path: root/fs/mbcache.c
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] mbcache: Remove unused mb_cache_shrink parameterAndreas Gruenbacher
The cache parameter to mb_cache_shrink isn't used. We may as well remove it. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
