path: root/fs/logfs
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20logfs: missing cleanup on register_filesystem() failureAl Viro
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-20vfs: check i_nlink limits in vfs_{mkdir,rename_dir,link}Al Viro
New field of struct super_block - ->s_max_links. Maximal allowed value of ->i_nlink or 0; in the latter case all checks still need to be done in ->link/->mkdir/->rename instances. Note that this limit applies both to directoris and to non-directories. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20logfs: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2012-02-01mtd: fix merge conflict resolution breakageArtem Bityutskiy
This patch fixes merge conflict resolution breakage introduced by merge d3712b9dfcf4 ("Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream"). The commit changed 'mtd_can_have_bb()' function and made it always return zero, which is incorrect. Instead, we need it to return whether the underlying flash device can have bad eraseblocks or not. UBI needs this information because it affects how it handles the underlying flash. E.g., if the underlying flash is NOR, it cannot have bad blocks and any write or erase error is fatal, and all we can do is to switch to R/O mode. We do not need to reserve a pool of good eraseblocks for bad eraseblocks handling, and so on. This patch also removes 'mtd_can_have_bb()' invocations from Logfs to ensure correct Logfs behavior. I've tested that with this patch UBI works on top of NOR and NAND flashes emulated by mtdram and nandsim correspondingly. This patch is based on patch from Linus Torvalds. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Jörn Engel <joern@logfs.org> Acked-by: Prasad Joshi <prasadjoshi.linux@gmail.com> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-31Merge tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstreamLinus Torvalds
There are few important bug fixes for LogFS * tag 'for-linus' of git://github.com/prasad-joshi/logfs_upstream: Logfs: Allow NULL block_isbad() methods logfs: Grow inode in delete path logfs: Free areas before calling generic_shutdown_super() logfs: remove useless BUG_ON MAINTAINERS: Add Prasad Joshi in LogFS maintiners logfs: Propagate page parameter to __logfs_write_inode logfs: set superblock shutdown flag after generic sb shutdown logfs: take write mutex lock during fsync and sync logfs: Prevent memory corruption logfs: update page reference count for pined pages Fix up conflict in fs/logfs/dev_mtd.c due to semantic change in what "mtd->block_isbad" means in commit f2933e86ad93: "Logfs: Allow NULL block_isbad() methods" clashing with the abstraction changes in the commits 7086c19d0742: "mtd: introduce mtd_block_isbad interface" and d58b27ed58a3: "logfs: do not use 'mtd->block_isbad' directly". This resolution takes the semantics from commit f2933e86ad93, and just makes mtd_block_isbad() return zero (false) if the 'block_isbad' function is NULL. But that also means that now "mtd_can_have_bb()" always returns 0. Now, "mtd_block_markbad()" will obviously return an error if the low-level driver doesn't support bad blocks, so this is somewhat non-symmetric, but it actually makes sense if a NULL "block_isbad" function is considered to mean "I assume that all my blocks are always good".
2012-01-28Logfs: Allow NULL block_isbad() methodsJoern Engel
Not all mtd drivers define block_isbad(). Let's assume no bad blocks instead of refusing to mount. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Grow inode in delete pathJoern Engel
Can be necessary if an inode gets deleted (through -ENOSPC) before being written. Might be better to move this into logfs_write_rec(), but for now go with the stupid&safe patch. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Free areas before calling generic_shutdown_super()Joern Engel
Or hit an assertion in map_invalidatepage() instead. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: remove useless BUG_ONJoern Engel
It prevents write sizes >4k. Signed-off-by: Joern Engel <joern@logfs.org>
2012-01-28logfs: Propagate page parameter to __logfs_write_inodePrasad Joshi
During GC LogFS has to rewrite each valid block to a separate segment. Rewrite operation reads data from an old segment and writes it to a newly allocated segment. Since every write operation changes data block pointers maintained in inode, inode should also be rewritten. In GC path to avoid AB-BA deadlock LogFS marks a page with PG_pre_locked in addition to locking the page (PG_locked). The page lock is ignored iff the page is pre-locked. LogFS uses a special file called segment file. The segment file maintains an 8 bytes entry for every segment. It keeps track of erase count, level etc. for every segment. Bad things happen with a segment belonging to the segment file is GCed ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/readwrite.c:297! invalid opcode: 0000 [#1] SMP Modules linked in: logfs joydev usbhid hid psmouse e1000 i2c_piix4 serio_raw [last unloaded: logfs] Pid: 20161, comm: mount Not tainted 3.1.0-rc3+ #3 innotek GmbH VirtualBox EIP: 0060:[<f809132a>] EFLAGS: 00010292 CPU: 0 EIP is at logfs_lock_write_page+0x6a/0x70 [logfs] EAX: 00000027 EBX: f73f5b20 ECX: c16007c8 EDX: 00000094 ESI: 00000000 EDI: e59be6e4 EBP: c7337b28 ESP: c7337b18 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process mount (pid: 20161, ti=c7336000 task=eb323f70 task.ti=c7336000) Stack: f8099a3d c7337b24 f73f5b20 00001002 c7337b50 f8091f6d f8099a4d f80994e4 00000003 00000000 c7337b68 00000000 c67e4400 00001000 c7337b80 f80935e5 00000000 00000000 00000000 00000000 e1fcf000 0000000f e59be618 c70bf900 Call Trace: [<f8091f6d>] logfs_get_write_page.clone.16+0xdd/0x100 [logfs] [<f80935e5>] logfs_mod_segment_entry+0x55/0x110 [logfs] [<f809460d>] logfs_get_segment_entry+0x1d/0x20 [logfs] [<f8091060>] ? logfs_cleanup_journal+0x50/0x50 [logfs] [<f809521b>] ostore_get_erase_count+0x1b/0x40 [logfs] [<f80965b8>] logfs_open_area+0xc8/0x150 [logfs] [<c141a7ec>] ? kmemleak_alloc+0x2c/0x60 [<f809668e>] __logfs_segment_write.clone.16+0x4e/0x1b0 [logfs] [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<c10dd563>] ? mempool_kmalloc+0x13/0x20 [<f809696f>] logfs_segment_write+0x17f/0x1d0 [logfs] [<f8092e8c>] logfs_write_i0+0x11c/0x180 [logfs] [<f8092f35>] logfs_write_direct+0x45/0x90 [logfs] [<f80934cd>] __logfs_write_buf+0xbd/0xf0 [logfs] [<c102900e>] ? kmap_atomic_prot+0x4e/0xe0 [<f809424b>] logfs_write_buf+0x3b/0x60 [logfs] [<f80947a9>] __logfs_write_inode+0xa9/0x110 [logfs] [<f8094cb0>] logfs_rewrite_block+0xc0/0x110 [logfs] [<f8095300>] ? get_mapping_page+0x10/0x60 [logfs] [<f8095aa0>] ? logfs_load_object_aliases+0x2e0/0x2f0 [logfs] [<f808e57d>] logfs_gc_segment+0x2ad/0x310 [logfs] [<f808e62a>] __logfs_gc_once+0x4a/0x80 [logfs] [<f808ed43>] logfs_gc_pass+0x683/0x6a0 [logfs] [<f8097a89>] logfs_mount+0x5a9/0x680 [logfs] [<c1126b21>] mount_fs+0x21/0xd0 [<c10f6f6f>] ? __alloc_percpu+0xf/0x20 [<c113da41>] ? alloc_vfsmnt+0xb1/0x130 [<c113db4b>] vfs_kern_mount+0x4b/0xa0 [<c113e06e>] do_kern_mount+0x3e/0xe0 [<c113f60d>] do_mount+0x34d/0x670 [<c10f2749>] ? strndup_user+0x49/0x70 [<c113fcab>] sys_mount+0x6b/0xa0 [<c142d87c>] syscall_call+0x7/0xb Code: f8 e8 8b 93 39 c9 8b 45 f8 3e 0f ba 28 00 19 d2 85 d2 74 ca eb d0 0f 0b 8d 45 fc 89 44 24 04 c7 04 24 3d 9a 09 f8 e8 09 92 39 c9 <0f> 0b 8d 74 26 00 55 89 e5 3e 8d 74 26 00 8b 10 80 e6 01 74 09 EIP: [<f809132a>] logfs_lock_write_page+0x6a/0x70 [logfs] SS:ESP 0068:c7337b18 ---[ end trace 96e67d5b3aa3d6ca ]--- The patch passes locked page to __logfs_write_inode. It calls function logfs_get_wblocks() to pre-lock the page. This ensures any further attempts to lock the page are ignored (esp from get_erase_count). Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: set superblock shutdown flag after generic sb shutdownPrasad Joshi
While unmounting the file system LogFS calls generic_shutdown_super. The function does file system independent superblock shutdown. However, it might result in call file system specific inode eviction. LogFS marks FS shutting down by setting bit LOGFS_SB_FLAG_SHUTDOWN in super->s_flags. Since, inode eviction might call truncate on inode, following BUG is observed when file system is unmounted: ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/segment.c:362! invalid opcode: 0000 [#1] PREEMPT SMP CPU 3 Modules linked in: logfs binfmt_misc ppdev virtio_blk parport_pc lp parport psmouse floppy virtio_pci serio_raw virtio_ring virtio Pid: 1933, comm: umount Not tainted 3.0.0+ #4 Bochs Bochs RIP: 0010:[<ffffffffa008c841>] [<ffffffffa008c841>] logfs_segment_write+0x211/0x230 [logfs] RSP: 0018:ffff880062d7b9e8 EFLAGS: 00010202 RAX: 000000000000000e RBX: ffff88006eca9000 RCX: 0000000000000000 RDX: ffff88006fd87c40 RSI: ffffea00014ff468 RDI: ffff88007b68e000 RBP: ffff880062d7ba48 R08: 8000000020451430 R09: 0000000000000000 R10: dead000000100100 R11: 0000000000000000 R12: ffff88006fd87c40 R13: ffffea00014ff468 R14: ffff88005ad0a460 R15: 0000000000000000 FS: 00007f25d50ea760(0000) GS:ffff88007fd80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000d05e48 CR3: 0000000062c72000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process umount (pid: 1933, threadinfo ffff880062d7a000, task ffff880070b44500) Stack: ffff880062d7ba38 ffff88005ad0a508 0000000000001000 0000000000000000 8000000020451430 ffffea00014ff468 ffff880062d7ba48 ffff88005ad0a460 ffff880062d7bad8 ffffea00014ff468 ffff88006fd87c40 0000000000000000 Call Trace: [<ffffffffa0088fee>] logfs_write_i0+0x12e/0x190 [logfs] [<ffffffffa0089360>] __logfs_write_rec+0x140/0x220 [logfs] [<ffffffffa0089312>] __logfs_write_rec+0xf2/0x220 [logfs] [<ffffffffa00894a4>] logfs_write_rec+0x64/0xd0 [logfs] [<ffffffffa0089616>] __logfs_write_buf+0x106/0x110 [logfs] [<ffffffffa008a19e>] logfs_write_buf+0x4e/0x80 [logfs] [<ffffffffa008a6b8>] __logfs_write_inode+0x98/0x110 [logfs] [<ffffffffa008a7c4>] logfs_truncate+0x54/0x290 [logfs] [<ffffffffa008abfc>] logfs_evict_inode+0xdc/0x190 [logfs] [<ffffffff8115eef5>] evict+0x85/0x170 [<ffffffff8115f126>] iput+0xe6/0x1b0 [<ffffffff8115b4a8>] shrink_dcache_for_umount_subtree+0x218/0x280 [<ffffffff8115ce91>] shrink_dcache_for_umount+0x51/0x90 [<ffffffff8114796c>] generic_shutdown_super+0x2c/0x100 [<ffffffffa008cc47>] logfs_kill_sb+0x57/0xf0 [logfs] [<ffffffff81147de5>] deactivate_locked_super+0x45/0x70 [<ffffffff811487ea>] deactivate_super+0x4a/0x70 [<ffffffff81163934>] mntput_no_expire+0xa4/0xf0 [<ffffffff8116469f>] sys_umount+0x6f/0x380 [<ffffffff814dd46b>] system_call_fastpath+0x16/0x1b Code: 55 c8 49 8d b6 a8 00 00 00 45 89 f9 45 89 e8 4c 89 e1 4c 89 55 b8 c7 04 24 00 00 00 00 e8 68 fc ff ff 4c 8b 55 b8 e9 3c ff ff ff <0f> 0b 0f 0b c7 45 c0 00 00 00 00 e9 44 fe ff ff 66 66 66 66 66 RIP [<ffffffffa008c841>] logfs_segment_write+0x211/0x230 [logfs] RSP <ffff880062d7b9e8> ---[ end trace fe6b040cea952290 ]--- Therefore, move super->s_flags setting after the fs-indenpendent work has been finished. Reviewed-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: take write mutex lock during fsync and syncPrasad Joshi
LogFS uses super->s_write_mutex while writing data to disk. Taking the same mutex lock in sync and fsync code path solves the following BUG: ------------[ cut here ]------------ kernel BUG at /home/prasad/logfs/dev_bdev.c:134! Pid: 2387, comm: flush-253:16 Not tainted 3.0.0+ #4 Bochs Bochs RIP: 0010:[<ffffffffa007deed>] [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] Call Trace: [<ffffffffa007c381>] logfs_open_area+0x91/0x150 [logfs] [<ffffffff8128dcb2>] ? find_level.clone.9+0x62/0x100 [<ffffffffa007c49c>] __logfs_segment_write.clone.20+0x5c/0x190 [logfs] [<ffffffff810ef005>] ? mempool_kmalloc+0x15/0x20 [<ffffffff810ef383>] ? mempool_alloc+0x53/0x130 [<ffffffffa007c7a4>] logfs_segment_write+0x1d4/0x230 [logfs] [<ffffffffa0078f8e>] logfs_write_i0+0x12e/0x190 [logfs] [<ffffffffa0079300>] __logfs_write_rec+0x140/0x220 [logfs] [<ffffffffa0079444>] logfs_write_rec+0x64/0xd0 [logfs] [<ffffffffa00795b6>] __logfs_write_buf+0x106/0x110 [logfs] [<ffffffffa007a13e>] logfs_write_buf+0x4e/0x80 [logfs] [<ffffffffa0073e33>] __logfs_writepage+0x23/0x80 [logfs] [<ffffffffa007410c>] logfs_writepage+0xdc/0x110 [logfs] [<ffffffff810f5ba7>] __writepage+0x17/0x40 [<ffffffff810f6208>] write_cache_pages+0x208/0x4f0 [<ffffffff810f5b90>] ? set_page_dirty+0x70/0x70 [<ffffffff810f653a>] generic_writepages+0x4a/0x70 [<ffffffff810f75d1>] do_writepages+0x21/0x40 [<ffffffff8116b9d1>] writeback_single_inode+0x101/0x250 [<ffffffff8116bdbd>] writeback_sb_inodes+0xed/0x1c0 [<ffffffff8116c5fb>] writeback_inodes_wb+0x7b/0x1e0 [<ffffffff8116cc23>] wb_writeback+0x4c3/0x530 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff8116cd6b>] wb_do_writeback+0xdb/0x290 [<ffffffff814d984d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff814d6208>] ? _raw_spin_unlock_irqrestore+0x18/0x40 [<ffffffff8105aa5a>] ? del_timer+0x8a/0x120 [<ffffffff8116cfac>] bdi_writeback_thread+0x8c/0x2e0 [<ffffffff8116cf20>] ? wb_do_writeback+0x290/0x290 [<ffffffff8106d2e6>] kthread+0x96/0xa0 [<ffffffff814de514>] kernel_thread_helper+0x4/0x10 [<ffffffff8106d250>] ? kthread_worker_fn+0x190/0x190 [<ffffffff814de510>] ? gs_change+0xb/0xb RIP [<ffffffffa007deed>] bdev_writeseg+0x25d/0x270 [logfs] ---[ end trace 0211ad60a57657c4 ]--- Reviewed-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: Prevent memory corruptionJoern Engel
This is a bad one. I wonder whether we were so far protected by no_free_segments(sb) usually being smaller than LOGFS_NO_AREAS. Found by Dan Carpenter <dan.carpenter@oracle.com> using smatch. Signed-off-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-28logfs: update page reference count for pined pagesPrasad Joshi
LogFS sets PG_private flag to indicate a pined page. We assumed that marking a page as private is enough to ensure its existence. But instead it is necessary to hold a reference count to the page. The change resolves the following BUG BUG: Bad page state in process flush-253:16 pfn:6a6d0 page flags: 0x100000000000808(uptodate|private) Suggested-and-Acked-by: Joern Engel <joern@logfs.org> Signed-off-by: Prasad Joshi <prasadjoshi.linux@gmail.com>
2012-01-10Merge tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6Linus Torvalds
MTD pull for 3.3 * tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6: (113 commits) mtd: Fix dependency for MTD_DOC200x mtd: do not use mtd->block_markbad directly logfs: do not use 'mtd->block_isbad' directly mtd: introduce mtd_can_have_bb helper mtd: do not use mtd->suspend and mtd->resume directly mtd: do not use mtd->lock, unlock and is_locked directly mtd: do not use mtd->sync directly mtd: harmonize mtd_writev usage mtd: do not use mtd->lock_user_prot_reg directly mtd: mtd->write_user_prot_reg directly mtd: do not use mtd->read_*_prot_reg directly mtd: do not use mtd->get_*_prot_info directly mtd: do not use mtd->read_oob directly mtd: mtdoops: do not use mtd->panic_write directly romfs: do not use mtd->get_unmapped_area directly mtd: do not use mtd->get_unmapped_area directly mtd: do use mtd->point directly mtd: introduce mtd_has_oob helper mtd: mtdcore: export symbols cleanup mtd: clean-up the default_mtd_writev function ... Fix up trivial edit/remove conflict in drivers/staging/spectra/lld_mtd.c
2012-01-09logfs: do not use 'mtd->block_isbad' directlyArtem Bityutskiy
Instead, use the new 'mtd_can_have_bb()' helper. Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: do not use mtd->sync directlyArtem Bityutskiy
This patch teaches 'mtd_sync()' to do nothing when the MTD driver does not have the '->sync()' method, which allows us to remove all direct 'mtd->sync' accesses. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: introduce mtd_block_isbad interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_sync interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_write interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_read interfaceArtem Bityutskiy
2012-01-09mtd: introduce mtd_erase interfaceArtem Bityutskiy
This patch is part of a patch-set which changes the MTD interface from 'mtd->func()' form to 'mtd_func()' form. We need this because we want to add common code to to all drivers in the mtd core level, which is impossible with the current interface when MTD clients call driver functions like 'read()' or 'write()' directly. At this point we just introduce a new inline wrapper function, but later some of them are expected to gain more code. E.g., the input parameters check should be moved to the wrappers rather than be duplicated at many drivers. This particular patch introduced the 'mtd_erase()' interface. The following patches add all the other interfaces one by one. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09logfs: rename functions starting with mtd_Artem Bityutskiy
We are going to re-work the MTD interface and change 'mtd->write()' to 'mtd_write()', 'mtd->read()' to 'mtd_read()' and so forth for all functions in the 'struct mtd_info' structure. However, logfs has its own 'mtd_read()', 'mtd_write()', etc functions which collide with our changes. This patch renames these logfs functions to 'logfs_mtd_read()', 'logfs_mtd_write()', etc. Additionally, to make the 'fs/logfs/dev_mtd.c' file look consistent, rename similarly all the other functions starting with 'mtd_'. Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-03logfs: propagate umode_tAl Viro
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-11-02logfs: remove unnecessary nlink settingMiklos Szeredi
alloc_inode() initializes i_nlink to 1. Remove unnecessary re-initialization. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Joern Engel <joern@logfs.org> CC: Prasad Joshi <prasadjoshi.linux@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-31lib/string.c: introduce memchr_inv()Akinobu Mita
memchr_inv() is mainly used to check whether the whole buffer is filled with just a specified byte. The function name and prototype are stolen from logfs and the implementation is from SLUB. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Matt Mackall <mpm@selenic.com> Acked-by: Joern Engel <joern@logfs.org> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31fs: add module.h to files that were implicitly using itPaul Gortmaker
Some files were using the complete module.h infrastructure without actually including the header at all. Fix them up in advance so once the implicit presence is removed, we won't get failures like this: CC [M] fs/nfsd/nfssvc.o fs/nfsd/nfssvc.c: In function 'nfsd_create_serv': fs/nfsd/nfssvc.c:335: error: 'THIS_MODULE' undeclared (first use in this function) fs/nfsd/nfssvc.c:335: error: (Each undeclared identifier is reported only once fs/nfsd/nfssvc.c:335: error: for each function it appears in.) fs/nfsd/nfssvc.c: In function 'nfsd': fs/nfsd/nfssvc.c:555: error: implicit declaration of function 'module_put_and_exit' make[3]: *** [fs/nfsd/nfssvc.o] Error 1 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-20logfs doesn't need ->permission() at allAl Viro
... and never did, what with its ->permission() being what we do by default when ->permission is NULL... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28logfs: remove unnecessary dentry_unhash from rmdir, dir renameSage Weil
logfs does not have problems with references to unlinked directories. CC: Joern Engel <joern@logfs.org> CC: logfs@logfs.org Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-03logfs: initialize superblock entries earlierLinus Torvalds
In particular, s_freeing_list needs to be initialized early, since it is used on some of the error paths when mounts fail. The mapping inode, for example, would be initialized and then free'd on an error path before s_freeing_list was initialized, but the inode drop operation needs the s_freeing_list to be set up. Normally you'd never see this, because not only is logfs fairly rare, but a successful mount will never have any issues. Reported-by: werner <w.landgraf@ru.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
