git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits)
cifs: remove unnecessary dentry_unhash on rmdir/rename_dir
ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir
exofs: remove unnecessary dentry_unhash on rmdir/rename_dir
nfs: remove unnecessary dentry_unhash on rmdir/rename_dir
ext2: remove unnecessary dentry_unhash on rmdir/rename_dir
ext3: remove unnecessary dentry_unhash on rmdir/rename_dir
ext4: remove unnecessary dentry_unhash on rmdir/rename_dir
btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir
ceph: remove unnecessary dentry_unhash calls
vfs: clean up vfs_rename_other
vfs: clean up vfs_rename_dir
vfs: clean up vfs_rmdir
vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems
libfs: drop unneeded dentry_unhash
vfs: update dentry_unhash() comment
vfs: push dentry_unhash on rename_dir into file systems
vfs: push dentry_unhash on rmdir into file systems
vfs: remove dget() from dentry_unhash()
vfs: dentry_unhash immediately prior to rmdir
vfs: Block mmapped writes while the fs is frozen
Simplify control flow to match vfs_rename_dir.
Signed-off-by: Sage Weil <sage@newdream.net>
Simplify control flow through vfs_rename_dir.
Simplify the control flow with an out label.
vfs_rename_dir() doesn't properly account for filesystems with
FS_RENAME_DOES_D_MOVE. If new_dentry has a target inode attached, it
unhashes the new_dentry prior to the rename() iop and rehashes it after,
but doesn't account for the possibility that rename() may have swapped
{old,new}_dentry. For FS_RENAME_DOES_D_MOVE filesystems, it rehashes
new_dentry (now the old renamed-from name, which d_move() expected to go
away), such that a subsequent lookup will find it. Currently all
FS_RENAME_DOES_D_MOVE filesystems compensate for this by failing in
d_revalidate.
The bug was introduced by: commit 349457ccf2592c14bdf13b6706170ae2e94931b1
"[PATCH] Allow file systems to manually d_move() inside of ->rename()"
Fix by not rehashing the new dentry. Rehashing used to be needed by
d_move() but isn't anymore.
Reported-by: Sage Weil <sage@newdream.net>
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
The helper is now only called by file systems, not the VFS.
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
This serves no useful purpose that I can discern. All callers (rename,
rmdir) hold their own reference to the dentry.
A quick audit of all file systems showed no relevant checks on the value
of d_count in vfs_rmdir/vfs_rename_dir paths.
This presumes that there is no reason to unhash a dentry if we fail because
it is a mountpoint or the LSM check fails, and that the LSM checks do not
depend on the dentry being unhashed.
new helper: complete_walk(). Done on successful completion
of walk, drops out of RCU mode, does d_revalidate of final
result if that hadn't been done already.
handle_reval_dot() and nameidata_drop_rcu_last() subsumed into
that one; callers converted to use of complete_walk().
Merge these into a single function (unlazy_walk(nd, dentry)),
kill ..._maybe variants
This solves a serious VFS-level bug in nested_symlink (which was
rewritten from do_follow_link), and follows the order of depth tests
that existed before.
The bug triggers a BUG_ON in fs/namei.c:1381, when running racer with
symlink and rename ops.
Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu>
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: stable@kernel.org
It's a hot function, and we're better off not mixing types in the mask
calculations. The compiler just ends up mixing 16-bit and 32-bit
operations, for no good reason.
So do everything in 'unsigned int' rather than mixing 'unsigned int'
masking with a 'umode_t' (16-bit) mode variable.
This, together with the parent commit (47a150edc2ae: "Cache user_ns in
struct cred") makes acl_permission_check() much nicer.
During RCU walk in path_lookupat and path_openat, the rcu lookup
frequently failed if looking up an absolute path, because when root
directory was looked up, seq number was not properly set in nameidata.
We dropped out of RCU walk in nameidata_drop_rcu due to mismatch in
directory entry's seq number. We reverted to slow path walk that need
to take references.
With the following patch, I saw a 50% increase in an exim mail server
benchmark throughput on a 4-socket Nehalem-EX system.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: stable@kernel.org (v2.6.38)
When following a mount in rcu-walk mode we must check if the incoming dentry
is telling us it may need to block, even if it isn't actually a mountpoint.
Signed-off-by: Ian Kent <raven@themaw.net>
deal with races in /proc/*/{syscall,stack,personality}
proc: enable writing to /proc/pid/mem
proc: make check_mem_permission() return an mm_struct on success
proc: hold cred_guard_mutex in check_mem_permission()
proc: disable mem_write after exec
mm: implement access_remote_vm
mm: factor out main logic of access_process_vm
mm: use mm_struct to resolve gate vma's in __get_user_pages
mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm
mm: arch: make in_gate_area take an mm_struct instead of a task_struct
mm: arch: make get_gate_vma take an mm_struct instead of a task_struct
x86: mark associated mm when running a task in 32 bit compatibility mode
x86: add context tag to mark mm when running a task in 32-bit compatibility mode
auxv: require the target to be tracable (or yourself)
close race in /proc/*/environ
report errors in /proc/*/*map* sanely
pagemap: close races with suid execve
make sessionid permissions in /proc/*/task/* match those in /proc/*
fix leaks in path_lookupat()
Fix up trivial conflicts in fs/proc/base.c
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cheat for now and say all files belong to init_user_ns. Next step will be
to let superblocks belong to a user_ns, and derive inode_userns(inode)
from inode->i_sb->s_user_ns. Finally we'll introduce more flexible
arrangements.
Changelog:
Feb 15: make is_owner_or_cap take const struct inode
Feb 23: make is_owner_or_cap bool
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
it's always false...
it's always false now
commit 574197e0de46a8a4db5c54ef7b65e43ffa8873a7 had a missing
piece, breaking the loop detection ;-/
* pull the handling of current->total_link_count into
__do_follow_link()
* put the common "do ->put_link() if needed and path_put() the link"
stuff into a helper (put_link(nd, link, cookie))
* rename __do_follow_link() to follow_link(), while we are at it
The last remaining place (resolution of nested symlink) converted
to the loop of the same kind we have in path_lookupat() and
path_openat().
Note that we still *do* have a recursion in pathname resolution;
can't avoid it, really. However, it's strictly for nested symlinks
now - i.e. ones in the middle of a pathname.
link_path_walk() has lost the tail now - it always walks everything
except the last component.
do_follow_link() renamed to nested_symlink() and moved down.
Now that link_path_walk() is called without LOOKUP_PARENT
only from do_follow_link(), we can simplify the checks in
last component handling. First of all, checking if we'd
arrived to a directory is not needed - the caller will check
it anyway. And LOOKUP_FOLLOW is guaranteed to be there,
since we only get to that place with nd->depth > 0.
Now the only caller of link_path_walk() that does *not* pass
LOOKUP_PARENT is do_follow_link()
... and note that we only need to do it for LAST_BIND symlinks
new helper: walk_component(). Handles everything except symlinks;
returns negative on error, 0 on success and 1 on symlinks we decided
to follow. Drops out of RCU mode on such symlinks.
link_path_walk() and do_last() switched to using that.
We don't want to allow creation of private hardlinks by different application
using the fd passed to them via SCM_RIGHTS. So limit the null relative name
usage in linkat syscall to CAP_DAC_READ_SEARCH
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
At that point we can't do almost nothing with them. They can be opened
with O_PATH, we can manipulate such descriptors with dup(), etc. and
we can see them in /proc/*/{fd,fdinfo}/*.
We can't (and won't be able to) follow /proc/*/fd/* symlinks for those;
there's simply not enough information for pathname resolution to go on
from such point - to resolve a symlink we need to know which directory
does it live in.
We will be able to do useful things with them after the next commit, though -
readlinkat() and fchownat() will be possible to use with dfd being an
O_PATH-opened symlink and empty relative pathname. Combined with
open_by_handle() it'll give us a way to do realink-by-handle and
lchown-by-handle without messing with more redundant syscalls.
New flag for open(2) - O_PATH. Semantics:
* pathname is resolved, but the file itself is _NOT_ opened
as far as filesystem is concerned.
* almost all operations on the resulting descriptors shall
fail with -EBADF. Exceptions are:
1) operations on descriptors themselves (i.e.
close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD),
fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD),
fcntl(fd, F_SETFD, ...))
2) fcntl(fd, F_GETFL), for a common non-destructive way to
check if descriptor is open
3) "dfd" arguments of ...at(2) syscalls, i.e. the starting
points of pathname resolution
* closing such descriptor does *NOT* affect dnotify or
posix locks.
* permissions are checked as usual along the way to file;
no permission checks are applied to the file itself. Of course,
giving such thing to syscall will result in permission checks (at
the moment it means checking that starting point of ....at() is
a directory and caller has exec permissions on it).
fget() and fget_light() return NULL on such descriptors; use of
fget_raw() and fget_raw_light() is needed to get them. That protects
existing code from dealing with those things.
There are two things still missing (they come in the next commits):
one is handling of symlinks (right now we refuse to open them that
way; see the next commit for semantics related to those) and another
is descriptor passing via SCM_RIGHTS datagrams.
Add inode->i_nlink == 0 check in VFS. Some of the file systems
do this internally. A followup patch will remove those instance.
This is needed to ensure that with link by handle we don't allow
to create hardlink of an unlinked file. The check also prevent a race
between unlink and link
For name_to_handle_at(2) we'll want both ...at()-style syscall that
would be usable for non-directory descriptors (with empty relative
pathname). Introduce new flag (AT_EMPTY_PATH) to deal with that and
corresponding LOOKUP_EMPTY; teach user_path_at() and path_init() to
deal with the latter.
new function: file_open_root(dentry, mnt, name, flags) opens the file
vfs_path_lookup would arrive to.
Note that name can be empty; in that case the usual requirement that
dentry should be a directory is lifted.
open-coded equivalents switched to it, may_open() got down exactly
one caller and became static.
New lookup flag: LOOKUP_ROOT. nd->root is set (and held) by caller,
path_init() starts walking from that place and all pathname resolution
machinery never drops nd->root if that flag is set. That turns
vfs_path_lookup() into a special case of do_path_lookup() *and*
gets us down to 3 callers of link_path_walk(), making it finally
feasible to rip the handling of trailing symlink out of link_path_walk().
That will not only simply the living hell out of it, but make life
much simpler for unionfs merge. Trailing symlink handling will
become iterative, which is a good thing for stack footprint in
a lot of situations as well.
That thing has devolved into rats nest of gotos; sane use of unlikely()
gets rid of that horror and gives much more readable structure:
* make a fast attempt to find a dentry; false negatives are OK.
In RCU mode if everything went fine, we are done, otherwise just drop
out of RCU. If we'd done (RCU) ->d_revalidate() and it had not refused
outright (i.e. didn't give us -ECHILD), remember its result.
* now we are not in RCU mode and hopefully have a dentry. If we
do not, lock parent, do full d_lookup() and if that has not found anything,
allocate and call ->lookup(). If we'd done that ->lookup(), remember that
dentry is good and we don't need to revalidate it.
* now we have a dentry. If it has ->d_revalidate() and we can't
skip it, call it.
* hopefully dentry is good; if not, either fail (in case of error)
or try to invalidate it. If d_invalidate() has succeeded, drop it and
retry everything as if original attempt had not found a dentry.
* now we can finish it up - deal with mountpoint crossing and
automount.
There used to be time when ->d_revalidate() couldn't return an error.
So intents code had lookup_instantiate_filp() stash ERR_PTR(error)
in nd->intent.open.filp and had it checked after lookup_hash(), to
catch the otherwise silent failures. That had been introduced by
commit 4af4c52f34606bdaab6930a845550c6fb02078a4. These days
->d_revalidate() can and does propagate errors back to callers
explicitly, so this check isn't needed anymore.
... and clean up a bit more
We have a bunch of diverging codepaths in do_last(); some of
them converge, but the case of having to create a new file
duplicates large part of common tail of the rest and exits
separately. Massage them so that they could be merged.
Lift it to lookup_one_len() and link_path_walk() resp. into the
same place where we calculated default hash function of the same
name.
only one caller left
Instead of path_lookupat() doing trailing symlink resolution,
use the same scheme as on the O_CREAT side. Walk with
LOOKUP_PARENT, then (in do_last()) look the final component
up, then either open it or return error or, if it's a symlink,
give the symlink back to path_openat() to be resolved there.
The really messy complication here is RCU. We don't want to drop
out of RCU mode before the final lookup, since we don't want to
bounce parent directory ->d_count without a good reason.
Result is _not_ pretty; later in the series we'll clean it up.
For now we are roughly back where we'd been before the revert
done by Nick's series - top-level logics of path_openat() is
cleaned up, do_last() does actual opening, symlink resolution is
done uniformly.
Don't stash the struct file * used as starting point of walk in nameidata;
pass file ** to path_init() instead.
New helper: terminate_walk(). An error has happened during pathname
resolution and we either drop nd->path or terminate RCU, depending
the mode we had been in. After that, nd is essentially empty.
Switch link_path_walk() to using that for cleanup.
Now the top-level logics in link_path_walk() is back to sanity. RCU
dependencies are in the lower-level functions.
Now we have do_follow_link() guaranteed to leave without dangling RCU
and the next step will get LOOKUP_RCU logics completely out of
link_path_walk().
