[ Upstream commit a5fdd713d256887b5f012608701149fa939e5645 ]
A statement was originally added in 2006 to shut up a gcc warning,
now but now clang warns about it:
fs/jfs/jfs_txnmgr.c:1932:15: error: variable 'pxd' is uninitialized when used within its own initialization
[-Werror,-Wuninitialized]
pxd_t pxd = pxd; /* truncated extent of xad */
Modern versions of gcc are fine without the silly assignment, so just
drop it. Tested with gcc-4.6 (released 2011), 4.7, 4.8, and 4.9.
Fixes: c9e3ad6021e5 ("JFS: Get rid of "may be used uninitialized" warnings")
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
commit 92d34134193e5b129dc24f8d79cb9196626e8d7a upstream.
The code is assuming the buffer is max_size length, but we weren't
allocating enough space for it.
Signed-off-by: Shankara Pailoor <shankarapailoor@gmail.com>
commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux
Pull writeback error handling updates from Jeff Layton:
"This pile continues the work from last cycle on better tracking
writeback errors. In v4.13 we added some basic errseq_t infrastructure
and converted a few filesystems to use it.
This set continues refining that infrastructure, adds documentation,
and converts most of the other filesystems to use it. The main
exception at this point is the NFS client"
* tag 'wberr-v4.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
ecryptfs: convert to file_write_and_wait in ->fsync
mm: remove optimizations based on i_size in mapping writeback waits
fs: convert a pile of fsync routines to errseq_t based reporting
gfs2: convert to errseq_t based writeback error reporting for fsync
fs: convert sync_file_range to use errseq_t based error-tracking
mm: add file_fdatawait_range and file_write_and_wait
fuse: convert to errseq_t based error tracking for fsync
mm: consolidate dax / non-dax checks for writeback
Documentation: add some docs for errseq_t
errseq: rename __errseq_set to errseq_set
jfs had previously avoided the use of MAX_LFS_FILESIZE because it hadn't
accounted for the whole 32-bit index range on 32-bit systems. That has
been fixed by commit 0cc3b0ec23ce ("Clarify (and fix) MAX_LFS_FILESIZE
macros"), so we can simplify the code now.
Suggested by Andreas Dilger.
Cc: jfs-discussion@lists.sourceforge.net
This way we don't need a block_device structure to submit I/O. The
block_device has different life time rules from the gendisk and
request_queue and is usually only available when the block device node
is open. Other callers need to explicitly create one (e.g. the lightnvm
passthrough code, or the new nvme multipathing code).
For the actual I/O path all that we need is the gendisk, which exists
once per block device. But given that the block layer also does
partition remapping we additionally need a partition index, which is
used for said remapping in generic_make_request.
Note that all the block drivers generally want request_queue or
sometimes the gendisk, so this removes a layer of indirection all
over the stack.
This patch converts most of the in-kernel filesystems that do writeback
out of the pagecache to report errors using the errseq_t-based
infrastructure that was recently added. This allows them to report
errors once for each open file description.
Most filesystems have a fairly straightforward fsync operation. They
call filemap_write_and_wait_range to write back all of the data and
wait on it, and then (sometimes) sync out the metadata.
For those filesystems this is a straightforward conversion from calling
filemap_write_and_wait_range in their fsync operation to calling
file_write_and_wait_range.
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Dave Kleikamp <dave.kleikamp@oracle.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Pull JFS fixes from David Kleikamp.
* tag 'jfs-4.13' of git://github.com/kleikamp/linux-shaggy:
jfs: preserve i_mode if __jfs_set_acl() fails
jfs: Don't clear SGID when inheriting ACLs
jfs: atomically read inode size
When changing a file's acl mask, __jfs_set_acl() will first set the group
bits of i_mode to the value of the mask, and only then set the actual
extended attribute representing the new acl.
If the second part fails (due to lack of space, for example) and the file
had no acl attribute to begin with, the system will from now on assume
that the mask permission bits are actual group permission bits, potentially
granting access to the wrong users.
Prevent this by only changing the inode mode after the acl has been set.
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
When new directory 'DIR1' is created in a directory 'DIR0' with SGID bit
set, DIR1 is expected to have SGID bit set (and owning group equal to
the owning group of 'DIR0'). However when 'DIR0' also has some default
ACLs that 'DIR1' inherits, setting these ACLs will result in SGID bit on
'DIR1' to get cleared if user is not member of the owning group.
Fix the problem by moving posix_acl_update_mode() out of
__jfs_set_acl() into jfs_set_acl(). That way the function will not be
called when inheriting ACLs which is what we want as it prevents SGID
bit clearing and the mode has been properly set by posix_acl_create()
anyway.
Fixes: 073931017b49d9458aa351605b43a7e34598caef
CC: stable@vger.kernel.org
CC: jfs-discussion@lists.sourceforge.net
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
Pull Writeback error handling fixes from Jeff Layton:
"The main rationale for all of these changes is to tighten up writeback
error reporting to userland. There are many ways now that writeback
errors can be lost, such that fsync/fdatasync/msync return 0 when
writeback actually failed.
This pile contains a small set of cleanups and writeback error
handling fixes that I was able to break off from the main pile (#2).
Two of the patches in this pile are trivial. The exceptions are the
patch to fix up error handling in write_one_page, and the patch to
make JFS pay attention to write_one_page errors"
* tag 'for-linus-v4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
fs: remove call_fsync helper function
mm: clean up error handling in write_one_page
JFS: do not ignore return code from write_one_page()
mm: drop "wait" parameter from write_one_page()
There are a couple places where jfs calls write_one_page() where clean
recovery is not possible. In these cases, the file system should be
marked dirty. To do this, it is now necessary to store the superblock in
the metapage structure.
Link: http://lkml.kernel.org/r/db45ab67-55c7-08ff-6776-f76b3bf5cbf5@oracle.com
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
The callers all set it to 1.
Also, make it clear that this function will not set any sort of AS_*
error, and that the caller must do so if necessary. No existing caller
uses this on normal files, so none of them need it.
Also, add __must_check here since, in general, the callers need to handle
an error here in some fashion.
Link: http://lkml.kernel.org/r/20170525103303.6524-1-jlayton@redhat.com
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Replace bi_error with a new bi_status to allow for a clear conversion.
Note that device mapper overloaded bi_error with a private value, which
we'll have to keep arround at least for now and thus propagate to a
proper blk_status_t value.
Signed-off-by: Jens Axboe <axboe@fb.com>
Now that all places setting inode->i_flags that should be reflected in
on-disk flags are gone, we can remove jfs_get_inode_flags() call.
Currently immutable and noatime flags on quota files are set by quota
code which requires us to copy inode->i_flags to our on disk version
of quota flags in GETFLAGS ioctl and copy_to_dinode(). Move to
setting / clearing these on-disk flags directly to save that copying.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
See i_size_read() comments in include/linux/fs.h
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull partial readlink cleanups from Miklos Szeredi.
This is the uncontroversial part of the readlink cleanup patch-set that
simplifies the default readlink handling.
Miklos and Al are still discussing the rest of the series.
* git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
vfs: make generic_readlink() static
vfs: remove ".readlink = generic_readlink" assignments
vfs: default to generic_readlink()
vfs: replace calling i_op->readlink with vfs_readlink()
proc/self: use generic_readlink
ecryptfs: use vfs_get_link()
bad_inode: add missing i_op initializers
Pull jfs update from David Kleikamp:
"The jfs piece of the current_time() series"
* tag 'jfs-4.10' of git://github.com/kleikamp/linux-shaggy:
fs: jfs: Replace CURRENT_TIME_SEC by current_time()
If .readlink == NULL implies generic_readlink().
Generated by:
to_del="\.readlink.*=.*generic_readlink"
for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
jfs uses nanosecond granularity for filesystem timestamps.
Only this assignment is not using nanosecond granularity.
Use current_time() to get the right granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Remove the WRITE_* and READ_SYNC wrappers, and just use the flags
directly. Where applicable this also drops usage of the
bio_set_op_attrs wrapper.
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
Pull misc vfs updates from Al Viro:
"Assorted misc bits and pieces.
There are several single-topic branches left after this (rename2
series from Miklos, current_time series from Deepa Dinamani, xattr
series from Andreas, uaccess stuff from from me) and I'd prefer to
send those separately"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits)
proc: switch auxv to use of __mem_open()
hpfs: support FIEMAP
cifs: get rid of unused arguments of CIFSSMBWrite()
posix_acl: uapi header split
posix_acl: xattr representation cleanups
fs/aio.c: eliminate redundant loads in put_aio_ring_file
fs/internal.h: add const to ns_dentry_operations declaration
compat: remove compat_printk()
fs/buffer.c: make __getblk_slow() static
proc: unsigned file descriptors
fs/file: more unsigned file descriptors
fs: compat: remove redundant check of nr_segs
cachefiles: Fix attempt to read i_blocks after deleting file [ver #2]
cifs: don't use memcpy() to copy struct iov_iter
get rid of separate multipage fault-in primitives
fs: Avoid premature clearing of capabilities
fs: Give dentry to inode_change_ok() instead of inode
fuse: Propagate dentry down to inode_change_ok()
ceph: Propagate dentry down to inode_change_ok()
xfs: Propagate dentry down to inode_change_ok()
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
This is trivial to do:
- add flags argument to foo_rename()
- check if flags doesn't have any other than RENAME_NOREPLACE
- assign foo_rename() to .rename2 instead of .rename
Filesystems converted:
affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos,
nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat.
Acked-by: Boaz Harrosh <ooo@electrozaur.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: Bob Copeland <me@bobcopeland.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Calling 'list_splice' followed by 'INIT_LIST_HEAD' is equivalent to
'list_splice_init'.
This has been spotted with the following coccinelle script:
expression y,z;
- list_splice(y,z);
- INIT_LIST_HEAD(y);
+ list_splice_init(y,z);
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
filemap_fdatawait/filemap_write_and_wait may fail, so check the return
value and jump to error_out in the case of error.
Signed-off-by: Quorum Laval <quorum.laval@gmail.com>
Pull vfs updates from Al Viro:
"Assorted cleanups and fixes.
Probably the most interesting part long-term is ->d_init() - that will
have a bunch of followups in (at least) ceph and lustre, but we'll
need to sort the barrier-related rules before it can get used for
really non-trivial stuff.
Another fun thing is the merge of ->d_iput() callers (dentry_iput()
and dentry_unlink_inode()) and a bunch of ->d_compare() ones (all
except the one in __d_lookup_lru())"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
fs/dcache.c: avoid soft-lockup in dput()
vfs: new d_init method
vfs: Update lookup_dcache() comment
bdev: get rid of ->bd_inodes
Remove last traces of ->sync_page
new helper: d_same_name()
dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()
vfs: clean up documentation
vfs: document ->d_real()
vfs: merge .d_select_inode() into .d_real()
unify dentry_iput() and dentry_unlink_inode()
binfmt_misc: ->s_root is not going anywhere
drop redundant ->owner initializations
ufs: get rid of redundant checks
orangefs: constify inode_operations
missed comment updates from ->direct_IO() prototype change
file_inode(f)->i_mapping is f->f_mapping
trim fsnotify hooks a bit
9p: new helper - v9fs_parent_fid()
debugfs: ->d_parent is never NULL or negative
This changes the vfs dentry hashing to mix in the parent pointer at the
_beginning_ of the hash, rather than at the end.
That actually improves both the hash and the code generation, because we
can move more of the computation to the "static" part of the dcache
setup, and do less at lookup runtime.
It turns out that a lot of other hash users also really wanted to mix in
a base pointer as a 'salt' for the hash, and so the slightly extended
interface ends up working well for other cases too.
Users that want a string hash that is purely about the string pass in a
'salt' pointer of NULL.
* merge branch 'salted-string-hash':
fs/dcache.c: Save one 32-bit multiply in dcache lookup
vfs: make the string hashes salt the hash
We always mixed in the parent pointer into the dentry name hash, but we
did it late at lookup time. It turns out that we can simplify that
lookup-time action by salting the hash with the parent pointer early
instead of late.
A few other users of our string hashes also wanted to mix in their own
pointers into the hash, and those are updated to use the same mechanism.
Hash users that don't have any particular initial salt can just use the
NULL pointer as a no-salt.
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: George Spelvin <linux@sciencehorizons.net>
This patch converts the simple bi_rw use cases in the block,
drivers, mm and fs code to set/get the bio operation using
bio_set_op_attrs/bio_op
These should be simple one or two liner cases, so I just did them
in one patch. The next patches handle the more complicated
cases in a module per patch.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
it's not needed for file_operations of inodes located on fs defined
in the hosting module and for file_operations that go into procfs.
preparation for similar switch in ->setxattr() (see the next commit for
rationale).
Pull remaining vfs xattr work from Al Viro:
"The rest of work.xattr (non-cifs conversions)"
btrfs: Switch to generic xattr handlers
ubifs: Switch to generic xattr handlers
jfs: Switch to generic xattr handlers
jfs: Clean up xattr name mapping
gfs2: Switch to generic xattr handlers
ceph: kill __ceph_removexattr()
ceph: Switch to generic xattr handlers
ceph: Get rid of d_find_alias in ceph_set_acl
