path: root/fs/jffs2/super.c
2006-05-19Merge git://git.infradead.org/mtd-2.6KaiGai Kohei
2006-05-15[JFFS2] Don't pack on-medium structures, because GCC emits crappy codeDavid Woodhouse
If we use __attribute__((packed)), GCC will _also_ assume that the structures aren't sensibly aligned, and it'll emit code to cope with that instead of straight word load/save. This can be _very_ suboptimal on architectures like ARM. Ideally, we want an attribute which just tells GCC not to do any padding, without the alignment side-effects. In the absense of that, we'll just drop the 'packed' attribute and hope that everything stays as it was (which to be fair is fairly much what we expect). And add some paranoia checks in the initialisation code, which should be optimised away completely in the normal case. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-13[JFFS2][XATTR] XATTR support on JFFS2 (version. 5)KaiGai Kohei
This attached patches provide xattr support including POSIX-ACL and SELinux support on JFFS2 (version.5). There are some significant differences from previous version posted at last December. The biggest change is addition of EBS(Erase Block Summary) support. Currently, both kernel and usermode utility (sumtool) can recognize xattr nodes which have JFFS2_NODETYPE_XATTR/_XREF nodetype. In addition, some bugs are fixed. - A potential race condition was fixed. - Unexpected fail when updating a xattr by same name/value pair was fixed. - A bug when removing xattr name/value pair was fixed. The fundamental structures (such as using two new nodetypes and exclusion mechanism by rwsem) are unchanged. But most of implementation were reviewed and updated if necessary. Espacially, we had to change several internal implementations related to load_xattr_datum() to avoid a potential race condition. [1/2] xattr_on_jffs2.kernel.version-5.patch [2/2] xattr_on_jffs2.utils.version-5.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] vfs: MS_VERBOSE should be MS_SILENTTheodore Ts'o
The meaning of MS_VERBOSE is backwards; if the bit is set, it really means, "don't be verbose". This is confusing and counter-intuitive. In addition, there is also no way to set the MS_VERBOSE flag in the mount(8) program in util-linux, but interesting, it does define options which would do the right thing if MS_SILENT were defined, which unfortunately we do not: #ifdef MS_SILENT { "quiet", 0, 0, MS_SILENT }, /* be quiet */ { "loud", 0, 1, MS_SILENT }, /* print out messages. */ #endif So the obvious fix is to deprecate the use of MS_VERBOSE and replace it with MS_SILENT. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[JFFS2] Fix the slab cache constructor of 'struct jffs2_inode_info' objects.Thomas Gleixner
JFFS2 initialize f->sem mutex as "locked" in the slab constructor which is a bug. Objects are freed with unlocked f->sem mutex. So, when they allocated again, f->sem is unlocked because the slab cache constructor is not called for them. The constructor is called only once when memory pages are allocated for objects (namely, when the slab layer allocates new slabs). So, sometimes 'struct jffs2_inode_info' are allocated with unlocked f->sem, sometimes with locked. This is a bug. Instead, initialize f->sem as unlocked in the constructor. I.e., in the "constructed" state f->sem must be unlocked. From: Keijiro Yano <keijiro_yano@yahoo.co.jp> Acked-by: Artem B. Bityutskiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-07[JFFS2] Clean up trailing white spacesThomas Gleixner
2005-11-06[JFFS2] Add erase block summary support (mount time improvement)Ferenc Havasi
The goal of summary is to speed up the mount time. Erase block summary (EBS) stores summary information at the end of every (closed) erase block. It is no longer necessary to scan all nodes separetly (and read all pages of them) just read this "small" summary, where every information is stored which is needed at mount time. This summary information is stored in a JFFS2_FEATURE_RWCOMPAT_DELETE. During the mount process if there is no summary info the orignal scan process will be executed. EBS works with NAND and NOR flashes, too. There is a user space tool called sumtool to generate this summary information for a JFFS2 image. Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-11-06[JFFS2] Remove support for virtual blocksFerenc Havasi
Remove support for virtual blocks, which are build by concatenation of multiple physical erase blocks. For more information please read the MTD mailing list thread "[PATCH] remove support for virtual blocks" Signed-off-by: Ferenc Havasi <havasi@inf.u-szeged.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-07-13[JFFS2] Init locks early during mountArtem B. Bityuckiy
In case of a mount error locks might be uninitialized but accessed by the resulting call to jffs2_kill_sb(). Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Kill GC thread before cleanupArtem B. Bityuckiy
First kill GC thread, then start clearing the internal structures Signed-off-by: Artem B. Bityuckiy <dedekind@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2005-05-23[JFFS2] Use a single config option for write buffer supportAndrew Victor
This patch replaces the current CONFIG_JFFS2_FS_NAND, CONFIG_JFFS2_FS_NOR_ECC and CONFIG_JFFS2_FS_DATAFLASH with a single configuration option - CONFIG_JFFS2_FS_WRITEBUFFER. The only functional change of this patch is that the slower div/mod calculations for SECTOR_ADDR(), PAGE_DIV() and PAGE_MOD() are now always used when CONFIG_JFFS2_FS_WRITEBUFFER is enabled. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
