commit ac278a9c505092dd82077a2446af8f9fc0d9c095 upstream.
Make sure that automount "symlinks" are followed regardless of LOOKUP_FOLLOW;
it should have no effect on them.
commit 7ea6600148c265b1fd53e521022b1d7aec81d974 upstream.
generic_permission was refusing CAP_DAC_READ_SEARCH-enabled
processes from opening DAC-protected files read-only, because
do_filp_open adds MAY_OPEN to the open mask.
Ignore MAY_OPEN. After this patch, CAP_DAC_READ_SEARCH is
again sufficient to open(fname, O_RDONLY) on a file to which
DAC otherwise refuses us read permission.
Reported-by: Mike Kazantsev <mk.fraggod@gmail.com>
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Mike Kazantsev <mk.fraggod@gmail.com>
commit 54566b2c1594c2326a645a3551f9d989f7ba3c5e upstream.
With the write_begin/write_end aops, page_symlink was broken because it
could no longer pass a GFP_NOFS type mask into the point where the
allocations happened. They are done in write_begin, which would always
assume that the filesystem can be entered from reclaim. This bug could
cause filesystem deadlocks.
The funny thing with having a gfp_t mask there is that it doesn't really
allow the caller to arbitrarily tinker with the context in which it can be
called. It couldn't ever be GFP_ATOMIC, for example, because it needs to
take the page lock. The only thing any callers care about is __GFP_FS
anyway, so turn that into a single flag.
Add a new flag for write_begin, AOP_FLAG_NOFS. Filesystems can now act on
this flag in their write_begin function. Change __grab_cache_page to
accept a nofs argument as well, to honour that flag (while we're there,
change the name to grab_cache_page_write_begin which is more instructive
and does away with random leading underscores).
This is really a more flexible way to go in the end anyway -- if a
filesystem happens to want any extra allocations aside from the pagecache
ones in ints write_begin function, it may now use GFP_KERNEL (rather than
GFP_NOFS) for common case allocations (eg. ocfs2_alloc_write_ctxt, for a
random example).
[kosaki.motohiro@jp.fujitsu.com: fix ubifs]
[kosaki.motohiro@jp.fujitsu.com: fix fuse]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: <stable@kernel.org>
[ Cleaned up the calling convention: just pass in the AOP flags
untouched to the grab_cache_page_write_begin() function. That
just simplifies everybody, and may even allow future expansion of the
logic. - Linus ]
commit 2e4d0924eb0c403ce4014fa139d1d61bf2c44fee upstream.
commit 3cdad42884bbd95d5aa01297e8236ea1bad70053 upstream.
commit a26eab2400f0477bfac0255600552394855016f7 upstream.
commit 3480b25743cb7404928d57efeaa3d085708b04c2 upstream.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
for July 17: early crash on x86-64)
SELinux needs MAY_APPEND to be passed down to the security hook.
Otherwise, we get permission denials when only append permission is
granted by policy even if the opening process specified O_APPEND.
Shows up as a regression in the ltp selinux testsuite, fixed by
this patch.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Preparation to untangling intents mess: reduce the number of do_path_lookup()
callers.
* do not pass nameidata; struct path is all the callers want.
* switch to new helpers:
user_path_at(dfd, pathname, flags, &path)
user_path(pathname, &path)
user_lpath(pathname, &path)
user_path_dir(pathname, &path) (fail if not a directory)
The last 3 are trivial macro wrappers for the first one.
* remove nameidata in callers.
Incidentally, the name that gives hundreds of false positives on grep
is not a good idea...
... and get rid of the last "let's deduce mask from nameidata->flags"
bit.
* MAY_CHDIR is redundant - it's an equivalent of MAY_ACCESS
* MAY_ACCESS on fuse should affect only the last step of pathname resolution
* fchdir() and chroot() should pass MAY_ACCESS, for the same reason why
chdir() needs that.
* now that we pass MAY_ACCESS explicitly in all cases, LOOKUP_ACCESS can be
removed; it has no business being in nameidata.
long overdue...
... so we ought to pass MAY_CHDIR to vfs_permission() instead of having
it triggered on every step of preceding pathname resolution. LOOKUP_CHDIR
is killed by that.
Remove the unused mode parameter from vfs_symlink and callers.
Thanks to Tetsuo Handa for noticing.
CC: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Why not reuse "inode" which is assigned as
struct inode *inode = old_dentry->d_inode;
in the beginning of vfs_link() ?
* kill nameidata * argument; map the 3 bits in ->flags anybody cares
about to new MAY_... ones and pass with the mask.
* kill redundant gfs2_iop_permission()
* sanitize ecryptfs_permission()
* fix remaining places where ->permission() instances might barf on new
MAY_... found in mask.
The obvious next target in that direction is permission(9)
folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz>
Lookup can install a child dentry for a deleted directory. This keeps
the directory dentry alive, and the inode pinned in the cache and on
disk, even after all external references have gone away.
This isn't a big problem normally, since memory pressure or umount
will clear out the directory dentry and its children, releasing the
inode. But for UBIFS this causes problems because its orphan area can
overflow.
Fix this by returning ENOENT for all lookups on a S_DEAD directory
before creating a child dentry.
Thanks to Zoltan Sogor for noticing this while testing UBIFS, and
Artem for the excellent analysis of the problem and testing.
Reported-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
generic_readlink calls ERR_PTR for negative and positive values
(vfs_readlink returns length of "link"), but it should not
(not an errno) and does not need to.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Acked-by: Miklos Szeredi <miklos@szeredi.hu>
Here are some more places where path_{get,put}() can be used instead of
dput()/mntput() pair.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: Jens Axboe <jens.axboe@oracle.com>
In case when both EEXIST and EROFS would apply we used to
return the former in mkdir(2) and friends. Lest anyone suspects
us of being consistent, in the same situation knfsd gave clients
nfs_erofs...
ro-bind series had switched the syscall side of things to
returning -EROFS and immediately broke an application - namely,
mkdir -p. Patch restores the original behaviour...
Implement a cgroup to track and enforce open and mknod restrictions on device
files. A device cgroup associates a device access whitelist with each cgroup.
A whitelist entry has 4 fields. 'type' is a (all), c (char), or b (block).
'all' means it applies to all types and all major and minor numbers. Major
and minor are either an integer or * for all. Access is a composition of r
(read), w (write), and m (mknod).
The root device cgroup starts with rwm to 'all'. A child devcg gets a copy of
the parent. Admins can then remove devices from the whitelist or add new
entries. A child cgroup can never receive a device access which is denied its
parent. However when a device access is removed from a parent it will not
also be removed from the child(ren).
An entry is added using devices.allow, and removed using
devices.deny. For instance
echo 'c 1:3 mr' > /cgroups/1/devices.allow
allows cgroup 1 to read and mknod the device usually known as
/dev/null. Doing
echo a > /cgroups/1/devices.deny
will remove the default 'a *:* mrw' entry.
CAP_SYS_ADMIN is needed to change permissions or move another task to a new
cgroup. A cgroup may not be granted more permissions than the cgroup's parent
has. Any task can move itself between cgroups. This won't be sufficient, but
we can decide the best way to adequately restrict movement later.
[akpm@linux-foundation.org: fix may-be-used-uninitialized warning]
Acked-by: James Morris <jmorris@namei.org>
Looks-good-to: Pavel Emelyanov <xemul@openvz.org>
Cc: Daniel Hokka Zakrisson <daniel@hozac.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Balbir Singh <balbir@in.ibm.com>
This is the first really tricky patch in the series. It elevates the writer
count on a mount each time a non-special file is opened for write.
We used to do this in may_open(), but Miklos pointed out that __dentry_open()
is used as well to create filps. This will cover even those cases, while a
call in may_open() would not have.
There is also an elevated count around the vfs_create() call in open_namei().
See the comments for more details, but we need this to fix a 'create, remount,
fail r/w open()' race.
Some filesystems forego the use of normal vfs calls to create
struct files. Make sure that these users elevate the mnt
writer count because they will get __fput(), and we need
to make sure they're balanced.
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
This also uses the little helper in the NFS code to make an if() a little bit
less ugly. We introduced the helper at the beginning of the series.
[AV: add missing nfsd pieces]
This takes care of all of the direct callers of vfs_mknod().
Since a few of these cases also handle normal file creation
as well, this also covers some calls to vfs_create().
So that we don't have to make three mnt_want/drop_write()
calls inside of the switch statement, we move some of its
logic outside of the switch and into a helper function
suggested by Christoph.
This also encapsulates a fix for mknod(S_IFREG) that Miklos
found.
[AV: merged mkdir handling, added missing nfsd pieces]
Signed-off-by: Christoph Hellwig <hch@infradead.org>
Elevate the write count during the vfs_rmdir() and vfs_unlink().
[AV: merged rmdir and unlink parts, added missing pieces in nfsd]
Acked-by: Serge Hallyn <serue@us.ibm.com>
open_namei() will, in the future, need to take mount write counts
over its creation and truncation (via may_open()) operations. It
needs to keep these write counts until any potential filp that is
created gets __fput()'d.
This gets complicated in the error handling and becomes very murky
as to how far open_namei() actually got, and whether or not that
mount write count was taken. That makes it a bad interface.
All that the current do_filp_open() really does is allocate the
nameidata on the stack, then call open_namei().
So, this merges those two functions and moves filp_open() over
to namei.c so it can be close to its buddy: do_filp_open(). It
also gets a kerneldoc comment in the process.
My end goal here is to make sure all users of may_open()
return filps. This will ensure that we properly release
mount write counts which were taken for the filp in
may_open().
This patch moves the sys_open flags to namei flags
calculation into fs/namei.c. We'll shortly be moving
the nameidata_to_filp() calls into namei.c, and this
gets the sys_open flags to a place where we can get
at them when we need them.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
[PATCH] get stack footprint of pathname resolution back to relative sanity
[PATCH] double iput() on failure exit in hugetlb
[PATCH] double dput() on failure exit in tiny-shmem
[PATCH] fix up new filp allocators
[PATCH] check for null vfsmount in dentry_open()
[PATCH] reiserfs: eliminate private use of struct file in xattr
[PATCH] sanitize hppfs
hppfs pass vfsmount to dentry_open()
[PATCH] restore export of do_kern_mount()
Fix kernel-doc notation warnings in fs/.
Warning(mmotm-2008-0314-1449//fs/super.c:560): missing initial short description on line:
* mark_files_ro
Warning(mmotm-2008-0314-1449//fs/locks.c:1277): missing initial short description on line:
* lease_get_mtime
* lease_get_mtime
Warning(mmotm-2008-0314-1449//fs/namei.c:1368): missing initial short description on line:
* lookup_one_len: filesystem helper to lookup single pathname component
Warning(mmotm-2008-0314-1449//fs/buffer.c:3221): missing initial short description on line:
* bh_uptodate_or_lock: Test whether the buffer is uptodate
Warning(mmotm-2008-0314-1449//fs/buffer.c:3240): missing initial short description on line:
* bh_submit_read: Submit a locked buffer for reading
Warning(mmotm-2008-0314-1449//fs/fs-writeback.c:30): missing initial short description on line:
* writeback_acquire: attempt to get exclusive writeback access to a device
Warning(mmotm-2008-0314-1449//fs/fs-writeback.c:47): missing initial short description on line:
* writeback_in_progress: determine whether there is writeback in progress
Warning(mmotm-2008-0314-1449//fs/fs-writeback.c:58): missing initial short description on line:
* writeback_release: relinquish exclusive writeback access against a device.
Warning(mmotm-2008-0314-1449//include/linux/jbd.h:351): contents before sections
Warning(mmotm-2008-0314-1449//include/linux/jbd.h:561): contents before sections
Warning(mmotm-2008-0314-1449//fs/jbd/transaction.c:1935): missing initial short description on line:
* void journal_invalidatepage()
Somebody had put struct nameidata in stack frame of link_path_walk().
Unfortunately, there are certain realities to deal with:
* It's in the middle of recursion. Depth is equal to the nesting
depth of symlinks, i.e. up to 8.
* struct namiedata is, even if one discards the intent junk,
at least 12 pointers + 5 ints.
* moreover, adding a stack frame is not free in that situation.
* there are fs methods called on top of that, and they also have
stack footprint.
* kernel stack is not infinite.
The thing is, even if one chooses to deal with -ESTALE that way (and it's
one hell of an overkill), the only thing that needs to be preserved is
vfsmount + dentry, not the entire struct nameidata.
* Use struct path in fs_struct.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
This introduces the symmetric function to path_put() for getting a reference
to the dentry and vfsmount of a struct path in the right order.
Use path_put() in a few places instead of {mnt,d}put()
* Add path_put() functions for releasing a reference to the dentry and
* Switch from path_release(nd) to path_put(&nd->path)
* Rename dput_path() to path_put_conditional()
[akpm@linux-foundation.org: fix cifs]
Cc: <linux-fsdevel@vger.kernel.org>
Cc: Steven French <sfrench@us.ibm.com>
This is the central patch of a cleanup series. In most cases there is no good
reason why someone would want to use a dentry for itself. This series reflects
that fact and embeds a struct path into nameidata.
Together with the other patches of this series
- it enforced the correct order of getting/releasing the reference count on
<dentry,vfsmount> pairs
- it prepares the VFS for stacking support since it is essential to have a
struct path in every place where the stack can be traversed
- it reduces the overall code size:
without patch series:
5321639 858418 715768 6895825 6938d1 vmlinux
with patch series:
5320026 858418 715768 6894212 693284 vmlinux
This patch:
Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere.
[akpm@linux-foundation.org: fix smack]
Cc: Casey Schaufler <casey@schaufler-ca.com>
path_release_on_umount() should only be called from sys_umount(). I merged the
function into sys_umount() instead of having in in namei.c.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Currently, no notification event has been sent when inode's link count
changed. This is inconvenient for the application in some cases:
Suppose you have the following directory structure
foo/test
bar/
and you watch test. If someone does "mv foo/test bar/", you get event
IN_MOVE_SELF and you know something has happened with the file "test".
However if someone does "ln foo/test bar/test" and "rm foo/test" you get no
inotify event for the file "test" (only directories "foo" and "bar" receive
events).
Furthermore it could be argued that link count belongs to file's metadata and
thus IN_ATTRIB should be sent when it changes.
The following patch implements sending of IN_ATTRIB inotify events when link
count of the inode changes, i.e., when a hardlink to the inode is created or
when it is removed. This event is sent in addition to all the events sent so
far. In particular, when a last link to a file is removed, IN_ATTRIB event is
sent in addition to IN_DELETE_SELF event.
Acked-by: Morten Welinder <mwelinder@gmail.com>
Cc: Robert Love <rlove@google.com>
Cc: John McCutchan <ttb@tentacle.dhs.org>
Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Way back when (in commit 834f2a4a1554dc5b2598038b3fe8703defcbe467, aka
"VFS: Allow the filesystem to return a full file pointer on open intent"
to be exact), Trond changed the open logic to keep track of the original
flags to a file open, in order to pass down the the intent of a dentry
lookup to the low-level filesystem.
However, when doing that reorganization, it changed the meaning of
namei_flags, and thus inadvertently changed the test of access mode for
directories (and RO filesystem) to use the wrong flag. So fix those
test back to use access mode ("acc_mode") rather than the open flag
("flag").
Issue noticed by Bill Roman at Datalight.
Reported-and-tested-by: Bill Roman <bill.roman@datalight.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
makes caller simpler *and* allows to scan ancestors
Add a new attribute flag ATTR_OPEN, with the meaning: "truncation was
initiated by open() due to the O_TRUNC flag".
This way filesystems wanting to implement truncation within their ->open()
method can ignore such truncate requests.
This is a quick & dirty hack, but it comes for free.
Cc: Andreas Dilger <adilger@clusterfs.com>
First of all, this makes the structure jumping look a little bit cleaner. So,
this stands alone as a tiny cleanup. But, we also need 'mnt' by itself a few
more times later in this series, so this isn't _just_ a cleanup.
may_open() calls vfs_permission() before it does checks for IS_RDONLY(inode).
It checks _again_ inside of vfs_permission().
The check inside of vfs_permission() is going away eventually. With the
mnt_want/drop_write() functions, all of the r/o checks (except for this one)
are consistently done before calling permission(). Because of this, I'd like
to use permission() to hold a debugging check to make sure that the
mnt_want/drop_write() calls are actually being made.
So, to do this:
1. remove the IS_RDONLY() check from permission()
2. enforce that you must mnt_want_write() before
even calling permission()
3. actually add the debugging check to permission()
We need to rearrange may_open() to do r/o checks before calling permission().
Here's the patch.
