path: root/fs/logfs/readwrite.c
2012-12-20logfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert logfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-26Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
Pull LogFS bugfixes from Prasad Joshi: - "logfs: query block device for number of pages to send with bio" This BUG was found when LogFS was used on KVM. The patch fixes the problem by asking for underlaying block device the number of pages to send with each BIO. - "logfs: maintain the ordering of meta-inode destruction" LogFS maintains file system meta-data in special inodes. These inodes are releated to each other, therefore they must be destroyed in a proper order. - "logfs: initialize the number of iovecs in bio" LogFS used to panic when it was created on an encrypted LVM volume. The patch fixes the problem by properly initializing the BIO. Plus a couple more: - logfs: create a pagecache page if it is not present - logfs: destroy the reserved inodes while unmounting * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: logfs: query block device for number of pages to send with bio logfs: maintain the ordering of meta-inode destruction logfs: create a pagecache page if it is not present logfs: initialize the number of iovecs in bio logfs: destroy the reserved inodes while unmounting
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-04-02logfs: destroy the reserved inodes while unmountingPrasad Joshi
We were assuming that the evict_inode() would never be called on reserved inodes. However, (after the commit 8e22c1a4e logfs: get rid of magical inodes) while unmounting the file system, in put_super, we call iput() on all of the reserved inodes. The following simple test used to cause a kernel panic on LogFS: 1. Mount a LogFS file system on /mnt 2. Create a file $ touch /mnt/a 3. Try to unmount the FS $ umount /mnt The simple fix would be to drop the assumption and properly destroy the reserved inodes. Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-03-20logfs: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-01-28logfs: Grow inode in delete pathJoern Engel
Can be necessary if an inode gets deleted (through -ENOSPC) before being written. Might be better to move this into logfs_write_rec(), but for now go with the stupid&safe patch. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Propagate page parameter to __logfs_write_inodePrasad Joshi
During GC LogFS has to rewrite each valid block to a separate segment. Rewrite operation reads data from an old segment and writes it to a newly allocated segment. Since every write operation changes data block pointers maintained in inode, inode should also be rewritten. In GC path to avoid AB-BA deadlock LogFS marks a page with PG_pre_locked in addition to locking the page (PG_locked). The page lock is ignored iff the page is pre-locked. LogFS uses a special file called segment file. The segment file maintains an 8 bytes entry for every segment. It keeps track of erase count, level etc. for every segment. Bad things happen with a segment belonging to the segment file is GCed ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/readwrite.c:297! invalid opcode: 0000 [#1] SMP Modules linked in: logfs joydev usbhid hid psmouse e1000 i2c_piix4 serio_raw [last unloaded: logfs] Pid: 20161, comm: mount Not tainted 3.1.0-rc3+ #3 innotek GmbH VirtualBox EIP: 0060:[<f809132a>] EFLAGS: 00010292 CPU: 0 EIP is at logfs_lock_write_page+0x6a/0x70 [logfs] EAX: 00000027 EBX: f73f5b20 ECX: c16007c8 EDX: 00000094 ESI: 00000000 EDI: e59be6e4 EBP: c7337b28 ESP: c7337b18 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process mount (pid: 20161, ti=c7336000 task=eb323f70 task.ti=c7336000) Stack: f8099a3d c7337b24 f73f5b20 00001002 c7337b50 f8091f6d f8099a4d f80994e4 00000003 00000000 c7337b68 00000000 c67e4400 00001000 c7337b80 f80935e5 00000000 00000000 00000000 00000000 e1fcf000 0000000f e59be618 c70bf900 Call Trace: [<f8091f6d>] logfs_get_write_page.clone.16+0xdd/0x100 [logfs] [<f80935e5>] logfs_mod_segment_entry+0x55/0x110 [logfs] [<f809460d>] logfs_get_segment_entry+0x1d/0x20 [logfs] [<f8091060>] ? logfs_cleanup_journal+0x50/0x50 [logfs] [<f809521b>] ostore_get_erase_count+0x1b/0x40 [logfs] [<f80965b8>] logfs_open_area+0xc8/0x150 [logfs] [<c141a7ec>] ? kmemleak_alloc+0x2c/0x60 [<f809668e>] __logfs_segment_write.clone.16+0x4e/0x1b0 [logfs] [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<f809696f>] logfs_segment_write+0x17f/0x1d0 [logfs] [<f8092e8c>] logfs_write_i0+0x11c/0x180 [logfs] [<f8092f35>] logfs_write_direct+0x45/0x90 [logfs] [<f80934cd>] __logfs_write_buf+0xbd/0xf0 [logfs] [<c102900e>] ? kmap_atomic_prot+0x4e/0xe0 [<f809424b>] logfs_write_buf+0x3b/0x60 [logfs] [<f80947a9>] __logfs_write_inode+0xa9/0x110 [logfs] [<f8094cb0>] logfs_rewrite_block+0xc0/0x110 [logfs] [<f8095300>] ? get_mapping_page+0x10/0x60 [logfs] [<f8095aa0>] ? logfs_load_object_aliases+0x2e0/0x2f0 [logfs] [<f808e57d>] logfs_gc_segment+0x2ad/0x310 [logfs] [<f808e62a>] __logfs_gc_once+0x4a/0x80 [logfs] [<f808ed43>] logfs_gc_pass+0x683/0x6a0 [logfs] [<f8097a89>] logfs_mount+0x5a9/0x680 [logfs] [<c1126b21>] mount_fs+0x21/0xd0 [<c10f6f6f>] ? __alloc_percpu+0xf/0x20 [<c113da41>] ? alloc_vfsmnt+0xb1/0x130 [<c113db4b>] vfs_kern_mount+0x4b/0xa0 [<c113e06e>] do_kern_mount+0x3e/0xe0 [<c113f60d>] do_mount+0x34d/0x670 [<c10f2749>] ? strndup_user+0x49/0x70 [<c113fcab>] sys_mount+0x6b/0xa0 [<c142d87c>] syscall_call+0x7/0xb Code: f8 e8 8b 93 39 c9 8b 45 f8 3e 0f ba 28 00 19 d2 85 d2 74 ca eb d0 0f 0b 8d 45 fc 89 44 24 04 c7 04 24 3d 9a 09 f8 e8 09 92 39 c9 <0f> 0b 8d 74 26 00 55 89 e5 3e 8d 74 26 00 8b 10 80 e6 01 74 09 EIP: [<f809132a>] logfs_lock_write_page+0x6a/0x70 [logfs] SS:ESP 0068:c7337b18 ---[ end trace 96e67d5b3aa3d6ca ]--- The patch passes locked page to __logfs_write_inode. It calls function logfs_get_wblocks() to pre-lock the page. This ensures any further attempts to lock the page are ignored (esp from get_erase_count). Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: take write mutex lock during fsync and syncPrasad Joshi
LogFS uses super->s_write_mutex while writing data to disk. Taking the same mutex lock in sync and fsync code path solves the following BUG: ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/dev_bdev.c:134! Pid: 2387, comm: flush-253:16 Not tainted 3.0.0+ #4 Bochs Bochs RIP: 0010:[<ffffffffa007deed>] [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] Call Trace: [<ffffffffa007c381>] logfs_open_area+0x91/0x150 [logfs] [<ffffffff8128dcb2>] ? find_level.clone.9+0x62/0x100 [<ffffffffa007c49c>] __logfs_segment_write.clone.20+0x5c/0x190 [logfs] [<ffffffff810ef005>] ? mempool_kmalloc+0x15/0x20 [<ffffffff810ef383>] ? mempool_alloc+0x53/0x130 [<ffffffffa007c7a4>] logfs_segment_write+0x1d4/0x230 [logfs] [<ffffffffa0078f8e>] logfs_write_i0+0x12e/0x190 [logfs] [<ffffffffa0079300>] __logfs_write_rec+0x140/0x220 [logfs] [<ffffffffa0079444>] logfs_write_rec+0x64/0xd0 [logfs] [<ffffffffa00795b6>] __logfs_write_buf+0x106/0x110 [logfs] [<ffffffffa007a13e>] logfs_write_buf+0x4e/0x80 [logfs] [<ffffffffa0073e33>] __logfs_writepage+0x23/0x80 [logfs] [<ffffffffa007410c>] logfs_writepage+0xdc/0x110 [logfs] [<ffffffff810f5ba7>] __writepage+0x17/0x40 [<ffffffff810f6208>] write_cache_pages+0x208/0x4f0 [<ffffffff810f5b90>] ? set_page_dirty+0x70/0x70 [<ffffffff810f653a>] generic_writepages+0x4a/0x70 [<ffffffff810f75d1>] do_writepages+0x21/0x40 [<ffffffff8116b9d1>] writeback_single_inode+0x101/0x250 [<ffffffff8116bdbd>] writeback_sb_inodes+0xed/0x1c0 [<ffffffff8116c5fb>] writeback_inodes_wb+0x7b/0x1e0 [<ffffffff8116cc23>] wb_writeback+0x4c3/0x530 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff8116cd6b>] wb_do_writeback+0xdb/0x290 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff814d6208>] ? _raw_spin_unlock_irqrestore+0x18/0x40 [<ffffffff8105aa5a>] ? del_timer+0x8a/0x120 [<ffffffff8116cfac>] bdi_writeback_thread+0x8c/0x2e0 [<ffffffff8116cf20>] ? wb_do_writeback+0x290/0x290 [<ffffffff8106d2e6>] kthread+0x96/0xa0 [<ffffffff814de514>] kernel_thread_helper+0x4/0x10 [<ffffffff8106d250>] ? kthread_worker_fn+0x190/0x190 [<ffffffff814de510>] ? gs_change+0xb/0xb RIP [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] ---[ end trace 0211ad60a57657c4 ]--- Reviewed-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: update page reference count for pined pagesPrasad Joshi
LogFS sets PG_private flag to indicate a pined page. We assumed that marking a page as private is enough to ensure its existence. But instead it is necessary to hold a reference count to the page. The change resolves the following BUG BUG: Bad page state in process flush-253:16 pfn:6a6d0 page flags: 0x100000000000808(uptodate|private) Suggested-and-Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-22logfs: fix "Kernel BUG at readwrite.c:1193"Prasad Joshi
This happens when __logfs_create() tries to write a new inode to the disk which is full. __logfs_create() associates the transaction pointer with inode. During the logfs_write_inode() function call chain this transaction pointer is moved from inode to page->private using function move_inode_to_page (do_write_inode() -> inode_to_page() -> move_inode_to_page) When the write inode fails, the transaction is aborted and iput is called on the failed inode. During delete_inode the same transaction pointer associated with the page is getting used. Thus causing kernel BUG. The patch checks for error in write_inode() and restores the page->private to NULL. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=20162 Signed-off-by: Prasad Joshi <prasadjoshi124@gmail.com> Cc: Joern Engel <joern@logfs.org> Cc: Florian Mickler <florian@mickler.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Maciej Rutecki <maciej.rutecki@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09convert logfs to ->evict_inode()Al Viro
2010-08-09logfs: get rid of magical inodesAl Viro
ordering problems at ->kill_sb() time are solved by doing iput() of these suckers in ->put_super() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-04logfs: commit reservations under space pressureJoern Engel
Ensures we only return -ENOSPC when there really is no space. Signed-off-by: Joern Engel <joern@logfs.org>
2010-05-01logfs: fix logfs_seek_hole()Joern Engel
logfs_seek_hole(inode, 0x200) would crap itself if the inode contained just 0x1ff (or fewer) blocks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-29LogFS: Fix typo in b6349ac8Joern Engel
2010-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Split large truncated into smaller chunks [LogFS] Set s_bdi [LogFS] Prevent mempool_destroy NULL pointer dereference [LogFS] Move assertion [LogFS] Plug 8 byte information leak [LogFS] Prevent memory corruption on large deletes [LogFS] Remove unused method Fix trivial conflict with added header includes in fs/logfs/super.c
2010-04-20[LogFS] Split large truncated into smaller chunksJoern Engel
Truncate would do an almost limitless amount of work without invoking the garbage collector in between. Split it up into more manageable, though still large, chunks. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-15[LogFS] Prevent mempool_destroy NULL pointer dereferenceJoern Engel
It would probably be better to just accept NULL pointers in mempool_destroy(). But for the current -rc series let's keep things simple. This patch was lost in the cracks for a while. Kevin Cernekee <cernekee@gmail.com> had to rediscover the problem and send a similar patch because of it. :( Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-13[LogFS] Prevent memory corruption on large deletesJoern Engel
Removing sufficiently large files would create aliases for a large number of segments. This in turn results in a large number of journal entries and an overflow of s_je_array. Cheap fix is to add a BUG_ON, turning memory corruption into something annoying, but less dangerous. Real fix is to count the number of affected segments and prevent the problem completely. Signed-off-by: Joern Engel <joern@logfs.org>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-03-30[LogFS] Remove unused methodJoern Engel
All callers are long gone. Signed-off-by: Joern Engel <joern@logfs.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-28Prevent data corruption in logfs_rewrite_block()Joern Engel
The comment was correct, so make the code match the comment. As the new comment indicates, we might be able to do a little less work. But for the current -rc series let's keep it simple and just fix the bug. Signed-off-by: Joern Engel <joern@logfs.org>
2010-03-04[LogFS] Only write journal if dirtyJoern Engel
This prevents unnecessary journal writes. More importantly it prevents an oops due to a journal write on failed mount.
2009-11-20[LogFS] add new flash file systemJoern Engel
This is a new flash file system. See Documentation/filesystems/logfs.txt Signed-off-by: Joern Engel <joern@logfs.org>
