that's the bulk of filesystem drivers dealing with inodes of their own
Pull MTD updates from Brian Norris:
- A few SPI NOR ID definitions
- Kill the NAND "max pagesize" restriction
- Fix some x16 bus-width NAND support
- Add NAND JEDEC parameter page support
- DT bindings for NAND ECC
- GPMI NAND updates (subpage reads)
- More OMAP NAND refactoring
- New STMicro SPI NOR driver (now in 40 patches!)
- A few other random bugfixes
* tag 'for-linus-20140405' of git://git.infradead.org/linux-mtd: (120 commits)
Fix index regression in nand_read_subpage
mtd: diskonchip: mem resource name is not optional
mtd: nand: fix mention to CONFIG_MTD_NAND_ECC_BCH
mtd: nand: fix GET/SET_FEATURES address on 16-bit devices
mtd: omap2: Use devm_ioremap_resource()
mtd: denali_dt: Use devm_ioremap_resource()
mtd: devices: elm: update DRIVER_NAME as "omap-elm"
mtd: devices: elm: configure parallel channels based on ecc_steps
mtd: devices: elm: clean elm_load_syndrome
mtd: devices: elm: check for hardware engine's design constraints
mtd: st_spi_fsm: Succinctly reorganise .remove()
mtd: st_spi_fsm: Allow loop to run at least once before giving up CPU
mtd: st_spi_fsm: Correct vendor name spelling issue - missing "M"
mtd: st_spi_fsm: Avoid duplicating MTD core code
mtd: st_spi_fsm: Remove useless consts from function arguments
mtd: st_spi_fsm: Convert ST SPI FSM (NOR) Flash driver to new DT partitions
mtd: st_spi_fsm: Move runtime configurable msg sequences into device's struct
mtd: st_spi_fsm: Supply the W25Qxxx chip specific configuration call-back
mtd: st_spi_fsm: Supply the S25FLxxx chip specific configuration call-back
mtd: st_spi_fsm: Supply the MX25xxx chip specific configuration call-back
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
If jffs2_new_inode() succeeds, it returns with f->sem held, and the caller
is responsible for releasing the lock. If it fails, it still returns with
the lock held, but the caller won't release the lock, which will lead to
deadlock.
Fix it by releasing the lock in jffs2_new_inode() on error.
Signed-off-by: Wang Guoli <andy.wangguoli@huawei.com>
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Cc: Wang Guoli <andy.wangguoli@huawei.com>
[Brian: not marked for stable; no one observed deadlock, and I don't
think it can happen here]
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux.
We should not support the MLC nand for jffs2. So if the nand type is
MLC, we quit immediatly.
Signed-off-by: Huang Shijie <b32955@freescale.com>
- General routine uid/gid conversion work
- When storing posix acls treat ACL_USER and ACL_GROUP separately
so I can call from_kuid or from_kgid as appropriate.
- When reading posix acls treat ACL_USER and ACL_GROUP separately
so I can call make_kuid or make_kgid as appropriate.
After we moved inode_sync_wait() from end_writeback() it doesn't make sense
to call the function end_writeback() anymore. Rename it to clear_inode()
which well says what the function really does - set I_CLEAR flag.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Pull MTD changes from David Woodhouse:
- Artem's cleanup of the MTD API continues apace.
- Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst
others.
- More work on DiskOnChip G3, new driver for DiskOnChip G4.
- Clean up debug/warning printks in JFFS2 to use pr_<level>.
Fix up various trivial conflicts, largely due to changes in calling
conventions for things like dmaengine_prep_slave_sg() (new inline
wrapper to hide new parameter, clashing with rewrite of previously last
parameter that used to be an 'append' flag, and is now a bitmap of
'unsigned long flags').
(Also some header file fallout - like so many merges this merge window -
and silly conflicts with sparse fixes)
* tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits)
mtd: docg3 add protection against concurrency
mtd: docg3 refactor cascade floors structure
mtd: docg3 increase write/erase timeout
mtd: docg3 fix inbound calculations
mtd: nand: gpmi: fix function annotations
mtd: phram: fix section mismatch for phram_setup
mtd: unify initialization of erase_info->fail_addr
mtd: support ONFI multi lun NAND
mtd: sm_ftl: fix typo in major number.
mtd: add device-tree support to spear_smi
mtd: spear_smi: Remove default partition information from driver
mtd: Add device-tree support to fsmc_nand
mtd: fix section mismatch for doc_probe_device
mtd: nand/fsmc: Remove sparse warnings and errors
mtd: nand/fsmc: Add DMA support
mtd: nand/fsmc: Access the NAND device word by word whenever possible
mtd: nand/fsmc: Use dev_err to report error scenario
mtd: nand/fsmc: Use devm routines
mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform
mtd: fsmc_nand: add pm callbacks to support hibernation
Use pr_fmt to prefix KBUILD_MODNAME to appropriate logging messages.
Remove now unnecessary internal prefixes from formats.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Use the more current logging style.
Coalesce formats, align arguments.
Convert uses of embedded function names to %s, __func__.
A couple of long line checkpatch errors I don't care about exist.
D1 and D2 macros are mostly uses to emit debugging messages.
Convert the logging uses of D1 & D2 to jffs2_dbg(level, fmt, ...)
to be a bit more consistent style with the rest of the kernel.
All jffs2_dbg output is now at KERN_DEBUG where some of
the previous uses were emitted at various KERN_<LEVEL>s.
after 250df6ed274d767da844a5d9f05720b804240197
(fs: protect inode->i_state with inode->i_lock), insert_inode_locked()
no longer returns the inode with I_NEW set on failure. However,
the error handler still calls unlock_new_inode() on failure,
which does a WARN_ON if I_NEW is not set, so any failure spews
a lot of warnings.
We can just drop the unlock_new_inode() if insert_inode_locked()
fails here.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Currently jffs2 has compile-time constants (and .config options)
controlling whether or not the various compression/decompression
drivers are built in and enabled. This is fine for embedded
systems, but it clashes with distribution kernels. Distro kernels
tend to turn on everything; this causes OpenFirmware to fall
over, as it understands ZLIB-compressed inodes. Booting a kernel
that has LZO compression enabled, writing to the boot partition,
and then rebooting causes OFW to fail to read the kernel from
the filesystem. This is because LZO compression has priority
when writing new data to jffs2, if LZO is enabled.
This patch adds mount option parsing, and a single supported
option ("compr=none"). This adds the flexibility of being
able to specify which compressor overrides on a per-superblock
basis. For now, we can simply disable compression;
additional flexibility coming soon.
v2: kill some printks, and implement show_options as suggested
by Artem Bityutskiy.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
so we can pass &inode->i_mode to it
it's S_ISLNK(mode), TYVM...
casting int * to mode_t * is not a good thing - on a *lot* of big-endian
architectures mode_t happens to be smaller than int and there it breaks
quite spectaculary...
Fucked-up-by: commit cfc8dc6f6f69ede939e09c2af06a01adee577285
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or
anything else, so that the filesystem can track internally if it
needs to push out a transaction for fdatasync or not.
This is just the prototype change with no user for it yet. I plan
to push large XFS changes for the next merge window, and getting
this trivial infrastructure in this window would help a lot to avoid
tree interdependencies.
Also remove incorrect comments that ->dirty_inode can't block. That
has been changed a long time ago, and many implementations rely on it.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git
drivers/mtd/mtd_blkdevs.c
Merge Grant's device-tree bits so that we can apply the subsequent fixes.
When JFFS2 is used for large volumes, the mount times are quite long.
Increasing the hash size provides a significant speed boost on the OLPC
XO-1 laptop.
Add logic that dynamically selects a hash size based on the size of
the medium. A 64mb medium will result in a hash size of 128, and a 512mb
medium will result in a hash size of 1024.
Signed-off-by: Daniel Drake <dsd@laptop.org>
The BKL is only used in put_super, fill_super and remount_fs that are all
three protected by the superblocks s_umount rw_semaphore. Therefore it is
safe to remove the BKL entirely.
* git://git.infradead.org/mtd-2.6: (79 commits)
mtd: Remove obsolete <mtd/compatmac.h> include
mtd: Update copyright notices
jffs2: Update copyright notices
mtd-physmap: add support users can assign the probe type in board files
mtd: remove redwood map driver
mxc_nand: Add v3 (i.MX51) Support
mxc_nand: support 8bit ecc
mxc_nand: fix correct_data function
mxc_nand: add V1_V2 namespace to registers
mxc_nand: factor out a check_int function
mxc_nand: make some internally used functions overwriteable
mxc_nand: rework get_dev_status
mxc_nand: remove 0xe00 offset from registers
mtd: denali: Add multi connected NAND support
mtd: denali: Remove set_ecc_config function
mtd: denali: Remove unuseful code in get_xx_nand_para functions
mtd: denali: Remove device_info_tag structure
mtd: m25p80: add support for the Winbond W25Q32 SPI flash chip
mtd: m25p80: add support for the Intel/Numonyx {16,32,64}0S33B SPI flash chips
mtd: m25p80: add support for the EON EN25P{32, 64} SPI flash chips
Fix up trivial conflicts in drivers/mtd/maps/{Kconfig,redwood.c} due to
redwood driver removal.
Make sure we check the truncate constraints early on in ->setattr by adding
those checks to inode_change_ok. Also clean up and document inode_change_ok
to make this obvious.
As a fallout we don't have to call inode_newsize_ok from simple_setsize and
simplify it down to a truncate_setsize which doesn't return an error. This
simplifies a lot of setattr implementations and means we use truncate_setsize
almost everywhere. Get rid of fat_setsize now that it's trivial and mark
ext2_setsize static to make the calling convention obvious.
Keep the inode_newsize_ok in vmtruncate for now as all callers need an
audit for its removal anyway.
Note: setattr code in ecryptfs doesn't call inode_change_ok at all and
needs a deeper audit, but that is left for later.
* git://git.infradead.org/~dwmw2/mtd-2.6.35:
jffs2: update ctime when changing the file's permission by setfacl
jffs2: Fix NFS race by using insert_inode_locked()
jffs2: Fix in-core inode leaks on error paths
mtd: Fix NAND submenu
mtd/r852: update card detect early.
mtd/r852: Fixes in case of DMA timeout
mtd/r852: register IRQ as last step
drivers/mtd: Use memdup_user
docbook: make mtd nand module init static
New inodes need to be locked as we're creating them, so they don't get used
by other things (like NFSd) before they're ready.
Pointed out by Al Viro.
Lots of filesystems calls vmtruncate despite not implementing the old
->truncate method. Switch them to use simple_setsize and add some
comments about the truncate code where it seems fitting.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14995
Reported-by: R. Diez <rdiezmail-kernelbugzilla@yahoo.de>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
[xfs, btrfs, capifs, shmem don't need BKL, exempt]
Signed-off-by: Alessio Igor Bogani <abogani@texware.it>
jffs2_write_super is only called from super.c and doesn't use any
functionality from fs.c. So move it over to super.c and make it
static there.
[should go in through the vfs tree as it is a requirement for the
next patch]
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
To support NFS export, we need to know the parent inode of directories.
Rather than growing the jffs2_inode_cache structure, share space with
the nlink field -- which was always set to 1 for directories anyway.
We don't actually care about nlink; we only care whether the inode in
question is unlinked or not.
This is going to obsolete all previous nodes, so treat it as deletion.
Addresses OLPC trac #6480
* git://git.infradead.org/mtd-2.6: (120 commits)
[MTD] Fix mtdoops.c compilation
[MTD] [NOR] fix startup lock when using multiple nor flash chips
[MTD] [DOC200x] eccbuf is statically defined and always evaluate to true
[MTD] Fix maps/physmap.c compilation with CONFIG_PM
[MTD] onenand: Add panic_write function to the onenand driver
[MTD] mtdoops: Use the panic_write function when present
[MTD] Add mtd panic_write function pointer
[MTD] [NAND] Freescale enhanced Local Bus Controller FCM NAND support.
[MTD] physmap.c: Add support for multiple resources
[MTD] [NAND] Fix misparenthesization introduced by commit 78b65179...
[MTD] [NAND] Fix Blackfin NFC ECC calculating bug with page size 512 bytes
[MTD] [NAND] Remove wrong operation in PM function of the BF54x NFC driver
[MTD] [NAND] Remove unused variable in plat_nand_remove
[MTD] Unlocking all Intel flash that is locked on power up.
[MTD] [NAND] at91_nand: Make mtdparts option can override board info
[MTD] mtdoops: Various minor cleanups
[MTD] mtdoops: Ensure sequential write to the buffer
[MTD] mtdoops: Perform write operations in a workqueue
[MTD] mtdoops: Add further error return code checking
[MTD] [NOR] Test devtype, not definition in flash_probe(), drivers/mtd/devices/lart.c
Stop the JFFS2 filesystem from using iget() and read_inode(). Replace
jffs2_read_inode() with jffs2_iget(), and call that instead of iget().
jffs2_iget() then uses iget_locked() directly and returns a proper error code
instead of an inode in the event of an error.
jffs2_do_fill_super() returns any error incurred when getting the root inode
instead of EINVAL.
Acked-by: Christoph Hellwig <hch@lst.de>
<viro> dwmw2: anyway, removing sgid from directories or from
files without S_IXGRP is a plain and simple bug
<viro> these days you don't need that logics at all - simply remove it
[In commit 9ed437c50d89eabae763dd422579f73fdebf288d we fixed a problem
with standard permissions on newly-created inodes, when POSIX ACLs are
enabled. This cleans it up...]
The attached patch separate jffs2_init_acl() into two parts.
The one is jffs2_init_acl_pre() called from jffs2_new_inode().
It compute ACL oriented inode->i_mode bits, and allocate in-memory ACL
objects associated with the new inode just before when inode meta
infomation is written to the medium.
The other is jffs2_init_acl_post() called from jffs2_symlink(),
jffs2_mkdir(), jffs2_mknod() and jffs2_do_create().
It actually writes in-memory ACL objects into the medium next to
the success of writing meta-information.
In the current implementation, we have to write a same inode meta
infomation twice when inode->i_mode is updated by the default ACL.
However, we can avoid the behavior by putting an updated i_mode
before it is written at first, as jffs2_init_acl_pre() doing.
Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
I've bisected the deadlock when many small appends are done on jffs2 down to
this commit:
commit 6fe6900e1e5b6fa9e5c59aa5061f244fe3f467e2
Author: Nick Piggin <npiggin@suse.de>
Date: Sun May 6 14:49:04 2007 -0700
mm: make read_cache_page synchronous
Ensure pages are uptodate after returning from read_cache_page, which allows
us to cut out most of the filesystem-internal PageUptodate calls.
I didn't have a great look down the call chains, but this appears to fixes 7
possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in
ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in
block2mtd. All depending on whether the filler is async and/or can return
with a !uptodate page.
It introduced a wait to read_cache_page, as well as a
read_cache_page_async function equivalent to the old read_cache_page
without any callers.
Switching jffs2_gc_fetch_page to read_cache_page_async for the old
behavior makes the deadlocks go away, but maybe reintroduces the
use-before-uptodate problem? I don't understand the mm/fs interaction
well enough to say.
[It's fine. dwmw2.]
Signed-off-by: Jason Lunz <lunz@falooley.org>
When POSIX ACL support was enabled, we weren't writing correct
legacy modes to the medium on inode creation, or when the ACL was set.
This meant that the permissions would be incorrect after the file system
was remounted.
drivers/mtd/Kconfig
