Even though we don't use the OOB for MLC nand flash,
we should use the bad block information to skip the bad block.
Patch url:
http://patchwork.ozlabs.org/linux-mtd/patch?q=mlc&filter=none&id=15477
Author:Kyungmin Park
Signed-off-by: Jason Liu <r64343@freescale.com>
JFFS2 community fix with not use OOB at MLC NAND, this patch
is coming from the MTD community
The function jffs2_nor_wbuf_flash_setup() doesn't allocate the verify buffer
if CONFIG_JFFS2_FS_WBUF_VERIFY is defined, so causing a kernel panic when
that macro is enabled and the verify function is called. Similarly the
jffs2_nor_wbuf_flash_cleanup() must free the buffer if
CONFIG_JFFS2_FS_WBUF_VERIFY is enabled.
The following patch fixes the problem.
The following patch applies to 2.6.30 kernel.
Signed-off-by: Massimo Cirillo <maxcir@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Cc: stable@kernel.org
This fixes "kernel BUG at fs/jffs2/file.c:251!".
This pseudocode hopefully illustrates the scenario that triggers it:
jffs2_write_begin {
jffs2_do_readpage_nolock {
jffs2_read_inode_range {
jffs2_read_dnode {
Data CRC 33c102e9 != calculated CRC 0ef77e7b for node at 005d42e4
return -EIO;
ClearPageUptodate(pg);
return 0;
jffs2_write_end {
BUG_ON(!PageUptodate(pg));
Signed-off-by: Anders Grafström <grfstrm@users.sourceforge.net>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
* git://git.infradead.org/mtd-2.6:
mtd: nand: fix build failure and incorrect return from omap_wait()
mtd: Use BLOCK_NIL consistently in NFTL/INFTL
mtd: m25p80 timeout too short for worst-case m25p16 devices
mtd: atmel_nand: Fix typo s/parititions/partitions/
mtd: cmdlineparts: Use 64-bit format when printing a debug message.
mtd: maps: Remove BUS_ID_SIZE from integrator_flash
jffs2: fix another potential leak on error path in scan.c
helpers: get_cached_acl(inode, type), set_cached_acl(inode, type, acl),
forget_cached_acl(inode, type).
ubifs/xattr.c needed includes reordered, the rest is a plain switchover.
* git://git.infradead.org/mtd-2.6: (63 commits)
mtd: OneNAND: Allow setting of boundary information when built as module
jffs2: leaking jffs2_summary in function jffs2_scan_medium
mtd: nand: Fix memory leak on txx9ndfmc probe failure.
mtd: orion_nand: use burst reads with double word accesses
mtd/nand: s3c6400 support for s3c2410 driver
[MTD] [NAND] S3C2410: Use DIV_ROUND_UP
[MTD] [NAND] S3C2410: Deal with unaligned lengths in S3C2440 buffer read/write
[MTD] [NAND] S3C2410: Allow the machine code to get the BBT table from NAND
[MTD] [NAND] S3C2410: Added a kerneldoc for s3c2410_nand_set
mtd: physmap_of: Add multiple regions and concatenation support
mtd: nand: max_retries off by one in mxc_nand
mtd: nand: s3c2410_nand_setrate(): use correct macros for 2412/2440
mtd: onenand: add bbt_wait & unlock_all as replaceable for some platform
mtd: Flex-OneNAND support
mtd: nand: add OMAP2/OMAP3 NAND driver
mtd: maps: Blackfin async: fix memory leaks in probe/remove funcs
mtd: uclinux: mark local stuff static
mtd: uclinux: do not allow to be built as a module
mtd: uclinux: allow systems to override map addr/size
mtd: blackfin NFC: fix hang when using NAND on BF527-EZKITs
In case of an error returned by file_dirty() 's' is not freed as the cleanup
path is skipped.
Reported by Coverity.
Signed-off-by: Christian Engelmayer <christian.engelmayer@frequentis.com>
The call to ->write_super from __sync_filesystem will go away, so make
sure jffs2 performs the same actions from inside ->sync_fs.
[xfs, btrfs, capifs, shmem don't need BKL, exempt]
Signed-off-by: Alessio Igor Bogani <abogani@texware.it>
Push down lock_super into ->write_super instances and remove it from the
caller.
Following filesystem don't need ->s_lock in ->write_super and are skipped:
* bfs, nilfs2 - no other uses of s_lock and have internal locks in
->write_super
* ext2 - uses BKL in ext2_write_super and has internal calls without s_lock
* reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in
->write_super
* xfs - no other uses of s_lock and uses internal lock (buffer lock on
superblock buffer) to serialize ->write_super. Also xfs_fs_write_super
is superflous and will go away in the next merge window
jffs2_write_super is only called from super.c and doesn't use any
functionality from fs.c. So move it over to super.c and make it
static there.
[should go in through the vfs tree as it is a requirement for the
next patch]
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
We just did a full fs writeout using sync_filesystem before, and if
that's not enough for the filesystem it can perform it's own writeout
in ->put_super, which many filesystems already do.
Move a call to foofs_write_super into every foofs_put_super for now to
guarantee identical behaviour until it's cleaned up by the individual
filesystem maintainers.
Exceptions:
- affs already has identical copy & pasted code at the beginning of
affs_put_super so no need to do it twice.
- xfs does the right thing without it and I have changes pending for
the xfs tree touching this are so I don't really need conflicts
here..
Erase errors such as:
"Newly-erased block contained word 0xa4ef223e at offset 0x0296a014"
and failure to write the clean marker,
moves the offending erase block to erasing list before calling
jffs2_erase_failed(). This is bad as jffs2_erase_failed() will
also move the block to the bad_list, but is now moving the
wrong block, causing FS corruption.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
* git://git.infradead.org/mtd-2.6: (53 commits)
[MTD] struct device - replace bus_id with dev_name(), dev_set_name()
[MTD] [NOR] Fixup for Numonyx M29W128 chips
[MTD] mtdpart: Make ecc_stats more realistic.
powerpc/85xx: TQM8548: Update DTS file for multi-chip support
powerpc: NAND: FSL UPM: document new bindings
[MTD] [NAND] FSL-UPM: Add wait flags to support board/chip specific delays
[MTD] [NAND] FSL-UPM: add multi chip support
[MTD] [NOR] Add device parent info to physmap_of
[MTD] [NAND] Add support for NAND on the Socrates board
[MTD] [NAND] Add support for 4KiB pages.
[MTD] sysfs support should not depend on CONFIG_PROC_FS
[MTD] [NAND] Add parent info for CAFÉ controller
[MTD] support driver model updates
[MTD] driver model updates (part 2)
[MTD] [NAND] move gen_nand's probe function to .devinit.text
[MTD] [MAPS] move sa1100 flash's probe function to .devinit.text
[MTD] fix use after free in register_mtd_blktrans
[MTD] [MAPS] Drop now unused sharpsl-flash map
[MTD] ofpart: Check name property to determine partition nodes.
Manually fix trivial conflict in drivers/mtd/maps/Makefile
current->fs->umask is what most of fs_struct users are doing.
Put that into a helper function.
size_t s is unsigned and cannot be less than 0.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Used kmem_cache_zalloc instead of kmem_cache_alloc/memset.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
At scan time we observed following scenario:
node A inserted
node B inserted
node C inserted -> sets overlapped flag on node B
node A is removed due to CRC failure -> overlapped flag on node B remains
while (tn->overlapped)
tn = tn_prev(tn);
==> crash, when tn_prev(B) is referenced.
When the ultimate node is removed at scan time and the overlapped flag
is set on the penultimate node, then nothing updates the overlapped
flag of that node. The overlapped iterators blindly expect that the
ultimate node does not have the overlapped flag set, which causes the
scan code to crash.
It would be a huge overhead to go through the node chain on node
removal and fix up the overlapped flags, so detecting such a case on
the fly in the overlapped iterators is a simpler and reliable
solution.
I've noticed some pretty poor behavior on OLPC machines after bootup, when
gdm/X are starting. The GCD monopolizes the scheduler (which in turns
means it gets to do more nand i/o), which results in processes taking much
much longer than they should to start.
As an example, on an OLPC machine going from OFW to a usable X (via
auto-login gdm) takes 2m 30s. The majority of this time is consumed by
the switch into graphical mode. With this patch, we cut a full 60s off of
bootup time. After bootup, things are much snappier as well.
Note that we have seen a CRC node error with this patch that causes the machine
to fail to boot, but we've also seen that problem without this patch.
Signed-off-by: Andres Salomon <dilinger@debian.org>
'rb_prev()', 'rb_next()' and 'rb_replace_node()' are declared in
include/linux/rbtree.h, no need for JFFS2 to re-declare them. I
believe these are left-overs from the old days when the common
RB tree code did not have those call and JFFS2 had private
implementation.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/arm/mach-pxa/corgi.c
arch/arm/mach-pxa/poodle.c
arch/arm/mach-pxa/spitz.c
With the write_begin/write_end aops, page_symlink was broken because it
could no longer pass a GFP_NOFS type mask into the point where the
allocations happened. They are done in write_begin, which would always
assume that the filesystem can be entered from reclaim. This bug could
cause filesystem deadlocks.
The funny thing with having a gfp_t mask there is that it doesn't really
allow the caller to arbitrarily tinker with the context in which it can be
called. It couldn't ever be GFP_ATOMIC, for example, because it needs to
take the page lock. The only thing any callers care about is __GFP_FS
anyway, so turn that into a single flag.
Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on
this flag in their write_begin function. Change __grab_cache_page to
accept a nofs argument as well, to honour that flag (while we're there,
change the name to grab_cache_page_write_begin which is more instructive
and does away with random leading underscores).
This is really a more flexible way to go in the end anyway -- if a
filesystem happens to want any extra allocations aside from the pagecache
ones in ints write_begin function, it may now use GFP_KERNEL (rather than
GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a
random example).
[kosaki.motohiro@jp.fujitsu.com: fix ubifs]
[kosaki.motohiro@jp.fujitsu.com: fix fuse]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@kernel.org> [2.6.28.x]
[ Cleaned up the calling convention: just pass in the AOP flags
untouched to the grab_cache_page_write_begin() function. That
just simplifies everybody, and may even allow future expansion of the
logic. - Linus ]
Triggered by a smaller cleanup from Jianjun Kong <jianjun@zeuux.org>
MTD internal API presently uses 32-bit values to represent
device size. This patch updates them to 64-bits but leaves
the external API unchanged. Extending the external API
is a separate issue for several reasons. First, no one
needs it at the moment. Secondly, whether the implementation
is done with IOCTLs, sysfs or both is still debated. Thirdly
external API changes require the internal API to be accepted
first.
Note that although the MTD API will be able to support 64-bit
device sizes, existing drivers do not and are not required
to do so, although NAND base has been updated.
In general, changing from 32-bit to 64-bit values cause little
or no changes to the majority of the code with the following
exceptions:
- printk message formats
- division and modulus of 64-bit values
- NAND base support
- 32-bit local variables used by mtdpart and mtdconcat
- naughtily assuming one structure maps to another
in MEMERASE ioctl
Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
[JFFS2] fix race condition in jffs2_lzo_compress()
[MTD] [NOR] Fix cfi_send_gen_cmd handling of x16 devices in x8 mode (v4)
[JFFS2] Fix lack of locking in thread_should_wake()
[JFFS2] Fix build failure with !CONFIG_JFFS2_FS_WRITEBUFFER
[MTD] [NAND] OMAP2: remove duplicated #include
deflate_mutex protects the globals lzo_mem and lzo_compress_buf. However,
jffs2_lzo_compress() unlocks deflate_mutex _before_ it has copied out the
compressed data from lzo_compress_buf. Correct this by moving the mutex
unlock after the copy.
In addition, document what deflate_mutex actually protects.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Acked-by: Richard Purdie <rpurdie@openedhand.com>
The thread_should_wake() function trawls through the list of 'very
dirty' eraseblocks, determining whether the background GC thread should
wake. Doing this without holding the appropriate locks is a bad idea.
OLPC Trac #8615
With this patch all directory fops instances that have a readdir
that doesn't take the BKL are switched to generic_file_llseek.
Now that JFFS2 can be exported by NFS, we need to get this right.
Now that the readdir/lookup deadlock issues have been dealt with, we can
export JFFS2 file systems again.
(For now, you have to specify fsid manually; we should add a method to
the export_ops to handle that too.)
Build failure introduced by 5bf1723723487ddb0b9c9641b6559da96b27cc93
[JFFS2] Write buffer offset adjustment for NOR-ECC (Sibley) flash
Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com>
After choosing new c->nextblock, don't leave the wbuf offset field
occasionally pointing at the start of the next physical eraseblock.
This was causing a BUG() on NOR-ECC (Sibley) flash, where we start
writing after the cleanmarker.
Among other this fix should cover write buffer offset adjustment
after flushing the last page of an eraseblock.
Signed-off-by: Alexander Belyakov <abelyako@googlemail.com>
Make the parameter names of jffs2_compress() in its comments match with the
actual implementation
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
We can't use vmalloc for the buffer we use for writing summaries,
because some drivers may want to DMA from it. So limit the size to 64KiB
and use kmalloc for it instead.
* git://git.infradead.org/mtd-2.6: (57 commits)
[MTD] [NAND] subpage read feature as a way to increase performance.
CPUFREQ: S3C24XX NAND driver frequency scaling support.
[MTD][NAND] au1550nd: remove unused variable
[MTD] jedec_probe: Fix SST 16-bit chip detection
[MTD][MTDPART] Fix a division by zero bug
[MTD][MTDPART] Cleanup and document the erase region handling
[MTD][MTDPART] Handle most checkpatch findings
[MTD][MTDPART] Seperate main loop from per-partition code in add_mtd_partition
[MTD] physmap: resume already suspended chips on failure to suspend
[MTD] physmap: Fix suspend/resume/shutdown bugs.
[MTD] [NOR] Fix -ETIMEO errors in CFI driver
[MTD] [NAND] fsl_elbc_nand: fix section mismatch with CONFIG_MTD_OF_PARTS=y
[JFFS2] Use .unlocked_ioctl
[MTD] Fix const assignment in the MTD command line partitioning driver
[MTD] [NOR] gen_probe: No debug message when debugging is disabled
[MTD] [NAND] remove __PPC__ hardcoded address from DiskOnChip drivers
[MTD] [MAPS] Remove the bast-flash driver.
[MTD] [NAND] fsl_elbc_nand: ecclayout cleanups
[MTD] [NAND] fsl_elbc_nand: implement support for flash-based BBT
[MTD] [NAND] fsl_elbc_nand: fix OOB workability for large page NAND chips
* kill nameidata * argument; map the 3 bits in ->flags anybody cares
about to new MAY_... ones and pass with the mask.
* kill redundant gfs2_iop_permission()
* sanitize ecryptfs_permission()
* fix remaining places where ->permission() instances might barf on new
MAY_... found in mask.
The obvious next target in that direction is permission(9)
folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz>
