[ Upstream commit 2cc7cc01c15f57d056318c33705647f87dcd4aab ]
Syzbot reported divide error in dbNextAG(). The problem was in missing
validation check for malicious image.
Syzbot crafted an image with bmp->db_numag equal to 0. There wasn't any
validation checks, but dbNextAG() blindly use bmp->db_numag in divide
expression
Fix it by validating bmp->db_numag in dbMount() and return an error if
image is malicious
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-and-tested-by: syzbot+46f5c25af73eb8330eb6@syzkaller.appspotmail.com
Signed-off-by: Pavel Skripkin <paskripkin@gmail.com>
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
[ Upstream commit 4208c398aae4c2290864ba15c3dab7111f32bec1 ]
The left shift of int 32 bit integer constant 1 is evaluated using 32 bit
arithmetic and then assigned to a signed 64 bit integer. In the case where
l2nb is 32 or more this can lead to an overflow. Avoid this by shifting
the value 1LL instead.
Addresses-Coverity: ("Uninitentional integer overflow")
Fixes: b40c2e665cd5 ("fs/jfs: TRIM support for JFS Filesystem")
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
patch replaces cases of:
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
as well as handling cases of:
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kmalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kmalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kmalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kmalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(u8) * COUNT
+ COUNT
kmalloc(
- sizeof(__u8) * COUNT
+ COUNT
kmalloc(
- sizeof(char) * COUNT
+ COUNT
kmalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_CONST
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kmalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kmalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kmalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kmalloc(
- sizeof(TYPE) * COUNT * STRIDE
kmalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kmalloc(
- sizeof(THING) * (COUNT) * STRIDE
kmalloc(
- sizeof(THING) * COUNT * (STRIDE)
kmalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kmalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kmalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kmalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kmalloc(
- COUNT * (STRIDE) * SIZE
kmalloc(
- COUNT * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * SIZE
kmalloc(
- COUNT * (STRIDE) * (SIZE)
kmalloc(
- (COUNT) * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * (SIZE)
kmalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kmalloc(
- (E1) * (E2) * E3
kmalloc(
- (E1) * (E2) * (E3)
kmalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Use a more current logging style.
Add __printf format and argument verification.
Remove embedded function names from formats.
Add %pf, __builtin_return_address(0) to jfs_error.
Add newlines to formats for kernel style consistency.
(One format already had an erroneous newline)
Coalesce formats and align arguments.
Object size reduced ~1KiB.
$ size fs/jfs/built-in.o*
201891 35488 63936 301315 49903 fs/jfs/built-in.o.new
202821 35488 64192 302501 49da5 fs/jfs/built-in.o.old
In a hasty fix to replace a 64-bit division with do_div, I
unintentionally assigned the divisor to a 32-bit variable.
Cc: Tino Reichardt <milky-kernel@mcmilk.de>
This patch adds support for the two linux interfaces of the discard/TRIM
command for SSD devices and sparse/thinly-provisioned LUNs.
JFS will support batched discard via FITRIM ioctl and online discard
with the discard mount option.
Signed-off-by: Tino Reichardt <list-jfs@mcmilk.de>
jfs has a few variables being set but never used.
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6:
jfs: add jfs specific ->setattr call
jfs: fix diAllocExt error in resizing filesystem
jfs_dmap.[ch]: trivial typo fix: s/heigth/height/g
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Jiri Kosina <trivial@kernel.org>
Cc: André Goddard Rosa <andre.goddard@gmail.com>
Cc: jfs-discussion@lists.sourceforge.net
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
replace all:
little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) +
expression_in_cpu_byteorder);
with:
leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder);
generated with semantic patch
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
Yeah, it's about time.
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Removed trailing spaces & tabs, and spaces preceding tabs.
Also a couple very minor comment cleanups.
(cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
Conversion of booleans to: generic-boolean.patch (2006-08-23)
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
This fixes a race where lsn could be cleared before taking the lock
the conversion was generated via scripts, and the result was validated
automatically via a script as well.
build and boot tested.
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it.
See mm/filemap.c:
And changes the filemap_write_and_wait() and filemap_write_and_wait_range().
Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite()
returns error. However, even if filemap_fdatawrite() returned an
error, it may have submitted the partially data pages to the device.
(e.g. in the case of -ENOSPC)
<quotation>
Andrew Morton writes,
If filemap_fdatawrite() returns an error, this might be due to some
I/O problem: dead disk, unplugged cable, etc. Given the generally
crappy quality of the kernel's handling of such exceptions, there's a
good chance that the filemap_fdatawait() will get stuck in D state
forever.
</quotation>
So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO.
Trond, could you please review the nfs part? Especially I'm not sure,
nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not.
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
Idea is to reduce false cacheline sharing and stuff
Replace assert statements with better error handling.
This patch fixes up a few problems with jfs's reserved inodes.
1. There is no need for the jfs code setting the I_DIRTY bits in i_state.
I am ashamed that the code ever did this, and surprised it hasn't been
noticed until now.
2. Make sure special inodes are on an inode hash list. If the inodes are
unhashed, __mark_inode_dirty will fail to put the inode on the
superblock's dirty list, and the data will not be flushed under memory
pressure.
3. Force writing journal data to disk when metapage_writepage is unable to
write a metadata page due to pending journal I/O.
The fix in inode.c is a real bug. It could result in undeleted, yet
unconnected files on big-endian hardware.
The others are trivial.
I'm finally getting around to cleaning out debug code that I've never used.
There has always been code ifdef'ed out by _JFS_DEBUG_DMAP, _JFS_DEBUG_IMAP,
_JFS_DEBUG_DTREE, and _JFS_DEBUG_XTREE, which I have personally never used,
and I doubt that anyone has since the design stage back in OS/2. There is
also a function, xtGather, that has never been used, and I don't know why it
was ever there.
jfs has never worked on architecutures where the page size was not 4K.
infrastructure for it.
Let it rip!
