path: root/fs/jfs
2014-01-31Merge tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fix from David Kleikamp: "Minor bug fix for linux-3.14" * tag 'jfs-3.14' of git://github.com/kleikamp/linux-shaggy: jfs: fix xattr value size overflow in __jfs_setxattr
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-25jfs: use generic posix ACL infrastructureChristoph Hellwig
Copy the scheme I introduced to btrfs many years ago to only use the xattr handler for ACLs, but pass plain attrs straight through. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Kleikamp <dave.kleikamp@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_create more usefulChristoph Hellwig
Rename the current posix_acl_created to __posix_acl_create and add a fully featured helper to set up the ACLs on file creation that uses get_acl(). Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_chmod more usefulChristoph Hellwig
Rename the current posix_acl_chmod to __posix_acl_chmod and add a fully featured ACL chmod helper that uses the ->set_acl inode operation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-02jfs: fix xattr value size overflow in __jfs_setxattrJie Liu
There is a potential overflow if the specified EA value size is greater than USHRT_MAX because the size of value is limited by the on-disk format (i.e, __le16), this issue could be reflected via the tests below: # touch /jfs/testfile # setfattr -n user.comment -v `perl -e 'print "A"x65536'` /jfs/testfile setfattr: /jfs/testfile: Invalid argument Syslog: ... jfs_xsetattr: xattr_size = 21, new_size = 65557 This patch add pre-checkups of EA value size against USHRT_MAX to avoid this problem, and return -E2BIG which is consistent with the VFS setxattr interface. Moreover, fix the debug code to print the correct function name. With this fix: setfattr: /jfs/testfile: Argument list too long Signed-off-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-10-22Merge tag 'jfs-3.12' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs bugfix from David Kleikamp: "Just a patch to fix an oops in an error path" * tag 'jfs-3.12' of git://github.com/kleikamp/linux-shaggy: jfs: fix error path in ialloc
2013-09-17jfs: fix error path in iallocDave Kleikamp
If insert_inode_locked() fails, we shouldn't be calling unlock_new_inode(). Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Tested-by: Michael L. Semon <mlsemon35@gmail.com> Cc: stable@vger.kernel.org
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-15jfs: fix readdir cookie incompatibility with NFSv4Dave Kleikamp
NFSv4 reserves readdir cookie values 0-2 for special entries (. and ..), but jfs allows a value of 2 for a non-special entry. This incompatibility can result in the nfs client reporting a readdir loop. This patch doesn't change the value stored internally, but adds one to the value exposed to the iterate method. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Tested-by: Christian Kujau <lists@nerdbynature.de>
2013-07-11Merge tag 'jfs-3.11' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs update from Dave Kleikamp: "A couple cleanups to JFS for 3.11" * tag 'jfs-3.11' of git://github.com/kleikamp/linux-shaggy: jfs: Update jfs_error jfs: fix sparse warning in fs/jfs/xattr.c
2013-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second set of VFS changes from Al Viro: "Assorted f_pos race fixes, making do_splice_direct() safe to call with i_mutex on parent, O_TMPFILE support, Jeff's locks.c series, ->d_hash/->d_compare calling conventions changes from Linus, misc stuff all over the place." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) Document ->tmpfile() ext4: ->tmpfile() support vfs: export lseek_execute() to modules lseek_execute() doesn't need an inode passed to it block_dev: switch to fixed_size_llseek() cpqphp_sysfs: switch to fixed_size_llseek() tile-srom: switch to fixed_size_llseek() proc_powerpc: switch to fixed_size_llseek() ubi/cdev: switch to fixed_size_llseek() pci/proc: switch to fixed_size_llseek() isapnp: switch to fixed_size_llseek() lpfc: switch to fixed_size_llseek() locks: give the blocked_hash its own spinlock locks: add a new "lm_owner_key" lock operation locks: turn the blocked_list into a hashtable locks: convert fl_link to a hlist_node locks: avoid taking global lock if possible when waking up blocked waiters locks: protect most of the file_lock handling with i_lock locks: encapsulate the fl_link list handling locks: make "added" in __posix_lock_file a bool ...
2013-07-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Lots of bug fixes, cleanups and optimizations. In the bug fixes category, of note is a fix for on-line resizing file systems where the block size is smaller than the page size (i.e., file systems 1k blocks on x86, or more interestingly file systems with 4k blocks on Power or ia64 systems.) In the cleanup category, the ext4's punch hole implementation was significantly improved by Lukas Czerner, and now supports bigalloc file systems. In addition, Jan Kara significantly cleaned up the write submission code path. We also improved error checking and added a few sanity checks. In the optimizations category, two major optimizations deserve mention. The first is that ext4_writepages() is now used for nodelalloc and ext3 compatibility mode. This allows writes to be submitted much more efficiently as a single bio request, instead of being sent as individual 4k writes into the block layer (which then relied on the elevator code to coalesce the requests in the block queue). Secondly, the extent cache shrink mechanism, which was introduce in 3.9, no longer has a scalability bottleneck caused by the i_es_lru spinlock. Other optimizations include some changes to reduce CPU usage and to avoid issuing empty commits unnecessarily." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits) ext4: optimize starting extent in ext4_ext_rm_leaf() jbd2: invalidate handle if jbd2_journal_restart() fails ext4: translate flag bits to strings in tracepoints ext4: fix up error handling for mpage_map_and_submit_extent() jbd2: fix theoretical race in jbd2__journal_restart ext4: only zero partial blocks in ext4_zero_partial_blocks() ext4: check error return from ext4_write_inline_data_end() ext4: delete unnecessary C statements ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree() jbd2: move superblock checksum calculation to jbd2_write_superblock() ext4: pass inode pointer instead of file pointer to punch hole ext4: improve free space calculation for inline_data ext4: reduce object size when !CONFIG_PRINTK ext4: improve extent cache shrink mechanism to avoid to burn CPU time ext4: implement error handling of ext4_mb_new_preallocation() ext4: fix corruption when online resizing a fs with 1K block size ext4: delete unused variables ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents jbd2: remove debug dependency on debug_fs and update Kconfig help text jbd2: use a single printk for jbd_debug() ...
2013-06-29Don't pass inode to ->d_hash() and ->d_compare()Linus Torvalds
Instances either don't look at it at all (the majority of cases) or only want it to find the superblock (which can be had as dentry->d_sb). A few cases that want more are actually safe with dentry->d_inode - the only precaution needed is the check that it hadn't been replaced with NULL by rmdir() or by overwriting rename(), which case should be simply treated as cache miss. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert jfsAl Viro
2013-06-05jfs: Update jfs_errorJoe Perches
Use a more current logging style. Add __printf format and argument verification. Remove embedded function names from formats. Add %pf, __builtin_return_address(0) to jfs_error. Add newlines to formats for kernel style consistency. (One format already had an erroneous newline) Coalesce formats and align arguments. Object size reduced ~1KiB. $ size fs/jfs/built-in.o* text data bss dec hex filename 201891 35488 63936 301315 49903 fs/jfs/built-in.o.new 202821 35488 64192 302501 49da5 fs/jfs/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2013-06-05jfs: fix sparse warning in fs/jfs/xattr.cDave Kleikamp
CHECK fs/jfs/xattr.c fs/jfs/xattr.c:1092:5: warning: symbol 'jfs_initxattrs' was not declared. Should it be static? Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2013-05-24fs/jfs: Add check if journaling to disk has been disabled in lbmRead()Gu Zheng
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2013-05-24jfs: Several bugs in jfs_freeze() and jfs_unfreeze()Vahram Martirosyan
The mentioned functions do not pay attention to the error codes returned by the functions updateSuper(), lmLogInit() and lmLogShutdown(). It brings to system crash later when writing to log. The patch adds corresponding code to check and return the error codes and to print correct error messages in case of errors. Found by Linux File System Verification project (linuxtesting.org). Signed-off-by: Vahram Martirosyan <vahram.martirosyan@linuxtesting.org> Reviewed-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-05-08Merge branch 'for-3.10/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core updates from Jens Axboe: - Major bit is Kents prep work for immutable bio vecs. - Stable candidate fix for a scheduling-while-atomic in the queue bypass operation. - Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging discard bios. - Tejuns changes to convert the writeback thread pool to the generic workqueue mechanism. - Runtime PM framework, SCSI patches exists on top of these in James' tree. - A few random fixes. * 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits) relay: move remove_buf_file inside relay_close_buf partitions/efi.c: replace useless kzalloc's by kmalloc's fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read() block: fix max discard sectors limit blkcg: fix "scheduling while atomic" in blk_queue_bypass_start Documentation: cfq-iosched: update documentation help for cfq tunables writeback: expose the bdi_wq workqueue writeback: replace custom worker pool implementation with unbound workqueue writeback: remove unused bdi_pending_list aoe: Fix unitialized var usage bio-integrity: Add explicit field for owner of bip_buf block: Add an explicit bio flag for bios that own their bvec block: Add bio_alloc_pages() block: Convert some code to bio_for_each_segment_all() block: Add bio_for_each_segment_all() bounce: Refactor __blk_queue_bounce to not use bi_io_vec raid1: use bio_copy_data() pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage pktcdvd: use bio_copy_data() block: Add bio_copy_data() ...
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-03Merge tag 'jfs-3.10' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull jfs fixes from David Kleikamp: "A couple fixes for jfs" (What's with the unhelpful pull request "explanations" from fs people today?) * tag 'jfs-3.10' of git://github.com/kleikamp/linux-shaggy: jfs: fix a couple races jfs: avoid undefined behavior from left-shifting by 32 bits
2013-05-01jfs: fix a couple racesDave Kleikamp
This patch fixes races uncovered by xfstests testcase 068. One race is the result of jfs_sync() trying to write a sync point to the journal after it has been frozen (or possibly in the process). Since freezing sync's the journal, there is no need to write a sync point so we simply want to return. The second involves jfs_write_inode() being called on a deleted inode. It calls jfs_flush_journal which is held up by the jfs_commit thread doing the final iput on the same deleted inode, which itself is waiting for the I_SYNC flag to be cleared. jfs_write_inode need not do anything when i_nlink is zero, which is the easy fix. Reported-by: Michael L. Semon <mlsemon35@gmail.com> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2013-03-23block: Remove bi_idx referencesKent Overstreet
For immutable bvecs, all bi_idx usage needs to be audited - so here we're removing all the unnecessary uses. Most of these are places where it was being initialized on a bio that was just allocated, a few others are conversions to standard macros. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-01-29Merge branch 'master' into for-nextJiri Kosina
Conflicts: drivers/devfreq/exynos4_bus.c Sync with Linus' tree to be able to apply patches that are against newer code (mvneta).
2013-01-17fs/jfs: Fix typo in comment : 'how may' -> 'how many'Philippe De Muyter
Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-07jfs: avoid undefined behavior from left-shifting by 32 bitsNickolai Zeldovich
Shifting a 32-bit int by 32 bits is undefined behavior in C, and results in different behavior on different architectures (e.g., x86 and PowerPC). diAlloc() in fs/jfs/jfs_imap.c computes a mask using 0xffffffffu<<(32-bitno), which can left-shift by 32 bits. To avoid unexpected behavior, explicitly check for bitno==0 and use a 0 mask. Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2012-12-20jfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-17jfs: Fix FITRIM argument handlingLukas Czerner
Currently when 'range->start' is beyond the end of file system nothing is done and that fact is ignored, where in fact we should return EINVAL. The same problem is when 'range.len' is smaller than file system block. Fix this by adding check for such conditions and return EINVAL appropriately. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Acked-by: Tino Reichardt <milky-kernel@mcmilk.de> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2012-10-03Merge tag 'jfs-3.7' of git://github.com/kleikamp/linux-shaggyLinus Torvalds
Pull JFS update from Dave Kleikamp: "JFS TRIM support and some minor fixes" * tag 'jfs-3.7' of git://github.com/kleikamp/linux-shaggy: jfs: Fix do_div precision in commit b40c2e66 JFS: use list_move instead of list_del/list_add jfs: Remove obsolete email address fs/jfs: TRIM support for JFS Filesystem
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-21userns: Convert jfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Dave Kleikamp <shaggy@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-18jfs: Fix do_div precision in commit b40c2e66Dave Kleikamp
In a hasty fix to replace a 64-bit division with do_div, I unintentionally assigned the divisor to a 32-bit variable. Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Cc: Tino Reichardt <milky-kernel@mcmilk.de>
2012-09-18userns: Pass a userns parameter into posix_acl_to_xattr and posix_acl_from_xattrEric W. Biederman
- Pass the user namespace the uid and gid values in the xattr are stored in into posix_acl_from_xattr. - Pass the user namespace kuid and kgid values should be converted into when storing uid and gid values in an xattr in posix_acl_to_xattr. - Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to pass in &init_user_ns. In the short term this change is not strictly needed but it makes the code clearer. In the longer term this change is necessary to be able to mount filesystems outside of the initial user namespace that natively store posix acls in the linux xattr format. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-17JFS: use list_move instead of list_del/list_addWei Yongjun
Using list_move() instead of list_del() + list_add(). spatch with a semantic match is used to found this problem. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2012-09-17fs/jfs: TRIM support for JFS FilesystemTino Reichardt
This patch adds support for the two linux interfaces of the discard/TRIM command for SSD devices and sparse/thinly-provisioned LUNs. JFS will support batched discard via FITRIM ioctl and online discard with the discard mount option. Signed-off-by: Tino Reichardt <list-jfs@mcmilk.de> Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
2012-07-23don't expose I_NEW inodes via dentry->d_inodeAl Viro
d_instantiate(dentry, inode); unlock_new_inode(inode); is a bad idea; do it the other way round... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22quota: Move quota syncing to ->sync_fs methodJan Kara
Since the moment writes to quota files are using block device page cache and space for quota structures is reserved at the moment they are first accessed we have no reason to sync quota before inode writeback. In fact this order is now only harmful since quota information can easily change during inode writeback (either because conversion of delayed-allocated extents or simply because of allocation of new blocks for simple filesystems not using page_mkwrite). So move syncing of quota information after writeback of inodes into ->sync_fs method. This way we do not have to use ->quota_sync callback which is primarily intended for use by quotactl syscall anyway and we get rid of calling ->sync_fs() twice unnecessarily. We skip quota syncing for OCFS2 since it does proper quota journalling in all cases (unlike ext3, ext4, and reiserfs which also support legacy non-journalled quotas) and thus there are no dirty quota structures. CC: "Theodore Ts'o" <tytso@mit.edu> CC: Joel Becker <jlbec@evilplan.org> CC: reiserfs-devel@vger.kernel.org Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Dave Kleikamp <shaggy@kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-20jfs: mising cleanup on register_filesystem() failureAl Viro
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
