path: root/fs/jffs2/nodemgmt.c
2008-05-01[JFFS2] Track parent inode for directories (for NFS export)David Woodhouse
To support NFS export, we need to know the parent inode of directories. Rather than growing the jffs2_inode_cache structure, share space with the nlink field -- which was always set to 1 for directories anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-23[JFFS2] Fix jffs2_reserve_space() when all blocks are pending erasure.David Woodhouse
When _all_ the blocks were on the erase_pending_list, we could't find a block to GC from but there was no _actually_ free space, and jffs2_reserve_space() would get a little unhappy. Handle this case by returning -EAGAIN from jffs2_garbage_collect_pass(). There are two callers of that function -- jffs2_flush_wbuf_gc(), which will interpret it as an error and flush the writebuffer by other means, and jffs2_reserve_space(), which we modify to respond to -EAGAIN with an immediate call to jffs2_erase_pending_blocks() and another run round the loop. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-04-22[JFFS2] semaphore->mutex conversionDavid Woodhouse
2008-04-22[JFFS2] Fix sparse warning in nodemgmt.cDavid Woodhouse
fs/jffs2/nodemgmt.c:60:8: warning: symbol 'ret' shadows an earlier one fs/jffs2/nodemgmt.c:45:6: originally declared here (reported by Harvey Harrison) Just remove the offending declaration of 'int ret' and use the earlier one. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-13[JFFS2] Don't count all 'very dirty' blocks except in debug modeDavid Woodhouse
... where we'll actually print the count in a debug message. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-10-06[JFFS2] Trigger garbage collection when very_dirty_list size becomes excessiveDavid Woodhouse
With huge amounts of free space, we weren't bothering to GC for while a while, and pathological numbers of obsolete nodes were accumulating, seriously affecting performance on NAND flash (OLPC trac #3978) Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-10[JFFS2] Whitespace cleanups.David Woodhouse
Convert many spaces to tabs; one or two other minor cosmetic fixes. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-06-28[JFFS2] Improve diagnostic output for 'node added in wrong place' checkDavid Woodhouse
Jocke has seen this fail. We want to know why. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-04-25[JFFS2] Tidy up licensing/copyright boilerplate.David Woodhouse
In particular, remove the bit in the LICENCE file about contacting Red Hat for alternative arrangements. Their errant IS department broke that arrangement a long time ago -- the policy of collecting copyright assignments from contributors came to an end when the plug was pulled on the servers hosting the project, without notice or reason. We do still dual-license it for use with eCos, with the GPL+exception licence approved by the FSF as being GPL-compatible. It's just that nobody has the right to license it differently. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-04-17[JFFS2] Prevent list corruption when handling write errorsAdrian Hunter
If a write error occurs, the affected block is placed on the bad_used_list. In the case that the write error occured when writing summary data the block was also being placed on the dirty_list, which caused list corruption and ultimately a soft lockup in jffs2_mark_node_obsolete. This fixes that. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [MTD] NAND: Select chip before checking write protect status [MTD] CORE mtdchar.c: fix off-by-one error in lseek() [MTD] NAND: Fix typo in mtd/nand/ts7250.c [JFFS2][XATTR] coexistence between xattr and write buffering support. [JFFS2][XATTR] Fix wrong copyright [JFFS2][XATTR] Re-define xd->refcnt as atomic_t [JFFS2][XATTR] Fix memory leak with jffs2_xattr_ref [JFFS2][XATTR] rid unnecessary writing of delete marker. [JFFS2][XATTR] Fix ACL bug when updating null xattr by null ACL. [JFFS2][XATTR] using 'delete marker' for xdatum/xref deletion [MTD] Fix off-by-one error in physmap.c [MTD] Remove unused 'nr_banks' variable from ixp2000 map driver [MTD NAND] s3c2412 support in s3c2410.c [MTD] Initialize 'writesize' [MTD] NAND: ndfc fix address offset thinko [MTD] NAND: S3C2410 convert prinks to dev_*()s [MTD] NAND: Missing fixups
2006-06-27[JFFS2][XATTR] using 'delete marker' for xdatum/xref deletionKaiGai Kohei
- When xdatum is removed, a new xdatum with 'delete marker' is written. (version==0xffffffff means 'delete marker') - When xref is removed, a new xref with 'delete marker' is written. (odd-numbered xseqno means 'delete marker') - delete_xattr_(datum/xref)_delay() are new deletion functions are added. We can only use them if we can detect the target obsolete xdatum/xref as a orphan or errir one. (e.g when inode deletion, or detecting crc error) [1/3] jffs2-xattr-v6-01-delete_marker.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-26[PATCH] fs: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B) under fs/. Cc: Ian Kent <raven@themaw.net> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Hans Reiser <reiserfs-dev@namesys.com> Cc: Urban Widmark <urban@teststation.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-18[JFFS2] When retiring nextblock, allocate a node_ref for the wasted spaceDavid Woodhouse
Failing to do so makes the calculated length of the last node incorrect, when we're not using eraseblock summaries. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-26[JFFS2] Switch to using an array of jffs2_raw_node_refs instead of a list.David Woodhouse
This allows us to drop another pointer from the struct jffs2_raw_node_ref, shrinking it to 8 bytes on 32-bit machines (if the TEST_TOTLEN) paranoia check is turned off, which will be committed soon). Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[JFFS2] Add 'jeb' argument to jffs2_prealloc_raw_node_refs()David Woodhouse
Preallocation of refs is shortly going to be a per-eraseblock thing, rather than per-filesystem. Add the required argument to the function. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-25[JFFS2] jffs2_free_all_node_refs() doesn't free them all. Rename it.David Woodhouse
... to jffs2_free_jeb_node_refs() since that's what it does. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24[JFFS2] Revert Artem's Bunkage in debug messages.David Woodhouse
Random unthinking 'cleanup' caused debug messages like this: Obsoleting node at 0x0006daf4 of len 0x3a4: <7>Dirtying If messages are continuation of an existing line, they don't need to be prefixed with KERN_DEBUG. THINK. Or you will be replaced by a small shell script. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24[JFFS2] Introduce ref_next() macro for finding next physical nodeDavid Woodhouse
Another part of the preparation for switching to an array... Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-24[JFFS2] Reduce visibility of raw_node_ref to upper layers of JFFS2 code.David Woodhouse
As the first step towards eliminating the ref->next_phys member and saving memory by using an _array_ of struct jffs2_raw_node_ref per eraseblock, stop the write functions from allocating their own refs; have them just _reserve_ the appropriate number instead. Then jffs2_link_node_ref() can just fill them in. Use a linked list of pre-allocated refs in the superblock, for now. Once we switch to an array, it'll just be a case of extending that array. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-23[JFFS2] Remove flash offset argument from various functions.David Woodhouse
We don't need the upper layers to deal with the physical offset. It's _always_ c->nextblock->offset + c->sector_size - c->nextblock->free_size so we might as well just let the actual write functions deal with that. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-22[JFFS2] Add some preemptive BUG checks for XATTR codeDavid Woodhouse
In a couple of places, we assume that what's at the end of the ->next_in_ino list is a struct jffs2_inode_cache. Let's check for that, since we expect it to change soon. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-22[JFFS2] Extend jffs2_link_node_ref() to link into per-inode list too.David Woodhouse
Let's avoid the potential for forgetting to set ref->next_in_ino, by doing it within jffs2_link_node_ref() instead. This highlights the ugliness of what we're currently doing with xattr_datum and xattr_ref structures -- we should find a nicer way of dealing with that. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-21[JFFS2] Finally eliminate __totlen field from struct jffs2_raw_node_refDavid Woodhouse
Well, almost. We'll actually keep a 'TEST_TOTLEN' macro set for now, and keep doing some paranoia checks to make sure it's all working correctly. But if TEST_TOTLEN is unset, the size of struct jffs2_raw_node_ref drops from 16 bytes to 12 on 32-bit machines. That's a saving of about half a megabyte of memory on the OLPC prototype board, with 125K or so nodes in its 512MiB of flash. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-21[JFFS2] Add length argument to jffs2_add_physical_node_ref()David Woodhouse
If __totlen is going away, we need to pass the length in separately. Also stop callers from needlessly setting ref->next_phys to NULL, since that's done for them... and since that'll also be going away soon. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-20[JFFS2] Introduce jffs2_link_node_ref() function to reduce code duplicationDavid Woodhouse
The same sequence of code was repeated in many places, to add a new struct jffs2_raw_node_ref to an eraseblock and adjust the space accounting accordingly. Move it out-of-line. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-20[JFFS2] Reduce calls to ref_totlen() in jffs2_mark_node_obsolete()David Woodhouse
We were calling ref_totlen() 18 times. Even before that becomes a real function rather than just a dereference, apparently some compilers still suck anyway. It'll _certainly_ suck after ref_totlen() becomes more complicated, so calculate it once and don't rely on CSE. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-11-07[JFFS2] Clean up trailing white spacesThomas Gleixner
2005-11-06[JFFS2] Debug code simplification, update TODOArtem B. Bityutskiy
Simplify the debugging code further. Update the TODO list Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Account summary space in reserved_size.Ferenc Havasi
Always keep valid data in reserved_size. It did not cause problems, but the reservation code was unoptimal when centralized summary was active or the size of the erase block was very small. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Add erase block summary support (mount time improvement)Ferenc Havasi
The goal of summary is to speed up the mount time. Erase block summary (EBS) stores summary information at the end of every (closed) erase block. It is no longer necessary to scan all nodes separetly (and read all pages of them) just read this "small" summary, where every information is stored which is needed at mount time. This summary information is stored in a JFFS2_FEATURE_RWCOMPAT_DELETE. During the mount process if there is no summary info the orignal scan process will be executed. EBS works with NAND and NOR flashes, too. There is a user space tool called sumtool to generate this summary information for a JFFS2 image. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 3Artem B. Bityutskiy
Various simplifiactions. printk format corrections. Convert more code to use the new debug functions. Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Debug code clean up - step 1Artem B. Bityutskiy
Move debug functions into a seperate source file Signed-off-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Suppress annoying debug messagesArtem B. Bityuckiy
Embrace uneeded messages in D1(). Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Add KERN_DEBUG level to printksArtem B. Bityuckiy
2005-05-23[JFFS2] Forbid to free inode_cache objects if its nlink isn't zero.Artem B. Bityuckiy
2005-05-23[JFFS2] Fix NOR specific scan BUG Artem B. Bityuckiy
Fix fairly sad NOR-specific bug - during FS building ic->scan_dents isn't zero, but jffs2_mark_node_obsolete() migt be called it tries to finde the ic corresponding to ref - this requires ic->scan_dents = 0. Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Prevent ino cache removal for inodes in useDavid Woodhouse
Don't remove inocache for inodes which are in read_inode() or clear_inode() until they're done. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Code cleanup Estelle Hammache
Code beautification and block filing correction for optimization. Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Fix refile of blocks due to write failure. Estelle Hammache
avoid segfault when nextblock was refiled because of a write failure - avoid filing blocks on the clean list when they have wasted space Signed-off-by: Estelle Hammache <estelle.hammache@st.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
