path: root/fs/libfs.c
2007-05-09fs/libfs.c: >80 columns line break fixRonni Nielsen
Signed-off-by: Ronni Nielsen <theronni@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08inode numbering: change libfs sb creation routines to avoid collisions with ↵Jeff Layton
their root inodes This patch makes it so that simple_fill_super and get_sb_pseudo assign their root inodes to be number 1. It also fixes up a couple of callers of simple_fill_super that were passing in files arrays that had an index at number 1, and adds a warning for any caller that sends in such an array. It would have been nice to have made it so that it wasn't possible to make such a collision, but some callers need to be able to control what inode number their entries get, so I think this is the best that can be done. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] shmem and simple const super_operationsHugh Dickins
shmem's super_operations were missed from the recent const-ification; and simple_fill_super()'s, which can share with get_sb_pseudo()'s. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] fs: fix libfs data leakNick Piggin
simple_prepare_write leaks uninitialised kernel data. This happens because the it leaves an uninitialised "hole" over the part of the page that the write is expected to go to. This is fine, but it then marks the page uptodate, which means a concurrent read can come in and copy the uninitialised memory into userspace before it written to. Fix it by simply marking it uptodate in simple_commit_write instead, after the hole has been filled in. This could theoretically break an fs that uses simple_prepare_write and not simple_commit_write, and that relies on the incorrect simple_prepare_write behaviour. Luckily, none of those exists in the tree. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 2Arjan van de Ven
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] libfs: remove page up-to-date check from simple_readpagePekka J Enberg
Remove the unnecessary PageUptodate check from simple_readpage. The only two callers for ->readpage that don't have explicit PageUptodate check are read_cache_pages and page_cache_read which operate on newly allocated pages which don't have the flag set. [akpm: use the allegedly-faster clear_page(), too] Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] core: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B). Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09VFS: Unexport do_kern_mount() and clean up simple_pin_fs()Trond Myklebust
Replace all module uses with the new vfs_kern_mount() interface, and fix up simple_pin_fs(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: fs/libfs.cIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] debugfs: hard link count wrongVincent Hanquez
Fix incorrect nlink of root inode for filesystems that use simple_fill_super(). Signed-off-by: Vincent Hanquez <vincent@snarc.org> Cc: Greg KH <gregkh@suse.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] shrink dentry structEric Dumazet
Some long time ago, dentry struct was carefully tuned so that on 32 bits UP, sizeof(struct dentry) was exactly 128, ie a power of 2, and a multiple of memory cache lines. Then RCU was added and dentry struct enlarged by two pointers, with nice results for SMP, but not so good on UP, because breaking the above tuning (128 + 8 = 136 bytes) This patch reverts this unwanted side effect, by using an union (d_u), where d_rcu and d_child are placed so that these two fields can share their memory needs. At the time d_free() is called (and d_rcu is really used), d_child is known to be empty and not touched by the dentry freeing. Lockless lookups only access d_name, d_parent, d_lock, d_op, d_flags (so the previous content of d_child is not needed if said dentry was unhashed but still accessed by a CPU because of RCU constraints) As dentry cache easily contains millions of entries, a size reduction is worth the extra complexity of the ugly C union. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Maneesh Soni <maneesh@in.ibm.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Ian Kent <raven@themaw.net> Cc: Paul Jackson <pj@sgi.com> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@epoch.ncsc.mil> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] fix fsync(dir) return value for ram-based filesystemsHugh Dickins
Any filesystem which is using simple_dir_operations will retunr -EINVAL for fsync() on a directory. Make it return zero instead. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] libfs: add simple attribute filesArnd Bergmann
Based on the discussion about spufs attributes, this is my suggestion for a more generic attribute file support that can be used by both debugfs and spufs. Simple attribute files behave similarly to sequential files from a kernel programmers perspective in that a standard set of file operations is provided and only an open operation needs to be written that registers file specific get() and set() functions. These operations are defined as void foo_set(void *data, u64 val); and u64 foo_get(void *data); where data is the inode->u.generic_ip pointer of the file and the operations just need to make send of that pointer. The infrastructure makes sure this works correctly with concurrent access and partial read calls. A macro named DEFINE_SIMPLE_ATTRIBUTE is provided to further simplify using the attributes. This patch already contains the changes for debugfs to use attributes for its internal file operations. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
