path: root/fs/jfs/jfs_filsys.h
2012-09-17fs/jfs: TRIM support for JFS FilesystemTino Reichardt
This patch adds support for the two linux interfaces of the discard/TRIM command for SSD devices and sparse/thinly-provisioned LUNs. JFS will support batched discard via FITRIM ioctl and online discard with the discard mount option. Signed-off-by: Tino Reichardt <list-jfs@mcmilk.de> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2007-06-06JFS: Whitespace cleanup and remove some dead codeDave Kleikamp
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2006-12-06JFS: Fix conflicting superblock flagsDave Kleikamp
JFS_NOINTEGRITY and JFS_USRQUOTA are defined to be the same value. Change JFS_NOINTEGRITY to 0x40 and re-order the flags in the header file to avoid repeating this problem. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-11-30Fix typos in doc and commentsJan Engelhardt
Changes persistant -> persistent. www.dictionary.com does not know persistant (with an A), but should it be one of those things you can spell in more than one correct way, let me know. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2005-09-07[PATCH] disk quotas fail when /etc/mtab is symlinked to /proc/mountsMark Bellon
If /etc/mtab is a regular file all of the mount options (of a file system) are written to /etc/mtab by the mount command. The quota tools look there for the quota strings for their operation. If, however, /etc/mtab is a symlink to /proc/mounts (a "good thing" in some environments) the tools don't write anything - they assume the kernel will take care of things. While the quota options are sent down to the kernel via the mount system call and the file system codes handle them properly unfortunately there is no code to echo the quota strings into /proc/mounts and the quota tools fail in the symlink case. The attached patchs modify the EXT[2|3] and JFS codes to add the necessary hooks. The show_options function of each file system in these patches currently deal with only those things that seemed related to quotas; especially in the EXT3 case more can be done (later?). Jan Kara also noted the difficulty in moving these changes above the FS codes responding similarly to myself to Andrew's comment about possible VFS migration. Issue summary: - FS codes have to process the entire string of options anyway. - Only FS codes that use quotas must have a show_options function (for quotas to work properly) however quotas are only used in a small number of FS. - Since most of the quota using FS support other options these FS codes should have the a show_options function to show those options - and the quota echoing becomes virtually negligible. Based on feedback I have modified my patches from the original: JFS a missing patch has been restored to the posting EXT[2|3] and JFS always use the show_options function - Each FS has at least one FS specific option displayed - QUOTA output is under a CONFIG_QUOTA ifdef - a follow-on patch will add a multitude of options for each FS EXT[2|3] and JFS "quota" is treated as "usrquota" EXT3 journalled data check for journalled quota removed EXT[2|3] mount when quota specified but not compiled in - no changes from my original patch. I tested the patch and the codes warn but - still mount. With all due respection I believe the comments otherwise were a - misread of the patch. Please reread/test and comment. XFS patch removed - the XFS team already made the necessary changes EXT3 mixing old and new quotas are handled differently (not purely exclusive) - if old and new quotas for the same type are used together the old type is silently depricated for compatability (e.g. usrquota and usrjquota) - mixing of old and new quotas is an error (e.g. usrjquota and grpquota) Signed-off-by: Mark Bellon <mbellon@mvista.com> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
