commit fbabfd0f4ee2e8847bf56edf481249ad1bb8c44d upstream.
To ensure it is safe to mount proc and sysfs I need to check if
filesystems that are mounted on top of them are mounted on truly empty
directories. Given that some directories can gain entries over time,
knowing that a directory is empty right now is insufficient.
Therefore add supporting infrastructure for permantently empty
directories that proc and sysfs can use when they create mount points
for filesystems and fs_fully_visible can use to test for permanently
empty directories to ensure that nothing will be gained by mounting a
fresh copy of proc or sysfs.
library helpers called by filesystem drivers on their own inodes
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Add a new mount option which enables a new "lazytime" mode. This mode
causes atime, mtime, and ctime updates to only be made to the
in-memory version of the inode. The on-disk times will only get
updated when (a) if the inode needs to be updated for some non-time
related change, (b) if userspace calls fsync(), syncfs() or sync(), or
(c) just before an undeleted inode is evicted from memory.
This is OK according to POSIX because there are no guarantees after a
crash unless userspace explicitly requests via a fsync(2) call.
For workloads which feature a large number of random write to a
preallocated file, the lazytime mount option significantly reduces
writes to the inode table. The repeated 4k writes to a single block
will result in undesirable stress on flash devices and SMR disk
drives. Even on conventional HDD's, the repeated writes to the inode
table block will trigger Adjacent Track Interference (ATI) remediation
latencies, which very negatively impact long tail latencies --- which
is a very big deal for web serving tiers (for example).
Google-Bug-Id: 18297052
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
In later patches, we're going to add a new lock_manager_operation to
finish setting up the lease while still holding the i_lock. To do
this, we'll need to pass a little bit of info in the fcntl setlease
case (primarily an fasync structure). Plumb the extra pointer into
there in advance of that.
We declare this pointer as a void ** to make it clear that this is
private info, and that the caller isn't required to set this unless
the lm_setup specifically requires it.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
GFS2 and NFS have setlease routines that always just return -EINVAL.
Turn that into a generic routine that can live in fs/libfs.c.
Cc: <linux-nfs@vger.kernel.org>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: <cluster-devel@redhat.com>
Acked-by: Trond Myklebust <trond.myklebust@primarydata.com>
Description by Jan Kara:
"A lot of older filesystems don't properly flush volatile disk caches
on fsync(2) which can lead to loss of fsynced data after power failure.
This patch makes generic_file_fsync() issue proper cache flush to fix the
problem. Sysadmin can use /sys/devices/.../cache_type to tell the system
it should not send the cache flush."
[akpm@linux-foundation.org: nuke ifdef]
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Jan Kara <jack@suse.cz>
Suggested-by: Christoph Hellwig <hch@infradead.org>
Cc: Jan Kara <jack@suse.cz>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Rename simple_delete_dentry() to always_delete_dentry() and export it.
Export simple_dentry_operations, while we are at it, and get rid of
their duplicates
duplicated to hell and back...
new helpers - dir_emit_dot(file, ctx, dentry), dir_emit_dotdot(file, ctx),
dir_emit_dots(file, ctx).
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
But the kernel decided to call it "origin" instead. Fix most of the
sites.
Wrong function name in the kerneldoc description of generic_fh_to_parent().
Signed-off-by: Yanchuan Nian <ycnian@gmail.com>
Pass mount flags to sget() so that it can use them in initialising a new
superblock before the set function is called. They could also be passed to the
compare function.
Just the flags; only NFS cares even about that, but there are
legitimate uses for such argument. And getting rid of that
completely would require splitting ->lookup() into a couple
of methods (at least), so let's leave that alone for now...
This allows comparing hash and len in one operation on 64-bit
architectures. Right now only __d_lookup_rcu() takes advantage of this,
since that is the case we care most about.
The use of anonymous struct/unions hides the alternate 64-bit approach
from most users, the exception being a few cases where we initialize a
'struct qstr' with a static initializer. This makes the problematic
cases use a new QSTR_INIT() helper function for that (but initializing
just the name pointer with a "{ .name = xyzzy }" initializer remains
valid, as does just copying another qstr structure).
d_genocide() does _not_ evict dentries; it just removes extra ref
pinning each of those. Normally it's followed by shrinking the
tree (it's done just before generic_shutdown_super() by kill_litter_super()),
but in case of simple_fill_super() nothing of that kind will follow.
Just do shrink_dcache_parent() manually.
debugfs and a few other drivers use an open-coded version of
simple_open() to pass a pointer from the file to the read/write file
ops. Add support for this simple case to libfs so that we can remove
the many duplicate copies of this simple function.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export
kill_bdev as well, so brd doesn't have to open code it. Reduce
buffer_head.h requirement accordingly.
Removed a rather large comment from invalidate_bdev, as it looked a bit
obsolete to bother moving. The small comment replacing it says enough.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
put dentry if inode allocation failed, d_genocide() cannot release it
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
On ramfs and other simple_rename() users IN_DELETE_SELF is not generated
for victim of overwriting rename() if it's is a directory. Works on
most of the local filesystems and really trivial to fix...
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
New helper (non-exported, fs/internal.h-only): __d_alloc(sb, name).
Allocates dentry, sets its ->d_sb to given superblock and sets
->d_op accordingly. Old d_alloc(NULL, name) callers are converted
to that (all of them know what superblock they want). d_alloc()
itself is left only for parent != NULl case; uses __d_alloc(),
inserts result into the list of parent's children.
Note that now ->d_sb is assign-once and never NULL *and*
->d_parent is never NULL either.
Assume that /sys/kernel/debug/dummy64 is debugfs file created by
debugfs_create_x64().
# cd /sys/kernel/debug
# echo 0x1234567812345678 > dummy64
# cat dummy64
0x0000000012345678
# echo 0x80000000 > dummy64
# cat dummy64
0xffffffff80000000
A value larger than INT_MAX cannot be written to the debugfs file created
by debugfs_create_u64 or debugfs_create_x64 on 32bit machine. Because
simple_attr_write() uses simple_strtol() for the conversion.
To fix this, use simple_strtoll() instead.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
dcache_lock no longer protects anything. remove it.
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't
using dcache_lock for these anyway (eg. using i_mutex).
Note: if we change the locking rule in future so that ->d_child protection is
provided only with ->d_parent->d_lock, it may allow us to reduce some locking.
But it would be an exception to an otherwise regular locking scheme, so we'd
have to see some good results. Probably not worthwhile.
Protect d_unhashed(dentry) condition with d_lock. This means keeping
DCACHE_UNHASHED bit in synch with hash manipulations.
Change d_delete from a dentry deletion notification to a dentry caching
advise, more like ->drop_inode. Require it to be constant and idempotent,
and not take d_lock. This is how all existing filesystems use the callback
anyway.
This makes fine grained dentry locking of dput and dentry lru scanning
much simpler.
Clones an existing reference to inode; caller must already hold one.
Add a new helper to write out the inode using the writeback code,
that is including the correct dirty bit and list manipulation. A few
of filesystems already opencode this, and a lot of others should be
using it instead of using write_inode_now which also writes out the
data.
generic_check_addressable() erroneously shifts pages down by a block
factor when it should be shifting up. To prevent overflow, we shift
blocks down to pages.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
As part of adding support for OCFS2 to mount huge volumes, we need to
check that the sector_t and page cache of the system are capable of
addressing the entire volume.
An identical check already appears in ext3 and ext4. This patch moves
the addressability check into its own function in fs/libfs.c and
modifies ext3 and ext4 to invoke it.
[Edited to -EINVAL instead of BUG_ON() for bad blocksize_bits -- Joel]
Signed-off-by: Patrick LoPresti <lopresti@gmail.com>
Cc: linux-ext4@vger.kernel.org
Acked-by: Andreas Dilger <adilger@dilger.ca>
Make sure we check the truncate constraints early on in ->setattr by adding
those checks to inode_change_ok. Also clean up and document inode_change_ok
to make this obvious.
As a fallout we don't have to call inode_newsize_ok from simple_setsize and
simplify it down to a truncate_setsize which doesn't return an error. This
simplifies a lot of setattr implementations and means we use truncate_setsize
almost everywhere. Get rid of fat_setsize now that it's trivial and mark
ext2_setsize static to make the calling convention obvious.
Keep the inode_newsize_ok in vmtruncate for now as all callers need an
audit for its removal anyway.
Note: setattr code in ecryptfs doesn't call inode_change_ok at all and
needs a deeper audit, but that is left for later.
With the new truncate sequence every filesystem that wants to support file
size changes on disk needs to implement its own ->setattr. So instead
of calling inode_setattr which supports size changes call into a simple
method that doesn't support this. simple_setattr is almost what we
want except that it does not mark the inode dirty after changes. Given
that marking the inode dirty is a no-op for the simple in-memory filesystems
that use simple_setattr currently just add the mark_inode_dirty call.
Also add a WARN_ON for the presence of a truncate method to simple_setattr
to catch new instances of it during the transition period.
Despite its name it's now a generic implementation of ->setattr, but
rather a helper to copy attributes from a struct iattr to the inode.
Rename it to setattr_copy to reflect this fact.
It's used to superblock ->s_magic, which is unsigned long.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Reviewed-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
CC: stable@kernel.org
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than
setattr > vmtruncate > truncate, have filesystems call their truncate sequence
from ->setattr if filesystem specific operations are required. vmtruncate is
deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced
previously should be used.
simple_setattr is introduced for simple in-ram filesystems to implement
the new truncate sequence. Eventually all filesystems should be converted
to implement a setattr, and the default code in notify_change should go
away.
simple_setsize is also introduced to perform just the ATTR_SIZE portion
of simple_setattr (ie. changing i_size and trimming pagecache).
To implement the new truncate sequence:
- filesystem specific manipulations (eg freeing blocks) must be done in
the setattr method rather than ->truncate.
- vmtruncate can not be used by core code to trim blocks past i_size in
the event of write failure after allocation, so this must be performed
in the fs code.
- convert usage of helpers block_write_begin, nobh_write_begin,
cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed
variants. These avoid calling vmtruncate to trim blocks (see previous).
- inode_setattr should not be used. generic_setattr is a new function
to be used to copy simple attributes into the generic inode.
- make use of the better opportunity to handle errors with the new sequence.
Big problem with the previous calling sequence: the filesystem is not called
until i_size has already changed. This means it is not allowed to fail the
call, and also it does not know what the previous i_size was. Also, generic
code calling vmtruncate to truncate allocated blocks in case of error had
no good way to return a meaningful error (or, for example, atomically handle
block deallocation).
We don't name our generic fsync implementations very well currently.
The no-op implementation for in-memory filesystems currently is called
simple_sync_file which doesn't make too much sense to start with,
the the generic one for simple filesystems is called simple_fsync
which can lead to some confusion.
This patch renames the generic file fsync method to generic_file_fsync
to match the other generic_file_* routines it is supposed to be used
with, and the no-op implementation to noop_fsync to make it obvious
what to expect. In addition add some documentation for both methods.
