commit 7bd88377d482e1eae3c5329b12e33cfd664fa6a9 upstream.
return the value instead, and have path_init() do the assignment. Broken by
"vfs: Fix absolute RCU path walk failures due to uninitialized seq number",
which was Cc-stable with 2.6.38+ as destination. This one should go where
it went.
To avoid dummy value returned in case when root is already set (it would do
no harm, actually, since the only caller that doesn't ignore the return value
is guaranteed to have nd->root *not* set, but it's more obvious that way),
lift the check into callers. And do the same to set_root(), to keep them
in sync.
[lizf: Backported to 3.4:
- remove the changes to follow_link() as it doesn't call set_root()]
Signed-off-by: Zefan Li <lizefan@huawei.com>
It turns out that there are more cases than CONFIG_DEBUG_PAGEALLOC that
can have holes in the kernel address space: it seems to happen easily
with Xen, and it looks like the AMD gart64 code will also punch holes
dynamically.
Actually hitting that case is still very unlikely, so just do the
access, and take an exception and fix it up for the very unlikely case
of it being a page-crosser with no next page.
And hey, this abstraction might even help other architectures that have
other issues with unaligned word accesses than the possible missing next
page. IOW, this could do the byte order magic too.
Peter Anvin fixed a thinko in the shifting for the exception case.
Reported-and-tested-by: Jana Saout <jana@saout.de>
Cc: Peter Anvin <hpa@zytor.com>
I have a new optimized x86 "strncpy_from_user()" that will use these
same helper functions for all the same reasons the name lookup code uses
them. This is preparation for that.
This moves them into an architecture-specific header file. It's
architecture-specific for two reasons:
- some of the functions are likely to want architecture-specific
implementations. Even if the current code happens to be "generic" in
the sense that it should work on any little-endian machine, it's
likely that the "multiply by a big constant and shift" implementation
is less than optimal for an architecture that has a guaranteed fast
bit count instruction, for example.
- I expect that if architectures like sparc want to start playing
around with this, we'll need to abstract out a few more details (in
particular the actual unaligned accesses). So we're likely to have
more architecture-specific stuff if non-x86 architectures start using
this.
(and if it turns out that non-x86 architectures don't start using
this, then having it in an architecture-specific header is still the
right thing to do, of course)
64252c75a2196a0cf1e0d3777143ecfe0e3ae650 "vfs: remove dget() from
dentry_unhash()" changed the implementation but not the comment.
Cc: Sage Weil <sage@newdream.net>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Split __lookup_hash into two component functions:
lookup_dcache - tries cached lookup, returns whether real lookup is needed
lookup_real - calls i_op->lookup
This eliminates code duplication between d_alloc_and_lookup() and
d_inode_lookup().
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
now we have __lookup_hash() open-coded if !dentry case;
just call the damn thing instead...
Reorder if-else cases for starters...
Everything arriving into if (!dentry) will have need_reval = 1.
Indeed, the only way to get there with need_reval reset to 0 would
be via
if (unlikely(d_need_lookup(dentry)))
goto unlazy;
if (unlikely(dentry->d_flags & DCACHE_OP_REVALIDATE)) {
status = d_revalidate(dentry, nd);
if (unlikely(status <= 0)) {
if (status != -ECHILD)
need_reval = 0;
goto unlazy;
unlazy:
/* no assignments to dentry */
if (dentry && unlikely(d_need_lookup(dentry))) {
dput(dentry);
dentry = NULL;
and if d_need_lookup() had already been false the first time around, it
will remain false on the second call as well.
d_lookup() *will* fail after successful d_invalidate(), if we are
holding i_mutex all along. IOW, we don't need to jump back to
l: - we know what path will be taken there and can do that (i.e.
d_alloc_and_lookup()) directly.
keep holding ->i_mutex over revalidation parts
Duplicate the revalidation-related parts into if (!dentry) branch.
Next step will be to pull them under i_mutex.
This and the next 8 commits are more or less a splitup of patch
by Miklos; folks, when you are working with something that convoluted,
carve your patches up into easily reviewed steps, especially when
a lot of codepaths involved are rarely hit...
The only caller of __lookup_hash() that needs the exec permission check on
parent is lookup_one_len().
All lookup_hash() callers already checked permission in LOOKUP_PARENT walk.
__lookup_hash() calls ->lookup() if the dentry needs lookup and on success
revalidates the dentry (all under dir->i_mutex).
While this is harmless it doesn't make a lot of sense.
Doing revalidate on a dentry which has not yet been looked up makes no sense.
Move the d_need_lookup() check before d_revalidate().
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
While doing the fs/namei.c cleanups, I ran sparse on it, and it pointed
out other large integers and a couple of cases of us using '0' instead
of the proper 'NULL'.
Sparse still doesn't understand some of the conditional locking going
on, but that's no excuse for not fixing up the trivial stuff.
In commit commit 1de5b41cd3b2 ("fs/namei.c: fix warnings on 32-bit")
Andrew said that there must be a tidier way of doing this.
This is that tidier way.
We want it to match what hash_name() is doing, which means extra
multiply by 9 in this case...
Reported-and-Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Merge first batch of patches from Andrew Morton:
"A few misc things and all the MM queue"
* emailed from Andrew Morton <akpm@linux-foundation.org>: (92 commits)
memcg: avoid THP split in task migration
thp: add HPAGE_PMD_* definitions for !CONFIG_TRANSPARENT_HUGEPAGE
memcg: clean up existing move charge code
mm/memcontrol.c: remove unnecessary 'break' in mem_cgroup_read()
mm/memcontrol.c: remove redundant BUG_ON() in mem_cgroup_usage_unregister_event()
mm/memcontrol.c: s/stealed/stolen/
memcg: fix performance of mem_cgroup_begin_update_page_stat()
memcg: remove PCG_FILE_MAPPED
memcg: use new logic for page stat accounting
memcg: remove PCG_MOVE_LOCK flag from page_cgroup
memcg: simplify move_account() check
memcg: remove EXPORT_SYMBOL(mem_cgroup_update_page_stat)
memcg: kill dead prev_priority stubs
memcg: remove PCG_CACHE page_cgroup flag
memcg: let css_get_next() rely upon rcu_read_lock()
cgroup: revert ss_id_lock to spinlock
idr: make idr_get_next() good for rcu_read_lock()
memcg: remove unnecessary thp check in page stat accounting
memcg: remove redundant returns
memcg: enum lru_list lru
i386 allnoconfig:
fs/namei.c: In function 'has_zero':
fs/namei.c:1617: warning: integer constant is too large for 'unsigned long' type
fs/namei.c: In function 'hash_name':
fs/namei.c:1635: warning: integer constant is too large for 'unsigned long' type
There must be a tidier way of doing this.
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Pull kmap_atomic cleanup from Cong Wang.
It's been in -next for a long time, and it gets rid of the (no longer
used) second argument to k[un]map_atomic().
Fix up a few trivial conflicts in various drivers, and do an "evil
merge" to catch some new uses that have come in since Cong's tree.
* 'kmap_atomic' of git://github.com/congwang/linux: (59 commits)
feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal
highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename]
drbd: remove the second argument of k[un]map_atomic()
zcache: remove the second argument of k[un]map_atomic()
gma500: remove the second argument of k[un]map_atomic()
dm: remove the second argument of k[un]map_atomic()
tomoyo: remove the second argument of k[un]map_atomic()
sunrpc: remove the second argument of k[un]map_atomic()
rds: remove the second argument of k[un]map_atomic()
net: remove the second argument of k[un]map_atomic()
mm: remove the second argument of k[un]map_atomic()
lib: remove the second argument of k[un]map_atomic()
power: remove the second argument of k[un]map_atomic()
kdb: remove the second argument of k[un]map_atomic()
udf: remove the second argument of k[un]map_atomic()
ubifs: remove the second argument of k[un]map_atomic()
squashfs: remove the second argument of k[un]map_atomic()
reiserfs: remove the second argument of k[un]map_atomic()
ocfs2: remove the second argument of k[un]map_atomic()
ntfs: remove the second argument of k[un]map_atomic()
New field of struct super_block - ->s_max_links. Maximal allowed
value of ->i_nlink or 0; in the latter case all checks still need
to be done in ->link/->mkdir/->rename instances. Note that this
limit applies both to directoris and to non-directories.
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: Cong Wang <amwang@redhat.com>
* branch 'dcache-word-accesses':
vfs: use 'unsigned long' accesses for dcache name comparison and hashing
This does the name hashing and lookup using word-sized accesses when
that is efficient, namely on x86 (although any little-endian machine
with good unaligned accesses would do).
It does very much depend on little-endian logic, but it's a very hot
couple of functions under some real loads, and this patch improves the
performance of __d_lookup_rcu() and link_path_walk() by up to about 30%.
Giving a 10% improvement on some very pathname-heavy benchmarks.
Because we do make unaligned accesses past the filename, the
optimization is disabled when CONFIG_DEBUG_PAGEALLOC is active, and we
effectively depend on the fact that on x86 we don't really ever have the
last page of usable RAM followed immediately by any IO memory (due to
ACPI tables, BIOS buffer areas etc).
Some of the bit operations we do are a bit "subtle". It's commented,
but you do need to really think about the code. Or just consider it
black magic.
Thanks to people on G+ for some of the optimized bit tricks.
complete_walk() returns either ECHILD or ESTALE. do_last() turns this into
ECHILD unconditionally. If not in RCU mode, this error will reach userspace
which is complete nonsense.
CC: stable@vger.kernel.org
complete_walk() already puts nd->path, no need to do it again at cleanup time.
This would result in Oopses if triggered, apparently the codepath is not too
well exercised.
Ok, this is hacky, and only works on little-endian machines with goo
unaligned handling. And even then only with CONFIG_DEBUG_PAGEALLOC
disabled, since it can access up to 7 bytes after the pathname.
But it runs like a bat out of hell.
Commit 5707c87f "vfs: uninline full_name_hash()" broke the modular
build, because it needs exporting now that it isn't inlined any more.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
The code in link_path_walk() that finds out the length and the hash of
the next path component is some of the hottest code in the kernel. And
I have a version of it that does things at the full width of the CPU
wordsize at a time, but that means that we *really* want to split it up
into a separate helper function.
So this re-organizes the code a bit and splits the hashing part into a
helper function called "hash_name()". It returns the length of the
pathname component, while at the same time computing and writing the
hash to the appropriate location.
The code generation is slightly changed by this patch, but generally for
the better - and the added abstraction actually makes the code easier to
read too. And the new interface is well suited for replacing just the
"hash_name()" function with alternative implementations.
.. and also use it in lookup_one_len() rather than open-coding it.
There aren't any performance-critical users, so inlining it is silly.
But it wouldn't matter if it wasn't for the fact that the word-at-a-time
dentry name patches want to conditionally replace the function, and
uninlining it sets the stage for that.
So again, this is a preparatory patch that doesn't change any semantics,
and only prepares for a much cleaner and testable word-at-a-time dentry
name accessor patch.
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
d_inode_lookup() leaks a dentry reference on IS_DEADDIR().
Just a code cleanup really. We don't need to make a function call just for
it to return on error. This also makes the VFS function even easier to follow
and removes a conditional on a hot path.
Signed-off-by: Eric Paris <eparis@redhat.com>
the second victim...
switch __lookup_mnt() to returning struct mount *; callers adjusted.
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Mountpoint crossing is similar to following procfs symlinks - we do
not get ->d_revalidate() called for dentry we have arrived at, with
unpleasant consequences for NFS4.
Simple way to reproduce the problem in mainline:
cat >/tmp/a.c <<'EOF'
#include <unistd.h>
#include <fcntl.h>
#include <stdio.h>
main()
struct flock fl = {.l_type = F_RDLCK, .l_whence = SEEK_SET, .l_len = 1};
if (fcntl(0, F_SETLK, &fl))
perror("setlk");
EOF
cc /tmp/a.c -o /tmp/test
then on nfs4:
mount --bind file1 file2
/tmp/test < file1 # ok
/tmp/test < file2 # spews "setlk: No locks available"...
What happens is the missing call of ->d_revalidate() after mountpoint
crossing and that's where NFS4 would issue OPEN request to server.
The fix is simple - treat mountpoint crossing the same way we deal with
following procfs-style symlinks. I.e. set LOOKUP_JUMPED...
Cc: stable@kernel.org
