that's the bulk of filesystem drivers dealing with inodes of their own
Add a flags argument to struct xattr_handler and pass it to all xattr
handler methods. This allows using the same methods for multiple
handlers, e.g. for the ACL methods which perform exactly the same action
for the access and default ACLs, just using a different underlying
attribute. With a little more groundwork it'll also allow sharing the
methods for the regular user/trusted/secure handlers in extN, ocfs2 and
jffs2 like it's already done for xfs in this patch.
Also change the inode argument to the handlers to a dentry to allow
using the handlers mechnism for filesystems that require it later,
e.g. cifs.
[with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>]
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Joel Becker <joel.becker@oracle.com>
Convert many spaces to tabs; one or two other minor cosmetic fixes.
In particular, remove the bit in the LICENCE file about contacting
Red Hat for alternative arrangements. Their errant IS department broke
that arrangement a long time ago -- the policy of collecting copyright
assignments from contributors came to an end when the plug was pulled on
the servers hosting the project, without notice or reason.
We do still dual-license it for use with eCos, with the GPL+exception
licence approved by the FSF as being GPL-compatible. It's just that nobody
has the right to license it differently.
Unify each file header part with any jffs2 file.
[7/10] jffs2-xattr-v5.1-07-unify_file_header.patch
Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
This attached patches provide xattr support including POSIX-ACL and
SELinux support on JFFS2 (version.5).
There are some significant differences from previous version posted
at last December.
The biggest change is addition of EBS(Erase Block Summary) support.
Currently, both kernel and usermode utility (sumtool) can recognize
xattr nodes which have JFFS2_NODETYPE_XATTR/_XREF nodetype.
In addition, some bugs are fixed.
- A potential race condition was fixed.
- Unexpected fail when updating a xattr by same name/value pair was fixed.
- A bug when removing xattr name/value pair was fixed.
The fundamental structures (such as using two new nodetypes and exclusion
mechanism by rwsem) are unchanged. But most of implementation were reviewed
and updated if necessary.
Espacially, we had to change several internal implementations related to
load_xattr_datum() to avoid a potential race condition.
[1/2] xattr_on_jffs2.kernel.version-5.patch
[2/2] xattr_on_jffs2.utils.version-5.patch
