path: root/fs/locks.c
2013-02-22new helper: file_inode(file)Al Viro
2012-10-09nfs: disintegrate UAPI for nfsJ. Bruce Fields
This is to complete part of the Userspace API (UAPI) disintegration for which the preparatory patches were pulled recently. After these patches, userspace headers will be segregated into: include/uapi/linux/.../foo.h for the userspace interface stuff, and: include/linux/.../foo.h for the strictly kernel internal stuff. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-08-20vfs: don't treat fl_type as a bitmapJeff Layton
The rules for fl_type are rather convoluted. Typically it's treated as holding specific values, except in the case of LOCK_MAND, in which case it can be or'ed with LOCK_READ|LOCK_WRITE. On some arches F_WRLCK == 2 and F_UNLCK == 3, so and'ing with F_WRLCK will also catch the F_UNLCK case. It's unlikely in either case here that we'd ever see F_UNLCK since those shouldn't end up on any lists, but it's still best to be consistent. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-08-01locks: remove unused lm_release_privateJ. Bruce Fields
In commit 3b6e2723f32d ("locks: prevent side-effects of locks_release_private before file_lock is initialized") we removed the last user of lm_release_private without removing the field itself. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31Merge branch 'nfsd-next' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd changes from J. Bruce Fields: "This has been an unusually quiet cycle--mostly bugfixes and cleanup. The one large piece is Stanislav's work to containerize the server's grace period--but that in itself is just one more step in a not-yet-complete project to allow fully containerized nfs service. There are a number of outstanding delegation, container, v4 state, and gss patches that aren't quite ready yet; 3.7 may be wilder." * 'nfsd-next' of git://linux-nfs.org/~bfields/linux: (35 commits) NFSd: make boot_time variable per network namespace NFSd: make grace end flag per network namespace Lockd: move grace period management from lockd() to per-net functions LockD: pass actual network namespace to grace period management functions LockD: manage grace list per network namespace SUNRPC: service request network namespace helper introduced NFSd: make nfsd4_manager allocated per network namespace context. LockD: make lockd manager allocated per network namespace LockD: manage grace period per network namespace Lockd: add more debug to host shutdown functions Lockd: host complaining function introduced LockD: manage used host count per networks namespace LockD: manage garbage collection timeout per networks namespace LockD: make garbage collector network namespace aware. LockD: mark host per network namespace on garbage collect nfsd4: fix missing fault_inject.h include locks: move lease-specific code out of locks_delete_lock locks: prevent side-effects of locks_release_private before file_lock is initialized NFSd: set nfsd_serv to NULL after service destruction NFSd: introduce nfsd_destroy() helper ...
2012-07-27locks: move lease-specific code out of locks_delete_lockJ. Bruce Fields
No point putting something only used by one caller into common code. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-07-27locks: prevent side-effects of locks_release_private before file_lock is ↵Filipe Brandenburger
initialized When calling fcntl(fd, F_SETLEASE, lck) [with lck=F_WRLCK or F_RDLCK], the custom signal or owner (if any were previously set using F_SETSIG or F_SETOWN fcntls) would be reset when F_SETLEASE was called for the second time on the same file descriptor. This bug is a regression of 2.6.37 and is described here: https://bugzilla.kernel.org/show_bug.cgi?id=43336 This patch reverts a commit from Oct 2004 (with subject "nfs4 lease: move the f_delown processing") which originally introduced the lm_release_private callback. Signed-off-by: Filipe Brandenburger <filbranden@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2012-07-23locks: fix checking of fcntl_setlease argumentJ. Bruce Fields
The only checks of the long argument passed to fcntl(fd,F_SETLEASE,.) are done after converting the long to an int. Thus some illegal values may be let through and cause problems in later code. [ They actually *don't* cause problems in mainline, as of Dave Jones's commit 8d657eb3b438 "Remove easily user-triggerable BUG from generic_setlease", but we should fix this anyway. And this patch will be necessary to fix real bugs on earlier kernels. ] Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-13Remove easily user-triggerable BUG from generic_setleaseDave Jones
This can be trivially triggered from userspace by passing in something unexpected. kernel BUG at fs/locks.c:1468! invalid opcode: 0000 [#1] SMP RIP: 0010:generic_setlease+0xc2/0x100 Call Trace: __vfs_setlease+0x35/0x40 fcntl_setlease+0x76/0x150 sys_fcntl+0x1c6/0x810 system_call_fastpath+0x1a/0x1f Signed-off-by: Dave Jones <davej@redhat.com> Cc: stable@kernel.org # 3.2+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29switch flock to fget_light/fput_lightAl Viro
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-03userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfsEric W. Biederman
Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-01CIFS: Fix VFS lock usage for oplocked filesPavel Shilovsky
We can deadlock if we have a write oplock and two processes use the same file handle. In this case the first process can't unlock its lock if the second process blocked on the lock in the same time. Fix it by using posix_lock_file rather than posix_lock_file_wait under cinode->lock_mutex. If we request a blocking lock and posix_lock_file indicates that there is another lock that prevents us, wait untill that lock is released and restart our call. Cc: stable@kernel.org Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-12-26vfs: fix handling of lock allocation failure in lease-break caseLinus Torvalds
Bruce Fields notes that commit 778fc546f749 ("locks: fix tracking of inprogress lease breaks") introduced a possible error pointer dereference on failure to allocate memory. locks_conflict() will dereference the passed-in new lease lock structure that may be an error pointer. This means an open (without O_NONBLOCK set) on a file with a lease applied (generally only done when Samba or nfsd (with v4) is running) could crash if a kmalloc() fails. So instead of playing games with IS_ERROR() all over the place, just check the allocation failure early. That makes the code more straightforward, and avoids this possible bad pointer dereference. Based-on-patch-by: J. Bruce Fields <bfields@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-25Merge branch 'for-3.2' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.2' of git://linux-nfs.org/~bfields/linux: (103 commits) nfs41: implement DESTROY_CLIENTID operation nfsd4: typo logical vs bitwise negate for want_mask nfsd4: allow NFS4_SHARE_SIGNAL_DELEG_WHEN_RESRC_AVAIL | NFS4_SHARE_PUSH_DELEG_WHEN_UNCONTENDED nfsd4: seq->status_flags may be used unitialized nfsd41: use SEQ4_STATUS_BACKCHANNEL_FAULT when cb_sequence is invalid nfsd4: implement new 4.1 open reclaim types nfsd4: remove unneeded CLAIM_DELEGATE_CUR workaround nfsd4: warn on open failure after create nfsd4: preallocate open stateid in process_open1() nfsd4: do idr preallocation with stateid allocation nfsd4: preallocate nfs4_file in process_open1() nfsd4: clean up open owners on OPEN failure nfsd4: simplify process_open1 logic nfsd4: make is_open_owner boolean nfsd4: centralize renew_client() calls nfsd4: typo logical vs bitwise negate nfs: fix bug about IPv6 address scope checking nfsd4: more robust ignoring of WANT bits in OPEN nfsd4: move name-length checks to xdr nfsd4: move access/deny validity checks to xdr code ...
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-21leases: split up generic_setlease into lock/unlock casesJ. Bruce Fields
Eventually we should probably do the same thing to the file operations as well. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-08-19locks: setlease cleanupJ. Bruce Fields
There's an incorrect comment here. Also clean up the logic: the "rdlease" and "wrlease" locals are confusingly named, and don't really add anything since we can make a decision as soon as we hit one of these cases. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-08-19locks: fix tracking of inprogress lease breaksJ. Bruce Fields
We currently use a bit in fl_flags to record whether a lease is being broken, and set fl_type to the type (RDLCK or UNLCK) that it will eventually have. This means that once the lease break starts, we forget what the lease's type *used* to be. Breaking a read lease will then result in blocking read opens, even though there's no conflict--because the lease type is now F_UNLCK and we can no longer tell whether it was previously a read or write lease. So, instead keep fl_type as the original type (the type which we enforce), and keep track of whether we're unlocking or merely downgrading by replacing the single FL_INPROGRESS flag by FL_UNLOCK_PENDING and FL_DOWNGRADE_PENDING flags. To get this right we also need to track separate downgrade and break times, to handle the case where a write-leased file gets conflicting opens first for read, then later for write. (I first considered just eliminating the downgrade behavior completely--nfsv4 doesn't need it, and nobody as far as I can tell actually uses it currently--but Jeremy Allison tells me that Windows oplocks do behave this way, so Samba will probably use this some day.) Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-08-19locks: move F_INPROGRESS from fl_type to fl_flags fieldJ. Bruce Fields
F_INPROGRESS isn't exposed to userspace. To me it makes more sense in fl_flags.... Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-08-19locks: minor lease cleanupJ. Bruce Fields
Use a helper function, to simplify upcoming changes. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-20locks: rename lock-manager opsJ. Bruce Fields
Both the filesystem and the lock manager can associate operations with a lock. Confusingly, one of them (fl_release_private) actually has the same name in both operation structures. It would save some confusion to give the lock-manager ops different names. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15fs: locks: remove init_onceMiklos Szeredi
From: Miklos Szeredi <mszeredi@suse.cz> Remove SLAB initialization entirely, as suggested by Bruce and Linus. Allocate with __GFP_ZERO instead and only initialize list heads. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-06fs: fix lock initializationMiklos Szeredi
locks_alloc_lock() assumed that the allocated struct file_lock is already initialized to zero members. This is only true for the first allocation of the structure, after reuse some of the members will have random values. This will for example result in passing random fl_start values to userspace in fuse for FL_FLOCK locks, which is an information leak at best. Fix by reinitializing those members which may be non-zero after freeing. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'for-2.6.39' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux: SUNRPC: Remove resource leak in svc_rdma_send_error() nfsd: wrong index used in inner loop nfsd4: fix comment and remove unused nfsd4_file fields nfs41: make sure nfs server return right ca_maxresponsesize_cached nfsd: fix compile error svcrpc: fix bad argument in unix_domain_find nfsd4: fix struct file leak nfsd4: minor nfs4state.c reshuffling svcrpc: fix rare race on unix_domain creation nfsd41: modify the members value of nfsd4_op_flags nfsd: add proc file listing kernel's gss_krb5 enctypes gss:krb5 only include enctype numbers in gm_upcall_enctypes NFSD, VFS: Remove dead code in nfsd_rename() nfsd: kill unused macro definition locks: use assign_type()
2011-03-07locks: use assign_type()Namhyung Kim
Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-05fs/locks.c: Remove stale FIXME left over from BKL conversionMatt Fleming
The comment is no longer true as (now that the BKL conversion is finished) a spinlock _is_ now used to protect file_lock_list, blocked_list and inode->i_flock. Signed-off-by: Matt Fleming <matt.fleming@linux.intel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-01-14Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits) nfsd4: fix callback restarting nfsd: break lease on unlink, link, and rename nfsd4: break lease on nfsd setattr nfsd: don't support msnfs export option nfsd4: initialize cb_per_client nfsd4: allow restarting callbacks nfsd4: simplify nfsd4_cb_prepare nfsd4: give out delegations more quickly in 4.1 case nfsd4: add helper function to run callbacks nfsd4: make sure sequence flags are set after destroy_session nfsd4: re-probe callback on connection loss nfsd4: set sequence flag when backchannel is down nfsd4: keep finer-grained callback status rpc: allow xprt_class->setup to return a preexisting xprt rpc: keep backchannel xprt as long as server connection rpc: move sk_bc_xprt to svc_xprt nfsd4: allow backchannel recovery nfsd4: support BIND_CONN_TO_SESSION nfsd4: modify session list under cl_lock Documentation: fl_mylease no longer exists ... Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The vfs-scale work touched some msnfs cases, and this merge removes support for that entirely, so the conflict was trivial to resolve.
2011-01-07fs: dcache scale dentry refcountNick Piggin
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a 0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when we start protecting many other dentry members with d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-04locks: minor setlease cleanupJ. Bruce Fields
2011-01-04locks: eliminate fl_mylease callbackJ. Bruce Fields
The nfs server only supports read delegations for now, so we don't care how conflicts are determined. All we care is that unlocks are recognized as matching the leases they are meant to remove. After the last patch, a comparison of struct files will work for that purpose. So we no longer need this callback. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-10locks: remove dead lease error-handling codeJ. Bruce Fields
A minor oversight from f7347ce4ee7c65415f84be915c018473e7076f31, "fasync: re-organize fasync entry insertion to allow it under a spinlock": this cleanup-on-error was only needed to handle -ENOMEM. Now that we're preallocating it's unneeded. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-11-10locks: fix leak on merging leasesJ. Bruce Fields
We must also free the passed-in lease in the case it wasn't used because an existing lease was upgrade/downgraded or already existed. Note the nfsd caller doesn't care because it's fl_change callback returns an error in those cases. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-31locks: remove fl_copy_lock lock_manager operationChristoph Hellwig
This one was only used for a nasty hack in nfsd, which has recently been removed. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-31locks: let the caller free file_lock on ->setlease failureChristoph Hellwig
The caller allocated it, the caller should free it. The only issue so far is that we could change the flp pointer even on an error return if the fl_change callback failed. But we can simply move the flp assignment after the fl_change invocation, as the callers don't care about the flp return value if the setlease call failed. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30locks: fix setlease methods to free passed-in lockJ. Bruce Fields
We modified setlease to require the caller to allocate the new lease in the case of creating a new lease, but forgot to fix up the filesystem methods. Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Steve French <sfrench@samba.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30locks: fix leaks on setlease errorsJ. Bruce Fields
We're depending on setlease to free the passed-in lease on failure. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-30locks: prevent ENOMEM on lease unlockJ. Bruce Fields
Removing a lock shouldn't require any allocations; a failure due to ENOMEM leaves the caller with a choice between retrying or giving up and leaking an unused lease. Next we should split the other lease calls into add and delete cases. I wanted to start with just the bugfix. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27Merge branch 'flock' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'flock' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: locks: turn lock_flocks into a spinlock fasync: re-organize fasync entry insertion to allow it under a spinlock locks/nfsd: allocate file lock outside of spinlock lockd: fix nlmsvc_notify_blocked locking lockd: push lock_flocks down
2010-10-27locks: turn lock_flocks into a spinlockArnd Bergmann
Nothing depends on lock_flocks using the BKL any more, so we can do the switch over to a private spinlock. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-27fasync: re-organize fasync entry insertion to allow it under a spinlockLinus Torvalds
You currently cannot use "fasync_helper()" in an atomic environment to insert a new fasync entry, because it will need to allocate the new "struct fasync_struct". Yet fcntl_setlease() wants to call this under lock_flocks(), which is in the process of being converted from the BKL to a spinlock. In order to fix this, this abstracts out the actual fasync list insertion and the fasync allocations into functions of their own, and teaches fs/locks.c to pre-allocate the fasync_struct entry. That way the actual list insertion can happen while holding the required spinlock. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bfields@redhat.com: rebase on top of my changes to Arnd's patch] Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-27locks/nfsd: allocate file lock outside of spinlockArnd Bergmann
As suggested by Christoph Hellwig, this moves allocation of new file locks out of generic_setlease into the callers, nfs4_open_delegation and fcntl_setlease in order to allow GFP_KERNEL allocations when lock_flocks has become a spinlock. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: J. Bruce Fields <bfields@redhat.com>
2010-10-26procfs: fix numbering in /proc/locksJerome Marchand
The lock number in /proc/locks (first field) is implemented by a counter (private field of struct seq_file) which is incremented at each call of locks_show() and reset to 1 in locks_start() whatever the offset is. It should be reset according to the actual position in the list. Because of this, the numbering erratically restarts at 1 several times when reading a long /proc/locks file. Moreover, locks_show() can be called twice to print a single line thus skipping a number. The counter should be incremented in locks_next(). And last, pos is a loff_t, which can be bigger than a pointer, so we don't use the pointer as an integer anymore, and allocate a loff_t instead. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05fs/locks.c: prepare for BKL removalArnd Bergmann
This prepares the removal of the big kernel lock from the file locking code. We still use the BKL as long as fs/lockd uses it and ceph might sleep, but we can flip the definition to a private spinlock as soon as that's done. All users outside of fs/lockd get converted to use lock_flocks() instead of lock_kernel() where appropriate. Based on an earlier patch to use a spinlock from Matthew Wilcox, who has attempted this a few times before, the earliest patch from over 10 years ago turned it into a semaphore, which ended up being slower than the BKL and was subsequently reverted. Someone should do some serious performance testing when this becomes a spinlock, since this has caused problems before. Using a spinlock should be at least as good as the BKL in theory, but who knows... Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Matthew Wilcox <willy@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Miklos Szeredi <mszeredi@suse.cz> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: John Kacur <jkacur@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: linux-kernel@vger.kernel.org Cc: linux-fsdevel@vger.kernel.org
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-03Switch may_open() and break_lease() to passing O_...Al Viro
... instead of mixing FMODE_ and O_ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-05Fix misspelling of "should" and "shouldn't" in comments.Adam Buchbinder
Some comments misspell "should" or "shouldn't"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-22const: make lock_manager_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
