new nodetypes and exclusion mechanism by rwsem) are unchanged. But most of implementation were reviewed and updated if necessary. Espacially, we had to change several internal implementations related to load_xattr_datum() to avoid a potential race condition. [1/2] xattr_on_jffs2.kernel.version-5.patch [2/2] xattr_on_jffs2.utils.version-5.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-23[PATCH] jffs2 debug gcc-2.9x fixAndrew Morton
Work around gcc-2.95.x macro expansion bug. Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[JFFS2] Clean up trailing white spacesThomas Gleixner
2005-11-06[JFFS2] Fix broken compile when debug level = 2Artem B. Bityutskiy
Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code simplification, update TODOArtem B. Bityutskiy
Simplify the debugging code further. Update the TODO list Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug message format clean upArtem B. Bityutskiy
2005-11-06[JFFS2] Add erase block summary support (mount time improvement)Ferenc Havasi
The goal of summary is to speed up the mount time. Erase block summary (EBS) stores summary information at the end of every (closed) erase block. It is no longer necessary to scan all nodes separetly (and read all pages of them) just read this "small" summary, where every information is stored which is needed at mount time. This summary information is stored in a JFFS2_FEATURE_RWCOMPAT_DELETE. During the mount process if there is no summary info the orignal scan process will be executed. EBS works with NAND and NOR flashes, too. There is a user space tool called sumtool to generate this summary information for a JFFS2 image. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] More message formatting cleanupsArtem B. Bityutskiy
2005-11-06[JFFS2] Make the JFFS2 messages a bit nicerArtem B. Bityutskiy
2005-11-06[JFFS2] Debug code clean up - step 7Artem B. Bityutskiy
Remove more noisy debugs. Add current->pid to debug messages. Remove bogus includes. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 6Artem B. Bityutskiy
Remove extra noisy debugs Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Refine fragtree debug macrosArtem B. Bityutskiy
2005-11-06[JFFS2] Debug code clean up - step 4Artem B. Bityutskiy
Small comment cleanups. Remove a unused macro Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Namespace clean upArtem B. Bityutskiy
Rename functions to a name matching the functionality. Remove stall debug code Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 3Artem B. Bityutskiy
Various simplifiactions. printk format corrections. Convert more code to use the new debug functions. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 1Artem B. Bityutskiy
Move debug functions into a seperate source file Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
