Currently, nlmclnt_lock will break out of the for(;;) loop when
the reclaimer wakes up the blocking lock thread by setting
nlm_lck_denied_grace_period. This causes the lock request to fail
with an ENOLCK error.
The intention was always to ensure that we resend the lock request
after the grace period has expired.
Reported-by: Wangyuan Zhang <Wangyuan.Zhang@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: stable@vger.kernel.org
Even though nlmclnt_reclaim() is only one call into the stack frame,
928 bytes on the stack seems like a lot. Recode to dynamically
allocate the request structure once from within the reclaimer task,
then pass this pointer into nlmclnt_reclaim() for reuse on
subsequent calls.
smatch analysis:
fs/lockd/clntproc.c:620 nlmclnt_reclaim() warn: 'reqst' puts
928 bytes on stack
Also remove redundant assignment of 0 after memset.
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
addr.h
These routines are used by server and client code, so having them in a
separate header would be best.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
- Convert the non-trivial ones into WARN_ON_ONCE().
- Remove the trivial refcounting BUGs
- Offset bound checks are done in the NFS client code.
- So are filehandle size checks
- The cookie length is a constant
- The utsname()->nodename is already bounded
The current code is clearing it in all cases _except_ when zero.
Reported-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Commit e9406db20fecbfcab646bad157b4cfdc7cadddfb (lockd: per-net
NSM client creation and destruction helpers introduced) contains
a nasty race on initialisation of the per-net NSM client because
it doesn't check whether or not the client is set after grabbing
the nsm_create_mutex.
Reported-by: Nix <nix@esperi.org.uk>
If the filehandle is stale, or open access is denied for some reason,
nlm_fopen() may return one of the NLMv4-specific error codes nlm4_stale_fh
or nlm4_failed. These get passed right through nlm_lookup_file(),
and so when nlmsvc_retrieve_args() calls the latter, it needs to filter
the result through the cast_status() machinery.
Failure to do so, will trigger the BUG_ON() in encode_nlm_stat...
Reported-by: Larry McVoy <lm@bitmover.com>
Cc: stable@kernel.org
Pull nfsd update from J Bruce Fields:
"Another relatively quiet cycle. There was some progress on my
remaining 4.1 todo's, but a couple of them were just of the form
"check that we do X correctly", so didn't have much affect on the
code.
Other than that, a bunch of cleanup and some bugfixes (including an
annoying NFSv4.0 state leak and a busy-loop in the server that could
cause it to peg the CPU without making progress)."
* 'for-3.7' of git://linux-nfs.org/~bfields/linux: (46 commits)
UAPI: (Scripted) Disintegrate include/linux/sunrpc
UAPI: (Scripted) Disintegrate include/linux/nfsd
nfsd4: don't allow reclaims of expired clients
nfsd4: remove redundant callback probe
nfsd4: expire old client earlier
nfsd4: separate session allocation and initialization
nfsd4: clean up session allocation
nfsd4: minor free_session cleanup
nfsd4: new_conn_from_crses should only allocate
nfsd4: separate connection allocation and initialization
nfsd4: reject bad forechannel attrs earlier
nfsd4: enforce per-client sessions/no-sessions distinction
nfsd4: set cl_minorversion at create time
nfsd4: don't pin clientids to pseudoflavors
nfsd4: fix bind_conn_to_session xdr comment
nfsd4: cast readlink() bug argument
NFSD: pass null terminated buf to kstrtouint()
nfsd: remove duplicate init in nfsd4_cb_recall
nfsd4: eliminate redundant nfs4_free_stateid
fs/nfsd/nfs4idmap.c: adjust inconsistent IS_ERR and PTR_ERR
Pull NFS client updates from Trond Myklebust:
"Features include:
- Remove CONFIG_EXPERIMENTAL dependency from NFSv4.1
Aside from the issues discussed at the LKS, distros are shipping
NFSv4.1 with all the trimmings.
- Fix fdatasync()/fsync() for the corner case of a server reboot.
- NFSv4 OPEN access fix: finally distinguish correctly between
open-for-read and open-for-execute permissions in all situations.
- Ensure that the TCP socket is closed when we're in CLOSE_WAIT
- More idmapper bugfixes
- Lots of pNFS bugfixes and cleanups to remove unnecessary state and
make the code easier to read.
- In cases where a pNFS read or write fails, allow the client to
resume trying layoutgets after two minutes of read/write-
through-mds.
- More net namespace fixes to the NFSv4 callback code.
- More net namespace fixes to the NFSv3 locking code.
- More NFSv4 migration preparatory patches.
Including patches to detect network trunking in both NFSv4 and
NFSv4.1
- pNFS block updates to optimise LAYOUTGET calls."
* tag 'nfs-for-3.7-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (113 commits)
pnfsblock: cleanup nfs4_blkdev_get
NFS41: send real read size in layoutget
NFS41: send real write size in layoutget
NFS: track direct IO left bytes
NFSv4.1: Cleanup ugliness in pnfs_layoutgets_blocked()
NFSv4.1: Ensure that the layout sequence id stays 'close' to the current
NFSv4.1: Deal with seqid wraparound in the pNFS return-on-close code
NFSv4 set open access operation call flag in nfs4_init_opendata_res
NFSv4.1: Remove the dependency on CONFIG_EXPERIMENTAL
NFSv4 reduce attribute requests for open reclaim
NFSv4: nfs4_open_done first must check that GETATTR decoded a file type
NFSv4.1: Deal with wraparound when updating the layout "barrier" seqid
NFSv4.1: Deal with wraparound issues when updating the layout stateid
NFSv4.1: Always set the layout stateid if this is the first layoutget
NFSv4.1: Fix another refcount issue in pnfs_find_alloc_layout
NFSv4: don't put ACCESS in OPEN compound if O_EXCL
NFSv4: don't check MAY_WRITE access bit in OPEN
NFS: Set key construction data for the legacy upcall
NFSv4.1: don't do two EXCHANGE_IDs on mount
NFS: nfs41_walk_client_list(): re-lock before iterating
This is to complete part of the Userspace API (UAPI) disintegration for which
the preparatory patches were pulled recently. After these patches, userspace
headers will be segregated into:
include/uapi/linux/.../foo.h
for the userspace interface stuff, and:
include/linux/.../foo.h
for the strictly kernel internal stuff.
NSM RPC client can be required on NFSv3 umount, when child reaper is dying
(and destroying it's mount namespace). It means, that current nsproxy is set
to NULL already, but creation of RPC client requires UTS namespace for gaining
hostname string.
This patch creates reference-counted per-net NSM client on first monitor
request and destroys it after last unmonitor request.
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Cc: <stable@vger.kernel.org>
Taking hostname from uts namespace if not safe, because this cuold be
performind during umount operation on child reaper death. And in this case
current->nsproxy is NULL already.
NSM RPC client can be required on NFSv3 umount, when child reaper is dying (and
destroying it's mount namespace). It means, that current nsproxy is set to
hostname string.
This patch introduces reference counted NFS RPC clients creation and
destruction helpers (similar to RPCBIND RPC clients).
we need to grab mutex before the reference counter reaches 0
svc_recv() returns only -EINTR or -EAGAIN. If we really want to worry
about the case where it has a bug that causes it to return something
else, we could stick a WARN() in svc_recv. But it's silly to require
every caller to have all this boilerplate to handle that case.
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
It's used both for client and server hosts; we can't do nlmclnt_release_host()
on failure exits, since the host might need nlmsvc_release_host(), with BUG_ON()
for calling the wrong one. Makes life simpler for callers, actually...
Passed network namespace replaced hard-coded init_net
This is a cleanup patch - makes code looks simplier.
It replaces widely used rqstp->rq_xprt->xpt_net by introduced SVC_NET(rqstp).
Just a small cleanup.
This patch introduces moves nrhosts in per-net data.
It also adds kernel warning to nlm_shutdown_hosts_net() about remaining hosts
in specified network namespace context.
This patch moves next_gc to per-net data.
Note: passed network can be NULL (when Lockd kthread is exiting of Lockd
module is removing).
This is required for per-network NLM shutdown and cleanup.
This patch passes init_net for a while.
Pull the rest of the nfsd commits from Bruce Fields:
"... and then I cherry-picked the remainder of the patches from the
head of my previous branch"
This is the rest of the original nfsd branch, rebased without the
delegation stuff that I thought really needed to be redone.
I don't like rebasing things like this in general, but in this situation
this was the lesser of two evils.
* 'for-3.5' of git://linux-nfs.org/~bfields/linux: (50 commits)
nfsd4: fix, consolidate client_has_state
nfsd4: don't remove rebooted client record until confirmation
nfsd4: remove some dprintk's and a comment
nfsd4: return "real" sequence id in confirmed case
nfsd4: fix exchange_id to return confirm flag
nfsd4: clarify that renewing expired client is a bug
nfsd4: simpler ordering of setclientid_confirm checks
nfsd4: setclientid: remove pointless assignment
nfsd4: fix error return in non-matching-creds case
nfsd4: fix setclientid_confirm same_cred check
nfsd4: merge 3 setclientid cases to 2
nfsd4: pull out common code from setclientid cases
nfsd4: merge last two setclientid cases
nfsd4: setclientid/confirm comment cleanup
nfsd4: setclientid remove unnecessary terms from a logical expression
nfsd4: move rq_flavor into svc_cred
nfsd4: stricter cred comparison for setclientid/exchange_id
nfsd4: move principal name into svc_cred
nfsd4: allow removing clients not holding state
nfsd4: rearrange exchange_id logic to simplify
Pull nfsd update from Bruce Fields.
* 'for-3.5-take-2' of git://linux-nfs.org/~bfields/linux: (23 commits)
nfsd: trivial: use SEEK_SET instead of 0 in vfs_llseek
SUNRPC: split upcall function to extract reusable parts
nfsd: allocate id-to-name and name-to-id caches in per-net operations.
nfsd: make name-to-id cache allocated per network namespace context
nfsd: make id-to-name cache allocated per network namespace context
nfsd: pass network context to idmap init/exit functions
nfsd: allocate export and expkey caches in per-net operations.
nfsd: make expkey cache allocated per network namespace context
nfsd: make export cache allocated per network namespace context
nfsd: pass pointer to export cache down to stack wherever possible.
nfsd: pass network context to export caches init/shutdown routines
Lockd: pass network namespace to creation and destruction routines
NFSd: remove hard-coded dereferences to name-to-id and id-to-name caches
nfsd: pass pointer to expkey cache down to stack wherever possible.
nfsd: use hash table from cache detail in nfsd export seq ops
nfsd: pass svc_export_cache pointer as private data to "exports" seq file ops
nfsd: use exp_put() for svc_export_cache put
nfsd: use cache detail pointer from svc_export structure on cache put
nfsd: add link to owner cache detail to svc_export structure
nfsd: use passed cache_detail pointer expkey_parse()
This is just a code move, which from my POV makes the code look better.
I.e. now on start we have 3 different stages:
1) Service creation.
2) Service per-net data allocation.
3) Service start.
This function creates service if it doesn't exist, or increases usage
counter if it does, and returns a pointer to it. The usage counter will
be droppepd by svc_destroy() later in lockd_up().
This patch also replaces svc_rpcb_setup() with svc_bind().
The idea is to separate service destruction and per-net operations,
because these are two different things and the mix looks ugly.
Notes:
1) For NFS server this patch looks ugly (sorry for that). But these
place will be rewritten soon during NFSd containerization.
2) LockD per-net counter increase int lockd_up() was moved prior to
make_socks() to make lockd_down_net() call safe in case of error.
This new routine is responsible for service registration in a specified
network context.
The idea is to separate service creation from per-net operations.
Note also: since registering service with svc_bind() can fail, the
service will be destroyed and during destruction it will try to
unregister itself from rpcbind. In this case unregistration has to be
skipped.
comparing be32 values for < is not doing the right thing...
v2: dereference of most probably already released nlm_host removed in
nlmclnt_done() and reclaimer().
These routines are called from locks reclaimer() kernel thread. This thread
works in "init_net" network context and currently relays on persence on lockd
thread and it's per-net resources. Thus lockd_up() and lockd_down() can't relay
on current network context. So let's pass corrent one into them.
The nfs containerization work is a prerequisite for Jeff Layton's reboot
recovery rework.
Stephen Rothwell reports:
net/sunrpc/rpcb_clnt.c: In function 'rpcb_enc_mapping':
net/sunrpc/rpcb_clnt.c:820:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_dec_getport':
net/sunrpc/rpcb_clnt.c:837:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_dec_set':
net/sunrpc/rpcb_clnt.c:860:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_enc_getaddr':
net/sunrpc/rpcb_clnt.c:892:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_dec_getaddr':
net/sunrpc/rpcb_clnt.c:914:19: warning: unused variable 'task' [-Wunused-variable]
fs/lockd/svclock.c:49:20: warning: 'nlmdbg_cookie2a' declared 'static' but never defined [-Wunused-function]
If you try to set grace_period or timeout via a module parameter
to lockd, and do this on a big-endian machine where
sizeof(int) != sizeof(unsigned long)
it won't work. This number given will be effectively shifted right
by the difference in those two sizes.
So cast kp->arg properly to get correct result.
Signed-off-by: NeilBrown <neilb@suse.de>
Lockd now managed in network namespace context. And this patch introduces
network namespace related NLM hosts shutdown in case of releasing per-net Lockd
resources.
NLM host is network namespace aware now.
So NSM have to take it into account.
