Create a generic function to check incoming FS_IOC_SETFLAGS flag values
and later prepare the inode for updates so that we can standardize the
implementations that follow ext4's flag values.
Note that the efivarfs implementation no longer fails a no-op SETFLAGS
without CAP_LINUX_IMMUTABLE since that's the behavior in ext*.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Acked-by: David Sterba <dsterba@suse.com>
Reviewed-by: Bob Peterson <rpeterso@redhat.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
Pull jfs updates from Dave Kleikamp:
"Several minor jfs fixes"
* tag 'jfs-5.2' of git://github.com/kleikamp/linux-shaggy:
jfs: fix bogus variable self-initialization
fs/jfs: Switch to use new generic UUID API
jfs: compare old and new mode before setting update_mode flag
jfs: remove incorrect comment in jfs_superblock
jfs: fix spelling mistake, EACCESS -> EACCES
synchronous part can be moved to ->evict_inode(), the rest -
->free_inode() fodder
A statement was originally added in 2006 to shut up a gcc warning,
now but now clang warns about it:
fs/jfs/jfs_txnmgr.c:1932:15: error: variable 'pxd' is uninitialized when used within its own initialization
[-Werror,-Wuninitialized]
pxd_t pxd = pxd; /* truncated extent of xad */
Modern versions of gcc are fine without the silly assignment, so just
drop it. Tested with gcc-4.6 (released 2011), 4.7, 4.8, and 4.9.
Fixes: c9e3ad6021e5 ("JFS: Get rid of "may be used uninitialized" warnings")
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
There are new types and helpers that are supposed to be used in new code.
As a preparation to get rid of legacy types and API functions do
the conversion here.
If new mode is the same as old mode we don't have to reset
inode mode in the rest of the code, so compare old and new
mode before setting update_mode flag.
Signed-off-by: Chengguang Xu <cgxu519@gmx.com>
There is a comment in struct jfs_superblock that incorrectly labels
a 128-byte boundary. It has never been correct.
Shenghui Wang proposed moving it to the correct spot, before s_xlogpxd,
but at this point, I believe it is best just to remove it.
Reported-by: Shenghui Wang <shhuiw@foxmail.com>
Trivial fix to a spelling mistake of the error access name EACCESS,
rename to EACCES
We don't need to call dquot_initialize() twice in jfs_evict_inode(),
remove one of them for cleanup.
Signed-off-by: Chao Yu <yuchao0@huawei.com>
We treat quota option as usrquota, so remove quota option from ignore
list.
default_acl and acl of newly created inode will be initiated
as ACL_NOT_CACHED in vfs function inode_init_always() and later
will be updated by calling xxx_init_acl() in specific filesystems.
Howerver, when default_acl and acl are NULL then they keep the value
of ACL_NOT_CACHED, this patch tries to cache NULL for acl/default_acl
in this case.
Pull jfs update from David Kleikamp:
"Just one jfs patch for 4.19"
* tag 'jfs-4.19' of git://github.com/kleikamp/linux-shaggy:
jfs: use time64_t for otime
Pull vfs icache updates from Al Viro:
- NFS mkdir/open_by_handle race fix
- analogous solution for FUSE, replacing the one currently in mainline
- new primitive to be used when discarding halfway set up inodes on
failed object creation; gives sane warranties re icache lookups not
returning such doomed by still not freed inodes. A bunch of
filesystems switched to that animal.
- Miklos' fix for last cycle regression in iget5_locked(); -stable will
need a slightly different variant, unfortunately.
- misc bits and pieces around things icache-related (in adfs and jfs).
* 'work.mkdir' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
jfs: don't bother with make_bad_inode() in ialloc()
adfs: don't put inodes into icache
new helper: inode_fake_hash()
vfs: don't evict uninitialized inode
jfs: switch to discard_new_inode()
ext2: make sure that partially set up inodes won't be returned by ext2_iget()
udf: switch to discard_new_inode()
ufs: switch to discard_new_inode()
btrfs: switch to discard_new_inode()
new primitive: discard_new_inode()
kill d_instantiate_no_diralias()
nfs_instantiate(): prevent multiple aliases for directory inode
Bart Massey reported what turned out to be a usercopy whitelist false
positive in JFS when symlink contents exceeded 128 bytes. The inline
inode data (i_inline) is actually designed to overflow into the "extended
area" following it (i_inline_ea) when needed. So the whitelist needed to
be expanded to include both i_inline and i_inline_ea (the whole size
of which is calculated internally using IDATASIZE, 256, instead of
sizeof(i_inline), 128).
$ cd /mnt/jfs
$ touch $(perl -e 'print "B" x 250')
$ ln -s B* b
$ ls -l >/dev/null
[ 249.436410] Bad or missing usercopy whitelist? Kernel memory exposure attempt detected from SLUB object 'jfs_ip' (offset 616, size 250)!
Reported-by: Bart Massey <bart.massey@gmail.com>
Fixes: 8d2704d382a9 ("jfs: Define usercopy region in jfs_ip slab cache")
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: jfs-discussion@lists.sourceforge.net
Cc: stable@vger.kernel.org
We hit that when inumber allocation has failed. In that case
the in-core inode is not hashed and since its ->i_nlink is 1
the only place where jfs checks is_bad_inode() won't be reached.
open-coded in a quite a few places...
we don't want open-by-handle to pick an in-core inode that
has failed setup halfway through.
The file creation time in the inode uses time_t which is defined
differently on 32-bit and 64-bit architectures and deprecated. The
representation in the inode uses an unsigned 32-bit number, but this
gets wrapped around after year 2038 when assigned to a time_t.
This changes the type to time64_t, so we can support the full range of
timestamps between 1970 and 2106 on 32-bit systems like we do on 64-bit
systems already, and matching what we do for the atime/ctime/mtime stamps
since the introduction of 64-bit timestamps in VFS.
Note: the otime stamp is not actually used anywhere at the moment in
the kernel, it is just set when writing a file, so none of this really
makes a difference unless we implement setting the btime field in the
getattr() callback.
Pull jfs fix from Dave Kleikamp:
"This fixes a too-small allocation in the xattr code"
* tag 'jfs-4.18' of git://github.com/kleikamp/linux-shaggy:
jfs: Fix inconsistency between memory allocation and ea_buf->max_size
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
patch replaces cases of:
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
as well as handling cases of:
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kmalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kmalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kmalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kmalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(u8) * COUNT
+ COUNT
kmalloc(
- sizeof(__u8) * COUNT
+ COUNT
kmalloc(
- sizeof(char) * COUNT
+ COUNT
kmalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_CONST
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kmalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kmalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kmalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kmalloc(
- sizeof(TYPE) * COUNT * STRIDE
kmalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kmalloc(
- sizeof(THING) * (COUNT) * STRIDE
kmalloc(
- sizeof(THING) * COUNT * (STRIDE)
kmalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kmalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kmalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kmalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kmalloc(
- COUNT * (STRIDE) * SIZE
kmalloc(
- COUNT * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * SIZE
kmalloc(
- COUNT * (STRIDE) * (SIZE)
kmalloc(
- (COUNT) * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * (SIZE)
kmalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kmalloc(
- (E1) * (E2) * E3
kmalloc(
- (E1) * (E2) * (E3)
kmalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
The code is assuming the buffer is max_size length, but we weren't
allocating enough space for it.
Signed-off-by: Shankara Pailoor <shankarapailoor@gmail.com>
Pull procfs updates from Al Viro:
"Christoph's proc_create_... cleanups series"
* 'hch.procfs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (44 commits)
xfs, proc: hide unused xfs procfs helpers
isdn/gigaset: add back gigaset_procinfo assignment
proc: update SIZEOF_PDE_INLINE_NAME for the new pde fields
tty: replace ->proc_fops with ->proc_show
ide: replace ->proc_fops with ->proc_show
ide: remove ide_driver_proc_write
isdn: replace ->proc_fops with ->proc_show
atm: switch to proc_create_seq_private
atm: simplify procfs code
bluetooth: switch to proc_create_seq_data
netfilter/x_tables: switch to proc_create_seq_private
netfilter/xt_hashlimit: switch to proc_create_{seq,single}_data
neigh: switch to proc_create_seq_data
hostap: switch to proc_create_{seq,single}_data
bonding: switch to proc_create_seq_data
rtc/proc: switch to proc_create_single_data
drbd: switch to proc_create_single
resource: switch to proc_create_seq_data
staging/rtl8192u: simplify procfs code
jfs: simplify procfs code
Use remove_proc_subtree to remove the whole subtree on cleanup, and
unwind the registration loop into individual calls. Switch to use
proc_create_seq where applicable.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull hardened usercopy whitelisting from Kees Cook:
"Currently, hardened usercopy performs dynamic bounds checking on slab
cache objects. This is good, but still leaves a lot of kernel memory
available to be copied to/from userspace in the face of bugs.
To further restrict what memory is available for copying, this creates
a way to whitelist specific areas of a given slab cache object for
copying to/from userspace, allowing much finer granularity of access
control.
Slab caches that are never exposed to userspace can declare no
whitelist for their objects, thereby keeping them unavailable to
userspace via dynamic copy operations. (Note, an implicit form of
whitelisting is the use of constant sizes in usercopy operations and
get_user()/put_user(); these bypass all hardened usercopy checks since
these sizes cannot change at runtime.)
This new check is WARN-by-default, so any mistakes can be found over
the next several releases without breaking anyone's system.
The series has roughly the following sections:
- remove %p and improve reporting with offset
- prepare infrastructure and whitelist kmalloc
- update VFS subsystem with whitelists
- update SCSI subsystem with whitelists
- update network subsystem with whitelists
- update process memory with whitelists
- update per-architecture thread_struct with whitelists
- update KVM with whitelists and fix ioctl bug
- mark all other allocations as not whitelisted
- update lkdtm for more sensible test overage"
* tag 'usercopy-v4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: (38 commits)
lkdtm: Update usercopy tests for whitelisting
usercopy: Restrict non-usercopy caches to size 0
kvm: x86: fix KVM_XEN_HVM_CONFIG ioctl
kvm: whitelist struct kvm_vcpu_arch
arm: Implement thread_struct whitelist for hardened usercopy
arm64: Implement thread_struct whitelist for hardened usercopy
x86: Implement thread_struct whitelist for hardened usercopy
fork: Provide usercopy whitelisting for task_struct
fork: Define usercopy region in thread_stack slab caches
fork: Define usercopy region in mm_struct slab caches
net: Restrict unwhitelisted proto caches to size 0
sctp: Copy struct sctp_sock.autoclose to userspace using put_user()
sctp: Define usercopy region in SCTP proto slab cache
caif: Define usercopy region in caif proto slab cache
ip: Define usercopy region in IP proto slab cache
net: Define usercopy region in struct proto slab cache
scsi: Define usercopy region in scsi_sense_cache slab cache
cifs: Define usercopy region in cifs_request slab cache
vxfs: Define usercopy region in vxfs_inode slab cache
ufs: Define usercopy region in ufs_inode_cache slab cache
The jfs symlink pathnames, stored in struct jfs_inode_info.i_inline and
therefore contained in the jfs_ip slab cache, need to be copied to/from
userspace.
cache object allocation:
fs/jfs/super.c:
jfs_alloc_inode(...):
jfs_inode = kmem_cache_alloc(jfs_inode_cachep, GFP_NOFS);
return &jfs_inode->vfs_inode;
fs/jfs/jfs_incore.h:
JFS_IP(struct inode *inode):
return container_of(inode, struct jfs_inode_info, vfs_inode);
fs/jfs/inode.c:
jfs_iget(...):
inode->i_link = JFS_IP(inode)->i_inline;
example usage trace:
readlink_copy+0x43/0x70
vfs_readlink+0x62/0x110
SyS_readlinkat+0x100/0x130
fs/namei.c:
readlink_copy(..., link):
copy_to_user(..., link, len);
(inlined in vfs_readlink)
generic_readlink(dentry, ...):
struct inode *inode = d_inode(dentry);
const char *link = inode->i_link;
readlink_copy(..., link);
In support of usercopy hardening, this patch defines a region in the
jfs_ip slab cache in which userspace copy operations are allowed.
This region is known as the slab cache's usercopy region. Slab caches
can now check that each dynamically sized copy operation involving
cache-managed memory falls entirely within the slab's usercopy region.
This patch is modified from Brad Spengler/PaX Team's PAX_USERCOPY
whitelisting code in the last public patch of grsecurity/PaX based on my
understanding of the code. Changes or omissions from the original code are
mine and don't reflect the original grsecurity/PaX code.
Signed-off-by: David Windsor <dave@nullcore.net>
[kees: adjust commit log, provide usage trace]
Acked-by: Dave Kleikamp <dave.kleikamp@oracle.com>
This link is replicated in most filesystems' config stanzas. Referring
to an archived version of that site is pointless as it mostly deals with
patches; user documentation is available elsewhere.
Signed-off-by: Adam Borowski <kilobyte@angband.pl>
CC: Alexander Viro <viro@zeniv.linux.org.uk>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: "Yan, Zheng" <zyan@redhat.com>
Acked-by: Chao Yu <yuchao0@huawei.com>
Acked-by: Jaegeuk Kim <jaegeuk@kernel.org>
Acked-by: Steve French <smfrench@gmail.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This is a pure automated search-and-replace of the internal kernel
superblock flags.
The s_flags are now called SB_*, with the names and the values for the
moment mirroring the MS_* flags that they're equivalent to.
Note how the MS_xyz flags are the ones passed to the mount system call,
while the SB_xyz flags are what we then use in sb->s_flags.
The script to do this was:
# places to look in; re security/*: it generally should *not* be
# touched (that stuff parses mount(2) arguments directly), but
# there are two places where we really deal with superblock flags.
FILES="drivers/mtd drivers/staging/lustre fs ipc mm \
include/linux/fs.h include/uapi/linux/bfs_fs.h \
security/apparmor/apparmorfs.c security/apparmor/include/lib.h"
# the list of MS_... constants
SYMS="RDONLY NOSUID NODEV NOEXEC SYNCHRONOUS REMOUNT MANDLOCK \
DIRSYNC NOATIME NODIRATIME BIND MOVE REC VERBOSE SILENT \
POSIXACL UNBINDABLE PRIVATE SLAVE SHARED RELATIME KERNMOUNT \
I_VERSION STRICTATIME LAZYTIME SUBMOUNT NOREMOTELOCK NOSEC BORN \
ACTIVE NOUSER"
SED_PROG=
for i in $SYMS; do SED_PROG="$SED_PROG -e s/MS_$i/SB_$i/g"; done
# we want files that contain at least one of MS_...,
# with fs/namespace.c and fs/pnode.c excluded.
L=$(for i in $SYMS; do git grep -w -l MS_$i $FILES; done| sort|uniq|grep -v '^fs/namespace.c'|grep -v '^fs/pnode.c')
for f in $L; do sed -i $f $SED_PROG; done
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Pull jfs updates from David Kleikamp:
"A couple small fixes for jfs"
* tag 'jfs-4.15' of git://github.com/kleikamp/linux-shaggy:
jfs: Add missing NULL pointer check in __get_metapage
jfs: remove increment of i_version counter
alloc_metapage can return a NULL pointer so check for that.
Signed-off-by: Juerg Haefliger <juerg.haefliger@canonical.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
JFS does not set SB_I_VERSION and doesn't use the i_version counter
internally. Just remove this increment.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux
Pull writeback error handling updates from Jeff Layton:
"This pile continues the work from last cycle on better tracking
writeback errors. In v4.13 we added some basic errseq_t infrastructure
and converted a few filesystems to use it.
This set continues refining that infrastructure, adds documentation,
and converts most of the other filesystems to use it. The main
exception at this point is the NFS client"
* tag 'wberr-v4.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
ecryptfs: convert to file_write_and_wait in ->fsync
mm: remove optimizations based on i_size in mapping writeback waits
fs: convert a pile of fsync routines to errseq_t based reporting
gfs2: convert to errseq_t based writeback error reporting for fsync
fs: convert sync_file_range to use errseq_t based error-tracking
mm: add file_fdatawait_range and file_write_and_wait
fuse: convert to errseq_t based error tracking for fsync
mm: consolidate dax / non-dax checks for writeback
Documentation: add some docs for errseq_t
errseq: rename __errseq_set to errseq_set
jfs had previously avoided the use of MAX_LFS_FILESIZE because it hadn't
accounted for the whole 32-bit index range on 32-bit systems. That has
been fixed by commit 0cc3b0ec23ce ("Clarify (and fix) MAX_LFS_FILESIZE
macros"), so we can simplify the code now.
Suggested by Andreas Dilger.
This way we don't need a block_device structure to submit I/O. The
block_device has different life time rules from the gendisk and
request_queue and is usually only available when the block device node
is open. Other callers need to explicitly create one (e.g. the lightnvm
passthrough code, or the new nvme multipathing code).
For the actual I/O path all that we need is the gendisk, which exists
once per block device. But given that the block layer also does
partition remapping we additionally need a partition index, which is
used for said remapping in generic_make_request.
Note that all the block drivers generally want request_queue or
sometimes the gendisk, so this removes a layer of indirection all
over the stack.
This patch converts most of the in-kernel filesystems that do writeback
out of the pagecache to report errors using the errseq_t-based
infrastructure that was recently added. This allows them to report
errors once for each open file description.
Most filesystems have a fairly straightforward fsync operation. They
call filemap_write_and_wait_range to write back all of the data and
wait on it, and then (sometimes) sync out the metadata.
For those filesystems this is a straightforward conversion from calling
filemap_write_and_wait_range in their fsync operation to calling
file_write_and_wait_range.
Pull JFS fixes from David Kleikamp.
* tag 'jfs-4.13' of git://github.com/kleikamp/linux-shaggy:
jfs: preserve i_mode if __jfs_set_acl() fails
jfs: Don't clear SGID when inheriting ACLs
jfs: atomically read inode size
When changing a file's acl mask, __jfs_set_acl() will first set the group
bits of i_mode to the value of the mask, and only then set the actual
extended attribute representing the new acl.
If the second part fails (due to lack of space, for example) and the file
had no acl attribute to begin with, the system will from now on assume
that the mask permission bits are actual group permission bits, potentially
granting access to the wrong users.
Prevent this by only changing the inode mode after the acl has been set.
Signed-off-by: Ernesto A. Fernández <ernesto.mnd.fernandez@gmail.com>
When new directory 'DIR1' is created in a directory 'DIR0' with SGID bit
set, DIR1 is expected to have SGID bit set (and owning group equal to
the owning group of 'DIR0'). However when 'DIR0' also has some default
ACLs that 'DIR1' inherits, setting these ACLs will result in SGID bit on
'DIR1' to get cleared if user is not member of the owning group.
Fix the problem by moving posix_acl_update_mode() out of
__jfs_set_acl() into jfs_set_acl(). That way the function will not be
called when inheriting ACLs which is what we want as it prevents SGID
bit clearing and the mode has been properly set by posix_acl_create()
anyway.
Fixes: 073931017b49d9458aa351605b43a7e34598caef
CC: stable@vger.kernel.org
CC: jfs-discussion@lists.sourceforge.net
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
Pull Writeback error handling fixes from Jeff Layton:
"The main rationale for all of these changes is to tighten up writeback
error reporting to userland. There are many ways now that writeback
errors can be lost, such that fsync/fdatasync/msync return 0 when
writeback actually failed.
This pile contains a small set of cleanups and writeback error
handling fixes that I was able to break off from the main pile (#2).
Two of the patches in this pile are trivial. The exceptions are the
patch to fix up error handling in write_one_page, and the patch to
make JFS pay attention to write_one_page errors"
* tag 'for-linus-v4.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jlayton/linux:
fs: remove call_fsync helper function
mm: clean up error handling in write_one_page
JFS: do not ignore return code from write_one_page()
mm: drop "wait" parameter from write_one_page()
There are a couple places where jfs calls write_one_page() where clean
recovery is not possible. In these cases, the file system should be
marked dirty. To do this, it is now necessary to store the superblock in
the metapage structure.
Link: http://lkml.kernel.org/r/db45ab67-55c7-08ff-6776-f76b3bf5cbf5@oracle.com
Cc: Jeff Layton <jlayton@redhat.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
The callers all set it to 1.
Also, make it clear that this function will not set any sort of AS_*
error, and that the caller must do so if necessary. No existing caller
uses this on normal files, so none of them need it.
Also, add __must_check here since, in general, the callers need to handle
an error here in some fashion.
Link: http://lkml.kernel.org/r/20170525103303.6524-1-jlayton@redhat.com
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Replace bi_error with a new bi_status to allow for a clear conversion.
Note that device mapper overloaded bi_error with a private value, which
we'll have to keep arround at least for now and thus propagate to a
proper blk_status_t value.
Signed-off-by: Jens Axboe <axboe@fb.com>
Now that all places setting inode->i_flags that should be reflected in
on-disk flags are gone, we can remove jfs_get_inode_flags() call.
Currently immutable and noatime flags on quota files are set by quota
code which requires us to copy inode->i_flags to our on disk version
of quota flags in GETFLAGS ioctl and copy_to_dinode(). Move to
setting / clearing these on-disk flags directly to save that copying.
