path: root/fs/jfs/jfs_inode.h
2010-08-09switch jfs to ->evict_inode()Al Viro
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6: jfs: add jfs specific ->setattr call jfs: fix diAllocExt error in resizing filesystem jfs_dmap.[ch]: trivial typo fix: s/heigth/height/g
2010-04-16jfs: add jfs specific ->setattr callDmitry Monakhov
generic setattr not longer responsible for quota transfer. use jfs_setattr for all jfs's inodes. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05dquot: move dquot transfer responsibility into the filesystemChristoph Hellwig
Currently notify_change calls vfs_dq_transfer directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the transfer. Most filesystems already do this, only ufs and udf need the code added, and for jfs it needs to be enabled unconditionally instead of only when ACLs are enabled. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-27constify dentry_operations: JFSAl Viro
2008-02-07BKL-removal: Implement a compat_ioctl handler for JFSAndi Kleen
The ioctls were already compatible except for the actual values so this was fairly easy to do. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-02-07BKL-removal: Use unlocked_ioctl for jfsAndi Kleen
Convert jfs_ioctl over to not use the BKL. The only potential race I could see was with two ioctls in parallel changing the flags and losing the updates. Use the i_mutex to protect against this. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2008-02-07iget: stop JFS from using iget() and read_inode()David Howells
Stop the JFS filesystem from using iget() and read_inode(). Replace jfs_read_inode() with jfs_iget(), and call that instead of iget(). jfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. jfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22jfs: new export opsChristoph Hellwig
Trivial switch over to the new generic helpers. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: remove iget abuseChristoph Hellwig
When the exportfs interface was added the expectation was that filesystems provide an operation to convert from a file handle to an inode/dentry, but it kept a backwards compat option that still calls into iget. Calling into iget from non-filesystem code is very bad, because it gives too little information to filesystem, and simply crashes if the filesystem doesn't implement the ->read_inode routine. Fortunately there are only two filesystems left using this fallback: efs and jfs. This patch moves a copy of export_iget to each of those to implement the get_dentry method. While this is a temporary increase of lines of code in the kernel it allows for a much cleaner interface and important code restructuring in later patches. [akpm@linux-foundation.org: add jfs_get_inode_flags() declaration] Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25Copy i_flags to jfs inode flags on writeDave Kleikamp
This mirrors Jan Kara's patches for ext3. This patch makes sure that changes made to inode->i_flags are reflected on disk for jfs. It also moves a call of jfs_set_inode_flags() to be more consistent with where jfs_get_inode_flags() is called. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-10-02JFS: White space cleanupDave Kleikamp
Removed trailing spaces & tabs, and spaces preceding tabs. Also a couple very minor comment cleanups. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> (cherry picked from f74156539964d7b3d5164fdf8848e6a682f75b97 commit)
2006-07-26JFS: Quota support broken, no quota_read and quota_writeDave Kleikamp
jfs_quota_read/write are very near duplicates of ext2_quota_read/write. Cleaned up jfs_get_block as long as I had to change it to be non-static. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-09JFS: ext2 inode attributes for jfsHerbert Poetzl
ext2 inode attributes with relevance for jfs: 'a' EXT2_APPEND_FL -> append only 'i' EXT2_IMMUTABLE_FL -> immutable file 's' EXT2_SECRM_FL -> zero file 'u' EXT2_UNRM_FL -> allow for unrm 'A' EXT2_NOATIME_FL -> no access time 'D' EXT2_DIRSYNC_FL -> dirsync 'S' EXT2_SYNC_FL -> sync overview of jfs flags (partially for OS/2) value (OS/2) Linux ext2 attrs ------------------------------------------------ 0x00010000 IFJOURNAL - 0x00020000 ISPARSE used 0x00040000 INLINEEA used 0x00080000 - - JFS_NOATIME_FL 0x00100000 - - JFS_DIRSYNC_FL 0x00200000 - - JFS_SYNC_FL 0x00400000 - - JFS_SECRM_FL 0x00800000 ISWAPFILE - JFS_UNRM_FL 0x01000000 - - JFS_APPEND_FL 0x02000000 IREADONLY - JFS_IMMUTABLE_FL 0x04000000 IHIDDEN - - 0x08000000 ISYSTEM - - 0x10000000 - - 0x20000000 IDIRECTORY used 0x40000000 IARCHIVE - 0x80000000 INEWNAME - the implementation is straight forward, except for the fact that the attributes have to be mapped to match with the ext2 ones to avoid a separate tool for manipulating them (this could be avoided when using a separate flag field in the on-disk representation, but the overhead is minimal) a special jfs_ioctl is added to allow for the new JFS_IOC_GETFLAGS and JFS_IOC_SETFLAGS calls. a helper function jfs_set_inode_flags() to transfer the flags from the on-disk version to the inode minor changes to allow flag inheritance on inode creation, as well as a cleanup of the on-disk flags (including the new ones) beforementioned helper to map between ext2 and jfs versions of the new flags ... the JFS_SECRM_FL and JFS_UNRM_FL are not done yet and I'm not 100% sure they are worth the effort, the rest seems to work out of the box ... Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-05-04JFS: fix sparse warnings by moving extern declarations to headersDave Kleikamp
