path: root/fs/logfs
2015-11-06mm, fs: introduce mapping_gfp_constraint()Michal Hocko
There are many places which use mapping_gfp_mask to restrict a more generic gfp mask which would be used for allocations which are not directly related to the page cache but they are performed in the same context. Let's introduce a helper function which makes the restriction explicit and easier to track. This patch doesn't introduce any functional changes. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michal Hocko <mhocko@suse.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05logfs: fix build warningSudip Mukherjee
fs/logfs/dev_bdev.c: In function '__bdev_writeseg': include/linux/kernel.h:601:17: warning: comparison of distinct pointer types lacks a cast [enabled by default] (void) (&_min1 == &_min2); \ fs/logfs/dev_bdev.c:84:14: note: in expansion of macro 'min' max_pages = min(nr_pages, BIO_MAX_PAGES); fs/logfs/dev_bdev.c: In function 'do_erase': include/linux/kernel.h:601:17: warning: comparison of distinct pointer types lacks a cast [enabled by default] (void) (&_min1 == &_min2); \ fs/logfs/dev_bdev.c:174:14: note: in expansion of macro 'min' max_pages = min(nr_pages, BIO_MAX_PAGES); Lets use min_t and mention the type. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-13block: remove bio_get_nr_vecs()Kent Overstreet
We can always fill up the bio now, no need to estimate the possible size based on queue parameters. Acked-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com> [hch: rebased and wrote a changelog] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lin <ming.l@ssi.samsung.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-07-29block: add a bi_error field to struct bioChristoph Hellwig
Currently we have two different ways to signal an I/O error on a BIO: (1) by clearing the BIO_UPTODATE flag (2) by returning a Linux errno value to the bi_end_io callback The first one has the drawback of only communicating a single possible error (-EIO), and the second one has the drawback of not beeing persistent when bios are queued up, and are not passed along from child to parent bio in the ever more popular chaining scenario. Having both mechanisms available has the additional drawback of utterly confusing driver authors and introducing bugs where various I/O submitters only deal with one of them, and the others have to add boilerplate code to deal with both kinds of error returns. So add a new bi_error field to store an errno value directly in struct bio and remove the existing mechanisms to clean all this up. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.de> Reviewed-by: NeilBrown <neilb@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-05-10logfs: fix a pagecache leak for symlinksAl Viro
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-08-06fs/logfs/readwrite.c: kernel-doc warning fixesFabian Frederick
s/-/:/ and fix variable names. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-30Merge branch 'for-3.14/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block IO changes from Jens Axboe: "The major piece in here is the immutable bio_ve series from Kent, the rest is fairly minor. It was supposed to go in last round, but various issues pushed it to this release instead. The pull request contains: - Various smaller blk-mq fixes from different folks. Nothing major here, just minor fixes and cleanups. - Fix for a memory leak in the error path in the block ioctl code from Christian Engelmayer. - Header export fix from CaiZhiyong. - Finally the immutable biovec changes from Kent Overstreet. This enables some nice future work on making arbitrarily sized bios possible, and splitting more efficient. Related fixes to immutable bio_vecs: - dm-cache immutable fixup from Mike Snitzer. - btrfs immutable fixup from Muthu Kumar. - bio-integrity fix from Nic Bellinger, which is also going to stable" * 'for-3.14/core' of git://git.kernel.dk/linux-block: (44 commits) xtensa: fixup simdisk driver to work with immutable bio_vecs block/blk-mq-cpu.c: use hotcpu_notifier() blk-mq: for_each_* macro correctness block: Fix memory leak in rw_copy_check_uvector() handling bio-integrity: Fix bio_integrity_verify segment start bug block: remove unrelated header files and export symbol blk-mq: uses page->list incorrectly blk-mq: use __smp_call_function_single directly btrfs: fix missing increment of bi_remaining Revert "block: Warn and free bio if bi_end_io is not set" block: Warn and free bio if bi_end_io is not set blk-mq: fix initializing request's start time block: blk-mq: don't export blk_mq_free_queue() block: blk-mq: make blk_sync_queue support mq block: blk-mq: support draining mq queue dm cache: increment bi_remaining when bi_end_io is restored block: fixup for generic bio chaining block: Really silence spurious compiler warnings block: Silence spurious compiler warnings block: Kill bio_pair_split() ...
2014-01-23logfs: check for the return value after calling find_or_create_page()Younger Liu
In get_mapping_page(), after calling find_or_create_page(), the return value should be checked. This patch has been provided: http://www.spinics.net/lists/linux-fsdevel/msg66948.html but not been applied now. Signed-off-by: Younger Liu <liuyiyang@hisense.com> Cc: Younger Liu <younger.liucn@gmail.com> Cc: Vyacheslav Dubeyko <slava@dubeyko.com> Reviewed-by: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-24block: submit_bio_wait() conversionsKent Overstreet
It was being open coded in a few places. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Chris Mason <chris.mason@fusionio.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-23block: Abstract out bvec iteratorKent Overstreet
Immutable biovecs are going to require an explicit iterator. To implement immutable bvecs, a later patch is going to add a bi_bvec_done member to this struct; for now, this patch effectively just renames things. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Lars Ellenberg <drbd-dev@lists.linbit.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Geoff Levand <geoff@infradead.org> Cc: Yehuda Sadeh <yehuda@inktank.com> Cc: Sage Weil <sage@inktank.com> Cc: Alex Elder <elder@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: Joshua Morris <josh.h.morris@us.ibm.com> Cc: Philip Kelleher <pjk1939@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Neil Brown <neilb@suse.de> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: dm-devel@redhat.com Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: Benny Halevy <bhalevy@tonian.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Ben Myers <bpm@sgi.com> Cc: xfs@oss.sgi.com Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Guo Chao <yan@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: "Roger Pau Monné" <roger.pau@citrix.com> Cc: Jan Beulich <jbeulich@suse.com> Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Cc: Ian Campbell <Ian.Campbell@citrix.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Jiang Liu <jiang.liu@huawei.com> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Jerome Marchand <jmarchand@redhat.com> Cc: Joe Perches <joe@perches.com> Cc: Peng Tao <tao.peng@emc.com> Cc: Andy Adamson <andros@netapp.com> Cc: fanchaoting <fanchaoting@cn.fujitsu.com> Cc: Jie Liu <jeff.liu@oracle.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Pankaj Kumar <pankaj.km@samsung.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Mel Gorman <mgorman@suse.de>6
2013-11-23block: Convert various code to bio_for_each_segment()Kent Overstreet
With immutable biovecs we don't want code accessing bi_io_vec directly - the uses this patch changes weren't incorrect since they all own the bio, but it makes the code harder to audit for no good reason - also, this will help with multipage bvecs later. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@fusionio.com> Cc: Jaegeuk Kim <jaegeuk.kim@samsung.com> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-11-23block: submit_bio_wait() conversionsKent Overstreet
2013-07-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Lots of bug fixes, cleanups and optimizations. In the bug fixes category, of note is a fix for on-line resizing file systems where the block size is smaller than the page size (i.e., file systems 1k blocks on x86, or more interestingly file systems with 4k blocks on Power or ia64 systems.) In the cleanup category, the ext4's punch hole implementation was significantly improved by Lukas Czerner, and now supports bigalloc file systems. In addition, Jan Kara significantly cleaned up the write submission code path. We also improved error checking and added a few sanity checks. In the optimizations category, two major optimizations deserve mention. The first is that ext4_writepages() is now used for nodelalloc and ext3 compatibility mode. This allows writes to be submitted much more efficiently as a single bio request, instead of being sent as individual 4k writes into the block layer (which then relied on the elevator code to coalesce the requests in the block queue). Secondly, the extent cache shrink mechanism, which was introduce in 3.9, no longer has a scalability bottleneck caused by the i_es_lru spinlock. Other optimizations include some changes to reduce CPU usage and to avoid issuing empty commits unnecessarily." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits) ext4: optimize starting extent in ext4_ext_rm_leaf() jbd2: invalidate handle if jbd2_journal_restart() fails ext4: translate flag bits to strings in tracepoints ext4: fix up error handling for mpage_map_and_submit_extent() jbd2: fix theoretical race in jbd2__journal_restart ext4: only zero partial blocks in ext4_zero_partial_blocks() ext4: check error return from ext4_write_inline_data_end() ext4: delete unnecessary C statements ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree() jbd2: move superblock checksum calculation to jbd2_write_superblock() ext4: pass inode pointer instead of file pointer to punch hole ext4: improve free space calculation for inline_data ext4: reduce object size when !CONFIG_PRINTK ext4: improve extent cache shrink mechanism to avoid to burn CPU time ext4: implement error handling of ext4_mb_new_preallocation() ext4: fix corruption when online resizing a fs with 1K block size ext4: delete unused variables ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents jbd2: remove debug dependency on debug_fs and update Kconfig help text jbd2: use a single printk for jbd_debug() ...
2013-06-29[readdir] convert logfsAl Viro
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-03-23block: Remove bi_idx referencesKent Overstreet
For immutable bvecs, all bi_idx usage needs to be audited - so here we're removing all the unnecessary uses. Most of these are places where it was being initialized on a bio that was just allocated, a few others are conversions to standard macros. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-01-21fs/logfs: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Joern Engel <joern@logfs.org> CC: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-20logfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert logfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-26Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
Pull LogFS bugfixes from Prasad Joshi: - "logfs: query block device for number of pages to send with bio" This BUG was found when LogFS was used on KVM. The patch fixes the problem by asking for underlaying block device the number of pages to send with each BIO. - "logfs: maintain the ordering of meta-inode destruction" LogFS maintains file system meta-data in special inodes. These inodes are releated to each other, therefore they must be destroyed in a proper order. - "logfs: initialize the number of iovecs in bio" LogFS used to panic when it was created on an encrypted LVM volume. The patch fixes the problem by properly initializing the BIO. Plus a couple more: - logfs: create a pagecache page if it is not present - logfs: destroy the reserved inodes while unmounting * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: logfs: query block device for number of pages to send with bio logfs: maintain the ordering of meta-inode destruction logfs: create a pagecache page if it is not present logfs: initialize the number of iovecs in bio logfs: destroy the reserved inodes while unmounting
2012-07-23logfs: query block device for number of pages to send with bioPrasad Joshi
The block device driver puts a limit on maximum number of pages that can be sent with the bio. Not all block devices can handle BIO_MAX_PAGES number of pages in bio. Specifically the virtio-blk diriver limits it to 126. When the LogFS file system was excersized in KVM, the following bug from do_virtblk_request() was observed static void do_virtblk_request(struct request_queue *q) { .... .... while ((req = blk_peek_request(q)) != NULL) { BUG_ON(req->nr_phys_segments + 2 > vblk->sg_elems); .... .... } .... } The patch fixes the problem by querring the maximum number of pages in bio allowed from block device driver and then using those many pages during submit_bio. Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-07-23logfs: maintain the ordering of meta-inode destructionPrasad Joshi
LogFS does not use a specialized area to maintain the inodes. The inodes information is kept in a specialized file called inode file. Similarly, the segment information is kept in a segment file. Since the segment file also has an inode which is kept in the inode file, the inode for segment file must be evicted before the inode for inode file. The change fixes the following BUG during unmount Pid: 2057, comm: umount Not tainted 3.5.0-rc6+ #25 Bochs Bochs RIP: 0010:[<ffffffffa005c5f2>] [<ffffffffa005c5f2>] move_page_to_btree+0x32/0x1f0 [logfs] Process umount (pid: 2057, threadinfo ...) Call Trace: [<ffffffff8112adca>] ? find_get_pages+0x2a/0x180 [<ffffffffa00549f5>] logfs_invalidatepage+0x85/0x90 [logfs] [<ffffffff81136c51>] truncate_inode_page+0xb1/0xd0 [<ffffffff81136dcf>] truncate_inode_pages_range+0x15f/0x490 [<ffffffff81558549>] ? printk+0x78/0x7a [<ffffffff81137185>] truncate_inode_pages+0x15/0x20 [<ffffffffa005b7fc>] logfs_evict_inode+0x6c/0x190 [logfs] [<ffffffff8155c75b>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff8119e3d7>] evict+0xa7/0x1b0 [<ffffffff8119ea6e>] dispose_list+0x3e/0x60 [<ffffffff8119f1c4>] evict_inodes+0xf4/0x110 [<ffffffff81185b53>] generic_shutdown_super+0x53/0xf0 [<ffffffffa005d8f2>] logfs_kill_sb+0x52/0xf0 [logfs] [<ffffffff81185ec5>] deactivate_locked_super+0x45/0x80 [<ffffffff81186a4a>] deactivate_super+0x4a/0x70 [<ffffffff811a228e>] mntput_no_expire+0xde/0x140 [<ffffffff811a30ff>] sys_umount+0x6f/0x3a0 [<ffffffff8155d8e9>] system_call_fastpath+0x16/0x1b ---[ end trace 45f7752082cefafd ]--- Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-07-23logfs: create a pagecache page if it is not presentPrasad Joshi
While writing the partial journal entries we assumed that the page associated with the journal would always in locatable. This incorrect assumption resulted in the following BUG kernel BUG at /home/benixon/WD_SMR/kernels/linux-3.3.7-logfs/fs/logfs/journal.c:569! EIP is at logfs_write_area+0xb6/0x109 [logfs] EAX: 00000000 EBX: 00000000 ECX: ef6efea4 EDX: 00000000 ESI: 001b9000 EDI: f009e000 EBP: c3c13f14 ESP: c3c13ef0 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process sync (pid: 1799, ti=c3c12000 task=f07825b0 task.ti=c3c12000) Stack: 01001000 c3c13f26 781b9000 00000000 f009e000 f7286000 f1f83400 f8445071 f1f83400 c3c13f30 f8445ae9 c3c13f20 0000100a 000ee000 f009e000 00000001 c3c13f5c f8445d17 c05eb0ee 00000000 f1f83400 ef718000 f009e25c ea9c3d80 Call Trace: [<f8445071>] ? account_shadow+0x16d/0x16d [logfs] [<f8445ae9>] logfs_write_je+0x2a/0x44 [logfs] [<f8445d17>] logfs_write_anchor+0x114/0x228 [logfs] [<c05eb0ee>] ? empty+0x5/0x5 [<f8444522>] logfs_sync_fs+0x1e/0x31 [logfs] [<c051be66>] __sync_filesystem+0x5d/0x6f [<c051be8d>] sync_one_sb+0x15/0x17 [<c04ff8b0>] iterate_supers+0x59/0x9a [<c051be78>] ? __sync_filesystem+0x6f/0x6f [<c051befc>] sys_sync+0x29/0x4f [<c084285f>] sysenter_do_call+0x12/0x28 EIP: [<f8445127>] logfs_write_area+0xb6/0x109 [logfs] SS:ESP 0068:c3c13ef0 ---[ end trace ef6e9ef52601a945 ]--- The fix is to create the pagecache page if it is not locatable. Reported-and-tested-by: Benixon Dhas <Benixon.Dhas@wdc.com> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-04-02logfs: initialize the number of iovecs in bioPrasad Joshi
This fixes the following crash when a LogFS file system, created on a encrypted LVM volume, was mounted [ 526.548034] BUG: unable to handle kernel NULL pointer dereference at [ 526.550106] IP: [<ffffffff8131ecab>] memcpy+0xb/0x120 [ 526.551008] PGD bd60067 PUD 1778d067 PMD 0 [ 526.551783] Oops: 0000 [#1] SMP <d>Pid: 2043, comm: mount <d>RIP: 0010:[<ffffffff8131ecab>] [<ffffffff8131ecab>] memcpy+0xb/0x120 Call Trace: kcryptd_io_read+0xdb/0x100 crypt_map+0xfd/0x190 __map_bio+0x48/0x150 __split_and_process_bio+0x51b/0x630 dm_request+0x138/0x230 generic_make_request+0xca/0x100 submit_bio+0x87/0x110 sync_request+0xdd/0x120 [logfs] bdev_readpage+0x2e/0x70 [logfs] do_read_cache_page+0x82/0x180 logfs_mount+0x2ad/0x770 [logfs] mount_fs+0x47/0x1c0 vfs_kern_mount+0x72/0x110 do_kern_mount+0x54/0x110 do_mount+0x520/0x7f0 sys_mount+0x90/0xe0 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42292 Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-04-02logfs: destroy the reserved inodes while unmountingPrasad Joshi
We were assuming that the evict_inode() would never be called on reserved inodes. However, (after the commit 8e22c1a4e logfs: get rid of magical inodes) while unmounting the file system, in put_super, we call iput() on all of the reserved inodes. The following simple test used to cause a kernel panic on LogFS: 1. Mount a LogFS file system on /mnt 2. Create a file $ touch /mnt/a 3. Try to unmount the FS $ umount /mnt The simple fix would be to drop the assumption and properly destroy the reserved inodes. Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20logfs: missing cleanup on register_filesystem() failureAl Viro
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-20vfs: check i_nlink limits in vfs_{mkdir,rename_dir,link}Al Viro
New field of struct super_block - ->s_max_links. Maximal allowed value of ->i_nlink or 0; in the latter case all checks still need to be done in ->link/->mkdir/->rename instances. Note that this limit applies both to directoris and to non-directories. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20logfs: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-02-01mtd: fix merge conflict resolution breakageArtem Bityutskiy
This patch fixes merge conflict resolution breakage introduced by merge d3712b9dfcf4 ("Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream"). The commit changed 'mtd_can_have_bb()' function and made it always return zero, which is incorrect. Instead, we need it to return whether the underlying flash device can have bad eraseblocks or not. UBI needs this information because it affects how it handles the underlying flash. E.g., if the underlying flash is NOR, it cannot have bad blocks and any write or erase error is fatal, and all we can do is to switch to R/O mode. We do not need to reserve a pool of good eraseblocks for bad eraseblocks handling, and so on. This patch also removes 'mtd_can_have_bb()' invocations from Logfs to ensure correct Logfs behavior. I've tested that with this patch UBI works on top of NOR and NAND flashes emulated by mtdram and nandsim correspondingly. This patch is based on patch from Linus Torvalds. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Jörn Engel <joern@logfs.org> Acked-by: Prasad Joshi <prasadjoshi.linux@gmail.com> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-31Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
There are few important bug fixes for LogFS * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: Logfs: Allow NULL block_isbad() methods logfs: Grow inode in delete path logfs: Free areas before calling generic_shutdown_super() logfs: remove useless BUG_ON MAINTAINERS: Add Prasad Joshi in LogFS maintiners logfs: Propagate page parameter to __logfs_write_inode logfs: set superblock shutdown flag after generic sb shutdown logfs: take write mutex lock during fsync and sync logfs: Prevent memory corruption logfs: update page reference count for pined pages Fix up conflict in fs/logfs/dev_mtd.c due to semantic change in what "mtd->block_isbad" means in commit f2933e86ad93: "Logfs: Allow NULL block_isbad() methods" clashing with the abstraction changes in the commits 7086c19d0742: "mtd: introduce mtd_block_isbad interface" and d58b27ed58a3: "logfs: do not use 'mtd->block_isbad' directly". This resolution takes the semantics from commit f2933e86ad93, and just makes mtd_block_isbad() return zero (false) if the 'block_isbad' function is NULL. But that also means that now "mtd_can_have_bb()" always returns 0. Now, "mtd_block_markbad()" will obviously return an error if the low-level driver doesn't support bad blocks, so this is somewhat non-symmetric, but it actually makes sense if a NULL "block_isbad" function is considered to mean "I assume that all my blocks are always good".
2012-01-28Logfs: Allow NULL block_isbad() methodsJoern Engel
Not all mtd drivers define block_isbad(). Let's assume no bad blocks instead of refusing to mount. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Grow inode in delete pathJoern Engel
Can be necessary if an inode gets deleted (through -ENOSPC) before being written. Might be better to move this into logfs_write_rec(), but for now go with the stupid&safe patch. Signed-off-by: Joern Engel <joern@logfs.org>
