path: root/fs/jffs2/fs.c
2012-03-30Merge tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6Linus Torvalds
Pull MTD changes from David Woodhouse: - Artem's cleanup of the MTD API continues apace. - Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst others. - More work on DiskOnChip G3, new driver for DiskOnChip G4. - Clean up debug/warning printks in JFFS2 to use pr_<level>. Fix up various trivial conflicts, largely due to changes in calling conventions for things like dmaengine_prep_slave_sg() (new inline wrapper to hide new parameter, clashing with rewrite of previously last parameter that used to be an 'append' flag, and is now a bitmap of 'unsigned long flags'). (Also some header file fallout - like so many merges this merge window - and silly conflicts with sparse fixes) * tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits) mtd: docg3 add protection against concurrency mtd: docg3 refactor cascade floors structure mtd: docg3 increase write/erase timeout mtd: docg3 fix inbound calculations mtd: nand: gpmi: fix function annotations mtd: phram: fix section mismatch for phram_setup mtd: unify initialization of erase_info->fail_addr mtd: support ONFI multi lun NAND mtd: sm_ftl: fix typo in major number. mtd: add device-tree support to spear_smi mtd: spear_smi: Remove default partition information from driver mtd: Add device-tree support to fsmc_nand mtd: fix section mismatch for doc_probe_device mtd: nand/fsmc: Remove sparse warnings and errors mtd: nand/fsmc: Add DMA support mtd: nand/fsmc: Access the NAND device word by word whenever possible mtd: nand/fsmc: Use dev_err to report error scenario mtd: nand/fsmc: Use devm routines mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform mtd: fsmc_nand: add pm callbacks to support hibernation ...
2012-03-27jffs2: Use pr_fmt and remove jffs: from formatsJoe Perches
Use pr_fmt to prefix KBUILD_MODNAME to appropriate logging messages. Remove now unnecessary internal prefixes from formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-27jffs2: Convert printks to pr_<level>Joe Perches
Use the more current logging style. Coalesce formats, align arguments. Convert uses of embedded function names to %s, __func__. A couple of long line checkpatch errors I don't care about exist. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-27jffs2: Convert most D1/D2 macros to jffs2_dbgJoe Perches
D1 and D2 macros are mostly uses to emit debugging messages. Convert the logging uses of D1 & D2 to jffs2_dbg(level, fmt, ...) to be a bit more consistent style with the rest of the kernel. All jffs2_dbg output is now at KERN_DEBUG where some of the previous uses were emitted at various KERN_<LEVEL>s. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-09jffs2: fix up error handling for insert_inode_lockedEric Sandeen
after 250df6ed274d767da844a5d9f05720b804240197 (fs: protect inode->i_state with inode->i_lock), insert_inode_locked() no longer returns the inode with I_NEW set on failure. However, the error handler still calls unlock_new_inode() on failure, which does a WARN_ON if I_NEW is not set, so any failure spews a lot of warnings. We can just drop the unlock_new_inode() if insert_inode_locked() fails here. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-11-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (226 commits) mtd: tests: annotate as DANGEROUS in Kconfig mtd: tests: don't use mtd0 as a default mtd: clean up usage of MTD_DOCPROBE_ADDRESS jffs2: add compr=lzo and compr=zlib options jffs2: implement mount option parsing and compression overriding mtd: nand: initialize ops.mode mtd: provide an alias for the redboot module name mtd: m25p80: don't probe device which has status of 'disabled' mtd: nand_h1900 never worked mtd: Add DiskOnChip G3 support mtd: m25p80: add EON flash EN25Q32B into spi flash id table mtd: mark block device queue as non-rotational mtd: r852: make r852_pm_ops static mtd: m25p80: add support for at25df321a spi data flash mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks mtd: nand: switch `check_pattern()' to standard `memcmp()' mtd: nand: invalidate cache on unaligned reads mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set mtd: nand: wait to set BBT version mtd: nand: scrub BBT on ECC errors ... Fix up trivial conflicts: - arch/arm/mach-at91/board-usb-a9260.c Merged into board-usb-a926x.c - drivers/mtd/maps/lantiq-flash.c add_mtd_partitions -> mtd_device_register vs changed to use mtd_device_parse_register.
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-19jffs2: implement mount option parsing and compression overridingAndres Salomon
Currently jffs2 has compile-time constants (and .config options) controlling whether or not the various compression/decompression drivers are built in and enabled. This is fine for embedded systems, but it clashes with distribution kernels. Distro kernels tend to turn on everything; this causes OpenFirmware to fall over, as it understands ZLIB-compressed inodes. Booting a kernel that has LZO compression enabled, writing to the boot partition, and then rebooting causes OFW to fail to read the kernel from the filesystem. This is because LZO compression has priority when writing new data to jffs2, if LZO is enabled. This patch adds mount option parsing, and a single supported option ("compr=none"). This adds the flexibility of being able to specify which compressor overrides on a per-superblock basis. For now, we can simply disable compression; additional flexibility coming soon. v2: kill some printks, and implement show_options as suggested by Artem Bityutskiy. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26jffs2: S_ISLNK(mode & S_IFMT) is pointlessAl Viro
it's S_ISLNK(mode), TYVM... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-24fix jffs2 ACLs on big-endian with 16bit mode_tAl Viro
casting int * to mode_t * is not a good thing - on a *lot* of big-endian architectures mode_t happens to be smaller than int and there it breaks quite spectaculary... Fucked-up-by: commit cfc8dc6f6f69ede939e09c2af06a01adee577285 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27fs: pass exact type of data dirties to ->dirty_inodeChristoph Hellwig
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or anything else, so that the filesystem can track internally if it needs to push out a transaction for fdatasync or not. This is just the prototype change with no user for it yet. I plan to push large XFS changes for the next merge window, and getting this trivial infrastructure in this window would help a lot to avoid tree interdependencies. Also remove incorrect comments that ->dirty_inode can't block. That has been changed a long time ago, and many implementations rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-30Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git Conflicts: drivers/mtd/mtd_blkdevs.c Merge Grant's device-tree bits so that we can apply the subsequent fixes. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-25jffs2: Dynamically choose inocache hash sizeDaniel Drake
When JFFS2 is used for large volumes, the mount times are quite long. Increasing the hash size provides a significant speed boost on the OLPC XO-1 laptop. Add logic that dynamically selects a hash size based on the size of the medium. A 64mb medium will result in a hash size of 128, and a 512mb medium will result in a hash size of 1024. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-10-04BKL: Remove BKL from jffs2Arnd Bergmann
The BKL is only used in put_super, fill_super and remount_fs that are all three protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: David Woodhouse <dwmw2@infradead.org>
2010-08-10Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (79 commits) mtd: Remove obsolete <mtd/compatmac.h> include mtd: Update copyright notices jffs2: Update copyright notices mtd-physmap: add support users can assign the probe type in board files mtd: remove redwood map driver mxc_nand: Add v3 (i.MX51) Support mxc_nand: support 8bit ecc mxc_nand: fix correct_data function mxc_nand: add V1_V2 namespace to registers mxc_nand: factor out a check_int function mxc_nand: make some internally used functions overwriteable mxc_nand: rework get_dev_status mxc_nand: remove 0xe00 offset from registers mtd: denali: Add multi connected NAND support mtd: denali: Remove set_ecc_config function mtd: denali: Remove unuseful code in get_xx_nand_para functions mtd: denali: Remove device_info_tag structure mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips ... Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to redwood driver removal.
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-08jffs2: Update copyright noticesDavid Woodhouse
2010-06-07Merge git://git.infradead.org/~dwmw2/mtd-2.6.35Linus Torvalds
* git://git.infradead.org/~dwmw2/mtd-2.6.35: jffs2: update ctime when changing the file's permission by setfacl jffs2: Fix NFS race by using insert_inode_locked() jffs2: Fix in-core inode leaks on error paths mtd: Fix NAND submenu mtd/r852: update card detect early. mtd/r852: Fixes in case of DMA timeout mtd/r852: register IRQ as last step drivers/mtd: Use memdup_user docbook: make mtd nand module init static
2010-06-03jffs2: Fix NFS race by using insert_inode_locked()David Woodhouse
New inodes need to be locked as we're creating them, so they don't get used by other things (like NFSd) before they're ready. Pointed out by Al Viro. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-05-27kill spurious reference to vmtruncatenpiggin@suse.de
Lots of filesystems calls vmtruncate despite not implementing the old ->truncate method. Switch them to use simple_setsize and add some comments about the truncate code where it seems fitting. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-25JFFS2: avoid using C++ keyword `new' in userspace-visible headerAndrew Morton
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14995 Reported-by: R. Diez <rdiezmail-kernelbugzilla@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11jffs2: move jffs2_write_super to super.cChristoph Hellwig
jffs2_write_super is only called from super.c and doesn't use any functionality from fs.c. So move it over to super.c and make it static there. [should go in through the vfs tree as it is a requirement for the next patch] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-09-01CRED: Wrap task credential accesses in the JFFS2 filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-18[JFFS2] Fill in f_fsid field in jffs2_statfs()David Woodhouse
2008-05-01[JFFS2] Track parent inode for directories (for NFS export)David Woodhouse
To support NFS export, we need to know the parent inode of directories. Rather than growing the jffs2_inode_cache structure, share space with the nlink field -- which was always set to 1 for directories anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-05-01[JFFS2] Invert last argument of jffs2_gc_fetch_inode(), make it boolean.David Woodhouse
We don't actually care about nlink; we only care whether the inode in question is unlinked or not. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[JFFS2] semaphore->mutex conversionDavid Woodhouse
2008-02-25[JFFS2] Use ALLOC_DELETION priority for truncation to zero lengthDavid Woodhouse
This is going to obsolete all previous nodes, so treat it as deletion. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-25[JFFS2] Set i_blocks when truncating filesDavid Woodhouse
Addresses OLPC trac #6480 Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-02-07Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (120 commits) [MTD] Fix mtdoops.c compilation [MTD] [NOR] fix startup lock when using multiple nor flash chips [MTD] [DOC200x] eccbuf is statically defined and always evaluate to true [MTD] Fix maps/physmap.c compilation with CONFIG_PM [MTD] onenand: Add panic_write function to the onenand driver [MTD] mtdoops: Use the panic_write function when present [MTD] Add mtd panic_write function pointer [MTD] [NAND] Freescale enhanced Local Bus Controller FCM NAND support. [MTD] physmap.c: Add support for multiple resources [MTD] [NAND] Fix misparenthesization introduced by commit 78b65179... [MTD] [NAND] Fix Blackfin NFC ECC calculating bug with page size 512 bytes [MTD] [NAND] Remove wrong operation in PM function of the BF54x NFC driver [MTD] [NAND] Remove unused variable in plat_nand_remove [MTD] Unlocking all Intel flash that is locked on power up. [MTD] [NAND] at91_nand: Make mtdparts option can override board info [MTD] mtdoops: Various minor cleanups [MTD] mtdoops: Ensure sequential write to the buffer [MTD] mtdoops: Perform write operations in a workqueue [MTD] mtdoops: Add further error return code checking [MTD] [NOR] Test devtype, not definition in flash_probe(), drivers/mtd/devices/lart.c ...
2008-02-07iget: stop JFFS2 from using iget() and read_inode()David Howells
Stop the JFFS2 filesystem from using iget() and read_inode(). Replace jffs2_read_inode() with jffs2_iget(), and call that instead of iget(). jffs2_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. jffs2_do_fill_super() returns any error incurred when getting the root inode instead of EINVAL. Signed-off-by: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-01[JFFS2] Don't strip sgid bit from inode permissionsDavid Woodhouse
<viro> dwmw2: anyway, removing sgid from directories or from files without S_IXGRP is a plain and simple bug <viro> these days you don't need that logics at all - simply remove it Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-20[JFFS2] Tidy up fix for ACL/permissions problem.KaiGai Kohei
[In commit 9ed437c50d89eabae763dd422579f73fdebf288d we fixed a problem with standard permissions on newly-created inodes, when POSIX ACLs are enabled. This cleans it up...] The attached patch separate jffs2_init_acl() into two parts. The one is jffs2_init_acl_pre() called from jffs2_new_inode(). It compute ACL oriented inode->i_mode bits, and allocate in-memory ACL objects associated with the new inode just before when inode meta infomation is written to the medium. The other is jffs2_init_acl_post() called from jffs2_symlink(), jffs2_mkdir(), jffs2_mknod() and jffs2_do_create(). It actually writes in-memory ACL objects into the medium next to the success of writing meta-information. In the current implementation, we have to write a same inode meta infomation twice when inode->i_mode is updated by the default ACL. However, we can avoid the behavior by putting an updated i_mode before it is written at first, as jffs2_init_acl_pre() doing. Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-13Merge Linux 2.6.23David Woodhouse
2007-09-02[JFFS2] fix write deadlock regressionJason Lunz
I've bisected the deadlock when many small appends are done on jffs2 down to this commit: commit 6fe6900e1e5b6fa9e5c59aa5061f244fe3f467e2 Author: Nick Piggin <npiggin@suse.de> Date: Sun May 6 14:49:04 2007 -0700 mm: make read_cache_page synchronous Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. It introduced a wait to read_cache_page, as well as a read_cache_page_async function equivalent to the old read_cache_page without any callers. Switching jffs2_gc_fetch_page to read_cache_page_async for the old behavior makes the deadlocks go away, but maybe reintroduces the use-before-uptodate problem? I don't understand the mm/fs interaction well enough to say. [It's fine. dwmw2.] Signed-off-by: Jason Lunz <lunz@falooley.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-08-22[JFFS2] Fix ACL vs. mode handling.David Woodhouse
When POSIX ACL support was enabled, we weren't writing correct legacy modes to the medium on inode creation, or when the ACL was set. This meant that the permissions would be incorrect after the file system was remounted. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-04-27Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/Kconfig Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-04-27JFFS2: add UBI supportArtem Bityutskiy
This patch make JFFS2 able to work with UBI volumes via the emulated MTD devices which are directly mapped to these volumes. Signed-off-by: Artem Bityutskiy <dedekind@infradead.org>
2007-04-25[JFFS2] Tidy up licensing/copyright boilerplate.David Woodhouse
In particular, remove the bit in the LICENCE file about contacting Red Hat for alternative arrangements. Their errant IS department broke that arrangement a long time ago -- the policy of collecting copyright assignments from contributors came to an end when the plug was pulled on the servers hosting the project, without notice or reason. We do still dual-license it for use with eCos, with the GPL+exception licence approved by the FSF as being GPL-compatible. It's just that nobody has the right to license it differently. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-12-10[JFFS2] replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[JFFS2][XATTR] Fix memory leak with jffs2_xattr_refKaiGai Kohei
If xattr_ref is associated with an orphan inode_cache on filesystem mounting, those xattr_refs are not released even if this inode_cache is released. This patch enables to call jffs2_xattr_delete_inode() for such a irregular inode_cachde too. Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-23[JFFS2] Remove flash offset argument from various functions.David Woodhouse
We don't need the upper layers to deal with the physical offset. It's _always_ c->nextblock->offset + c->sector_size - c->nextblock->free_size so we might as well just let the actual write functions deal with that. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
