path: root/fs/jfs
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09JFS: add uid, gid, and umask mount optionsDave Kleikamp
OS/2 doesn't initialize the uid, gid, or unix-style permission bits. The uid, gid, & umask mount options perform pretty much like those for the fat file system, overriding what is stored on disk. This is useful for users sharing the file system with OS/2. I implemented a little feature so that if you mask the execute bit, it will be re-enabled on directories when the appropriate read bit is unmasked. I didn't want to implement an fmask & dmask option. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-03-08JFS: Take logsync lock before testing mp->lsnDave Kleikamp
This fixes a race where lsn could be cleared before taking the lock Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-23JFS: kzalloc conversionEric Sesterhenn
this converts fs/jfs to kzalloc() usage. compile tested with make allyesconfig Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-22JFS: Add missing file from fa3241d24cf1182b0ffb6e4d412c3bc2a2ab7bf6Herbert Poetzl
My mistake here. I failed to checkin fs/jfs/ioctl.c Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-15JFS: Use the kthread_ APIChristoph Hellwig
Use the kthread_ API instead of opencoding lots of hairy code for kernel thread creation and teardown. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-02-10JFS: Fix regression. fsck complains if symlinks do not have INLINEEA attributeDave Kleikamp
2006-02-09JFS: ext2 inode attributes for jfsHerbert Poetzl
ext2 inode attributes with relevance for jfs: 'a' EXT2_APPEND_FL -> append only 'i' EXT2_IMMUTABLE_FL -> immutable file 's' EXT2_SECRM_FL -> zero file 'u' EXT2_UNRM_FL -> allow for unrm 'A' EXT2_NOATIME_FL -> no access time 'D' EXT2_DIRSYNC_FL -> dirsync 'S' EXT2_SYNC_FL -> sync overview of jfs flags (partially for OS/2) value (OS/2) Linux ext2 attrs ------------------------------------------------ 0x00010000 IFJOURNAL - 0x00020000 ISPARSE used 0x00040000 INLINEEA used 0x00080000 - - JFS_NOATIME_FL 0x00100000 - - JFS_DIRSYNC_FL 0x00200000 - - JFS_SYNC_FL 0x00400000 - - JFS_SECRM_FL 0x00800000 ISWAPFILE - JFS_UNRM_FL 0x01000000 - - JFS_APPEND_FL 0x02000000 IREADONLY - JFS_IMMUTABLE_FL 0x04000000 IHIDDEN - - 0x08000000 ISYSTEM - - 0x10000000 - - 0x20000000 IDIRECTORY used 0x40000000 IARCHIVE - 0x80000000 INEWNAME - the implementation is straight forward, except for the fact that the attributes have to be mapped to match with the ext2 ones to avoid a separate tool for manipulating them (this could be avoided when using a separate flag field in the on-disk representation, but the overhead is minimal) a special jfs_ioctl is added to allow for the new JFS_IOC_GETFLAGS and JFS_IOC_SETFLAGS calls. a helper function jfs_set_inode_flags() to transfer the flags from the on-disk version to the inode minor changes to allow flag inheritance on inode creation, as well as a cleanup of the on-disk flags (including the new ones) beforementioned helper to map between ext2 and jfs versions of the new flags ... the JFS_SECRM_FL and JFS_UNRM_FL are not done yet and I'm not 100% sure they are worth the effort, the rest seems to work out of the box ... Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-24JFS: semaphore to mutex conversion.Ingo Molnar
the conversion was generated via scripts, and the result was validated automatically via a script as well. build and boot tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2006-01-24Merge with /home/shaggy/git/linus-clean/Dave Kleikamp
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove jfs xattr permission checksChristoph Hellwig
remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] move xattr permission checks into the VFSakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> The xattr code has rather complex permission checks because the rules are very different for different attribute namespaces. This patch moves as much as we can into the generic code. Currently all the major disk based filesystems duplicate these checks, while many minor filesystems or network filesystems lack some or all of them. To do this we need defines for the extended attribute names in common code, I moved them up from JFS which had the nicest defintions. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] Fix and add EXPORT_SYMBOL(filemap_write_and_wait)OGAWA Hirofumi
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it. See mm/filemap.c: And changes the filemap_write_and_wait() and filemap_write_and_wait_range(). Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite() returns error. However, even if filemap_fdatawrite() returned an error, it may have submitted the partially data pages to the device. (e.g. in the case of -ENOSPC) <quotation> Andrew Morton writes, If filemap_fdatawrite() returns an error, this might be due to some I/O problem: dead disk, unplugged cable, etc. Given the generally crappy quality of the kernel's handling of such exceptions, there's a good chance that the filemap_fdatawait() will get stuck in D state forever. </quotation> So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO. Trond, could you please review the nfs part? Especially I'm not sure, nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not. Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29JFS: make buddy table staticArjan van de Ven
Idea is to reduce false cacheline sharing and stuff Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-11-10JFS: Add back directory i_size calculations for legacy partitionsDave Kleikamp
Linux-formatted jfs partitions have a different idea about what i_size represents than partitions formatted on OS/2. The i_size calculation is now based on the size of the directory index. For legacy partitions, which have no directory index, the i_size is never being updated. This patch adds back the original i_size calculations for legacy partitions. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-10-31JFS: set i_ctime & i_mtime on target directory when creating linksDave Kleikamp
jfs has never been setting i_ctime or i_mtime when creating either hard or symbolic links. I'm surprised nobody had noticed until now. Thanks to Chris Spiegel for reporting the problem. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-10-29[PATCH] mm: split page table lockHugh Dickins
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with a many-threaded application which concurrently initializes different parts of a large anonymous area. This patch corrects that, by using a separate spinlock per page table page, to guard the page table entries in that page, instead of using the mm's single page_table_lock. (But even then, page_table_lock is still used to guard page table allocation, and anon_vma allocation.) In this implementation, the spinlock is tucked inside the struct page of the page table page: with a BUILD_BUG_ON in case it overflows - which it would in the case of 32-bit PA-RISC with spinlock debugging enabled. Splitting the lock is not quite for free: another cacheline access. Ideally, I suppose we would use split ptlock only for multi-threaded processes on multi-cpu machines; but deciding that dynamically would have its own costs. So for now enable it by config, at some number of cpus - since the Kconfig language doesn't support inequalities, let preprocessor compare that with NR_CPUS. But I don't think it's worth being user-configurable: for good testing of both split and unsplit configs, split now at 4 cpus, and perhaps change that to 8 later. There is a benefit even for singly threaded processes: kswapd can be attacking one part of the mm while another part is busy faulting. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shaggy/jfs-2.6
2005-10-28JFS: make sure right-most xtree pages have header.next set to zeroDave Kleikamp
The xtTruncate code was only doing this for leaf pages. When a file is horribly fragmented, we may truncate a file leaving an internal page with an invalid head.next field, which may cause a stale page to be referenced. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-11JFS: Corrupted block map should not cause trapDave Kleikamp
Replace assert statements with better error handling. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-10-03JFS: make special inodes play nicely with page balancingDave Kleikamp
This patch fixes up a few problems with jfs's reserved inodes. 1. There is no need for the jfs code setting the I_DIRTY bits in i_state. I am ashamed that the code ever did this, and surprised it hasn't been noticed until now. 2. Make sure special inodes are on an inode hash list. If the inodes are unhashed, __mark_inode_dirty will fail to put the inode on the superblock's dirty list, and the data will not be flushed under memory pressure. 3. Force writing journal data to disk when metapage_writepage is unable to write a metadata page due to pending journal I/O. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-20JFS: don't dereference tlck->ip from txUpdateMapDave Kleikamp
The inode pointer may no longer be valid Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-15JFS: Fix sparse warnings, including endian errorDave Kleikamp
The fix in inode.c is a real bug. It could result in undeleted, yet unconnected files on big-endian hardware. The others are trivial. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-11Merge branch 'for-linus' from kernel.org:/.../shaggy/jfs-2.6 manuallyLinus Torvalds
Clash due to new delete_inode behavior (the filesystem now needs to do the truncate_inode_pages() call itself). Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] disk quotas fail when /etc/mtab is symlinked to /proc/mountsMark Bellon
If /etc/mtab is a regular file all of the mount options (of a file system) are written to /etc/mtab by the mount command. The quota tools look there for the quota strings for their operation. If, however, /etc/mtab is a symlink to /proc/mounts (a "good thing" in some environments) the tools don't write anything - they assume the kernel will take care of things. While the quota options are sent down to the kernel via the mount system call and the file system codes handle them properly unfortunately there is no code to echo the quota strings into /proc/mounts and the quota tools fail in the symlink case. The attached patchs modify the EXT[2|3] and JFS codes to add the necessary hooks. The show_options function of each file system in these patches currently deal with only those things that seemed related to quotas; especially in the EXT3 case more can be done (later?). Jan Kara also noted the difficulty in moving these changes above the FS codes responding similarly to myself to Andrew's comment about possible VFS migration. Issue summary: - FS codes have to process the entire string of options anyway. - Only FS codes that use quotas must have a show_options function (for quotas to work properly) however quotas are only used in a small number of FS. - Since most of the quota using FS support other options these FS codes should have the a show_options function to show those options - and the quota echoing becomes virtually negligible. Based on feedback I have modified my patches from the original: JFS a missing patch has been restored to the posting EXT[2|3] and JFS always use the show_options function - Each FS has at least one FS specific option displayed - QUOTA output is under a CONFIG_QUOTA ifdef - a follow-on patch will add a multitude of options for each FS EXT[2|3] and JFS "quota" is treated as "usrquota" EXT3 journalled data check for journalled quota removed EXT[2|3] mount when quota specified but not compiled in - no changes from my original patch. I tested the patch and the codes warn but - still mount. With all due respection I believe the comments otherwise were a - misread of the patch. Please reread/test and comment. XFS patch removed - the XFS team already made the necessary changes EXT3 mixing old and new quotas are handled differently (not purely exclusive) - if old and new quotas for the same type are used together the old type is silently depricated for compatability (e.g. usrquota and usrjquota) - mixing of old and new quotas is an error (e.g. usrjquota and grpquota) Signed-off-by: Mark Bellon <mbellon@mvista.com> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01JFS: Implement jfs_init_securityDave Kleikamp
This atomically initializes the security xattr when an object is created Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-09-01JFS: allow extended attributes to be set within a existing transactionDave Kleikamp
2005-08-30JFS: jfs_delete_inode should always call clear_inode.Dave Kleikamp
2005-08-30Merge refs/heads/for-linus from ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/shaggy/jfs-2.6.git
2005-08-19[PATCH] Fix up symlink function pointersAl Viro
This fixes up the symlink functions for the calling convention change: * afs, autofs4, befs, devfs, freevxfs, jffs2, jfs, ncpfs, procfs, smbfs, sysvfs, ufs, xfs - prototype change for ->follow_link() * befs, smbfs, xfs - same for ->put_link() Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-19Merge with /home/shaggy/git/linus-clean/Dave Kleikamp
2005-08-17JFS: Initialize dentry->d_op for negative dentries tooDave Kleikamp
2005-08-10JFS: Fix race in txLockDave Kleikamp
TxAnchor.anon_list is protected by jfsTxnLock (TXN_LOCK), but there was a place in txLock() that was removing an entry from the list without holding the spinlock. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-08-01JFS: Check for invalid inodes in jfs_delete_inodeDave Kleikamp
Some error paths may iput an invalid inode with i_nlink=0. jfs should not try to actually delete such an inode. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-27JFS: Improve sync barrier processingDave Kleikamp
Under heavy load, hot metadata pages are often locked by non-committed transactions, making them difficult to flush to disk. This prevents the sync point from advancing past a transaction that had modified the page. There is a point during the sync barrier processing where all outstanding transactions have been committed to disk, but no new transaction have been allowed to proceed. This is the best time to write the metadata. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-26JFS: Fix i_blocks accounting when allocation failsDave Kleikamp
A failure in dbAlloc caused a directory's i_blocks to be incorrectly incremented, causing jfs_fsck to find the inode to be corrupt. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-25JFS: Don't set log_SYNCBARRIER when log->active == 0Dave Kleikamp
If a metadata page is kept active, it is possible that the sync barrier logic continues to trigger, even if all active transactions have been phyically written to the journal. This can cause a hang, since the completion of the journal I/O is what unsets the sync barrier flag to allow new transactions to be created. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-22JFS: Fix typo in last patchDave Kleikamp
2005-07-15JFS: fsync wrong behavior when I/O failure occursQu Fuping
This is half of a patch that Qu Fuping submitted in April. The first part was applied to fs/mpage.c in 2.6.12-rc4. jfs_fsync should return error, but it doesn't wait for the metadata page to be uptodate, e.g.: jfs_fsync->jfs_commit_inode->txCommit->diWrite->read_metapage-> __get_metapage->read_cache_page reads a page from disk. Because read is async, when read_cache_page: err = filler(data, page), filler will not return error, it just submits I/O request and returns. So, page is not uptodate. Checking only if(IS_ERROR(mp->page)) is not enough, we should add "|| !PageUptodate(mp->page)" Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-15JFS: Remove assert statement in dbJoin & return -EIO insteadDave Kleikamp
2005-07-14JFS: Remove bogus WARN_ON statement and some dead codeDave Kleikamp
2005-07-13JFS: Need to be root to create files with security contextIan Dall
It turns out this is due to some inverted logic in xattr.c Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-13JFS: Allow security.* xattrs to be set on symlinksDave Kleikamp
All of the different xattr namespaces have different rules. user.* and ACL's are not allowed on symlinks, and since these were the first xattrs implemented, I assumed there was no need to support xattrs on symlinks. This one-line patch should fix it. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
2005-07-13Merge with /home/shaggy/git/linus-clean/Dave Kleikamp
