path: root/fs/lockd
2006-11-06[PATCH] sysctl: implement CTL_UNNUMBEREDEric W. Biederman
This patch takes the CTL_UNNUMBERD concept from NFS and makes it available to all new sysctl users. At the same time the sysctl binary interface maintenance documentation is updated to mention and to describe what is needed to successfully maintain the sysctl binary interface. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] lockd endianness annotationsAl Viro
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] fix svc_procfunc declarationAl Viro
svc_procfunc instances return __be32, not int Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] knfsd: Allow lockd to drop replies as appropriateNeilBrown
It is possible for the ->fopen callback from lockd into nfsd to find that an answer cannot be given straight away (an upcall is needed) and so the request has to be 'dropped', to be retried later. That error status is not currently propagated back. So: Change nlm_fopen to return nlm error codes (rather than a private protocol) and define a new nlm_drop_reply code. Cause nlm_drop_reply to cause the rpc request to get rpc_drop_reply when this error comes back. Cause svc_process to drop a request which returns a status of rpc_drop_reply. [akpm@osdl.org: fix warning storm] Cc: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] knfsd: Fix bug in recent lockd patches that can cause reclaim to failNeilBrown
When an nfs server shuts down, lockd needs to release all the locks even though the client still holds them. It should therefore not 'unmonitor' the clients, so that the files in nfs/sm will still be there when the nfs server restarts, so that those clients will be told to reclaim their locks. However the hosts are fully unmonitored, so statd may well remove the files. lockd has a test for 'sm_sticky' and avoid the unmonitor call if it is set, but it is currently not set. So set it when tearing down lockd. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: fix refount on nsmNeilBrown
If nlm_lookup_host finds what it is looking for it exits with an extra reference on the matching 'nsm' structure. So don't actually count the reference until we are (fairly) sure it is going to be used. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] Convert lockd to use the newer mutex instead of the older semaphoreNeil Brown
Both the (recently introduces) nsm_sema and the older f_sema are converted over. Cc: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: fix use of h_nextrebindOlaf Kirch
nlmclnt_recovery would try to force a portmap rebind by setting host->h_nextrebind to 0. The right thing to do here is to set it to the current time. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: export nsm_local_state to user space via sysctlOlaf Kirch
Every NLM call includes the client's NSM state. Currently, the Linux client always reports 0 - which seems not to cause any problems, but is not what the protocol says. This patch exposes the kernel's internal variable to user space via a sysctl, which can be set at system boot time by statd. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: match GRANTED_RES replies using cookiesOlaf Kirch
When we send a GRANTED_MSG call, we current copy the NLM cookie provided in the original LOCK call - because in 1996, some broken clients seemed to rely on this bug. However, this means the cookies are not unique, so that when the client's GRANTED_RES message comes back, we cannot simply match it based on the cookie, but have to use the client's IP address in addition. Which breaks when you have a multi-homed NFS client. The X/Open spec explicitly mentions that clients should not expect the same cookie; so one may hope that any clients that were broken in 1996 have either been fixed or rendered obsolete. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: make nlmclnt_next_cookie SMP safeOlaf Kirch
The way we incremented the NLM cookie in nlmclnt_next_cookie was not thread safe. This patch changes the counter to an atomic_t Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: optionally use hostnames for identifying peersOlaf Kirch
This patch adds the nsm_use_hostnames sysctl and module param. If set, lockd will use the client's name (as given in the NLM arguments) to find the NSM handle. This makes recovery work when the NFS peer is multi-homed, and the reboot notification arrives from a different IP than the original lock calls. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: simplify nlmsvc_invalidate_allNeilBrown
As a result of previous patches, the loop in nlmsvc_invalidate_all just sets h_expires for all client/hosts to 0 (though does it in a very complicated way). This was possibly meant to trigger early garbage collection but half the time '0' is in the future and so it infact delays garbage collection. Pre-aging the 'hosts' is not really needed at this point anyway so we throw out the loop and nlm_find_client which is no longer needed. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Add nlm_destroy_hostOlaf Kirch
This patch moves the host destruction code out of nlm_host_gc into a function of its own. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make nlm_traverse_* more flexibleOlaf Kirch
This patch makes nlm_traverse{locks,blocks,shares} and friends use a function pointer rather than a "action" enum. This function pointer is given two nlm_hosts (one given by the caller, the other taken from the lock/block/share currently visited), and is free to do with them as it wants. If it returns a non-zero value, the lockd/block/share is released. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: change nlm_file to use a hlistOlaf Kirch
This changes struct nlm_file and the nlm_files hash table to use a hlist instead of the home-grown lists. This allows us to remove f_hash which was only used to find the right hash chain to delete an entry from. It also increases the size of the nlm_files hash table from 32 to 128. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Change list of blocked list to list_nodeOlaf Kirch
This patch changes the nlm_blocked list to use a list_node instead of homegrown linked list handling. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make the hash chains use a hlist_nodeOlaf Kirch
Get rid of the home-grown singly linked lists for the nlm_host hash table. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make the nsm upcalls use the nsm_handleOlaf Kirch
This converts the statd upcalls to use the nsm_handle This means that we only register each host once with statd, rather than registering each host/vers/protocol triple. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Make nlm_host_rebooted use the nsm_handleOlaf Kirch
This patch makes the SM_NOTIFY handling understand and use the nsm_handle. To make it a bit clear what is happening: nlmclent_prepare_reclaim and nlmclnt_finish_reclaim get open-coded into 'reclaimer' The result is tidied up. Then some of that functionality is moved out into nlm_host_rebooted (which calls nlmclnt_recovery which starts a thread which runs reclaimer). Also host_rebooted now finds an nsm_handle rather than a host, then then iterates over all hosts and deals with each host that shares that nsm_handle. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: misc minor fixes, indentation changesOlaf Kirch
cleans up some code in lockd/host.c, fixes an error printk and makes it a fatal BUG if nlmsvc_free_host_resources fails. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: introduce nsm_handleOlaf Kirch
This patch introduces the nsm_handle, which is shared by all nlm_host objects referring to the same client. With this patch applied, all nlm_hosts from the same address will share the same nsm_handle. A future patch will add sharing by name. Note: this patch changes h_name so that it is no longer guaranteed to be an IP address of the host. When the host represents an NFS server, h_name will be the name passed in the mount call. When the host represents a client, h_name will be the name presented in the lock request received from the client. A h_name is only used for printing informational messages, this change should not be significant. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: when looking up a lockd host, pass hostname & lengthOlaf Kirch
This patch adds the peer's hostname (and name length) to all calls to nlm*_lookup_host functions. A subsequent patch will make use of these (is requested by a sysctl). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: consolidate common code for statd->lockd notificationOlaf Kirch
Common code from nlm4svc_proc_sm_notify and nlmsvc_proc_sm_notify is moved into a new nlm_host_rebooted. This is in preparation of a patch that will change the reboot notification handling entirely. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: hide use of lockd's h_monitored flagOlaf Kirch
This patch moves all checks of the h_monitored flag into the nsm_monitor/unmonitor functions. A subsequent patch will replace the mechanism by which we mark a host as being monitored. There is still one occurence of h_monitored outside of mon.c and that is in clntlock.c where we respond to a reboot. The subsequent patch will modify this too. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: Correctly handle error condition from lockd_upNeilBrown
If lockd_up fails - what should we expect? Do we have to later call lockd_down? Well the nfs client thinks "no", the nfs server thinks "yes". lockd thinks "yes". The only answer that really makes sense is "no" !! So: Make lockd_up only increment nlmsvc_users on success. Make nfsd handle errors from lockd_up properly. Make sure lockd_up(0) never fails when lockd is running so that the 'reclaimer' call to lockd_up doesn't need to be error checked. Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: Move makesock failed warning into make_socks.NeilBrown
Thus it is printed for any path that leads to failure (make_socks is called from two places). Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: Drop 'serv' option to svc_recv and svc_processNeilBrown
It isn't needed as it is available in rqstp->rq_server, and dropping it allows some local vars to be dropped. [akpm@osdl.org: build fix] Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: be more selective in which sockets lockd listens onNeilBrown
Currently lockd listens on UDP always, and TCP if CONFIG_NFSD_TCP is set. However as lockd performs services of the client as well, this is a problem. If CONFIG_NfSD_TCP is not set, and a tcp mount is used, the server will not be able to call back to lockd. So: - add an option to lockd_up saying which protocol is needed - Always open sockets for which an explicit port was given, otherwise only open a socket of the type required - Change nfsd to do one lockd_up per socket rather than one per thread. This - removes the dependancy on CONFIG_NFSD_TCP - means that lockd may open sockets other than at startup - means that lockd will *not* listen on UDP if the only mounts are TCP mount (and nfsd hasn't started). The latter is the only one that concerns me at all - I don't know if this might be a problem with some servers. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: add a callback for when last rpc thread finishesNeilBrown
nfsd has some cleanup that it wants to do when the last thread exits, and there will shortly be some more. So collect this all into one place and define a callback for an rpc service to call when the service is about to be destroyed. [akpm@osdl.org: cleanups, build fix] Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] add newline to nfs dprintkMartin Bligh
Add missing \n to dprintk Signed-off-by: Martin Bligh <mbligh@google.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22LOCKD: Convert to use new rpc_create() APIChuck Lever
Replace xprt_create_proto/rpc_create_client with new rpc_create() interface in the Network Lock Manager. Note that the semantics of NLM transports is now "hard" instead of "soft" to provide a better guarantee that lock requests will get to the server. Test plan: Repeated runs of Connectathon locking suite. Check network trace to ensure NLM requests are working correctly. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: Clean-up after previous patches.Chuck Lever
Remove some unused macros related to accessing an RPC peer address Test plan: Compile kernel with CONFIG_NFS option enabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22LOCKD: Teach lockd to use the new rpc_peeraddr() APIChuck Lever
Hide the details of how the RPC client stores remote peer addresses from the Network Lock Manager. Test plan: Destructive testing (unplugging the network temporarily). Connectathon with UDP and TCP. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-08-24LOCKD: Fix a deadlock in nlm_traverse_files()Trond Myklebust
nlm_traverse_files() is not allowed to hold the nlm_file_mutex while calling nlm_inspect file, since it may end up calling nlm_release_file() when releaseing the blocks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from e558d3cde986e04f68afe8c790ad68ef4b94587a commit)
2006-08-03NLM/lockd: remove b_doneJ. Bruce Fields
We never actually set the b_done field any more; it's always zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from af8412d4283ef91356e65e0ed9b025b376aebded commit)
2006-07-05NLM,NFSv4: Wait on local locks before we put RPC calls on the wireTrond Myklebust
Use FL_ACCESS flag to test and/or wait for local locks before we try requesting a lock from the server Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-07-05NLM,NFSv4: Don't put UNLOCK requests on the wire unless we hold a lockTrond Myklebust
Use the new behaviour of {flock,posix}_file_lock(F_UNLCK) to determine if we held a lock, and only send the RPC request to the server if this was the case. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NLM: Fix reclaim racesTrond Myklebust
Currently it is possible for a task to remove its locks at the same time as the NLM recovery thread is trying to recover them. This quickly leads to an Oops. Protect the locks using an rw semaphore while they are being recovered. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NLM: sem to mutex conversionTrond Myklebust
2006-04-19NFS: make 2 functions staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-26[PATCH] sem2mutex: fs/Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Cc: Robert Love <rml@tech9.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (103 commits) SUNRPC,RPCSEC_GSS: spkm3--fix config dependencies SUNRPC,RPCSEC_GSS: spkm3: import contexts using NID_cast5_cbc LOCKD: Make nlmsvc_traverse_shares return void LOCKD: nlmsvc_traverse_blocks return is unused SUNRPC,RPCSEC_GSS: fix krb5 sequence numbers. NFSv4: Dont list system.nfs4_acl for filesystems that don't support it. SUNRPC,RPCSEC_GSS: remove unnecessary kmalloc of a checksum SUNRPC: Ensure rpc_call_async() always calls tk_ops->rpc_release() SUNRPC: Fix memory barriers for req->rq_received NFS: Fix a race in nfs_sync_inode() NFS: Clean up nfs_flush_list() NFS: Fix a race with PG_private and nfs_release_page() NFSv4: Ensure the callback daemon flushes signals SUNRPC: Fix a 'Busy inodes' error in rpc_pipefs NFS, NLM: Allow blocking locks to respect signals NFS: Make nfs_fhget() return appropriate error values NFSv4: Fix an oops in nfs4_fill_super lockd: blocks should hold a reference to the nlm_file NFSv4: SETCLIENTID_CONFIRM should handle NFS4ERR_DELAY/NFS4ERR_RESOURCE NFSv4: Send the delegation stateid for SETATTR calls ...
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20LOCKD: Make nlmsvc_traverse_shares return voidJ. Bruce Fields
The nlmsvc_traverse_shares return value is always zero, hence useless. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20LOCKD: nlmsvc_traverse_blocks return is unusedJ. Bruce Fields
Note that we never return non-zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
